Showing results for tags 'pf receiver mod'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Dear All, here is another thing that was for long on my mind: Extend the range of the IR light based one-way communication for controlling the PF receiver without line-of-sight. There are many ways to do this; one would be to install IR repeaters all over the place; this has been realized by others in many different ways. An alternative is to access the PF receiver via radio frequency (RF). This again was done over and over again – my solution is a little minimalistic and simple but works very well. Executive summary (for those not interested in the details of this post) Motivation: Access to PF receivers without line-of-sight, particularly for PF trains. How to add a power/data 3 pin socket to the PF receiver (#8884). How to reversibly plug in a single LINX RXM 433 (or 315 or 418) MHz RF receiver chip into the modified PF receiver and use RF for communication. Result: With RF receiver plugged in, the PF receiver is accessed via RF, with RF receiver removed it works as before with IR control. Benefits: PF operation without line-of-sight Using all three available RF frequencies (315, 418, 433 MHz), 3 x 8 = 28 PF devices are independently controllable. When running newer PF receivers using the 1.2 PF protocol and knowing how operate the address bit in the 1.2 PF bit protocol, 3 x 16 = 48 PF devices are independently controllable. You may want to skip the remaining part of this post ... On to the details Upfront: It works perfectly well, I am very happy. However, I believe Philo’s superb knowledge is needed to explain why. Maybe you can help out, Philo … see further below. My approach builds on stone-old RF receivers from LINX. I bet there are tons of other devices out there, which outperform the LINX chips by far. I simply had these in bulk from China and I knew they behave well, when non-electronics people like me play with RF … The principle is as simple as it gets: The LINX RXM 433 chip constantly listens for a 433 MHz signal, once it finds one in that RF space it pulls its output from ground (= no such signal present) to VCC. A LINX TXM 433 chip does the opposite: It constantly monitors it’s logical input pin to go to VCC and then sends out a 433 MHz signal. This way a simple on-off-keyed (OOK) communication becomes possible. No encoding - no nothing, just OOK. These chips are just that: 433 MHz receivers and transmitters. I have already used them in this LEGO project.. Hacking the PF receiver Here is the part purists will hate though: We need to tap into the LEGO PF receiver electronics to get straight access to the PF receiver’s micro-controller data input line. This line should be directly connected to the IR receiver’s chip data out pin. Steps 1 to 3 Disassembly of the PF receiver as shown on Philo’s pages here. Details in 3), right, suggest to push the PF pins with a small screwdriver out of the socket – this way all 4 stay connected to the wire. It is then easier to get them back in place: Step 4 and 5 4) White arrow indicates the three pins we want to get access to. 5) Bending back the TL/VS/OS-type(?) IR receiver – there are so many of them. The one built into the PF receiver could be an OS 1638 (Philo – help!) – this one has a metal shield and voltage range of 2.7 – 5.5 V which fits nicely. The detail shows the 3 pin socket to be soldered with cut pins and solder applied. Step 6: Soldering a 3 pin socket terminal strip (2,54 mm) as shown here to the soldering side of the printed circuit board. Right: 4.15 V between VCC and GND with fully charged batteries, see volt meter reading. Step 7 and 8 7) Bending the IR receiver back into position. 8) A little drilling is necessary to widen the opening in the translucent plastic part – you may well use more sophisticated tools though. Steps 9 to 11 9) This is how it looks like after drilling (3 mm drill). 10) After cutting/filing the modified PCP goes back into the housing. Before we do that, we need to ply off one side of the yellow cover of the sliding switch, otherwise it will cover the 3 pin socket when in the channel 1 or 2 position. 11) Put the receiver back together. It now still works fine with IR control, nothing has changed so far. But we do have access to the micro controller’s data input as well as a nice power supply of about 4 V. Again, the power scheme on the receiver is shown. IN = logical data in. What makes life rather easy is that all the IR receivers (I know) have an open collector output, pulled up internally to VCC with 10 … 50 kOhm. Which means that you can simply put them “in parallel”. TLC did that in their RC trains #7897 and #7898, which has such detectors mounted on both sides. I looked into the RC electronics built into the casing permanently attached to the base plate, and indeed both IR receivers are hooked up in parallel to the micro controller. So in principle, one can now hook up further IR detectors to the PF receiver. A little test setup confirms that: But that’s is not what I wanted – radio control was the goal. The LINX RXM RF receiver assembled further above works with up to 4.2 V VCC which is a perfect match. And now it comes. As far as I am concerned, we need to invert the output of the RXM chip, which is VCC for a 433 MHz signal present – the IR receiver pulls its output to ground when 38 kHz IR light is present. I tried that: DATA out from the RXM via 1 kOhm resistor into a standard NPN transistor which should result in an inverted open collector output. The pull-up resistor to VCC is not required as there is one in the IR receiver. It works – but not robustly enough. I don’t know why – IR always works, RF “sometimes” not. Which means: Out with it. What works though is: Directly connecting the RXM output to the PF receiver input. IR is then not working anymore, but RF works flawlessly! This is what I wanted to ask Philo: Why on earth is that??? Here is the data sheet: https://www.linxtechnologies.com/wp/wp-content/uploads/rxm-fff-lr.pdf - and here is a sketch of the circuit I tried to use: http://www.brickshelf.com/gallery/ThorstenB/9VTrain/PFgoesRF/inverter_for_rxm.jpg This is how the PF receiver looks like, when the RF module is plugged in. In this configuration, IR does not work anymore, as mentioned above. Which is (accidentally, to be honest) very nice, as the receiver is not caring about any IR commands - and does not get confused. Upon unplugging the RF module, IR is operational again. Making the "RF receiver" Here is how I got it to work ... This is the "circuit diagram" (it is not, it is just how to solder the wires to the LINX RXM device. There are two chip versions shown: The one on the left (LINX RFM 433 LC-S) reached it's end of life longer ago, the one on the right (LINX RFM 433 LR-S) is the one currently sold. Pin-out is identical, the LR-S type has one additional output (RSSI), which I do not use at all. The LC-S chip is available from China dead-cheap, the newer for example from Mouser and many more suppliers of RF stuff. Step 1 to 3: 1) Tie both ground pads to ground and get the ground wire out. 2) Get VCC, DATA, and Antenna out. The Antenna should be 16.5 cm long. 3) Apply some heat shrink tubing around VCC, GND, and DATA wire. Step 4 and 5: 4) Solder the three wires to the 2,54 mm 3 pin connector in the right order (VCC right marked in white, GND center, DATA left. 5) Covering up with wider heat shrink tube – and done. A little white dot on both the receiver and the RF “module” helps to get the right connection. Both devices suffer from no damage at all though when hooked up in the wrong way (extensively tested). On the RF transmitting side the PF IR remote control (#8885 or #8879), an IR receiver chip and a RF transmitter is needed. For simplicity I used a LINX 433 TX LC/LR transmitter in combination with a TSOP 34838 IR receiver. Any 1738 or the like would do as well. In fact the IR RF transceiver referenced already above works fine. So what do we do with all this? First, communication without line-of-sight works very well – a video should be available soon demonstrating that (a train behind a bookshelf or in a tunnel). Second, the LINX chips are rather small and more importantly very robust in operation. The power consumption is reasonable and is readily available from the modified PF receiver. Third: The LINX chips also come as 315 MHz and 418 MHz versions. Which means that 3 x 8 = 24 PF channels are readily available. As the PF receivers don’t “see” the IR light anymore when the RF chip is plugged in, there is no IR trouble at the receiver side. On the transmitting side one has to make sure that the PF remotes do only shine their IR light onto the corresponding RF transmitter. Fourth - and most importantly for me: I got hold of an NXT IRLink sensor from HiTechnic. The IRLink natively “speaks” the RCX message protocol, the PF protocol, and the RC train protocol. It is some kind of C3PO – uniting the LEGO IR world. With the exception of Manas, I believe. I wrote a little NXT-G program that listens for RCX messages (in RF space that is), captures the ones that are of interest, interprets the data content of these messages and sends out PF or RC train commands into RF space. Any RC or PF controlled train equipped with the RF receiver will do what it was told. I am running 8 PF trains and 1 RC train using this scheme. And this is up next: Controlling PF trains with NXT + HiTechnic IRLink via RF communication. Requires certainly a little time though ... Thanks for reading. Regards, Thorsten
