Showing results for tags 'manic miners'.
"The scanners onboard the L.M.S Explorer have detected a cave system rich in Energy Crystals. However, the caves are small and large areas are only accessible by aquatic means of transportation. Rock Raiders HQ must be split into smaller units as the smaller nature of the caverns wonβt allow a single unit of the support station to maintain a breathable atmosphere for the entire network of tunnels. Construct a larger main HQ in the center of the cave system and then expand further out closer to the waterways and build an additional support station. Then build the Docs and teleport down a Rapid Rider. Be aware, the scanners have detected some movement in nearby caves. Use caution and try to secure the HQ using electric fences! Good luck down there, Rock Raider!" After close to two months of work I've finally completed my most extensive Rock Raiders MOC so far. With this build I wanted to add a lot of in-game elements that never made it into official sets. As well as showing of my "UCS" versions of the Rapid Rider and Loader Dozer. One of the defining features of this MOC compared to previous RR MOCs are the power paths. Working with a somewhat limited parts selection it was a bit tricky to get the shaping and proportions right. In the end I'm rather pleased with the outcome. The selection of buildings relate to the "start-of-the-mission" message written for this MOC. Hope you like it and as always cc is always welcome.
- 20 replies
- rock raiders
- manic miners
(and 1 more)
Tagged with:
