Showing results for tags 'ground drone'.
In this episode we'll explore some of my ground drones. The ATVRAAD (All Terrain Vertical Recon and Attack Aracno Drone) is an autonomous, or controllable, drone used for reconnaissance, surveillance, and pursuit missions. It carries an M60 machine gun only for defense or unavoidable attacks. This drone's unique feature is its ability to climb any surface, except upside down or at negative angles. It can therefore also climb vertical walls and avoid detection on the ground. Its highly articulated legs also allow it to enter buildings and windows, allowing it to maintain a low profile and better concealment. However, it is a very slow drone compared to other drones, only 20 km/h on the ground, and 5 km/h on vertical surfaces. This model was inspired by Devid VII's BL-01 drone. The Lego BDARS (Bomb Disposal Advanced Robotic System) is one of several versions of the EOD robot available to the Plighia security forces. This version differs from the others in that it was designed to combine an inexpensive yet efficient and useful vehicle. It therefore has two telescopic arms made of reinforced steel, two cameras, and can be armed with any type of handgun. The main telescopic robotic arm has a hand with built-in multipurpose tools, allowing it to operate on any type of explosive with precision and safety. Finally, its body is lightweight and compact, made of carbon fiber, with two independent tracks. Its main drawback is that it can only operate on flat or slightly uneven terrain and cannot climb stairs.
