Showing results for tags 'clean polish transparent'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. I did some research and posted results at bricklink. Details at http://www.bricklink...e.asp?ID=685097 In case dropbox passed bandwidth limit, here is more robust link for picture. https://secure.flick...tream/lightbox/ (EDIT added, edited from original post at bricklink.) Interesting. I heard of certain acrylic liquids that can fix some parts condition like scratches and such. I also decided to buy fairly worn parts from seller to fix to fix it up see if I can get it to great condition as possible. The windows was in decent but worn condition, at "raw" one is decent condition and other 2 had been bit discolored and somewhat "sandpapered" as you can see effect on paper behind it. There is also couple heavier than fixable scratches. After I used metal polish, then removed as much polish as I can and cleaned it, condition of parts was much improved. there was lot of micro-scratches after it but usable condition. Lot of discolor went away and pretty lot of "sandpapered" look went away too. Light reflection is worse I could get it to show up. (I wish I took better picture of that as by time I thought of it, I already dropped it into next step) (added: polish is really only necessary if there is deeper scratches than just "cloudy". It does remove ingrained stains very well, however. Do clean first so you can see if it needs polish or not.) The plate was in decent but well used condition, but I cannot polish it due to number of studs and difficulty on wiping polish off afterwards. Brasso probably will do better as it's more cleanable. After I left windows and plate in floor polish solution for couple minutes and dried it in few steps (very carefully as dust or fingerprint could mar it!) on wax baking paper. When it was dry enough (around 3 minutes) I got paper and dropped parts on it from inches off to shake off droplets. After 10 minutes I flipped it to other side and let it dry for other 10 minutes. Novus is recommended by other people but I used pledge floor polish which is also acrylic liquid. As you can see, results is pretty decent. You can see quite a bit of micro-scratches and few remaining deeper scratches. However, this liquid has altered refraction so it is not really visible when held in room without light refection or held up with light shining though it to your eyes. This is small improvement after metal polish. Notes on this: 1: If I ever decided to sell those (yeah right!) or any other parts done like this, I would disclose it. 2: Floor polish step is easy to make mistakes on. If there is dirt, it will be under very thin coating so it cannot be removed without metal polishing all way down again. Very good cleaning first is highly recommended! You can only touch parts of part drying in this coating where you don't care what those parts looks like. I used sides of windows and plate. (Added: if you want to see original, see reply #17)
