Showing results for tags 'faction contest'.
Where does your character lay his/her head at night? Do you crash in a berth on your starship? Do you have a luxury apartment? Maybe your species is more aquatic like the Mon Calamari and sleeps in the water or breathes a different atmosphere mix like the Kel'Dor and sleeps in an ammonium chamber. Or maybe you're part of an organized fighting force and you sleep in the barracks. Wherever you call home, show us your digs for this contest. The Rules: Portray your character or one of your supporting cast in his/her quarters/bunk. All entries must be posted as a new topic in the Factions subforum, the title prefixed by, "[Factions Ep. I]" All entries must be entered using this form: Link to Submittal Form All rules in the Core Rules topic apply unless otherwise stated in this explanation or the rules above. There are no restrictions on the size/form/content of the builds, as long as they follow the above described goals. The Episode will run from Jan 17th to Feb 25th. As long as it is still Feb 25th somewhere in the world, you can still enter. Entries posted after the deadline will be disqualified from the episode and will not be eligible to receive points or XP. Entries will be judged according to the following rules: Your build can earn up to 50 points. The amount of points you earn is also the amount of XP your character earns. IP will can be earned from entries for this contest if the build follows the normal IP rules. The faction that earns the highest cumulative XP will be the Winning Faction This episode/contest is open to all players of Factions, even if they joined EB or signed up for the game after the episode has begun, with the exception of the Star Wars staff, who are not eligible to win XP or prizes; the EB admins and moderators, who are not eligible to win prizes but may earn XP; and the episode host, who is not eligible to win prizes but may earn XP. All entries must be new creations, not posted anywhere else prior to the start date of this episode. You can use creations for this contest in other forums or contests, but it should not have been displayed before the start date for this contest. You may be asked by a staff member to change your entry if it is too similar to an earlier creation. All entries must be built from real LEGO or with Lego Digital Designer. Post pictures no larger than 1024x768, as specified in the EB Member Guidelines. You may do a 'full-blown photo edit' with all the text, effects, background compositing, support erasing, and other effects on one picture. All your other pictures may have no editing other than color adjustment or background removal for a solid-color background. For obvious reasons, any photo editing that changes the shape, functionality, or color (not tint or adjustment, but actual color) of a LEGO piece is prohibited,. All entries are considered WIPs (Works In Progress) until the deadline passes. Until the deadline has passed, you are allowed to change and improve your MOC. The Prizes: All the players on the winning faction will receive a PM with the location of the first holocron. You will receive XP equal to the number of points you are awarded from the judges. Your faction will receive IP if your MOC is eligible for them.
- 20 replies
- episode contest
- factions contest
(and 1 more)
Tagged with:
Savan stands in her Coruscant office reflecting on where fate has brought her. In charge of what is arguably the biggest crime syndicate in the galaxy, she is one of the most powerful beings alive. But how did it come to this? There was a time when Black Sun was an almost unknown entity. Certainly not one that drew respect wherever its members went. Back when Jedi and Sith fought across the stars... Back when the 9 Vigos were just beginning to cut their teeth on crime operations. They scattered across the galaxy to make a name for themselves. Savan reflected on that history and realized the old Vigos might have done more than just build a reputation for themselves. Perhaps they also stored treasures at their bases. With rumors of Jedi Holocrons resurfacing, maybe she could find one in the old Vigo's hideouts. But where were those? It was time for her to do more research. Contest Specifics: This will be a "seed part" challenge. You are allowed to enter up to 3 times but only once per seed part. That means you can choose up to 3 different seed parts for up to 3 different entries. Entries for this contest should be set during the Old Republic Era. Jedi and Sith are encouraged to be present but are not required. You must follow the general rules for where you are allowed to build to receive XP/IP for your team. You are allowed to use any planet or location within those guidelines for your entries. If you submit more than 1 entry, they may be on the same planet or different planets. For each seed part you choose, you will also have the opportunity to gain IP on the planet it's associated with. For example, a member of CorSec can build on Corellia for his/her first entry. If they pick Seed Part #1, they can also earn IP for their team on Planet #1. They will still earn the normal XP/IP on Corellia as well. Seed Parts and Planets: L3 - Sernpidal - Q5 - Feena - - any gray color allowed U7 - Baros - U12 - Teth - S15 - Molavar - O19 - Svivren - I18 - Lipsec - I16 - Cerea - - any shade allowed J6 - Keitum - - any color allowed The Rules: Portray a scene from the Old Republic Era on a planet your faction has access to. You must use one of the 9 seed parts. Only 1 seed part per entry is allowed for judging purposes. But you are allowed to use other seed parts as standard parts. All entries must be posted as a new topic in the Factions subforum, the title prefixed by, "[Factions Ep. 2]". You must also include the regular tagging in the usual format: [Sector - Planet - Faction]. I.E. [M10 - Kuat - TCR]. All entries must be entered using this form: Link to Submittal Form All rules in the Core Rules topic apply unless otherwise stated in this explanation or the rules above. There are no restrictions on the size/form/content of the builds, as long as they follow the above described goals. The Episode will run from May 3rd to Jun 30th. As long as it is still Jun 30th somewhere in the world, you can still enter. Entries posted after the deadline will be disqualified from the episode and will not be eligible to receive points or XP. Entries will be judged according to the following rules: Your build can earn up to 50 points. The amount of points you earn is also the amount of XP your character earns. IP will can be earned from entries for this contest if the build follows the normal IP rules. The player with the highest scored build using a particular seed part will win control of that seed part. The faction that controls the most seed parts will be the Winning Faction. If there is a tie between builds for a particular seed part, control of the seed part will go to the faction with the highest cumulative XP for that seed part (regardless of which factions were initially tied). If there is a tie between factions for control of the most seed parts, the faction with the highest cumulative XP on all of their winning seed part entries will be the Winning Faction (regardless of which factions were initially tied). This episode/contest is open to all players of Factions, even if they joined EB or signed up for the game after the episode has begun, with the exception of the Star Wars staff, who are not eligible to win XP or prizes; the EB admins and moderators, who are not eligible to win prizes but may earn XP; and the episode host, who is not eligible to win prizes but may earn XP. All entries must be new creations, not posted anywhere else prior to the start date of this episode. You can use creations for this contest in other forums or contests, but it should not have been displayed before the start date for this contest. You may be asked by a staff member to change your entry if it is too similar to an earlier creation. HINT: If you enter the Lego IDEAS Star Wars contest you can use it in this contest as well as long as you haven't posted it before this contest's start date. Same applies for the May the 4th EB contest. All entries must be built from real LEGO or with Lego Digital Designer. Post pictures no larger than 1024x768, as specified in the EB Member Guidelines. You may do a 'full-blown photo edit' with all the text, effects, background compositing, support erasing, and other effects on one picture. All your other pictures may have no editing other than color adjustment or background removal for a solid-color background. For obvious reasons, any photo editing that changes the shape, functionality, or color (not tint or adjustment, but actual color) of a LEGO piece is prohibited,. All entries are considered WIPs (Works In Progress) until the deadline passes. Until the deadline has passed, you are allowed to change and improve your MOC. The Prizes: One of the 9 planets is home to another Holocron. If your team gains 25 or more IP on that planet they will be PM'd that intel. You will receive XP equal to the number of points you are awarded from the judges. Your faction will receive IP on your posted planet if your MOC is eligible for them. They will also receive IP on the seed part planet if they earn 25 IP on that planet or more. Otherwise the IP on the seed part planet will disappear after this contest. The Winning Faction will keep any IP earned on the seed part planets, regardless of the 25 IP threshold.
Factions have appeared all over the galaxy. The New Republic is still trying to sway enough planets over to its side to become the legitimate replacement for the Empire. Various Imperial Factions are vying for control of as many sectors as they can manage to control. The Scum of the galaxy is running rampant. What does all this mean? A lot of business for the many Corporations across the galaxy. Starfighters in particular are in high demand. Incom, Sienar, and MandalMotors in particular have seen a spike in profits as every Faction buys up the Starfighters they think will help them gain control of new territories or hold on to the ones they already have. Incom - Location: Fresia K10 Z-95 Headhunter ARC-170 U-Wing T-47 Airspeeder (Snowspeeder) X-Wing Sienar - Location: Castell M9 Sith Infiltrator TIE Series: Fighter, Interceptor, Defender, Bomber, Advance, Reaper, Striker, etc. MandalMotors - Location: Mandalore O7 Fang Fighter Kom'rk Fighter M3-A Fighter Aka'jor Shuttle Lancer Class Pursuit Craft Contest Specifics: Build a Starfighter from one of the three Corporations. The Starfighter should be minifigure scale. It should clearly fall within the Starfighter category and not be classified as a transport ship or larger. If you have questions please ask! You can also build a setting for your Starfighter: the factory where it's built, a shipyard in space where it's built, testing the Starfighter on a planet, taking the Starfighter into battle, etc. Each entry will be judged in two ways. The Starfighter will be judged by itself. Then the setting will be judged. The combined score will equal your XP/IP for the contest. But control of the Corporation will only be judged on the score from the Starfighter. Entries can be set on any planet and will earn appropriate XP and IP there. Regular rules for IP access apply. The highest scoring Starfighter for each Corporation will earn 50 IP on the corresponding headquarters. Only the Starfighters will be scored for this reward. So if CorSec builds the best MandalMotors Starfighter, CorSec will get 50 IP on Mandalore regardless how many other entries there were from other Factions, and regardless of the setting for any of the Starfighters. The Rules: Must be minifigure-scale. Must be a starfighter produced by 1 of the three listed Corporations. It doesn't have to be on the list of examples under each Corporation, but if it's not you should provide Wookiepedia proof. All entries must be posted as a new topic in the Factions subforum, the title prefixed by [Factions Ep. 4][Corporation - Starfighter][Build Sector - Build Planet - Faction]. For example, “[Factions Ep. 4] [Sienar - TIE Striker] [M11 - Corellia - CS] Imperial Forces”. Each person is only allowed 2 entries. Each entry may be for a different Corporation or the same. However, Factions would be wise to coordinate their builds to maximize points within one Corporation. All entries must be entered using this form: Link to Submittal Form All rules in the Core Rules topic apply unless otherwise stated in this explanation or the rules above. There are no restrictions on the size/form/content of the builds, as long as they follow the above described goals. The Episode will run from November 27th to January 31st. As long as it is still Jan 31st somewhere in the world, you can still enter. Entries posted after the deadline will be disqualified from the episode and will not be eligible to receive points or XP. Entries will be judged according to the following rules: Your build can earn up to 50 points. The amount of points you earn is also the amount of XP your character earns. This episode/contest is open to all players of Factions, even if they joined EB or signed up for the game after the episode has begun, with the exception of the Star Wars staff, who are not eligible to win XP or prizes; the EB admins and moderators, who are not eligible to win prizes but may earn XP; and the episode host, who is not eligible to win prizes but may earn XP. All entries must be new creations, not posted anywhere else prior to the start date of this episode. You can use creations for this contest in other forums or contests, but it should not have been displayed before the start date for this contest. You may be asked by a staff member to change your entry if it is too similar to an earlier creation. All entries must be built from real LEGO or with Lego Digital Designer. No third-party molds may be used for the subject non-human. If you are using Lego Digital Designer, please remember you can only use existing colors and pieces. Also be aware that the judges will watching to make sure your LDD model could hold itself up in real-life. Post pictures no larger than 1024x768, as specified in the EB Member Guidelines. You may do a 'full-blown photo edit' with all the text, effects, background compositing, support erasing, and other effects on ANY picture. For obvious reasons, any photo editing that changes the shape, functionality, or color (not tint or adjustment, but actual color) of a LEGO piece is prohibited,. All entries are considered WIPs (Works In Progress) until the deadline passes. Until the deadline has passed, you are allowed to change and improve your MOC. The Prizes: You will receive XP equal to the number of points you are awarded from the judges. Your faction will receive IP on your posted planet if your MOC is eligible for them. If your Factions earns the most XP for a Corporation, they will earn 50 IP on the given headquarters for the Corporation.
With the fall of the Empire, non-human sentiments are reappearing in the Core Worlds. Some are disgusted by the migrants, many are profiting, more are sympathetic, few actually help. Contest Specifics: Build a non-human minifigure out of bricks. Must be in minifigure scale. Build a scene showing them traveling to the Core Worlds, arriving somewhere in the Core Worlds, or being visited by New Republic diplomats on their home world. Include a picture of the non-human you are portraying and a link to their Wookieepedia page. If you and Wookieepedia don't know where a species is from, you can use the planet on which they are seen in the canonical or expanded universe material. Please provide enough information for judges and other builders to find pictures or descriptions of the species. The Rules: Must be minifigure-scale. May not be a non-human as produced by LEGO. That means don't throw a molded Ewok head on a torso and call it an Ewok. The idea is to make unique, brick-built minifigures. Minifigure parts can be used (for example, the title pic has droid arms for legs and a helmet for a head), but use them in a unique way, ideally to create a non-human that they were not intended to represent. Droids are okay, as long as it is original (not produced by LEGO). So probe droids and battle droids wouldn't be original, but L3-37 or AZI-3 would be fine. Ideally these are droids with some personality, but if it is a unique representation without relying on LEGO molds, it should be okay. Feel free to check with Faction Leaders. All entries must be posted as a new topic in the Factions subforum, the title prefixed by [Factions Ep. 3] [Species - Home Sector - Home Planet] [Build Sector - Build Planet - Faction]. For example, “[Factions Ep. 3] [Skakoan - L9 - Skako] [M12 - Hosnian Prime - CFS] Techno Union Reformed”. You may post as many entries as you want. However, please be mindful of the quality of your builds. Judges reserve the right to award 0 points to exceedingly poor entries that seem to be taking advantage of this allowance. All entries must be entered using this form: Link to Submittal Form (When submitting the form, use the Home Sector and Home Planet for the non-human entry) All rules in the Core Rules topic apply unless otherwise stated in this explanation or the rules above. There are no restrictions on the size/form/content of the builds, as long as they follow the above described goals. The Episode will run from September 4th to October 31st. As long as it is still Oct 31st somewhere in the world, you can still enter. Entries posted after the deadline will be disqualified from the episode and will not be eligible to receive points or XP. Entries will be judged according to the following rules: Your build can earn up to 50 points. The amount of points you earn is also the amount of XP your character earns. IP will be earned on the non-human’s home planet (not the location of your actual build), regardless of accessibility, IF YOU HAVE THE HIGHEST SCORING BUILD FOR THAT NON-HUMAN. This episode/contest is open to all players of Factions, even if they joined EB or signed up for the game after the episode has begun, with the exception of the Star Wars staff, who are not eligible to win XP or prizes; the EB admins and moderators, who are not eligible to win prizes but may earn XP; and the episode host, who is not eligible to win prizes but may earn XP. All entries must be new creations, not posted anywhere else prior to the start date of this episode. You can use creations for this contest in other forums or contests, but it should not have been displayed before the start date for this contest. You may be asked by a staff member to change your entry if it is too similar to an earlier creation. All entries must be built from real LEGO or with Lego Digital Designer. No third-party molds may be used for the subject non-human. Post pictures no larger than 1024x768, as specified in the EB Member Guidelines. You may do a 'full-blown photo edit' with all the text, effects, background compositing, support erasing, and other effects on ANY picture. For obvious reasons, any photo editing that changes the shape, functionality, or color (not tint or adjustment, but actual color) of a LEGO piece is prohibited,. All entries are considered WIPs (Works In Progress) until the deadline passes. Until the deadline has passed, you are allowed to change and improve your MOC. The Prizes: You will receive XP equal to the number of points you are awarded from the judges. Your faction will receive IP on your non-human's home planet if you have the highest scoring build for that non-human. If more than one person builds a Quarren, only the best build will get the IP. If there is a tie, both builders will get IP. Your faction will not receive IP on the planet you are building. If you earn IP for a non-human from a planet containing a Holocron, you will be told at the end of the contest of the Holocron's presence on that planet, regardless of how much IP you receive on that planet.
