Sorry for a dumb question but I'm just getting back into NXT 1.0 programming and am having trouble with setting up a loop.
There are some activity blocks in a loop with logic control, which needs to repeat until a motor on another branch (parallel sequence beam) of the program has finished moving.
I've tried setting a variable after the move command so I can feed "false" into the logic plug on the loop control but I can't seem to get the wire to connect.
I must be making some sort of newbie mistake and would be grateful for any guidance. I've looked at some of the links in the Technic index but to no avail. (Anticipating *facepalm* when I work out what I'm doing wrong)
Thanks in advance.
:classic:
