So I got a little something interesting that I believe is a real first in this community and because the holiday was coming up I wanted to make it something really special, I give you a BALDWIN DISK DRIVER. This type of driver was designed and made by the Baldwin Locomotive Works and was used on railroads that ordered locomotives from Baldwin. This wheel was designed and made by me on AutoCAD 2022 and with the help of a humble XYZ Da Vinci 3d printer. It is 62.4 mm in diameter compared to the #13 43.2mm diameter. This took over 20 different attempts to create. It is still imperfect from the color of the wheel for I do not know any steam locomotive from Baldwin that used red colored wheels and the fact that it is not the plastic that is used on BrickTrainDepots wheels. Nevertheless, it still accepts standard axles and connector pieces in the exact same fashion as all of the other steam train drive wheels.
Here is the wheel with the connector peg and axle in their respective places.
For comparison, here is the disk driver(62.4mm) beside BTD's #13(43.2mm) Boxpok Driver
