Showing results for tags 'half-axles'.
New Half-axles for Lego Trial Trucks - Tatra T813 4x4 RC Trial Truck V4 I accidentally reversed the gears of the portal hubs of this pic. For Lego Tatra T813 4x4 RC Trial Truck V4 I decided to make new half-axles, more resistant than they already were the previous ones, so as to transmit the maximum torque ratio possible from wheels to ground. The photo of the axle shafts made with Lego bricks will be available by early next week. Project Starting from my previous axles, which had little resistance in the attack for wheels, I added the portal hubs from Lego set 8110 Mercedes-Benz Unimog U400, made specifically for this use. In the portal hubs I put gear reductions for a total gear ratio of, together with other gear reductions in the transmission, 9:1, then, nine complete revolutions of the pinion of the motor, the wheel it will perform a complete one. Lego Tatra T813 4x4 RC Trial Truck V4 My new axles shafts will be used by Lego Tatra T813 4x4 RC Trial Truck V4; thanks to them will greatly improve its performance and by the end of July will publish a new article and a new video dedicated to Lego Tatra T813 V4.
- 2 replies
- axles
- suspensions
(and 6 more)
Tagged with:
