Showing results for tags 'Jedi Knights'.
Aid the Jedi Warriors as they stop the 501st Legion Clone Trooper from causing destruction at the Jedi Temple on Coruscant during Operation Knightfall! My entry includes four army-building minifigures: a female Twilek Jedi Knight sporting two blue and green lightsaber, a male human Jedi Knight sporting a single green lightsaber, a female human Jedi Padawan sporting a single blue lightsaber, and a 501st Legion Clone Trooper. The build for this battlepack is an ancient Jedi Master statue that appears in the film. Building it was very intriguing because I built the bottom half with studs upwards and bottom half with studs downwards (both halves are connected by a single Technic axle). You can see this demonstrated in a picture below where the statue has been separated. The separation of the statue is also the feature of this battlepack; in which the 501st Legion causes destruction to the Jedi Temple (the feature also symbolizes the fall of the Jedi Order). The arms rise and fall using the ball joint connectors and are locked together by another Technic axle piece. Buying multiples of this battlepack is a great idea because you can create your own Jedi Temple with multiple statues (just like in Revenge of the Sith) and build your Jedi and 501st Legion armies. Hope you enjoy my second entry, and thanks for looking!
- 7 replies
- Jedi Temple
- Statue
(and 3 more)
Tagged with:
