Showing results for tags 'industrial locomotive'.
Want an SD40, but can't afford one? Here's a half-off deal for you: ...literally. These little locomotives are made by cutting an SD40 in half, attaching the frame to the truck, and installing a new and efficient prime mover and cab. I kid you not: Link to the manufacturer's website. I went about building this model the same way I usually do: Gather reference images, find an engineering drawing, and overlay grid paper over the scaling drawing. Complicating the matter was that the diagram in Tractive Power's specifications brochure was very obviously wrong -- there's no way the SD40 truck is that long! Comparing the drawing to photos of the real locomotive confirmed my suspicions. I overlaid a drawing of an SD40 truck on the diagram of the body, and worked from that. As with my Standard Class 2, I selectively compressed the wheelbase to make the axle-to-axle distance a whole number. This made building the truck frames much easier: After working out the frames, I worked on designing a drive train that would power all three wheels (once again, I picked a small prototype, which didn't help). Here's what I came up with: That's the ungeared 9V motor driving a shaft with a belt, powering all three axles with worms. The center axle slides to traverse curves: As a side bonus, I get to check another motor off my list of "motors to power a locomotive with". Because of the belt drive, unlike any of my other locomotives this locomotive's pulling power is limited by torque instead of weight (because the belt will slip first). It still has plenty of pulling power for something of its size. The locomotive traverses almost all track arrangements -- strangely, it will skip switches coming out of a curve, but only in one direction. The hood hides the battery box. One section isn't held on by anything, and comes off to reveal the power button: The other sections are only connected with one stud (and some interesting panel spacing to grab the power connector), making it easy to change the batteries. The receiver sits on top of the motor in the cab and receives signals through a hole in the roof. Unlike the other locomotives I've built, this one has great reception from all angles. I really wanted to build this locomotive in Curry Rail colors, but the parts I needed weren't available in either teal (too old) or bright green (too new?). So I built it in black, but left the frames grey to show the details better. Thanks for reading! Full Brickshelf gallery, pending moderation.
- 19 replies
- diesel locomotive
- industrial locomotive
- (and 3 more)
