Showing results for tags 'OOMN Member'.
This is a moc I've waited to post. After a bricklink order arrived today. I can say the moc is done. With that I give you my Dark Hunter Moc Grenak and his Energy Hound Limeup http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/001.jpg The goal with this moc was to use mainly green parts. The colors used are Mata Green Lime Green Metru Green Trans Light Green Trans Dark Green Trans Apple Green Black (If the part existed in Mata Green, Lime Green, Or Metru Green it was used instead of Black) Dark Bley (Just the metru head and the 3 long axles with the stud on the end.) This is Grenak's Backstory Grenak is a member of the Order of Mata Nui. Like other members he was experimented on to become stronger. He became physically faster and stronger but a side effect occured. He became unable to breathe normal air and could only breathe poison. So the Order fashioned a backpack that would syphon the toxins in the air and convert it into poison so Grenak could survive. Another side effect was Grenak grew a bunch of spikes. Grenak wears the Kanohi Zatth allowing him to summon rahi His weapon is a large Tri axe that allows him to control rahi. Though larger rahi require him to concentrate. He met Limup using his mask. Helryx sent Grenak and Limup to join the Dark Hunters as a secondary spy. Just incase Ancient should fail. He is currently on Spherus Magna with the other Dark Hunters ready to tell the order The Shadowed One's plans once he discovers them. I'll start with pics of Limup the energy hound Side (Limup is built similar to the Energy Hound Spinax but with some changes) http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/002.jpg Front (The head was the hardest to design using mainly green parts. I once used Ehlek's head Then Corroder's head But the Spikit head works best. http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/003.jpg Back http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/004.jpg Now pics of Grenak Front (He uses a custom torso built around a mata body.) http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/006.jpg Side (His joints aren't the strongest and the lime green ball joints tend to come loose. He is more a display piece than an play figure) http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/007.jpg Back (Those aren't wings. There used to siphon toxins from the air and turn it into poison which goes into the tanks) http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/011.jpg Back weapon stored http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/012.jpg Bonus pic Grenak and Limeup tracking something http://www.brickshelf.com/gallery/takanuinuva/GrenakAndLimup/010.jpg Gallery when public http://www.brickshelf.com/cgi-bin/gallery.cgi?f=526911 Comments and Critisim appriciated.
