Showing results for tags 'non-proportional'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hi, I have just purchased a lego servomotor 88004. I tested it with a standard battery box (8881) and switch (8869) and it work well, i.e. it moved to one of the 3 positions -90, 0 or +90 degrees. It worked also without the 8869 switch when I used the internal switch on the battery box. OK. This is exactly what I need in my project, with only one exception: I need to use an external 9V power supply, not the battery box. I hoped that I could use the same arrangement like I had used with other (M, L, XL) PF motors, i.e. 9V train regulator (set up for max output voltage), extension wire 8871, PF switch 8869 and the servomotor. And ... it did not work. I was surprised because I had believed that for this simple non-proportional control no additional electronics is needed, which was proven by my initial test with the servomotor and the battery box only. I looked at Philo's excellent web pages to see the internal schematic of the battery box. I found what I was expecting, i.e. there is no electronics there. The box just outputs 4 signals (0, 9V, C1 and C2) where C1 and C2 are connected either to 0 or 9V according to the position of the switch. So the catch seems to be in the extension wire that does not transmit the C1 and C2 signals when powered from the 9V supply. Am I right? Do you know a trick how to overcome this problem, so I could control the servomotor by the 8869 switch, yet with the 9V train supply? At the moment, I see just one solution: an empty battery box used as a transducer between the external 9V supply and the switch. But it is not very nice. Anything more clever?
