Showing results for tags 'arc 170 starfighter'.
To celebrate the release of Rogue One: A Star Wars Story today, I decided to build a 786-piece model of the ARC-170 Starfighter. While it does not actually appear in the movie, it was the Republic's precursor to the iconic X-Wing Starfighter that the Rebel Alliance used in their fleet. It includes three clone pilots and an R4-D5 astromech droid. I used 8088 as a skeleton, but did some major modifications as I will detail throughout the post. Here you can see the model as a whole. At first glance you may not see that much different from 8088 (apart from the engines), but I altered many minor aesthetic and functional components of the ship to make it more accurate and give better play features. The original model had 396 pieces. I almost doubled the part count of the original. Here's a front view. One of my main priorities with this model was to bring the s-foils in closer to the main wing. In the movie, they're flush against it when closed, but 8088 had an unsightly gap between everything. This was as close as I was able to get the s-foils to the main wings. In this side view you can see some of the tapering I attempted to do near the nose. I wanted the dark red to flush better with the stripe that goes back towards the cockpit. You can also see my addition of spring-loaded missiles to the main guns, of which there are also faux blaster tips to try to mask some of the spring missiles' prominence. I also tried to extend part of the underbelly to better connect with the nose as seen on the movie model. Nothing too much back here. Just a knob that when turned opens and closes the s-foils, similar to 8088, however pulling and pushing it operates a different function... In 8088, pushing the knob activated a series of flick-fire missiles. Here, pulling it releases a latch that drops down this gun caddy which is currently holding the pilots's personal weapons. This is securely held in the ship so it doesn't fall out while swooshing. Top-down view. I changed the shaping of the wing-tips to make them more symmetrical as they should be. Here's my personal favorite enhancement. I modified the engines based on thire5's UCS ARC-170 model, but scaled down appropriately. It was a nightmare getting each tile to line up properly and not give me a collision error. I spent a good few hours or so on this part alone. They're slightly larger than the turbines on 8088, but I don't think they're oversized. The internal skeleton of the turbines for those wondering how I did it. If you have any comments or suggestions for how my model could be improved, please share! I'm always looking for constructive criticism! May the Force be with you!
- 17 replies
- arc 170
- arc 170 starfighter
(and 5 more)
Tagged with:
