Showing results for tags 'broken home'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. Hello, I'd like you to show all the doors I've build for my last MOC. Some of them are quite tricky, others really simple (when you don't have to figure out everything on your own and just see the result). As you can see I use a technique here quite often that allows offsets that are not fixed. #1 Take a look at door #1. There is an extra inlet. You can put it into the frame and still move it. The trick is that you have to have several "segments". This fixes the inlet so that it stays in place. You could easily use this techniqe for exhibitions without worrying that something falls off. => the more segments, the more tight it is. Do not use only one segment. #2 same technique, different pattern. Note the colour usage in the outer frame: very light gray(!), light gray, yellowed light gray, bluish light grey and olive. #3 This one is really complicated because of the alternating brick directions. Think of two levels. One is used horizontally and the other vertically to connect the corresponding bricks in the back. #4 Easy (once you have the pattern) to build and looks very elegant. I love this one. #5 It's like #3 with a little simpler form. #6 Once again very easy to build from a picture, but it takes some time to figure out patterns that work. Which is your favourite one?
