Showing results for tags 'military tank'.
[MOC] Lego Expeditionary Light Tank M8 "Buford" AGS
ParmBrick posted a topic in The Military Section
Hi to all comrades, I am a lover like you of Lego military themes, I follow with passion the "The Brick Great War" from the beginning, even if I do not participate, over the years I have posted several of my creations in the old section, I am glad that there is now one entirely dedicated to this theme. I hope to be in the right place to post my military creations here. Having said that, today I present you my Lego Expeditionary Light Tank M8 "Buford" AGS, an improved version of the M8 AGS (Armoured Gun System) designed and manufactured by the Company BAE Systems. The mission for this vehicle is to have the ability to be airdropped behind an enemy lines and takes a position until the arrival of the main forces. It has level 3 armour package to increases the survivability against anti-tank guided missile and RPG, main armament of the BAE Systems Expeditionary Light Tank (ELT) is similar to the M8 AGS with one 105 mm gun. It also has the latest technological discoveries regarding communication, armaments and sensors. Lego Expeditionary Light Tank M8 "Buford" AGS by Jordan Parmegiani, su Flickr Lego Expeditionary Light Tank M8 "Buford" AGS (5) by Jordan Parmegiani, su Flickr Lego Expeditionary Light Tank M8 "Buford" AGS (3) by Jordan Parmegiani, su Flickr -
The Oplot M MBT armament includes a 125mm gun, 7.62mm coaxial machine gun and 12.7mm anti-aircraft machine gun. The gun is stabilised in both elevation and traverse. Types of ammunition that can be fired by the gun include APFSDS (armour-piercing fin-stabilised discarding sabot), HEAT (high explosive anti-tank), HE-FRAG (high explosive fragmentation) rounds as well as laser beam-riding guided missiles. The missile can be fired while both the tank and target are moving. The missile has a tandem warhead to defeat targets fitted with explosive reactive armour as well as modern spaced armour, optimised against HEAT attack. The Oplot M is fitted with very advanced technologies as integrated vehicle protection system, which includes passive armour, explosive reactive armour array as well as a number of other tank protection devices that are optimised against modern anti-tank weapons and make the tank considerably less vulnerable to the full range of anti-tank weapons, as smoke grenades launchers on the sides of the tank. One visible feature is the new PNK-6 panoramic tank sight. The Oplot is powered by a model 6TD-2 diesel engine developing 1,200 hp. Other images on my flickr page!
The Leclerc Scorpion or XLR is a modernized version of the French-made Leclerc Main Battle Tank (MBT). The renovated MBT Leclerc Scorpion / XLR will keep the same armament as the standard Leclerc tank which consists of a Giat 120 mm 52 caliber smoothbore gun designated the CN 120-26. The turret is equipped with an automatic loading system. The new Leclerc will be able to fire different types of 120 mm ammunition, the APFSDS (Armour-Piercing Fin-Stabilized Discarding-Sabot), HEAT (High-Explosive Anti-Tank), and High-Explosive (HE). A 12.7 mm machine gun is mounted coaxially with the main armament. The Leclerc Scorpion is also fitted with a remotely operated weapon station mounted on the top of the turret which is armed with a 7.62mm machine gun. The layout of the Leclerc MBT Scorpion / XLR variant is similar to the previous version of the Lerclerc tank. The Leclerc Scorpion is upgraded with a new armour package that includes additional modular armor on the hull and the turret. The Leclerc MBT Scorpion / XLR will use the same powerpack as the standard Leclerc tank which consists of a SACM V8X-1500 Hyperbar diesel engine developing 1,500 hp. The tank is fitted with advanced equipments as SICS, Barage counter-IED jammer, multi-spectral GALIX passive countermeasures system, BMS, HL-58 laser range-finder, SAGEM HL 60, SAGEM HL-70 gyrostabilised panoramic sight. Other images on my flickr page!
