Showing results for tags 'køf'.
Presenting another Köf...with wagons DSB Køf The Danish State Railways (DSB) shunter Køf was the Danish version of the legendary German Köf (Kleinlokomotive, Öl-antrieb durch dieselmotor, kraftübertragung mit Flüssigkeitbetriebe). 40 Køf shunters were built by Frichs from 1966 to 1969. A few are still in active service today. My model: DSB red & black livery used in the 1980s. Scale: 1:45 Length: 17 studs Width: 8 studs Bricks: 276 Powered: 1 x 9v motor or PF motor with the old 9v battery box using the PF to 9v extension wire Control: 9v / IR Reciever or SBrick Designed: 2012 Minor updated: 2018 Very high setting render from Stud.io with custom decals done in the PartDesigner tool. Easy access to the IR Receiver: Either 9v or PF can be used to run the model but PF requires the PF train motor to be connected to the older 9v battery box by extension wire in a very tight fit with little room to spare. DSB Litra Gs (I) wagons The Danish State Railways (DSB) classic 2-axle covered wagons with sliding doors were built by Scandia in Denmark. A huge numbers of 2.871 were built from 1953-1964. A few are still used today. My model: Scale: Approx. 1:50 Length: 26 studs Width: 7 studs Bricks (2023): 475 Designed: 2013 Updated: 2018, 2023 DSB Gs (I) wagons pushed by DSB Køf:
