Showing results for tags 'Solid Axle Suspension'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 2 results
  1. My latest release, a rerelease and rebuild of a three axle detachable gooseneck lowboy trailer with liftable third axle. The truck that goes with it is worked on right now! Will be released March 2015. Not yet had the change to work on a new video, but one will be available soon. So for now I use the first edition video of this model. Model "Trailer Tr4 MkII” is build with LEGO® in scale 1:17,5 and motorized using LEGO® Power Functions. It is not build after a specific brand or type of trailer. This build represents a three axle detachable gooseneck lowboy trailer with liftable third axle. The trailer features: solid axle suspension on all axles, one set of lights, kingpin, mechanical parking break, gooseneck frame support, remotely controlled liftable third axle, remotely lowering and lifting of the deck and this model has many details. This newly design and engineered trailer utilizes the same suspension as both "US Truck T1 MkII" and "US Truck T2 MkII". It uses LEGO® rubber belts and LEGO® rubber axle connectors. Designing and engineering this trailer parts availability is checked. So it can easily be build in the color as it is, Yellow, but it can also be build in Red, Blue and Black. Attention!!!: Both "US Truck T1 MkII" and "US Truck T2 MkII" needs to be adapted to be combined with "Trailer Tr4 MkII”!!! Else could be used a so called dolly which acts as a convert to fit the trailer. For this dolly building instructions will be available soon. Attention!!!: LEGO® Technic set 8258 Crane Truck needs to be adapted and requires a modified gooseneck!!! Instructions for "Trailer Tr4 MkII” to go with LEGO® Technic set 8258 Crane Truck will be available soon! This model is another custom design by Ingmar Spijkhoven AKA 2LegoOrNot2Lego that comes with building instructions and inventory/parts list!. So, you can build it yourself! To do so you can buy the Building Instructions. Early in the building process you will see what it is that you are building. You will be very excited from the moment you start the build of "Trailer Tr4 MkII" till you finish it with a total number of parts of about 1450 pieces. With this type of lowboy trailer the gooseneck is removed to make the deck accessible. Because the front part of the trailer rests on the surface the truck with the gooseneck still attached can drive off. In order to keep the gooseneck elevated at the correct hight is as a support. This support rests on the trucks frame. The ramps can be lowered and any self propelled load can enter the trailers deck. With the trailer loaded and the load secured the gooseneck can be reattached. This is done by backing up the truck aligned with the trailer. With a support that rests on the trucks frame the gooseneck can be lowered of lifted to make sure it comes in place. Finally the deck can be lifted again and the gooseneck can be locked so it doesn’t go anywhere without the trailer itself. Cheers, Ingmar Spijkhoven
  2. Presenting my latest MOC US Truck T2 MkII with instructions some people came with a question I did not expect. Never the less is this question fare enough: what about the frame. Some people are interested in the frame or chassis only and why not, I can imagine... :-) So here they are, the instructions for only the frame of my latest MOC: US Truck T2 MkII Hopefully this helps for some people to buy the instructions, without a lot of unwanted information. It may be obvious, but to make sure, you could easily build this frame in for example black. Black parts are much more common and a lot of Technic builders who have earlier sets have plenty of black parts... Cheers and enjoy building..., Ingmar Spijkhoven This is only the frame of an earlier released model. A model of a US truck with LEGO® Power Functions®. This truck is revered to as US Truck T2 MkII which is a rebuild and revised version of US Truck T2 I finished back in 2009. Like with all my models this truck's frame is build in scale 1:17,5. This model features: solid axle suspension on all axles, PF powered driving with power transmitted independently to both rear axles, Ackermann geometry on steering axle, Servo powered steering, fully functional fifth wheel and 1 set of PF lights. To give you an idea how these instructions look like here is a preview. Creating these instructions both quick progress on your build as well as each step being easy to understand the same time were very important. Early in the building process you will see what is happening, what it is that you are building. You will be very excited from the moment you start till you finish the build of this chassis with a total number of parts of about 800 pieces. To achieve this a lot of floating items are used, with added arrows to show where these items are suppose to be. Together with a lot of so called call outs (the smaller windows within a step that shows the assembling of a smaller sub part of the build) together with multi part steps the build will be in a flow. Included you'll find a parts overview. You rather want to use the parts list shown at rebrickable.com! Both building instructions and a parts list are available!
