Showing results for tags 'Luke´s X-Wing'.
Hello everyone here´s a project that took a while but it´s finally here´s Luke´s personal X-Wing based after the 9493 set As you can see a lot has changed since it was 9493, i tried to get the most accurate color scheme to Luke´s Red Five, i couldn´t make all the details on this scale so i had to paint the blue lines on the blasters & the gray line next to the tan one on the nose. Some of the most hevy MODs are located on the cockpit so let´s go there This is how all started i wanted to get a nicer cockpit so i did a nicer looking seat,a place to hold the light saber and some other controls. One of the sections i´m the most proud of is this,one of the things that always bother me on 9493 was that R2-D2 was in a vertical position instead of a horizontal one so i changed that and i heavely moded the greebles to be more accurate over all. Here´s a look on the back, it looks way nicer and accurate IMO (i originally had a Technic disk instead of that black nob but it was really hard to lock the S-Foils so i used the black nob instead) Here´s a look at the other side as the color scheme changes. I also added an UCS style base for display Here´s the X-Wing on all it´s glory. Thanks for taking the time for reading this i hope you like this thing as much as i do. I´ll also be happy to answer any questions you may have. Hope you have a fantastic day !! -Prime
