Showing results for tags 'felbermayr crane'.
In the past 2 months I've been working on a mobile crane. I initially started with the Liebherr 1350-6.1 but then decided to add another axle and go for the 1400-7.1 For reference I'm attaching an image of the Felbermayr livery I'm going for. I think blue is a nice alternative to the usual "yellow" technics mocs/cranes! image share Some of the features: integrated pneumatic suspensions (currently this crane can run both on pneumatics or normal shock absorbers) 7 solid axles of which 6 are steered and 5 are driven studded design (although the axles themselves are built in studless technique) as many details as possible (I haven't completed this MOC yet so at this stage there is room for adding more) decals/stickers where needed 2 or 3 Sbricks (1 in the carrier and 1or 2 in the upper structure) 2 L motor for driving 1 L motor for steering 1 M motor to extend the outriggers 1 M motor with autovalve to lower/raise the outriggers pneumatics. At the moment only the carrier has been completed digitally, upper structure to follow The chassis itself it's a 5 studs tall/thick and should provide enough rigidity. As you can see the outriggers take quite a lot of space, both driving and steering shafts had to go either below or above them! upload pictures Here a view of all the axles: currently showing pneumatic pumps but given how much they cost I've decided to use standard shock absorbers More renders. hosting images online image sharing sites free Hope you've enjoyed this. Will start building it soon hoping everything goes smooth! Then will develop the upper structure and share more images. Cheers, TheItalianBrick!
- 18 replies
- liebherr
- mobile crane
- (and 5 more)
