Showing results for tags 'maras mining'.
Mara Mining Station H17 Features: Over 100 lights Working turbolift. Rotating exhaust fans and satellite dish. Landing pads for ten ships. Garage bays for six ground vehicles. Mara Station H17 is situated on the planet L’imearn Main, a desolate planet with rich deposits of an iridescent mineral, Coredium, used in the production of several energy based technologies. Coredium is a stable mineral meaning that while iridescent, the ground upon which Mara Station is built is solid. Mining Coredium involves drilling a hole in the planet’s crust followed by exposing the Coredium to a solution (the formula for the solution is a company secret) that liquefies the Coredium causing it to expand and bubble up to the surface where it can be more readily collected. One of the greatest benefits of using Coredium is that upon liquefaction, Coredium needs no other processing in order to achieve a usable state. Furthering the uniqueness of this mining operation, the Coredium “mines” have be created by simply adding the solution to existing craters on the planet’s surface. Mara Station H17 was initially built as a research station consisting solely of the garage bays and associated landing pads on the west end of the current structure before the current mining process was perfected. The larger garage bays on the northern side of the structure housed the research laboratory while the smaller garage bays on the south side housed Moondogs used to scout the surface and bring mobile drilling rigs into the field. Upon discovering an important use for Coredium and a method to successfully mine the mineral, Mara station quickly expanded by adding a larger research facility to the old research station as well as multiple new land pads used to ship out mined Coredium. Mara Station also quickly became a popular target for Blacktron raids. The constant Blacktron raids led to the placement of three Peacemaker SAM sites as well as a permanent garrison of fighters at the station. View from the left side: There first two photos I took just last month while this MOC was on display at BrickMania ToyWorks in Minneapolis, MN. The original display, however, was built for BrickWorld, Chicago. Here is the backside of the base from the display at BW. Gives you a sense of where the cargo landing pads that lie on the backside of this base, a clear shot of which I couldn't get at Brickmania: Speaking of the 100+ lights- here are a few shots while this was on display at BrickWorld: I am pretty sure one of my personal space heroes, @Si-MOCs took this picture! Spot a ship or build you like? Here are some links to some of the various models that appear on this build: Ground Vehicles: LL928 M.C.V.P Maverick LL928 M.C.V.P U.V.P* MoonDog Ranger 4 Landing pads above the garages on west end: LL951 Blue Jacket LL214 Wasp LL1220 Dragon Hunter LL302 Hornet 1 Landing pad on top of base: LL929 Galaxy Explorer* 3 Landing pads on east side of base: LL165 Locust (x2) LL428 Monarch 2 Landing pads on back of base: LL330 Grasshopper LL330 Grasshopper-D variant* *Looks like I have a couple that haven't made it on EB yet. I will have to add those soon.
- 16 replies
- orionblu
- maras mining
(and 2 more)
Tagged with:
