Showing results for tags 'airport 2016'.
Hi everyone I would like to know your opinions of the new airport coming out in august in the USA. As a lego plane enthusiast i have had lego planes since the old 4 wide builds and missed out on the 2010 airport set. Do you think this set is worth getting or not. I am in a sort of dilemma because in my opinion its pros are equal to the cons. For the pros - It is the first Passenger airport since 3182 which is now ridiculously expensive - The control tower section of the airport can be added to my current one from 60022 cargo terminal - The plane has one of those doors that are the only type of large pieces that i actually like -The airport is sizable and contains a nice revolving door - The plane has a bathroom - The plane also has a flight attendant cart Cons- - The plane is too small - It has a ton of huge specialized parts - The rear landing gear is terrible - The airportort has nowhere near the appropriate amount of details - The control tower is on top of the airport - The price is 100$ and there are only about 700 parts - The engines should be on the wings because large planes do not usually have engines on the tail section - The wings are too far back - There is no jetway to get to the plane - The details that are in the airport are awkwardly placed - There is no co-pilot - The plane can only hold 5 passengers - The cockpit has no control levers - There is only one door - There seem to be a lot of stickers This is my list of pros and cons so i would like to ask you to evaluate it and if you recommend this set. Thx in advance. -Legoboy22
