Showing results for tags 'Space Lego Sci-fi SHIP'.
The Undaunted Benefactor is an ex-troop transport ship retrofitted by Zed Corp to serve as a Humanitarian Relief ship. The Benefactor is now under the control of the Velegrad benevolence fund, and is mainly used to provide humanitarian relief to the other, less prosperous planet in the Velegrad system. The ship has been refitted to carry modules on both sides, these can be used for a variety of things, such as a first aid module, escape pods, refugee evac pods, aid drop pods, or extra cargo capacity. The current fittings on the Benefactor are a escape pod for the crew, aid drop pods to be sent from low orbit to the more unreachable sections of a planet, a first aid module, a septic tank mainly for the crews use, but also for medical waste. The Ship has had its slip stream FTL drive stripped out as the space was needed for living quarters, and most of the Benefactor's business is in system and so convention travel was all that was needed. Similarly the main weapon turrets and missile batteries were stripped as they were seen as unneeded and to dangerous for civilian use. However one howitzer was retained, as they can be equipped with stun grenades to control unruly refugees. The ship has a constant flight crew of 2, a pilot and a commander, then there are 2 addition humanitarian workers, and depending on modules, a medical team. See the full gallery here - http://www.mocpages.com/moc.php/385884 Here we can see the good work the crew and ship of the Undaunted Benefactor is doing on Velegrad 3, a planet in the inner rotations of the Sun, that has recently experienced a civil war. It's considered Velegrad 1's duty top help the other planets in its system.
