Showing results for tags 'gear friction'.
The Lego Technic set 42140 App-Controlled Transformation Vehicle introduces two new gears - a flat version of the 12 tooth bevel gear and a flat version of the 20 tooth bevel gear. These gears are designed to have less friction. In this video I measure the difference in gearing efficiency between two gearboxes - one made from a stack of 3 of the original 12 and 20 tooth gears to create a 27 to 125 gearing ratio, and a similar version made from the new flat 12 and 20 tooth gears. The gear box losses are measured using a powered up motor and a powered up App to determined the efficiency of each gear box by lifting different weights. The results are presented and compared for each gearbox.
The relative friction of four different solutions for transferring motion from one axle to a far away axle are compared. The friction load differences are compared using a differential to measure the speed difference of the load on two medium motors. The four motion transfer solutions that are compared are a series of nine 16 teeth gears, three 40 teeth gears, a chain, and bevel gears driving a perpendicular axle.
