Showing results for tags 'falcon industries'.
With all of the other entries for the [TC6] SBrick contest, I thought I'd post some work in progress pictures of my own entry. Some time before the contest actually started, I was starting to build the chassis of a most unusual truck, a custom Kenworth C500 tridem-tridem with a Cormach 23000A loader crane, assembled by Falcon Industries of Canada. My model is not quite a straightforward replica, but more inspired by this machine. Initially, I was planning on making the model more like a flagship set, with no remote control, and just a single motor for all the crane functions. But, when I heard about the competition, I just had to adapt this model to enter. The model itself is about 30% complete, consisting mostly of the chassis, and some parts of the bodywork, including the unusual C500 engine hood. The model currently has the following features: Drive, via XL motor, to the rear three axles, and to a modeled V-12 engine. (not quite realistic, but it looks cool.) Steering on the front three axles via Servo motor, with differing angles between the axles. This is accomplished with steering arms of differing lengths. Lights, controlled via a switch. An opening hood, with two fold up panels on each side, and two removable panels, as for a real C500. Opening cabinets on either side, as on the real thing. (one has not been added yet.) I plan to add more features, including the crane itself, and the rest of the bodywork. The crane functions will be controlled with a function splitter, somewhat similar to 8043, but different, as the splitter only has two motors, but six outputs. Thus, for the purpose of the contest, the four functions are: Drive, via XL motor. Steer, via Servo motor. Function split control, via servo motor Function splitter, driven by XL motor, with six functions. (Raising the crane arm, bending the crane arm, extension, winching, slewing, and the outriggers.) Now, on to some more photos of the chassis. This shot shows the rear light cluster, but I've got a better shot. These two shots show how the hood opens, and the removable side panels. The engine actually has many details, including a supercharger, a cooling fan, an airtank, an oil filter, and a batter box, with wires. The battery box is the dbg box with two strings coming out of it, representing wires. This shot is in the dark, with the truck lights on. And now, the money shot, the underside, showing the different lengths of steering arms to get different steering angles, and the drive train to the rear. These are detail shots of the undersides, showing better the drive and steering mechanism. The truck is so long, you can't really get a good view of the underside in just one picture. A detail shot of the opening cabinet. I wonder what, if anything, I should put in there. The rear bumper, with license plate from set #8682 Nitro Intimidator, mudflaps made out of track links, and the taillights, which actually work. Although, the license plate is not correct, as the real truck is from Canada. That's all for now, I hope you guys like it. P.S. I actually had this written out earlier, but I accidentally turned off my computer, and lost it. Oops.
- 47 replies
