Showing results for tags 'forage harvester'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. Hello Community, I want to share a cool idea and model I came up with - using relative new 28T gears as sprockets for a tracked vehicle. When I first saw the inventory for the new 42168 John Deere 9700 Forage Harvester, I was impressed on how many gears are packed inside this small model so I decided to use as much as possible of them for a tracked Tractor. But can all that gears are used as sprockets for driving small tracks? Lets find it out. The new 28T gear fits literally perfect as sprocket and thanks to the soft tooths of that bevel gear, tracks are running surprisingly smooth. Every second tooth fits inside the gaps of the track links, where the other tooths fits inside the gaps of the track part itself and so on. With such a setup it might be possible to build a tracked vehicle and I tested alot on the tracks and the sprocket setup. Available gears from the 42168 Forage Harvester are not enough, so I decided to use the yellow gears only for the visible side of the model and to use other parts provided with the set to prevent the additional tracks from slipping... The model I ended up is a John Deere 8RX Tractor as alternate build for the 42168 John Deere Forage Harvester that requires 124 additional widely used track links (part 3873). Something odd, a model that requires additional tracks and let you the tires left over for some other cool stuff. The Tractor comes with steering and a working piston engine. Only parts from donor set 42168 are needed and all functions are working even without the additional track pieces. Lets take a look how smooth the tracks are running. The model is steered with wheel from the back (shown in blue) while the rear tracks are running the piston engine (shown in green) by driving the model smoothly over rough ground. Let the piston engine run by driving the tracks or by rotating the rear sprocket manually. Some impressions: If you like what you see and want to build your own John Deere 8RX Tractor Unit, feel free to support me on rebrickable. Happy Building.
  2. Hi, pleased to present the latest Æmiliabricks Lug work, a typical farm of our country. It required a long work and many buckets of pieces. This version is a work in progress as we still have to refine many details. Hope you all enjoy it.
