Showing results for tags 'lady jessica'.
With this MOC I present my second version of a Fremen Ornithopter. My original MOC was heavily based on bt.bricks Fremen Ornithoper which can be found here: https://btbricks.gumroad.com/l/ornithopter-fremen I wanted to make the Ornithopter more accurate in regards to the small Ornithopter Paul and Jessica used in Dune Part I. This new design is a complete overhaul to overcome a lot of the limitations of my original MOC and to make it also more movie accurate. The differences to my original version include the following: a full redesign of the main body, resulting in a "smoothed" outer shape another result of the body redesign is, that the part between the blade connectors and the cockpit shrunk by 2 studs full redesign of the cockpit with new side canopies (either part 3383 or part 65633) the blade connectors are now really sturdy no "wobbly" blade positioning anymore - move a blade and it stays instantly in place an overhaul of the wing blades themselves another overhaul of the tail new landing gear which is now capable of carrying the Ornithopter's weight on its own The MOC is available on rebrickable.
- 11 replies
