Showing results for tags '75333'.
I started modifying the new set straight away after the press images were published, hashing out some ideas in Studio. I was I inspired long ago by Mr_Idler's amazingly detailed and well proportioned Delta-7 and I've always wanted a little Jedi Starfighter on my shelf, this set presented the perfect opportunity. At first I added a lot of wedge plates to create complicated but fragile slopes around the cockpit, but after getting hold of the original set inventory and recreating it in Studio I managed to rebuild the ship with a lowered cockpit without using any extra pieces at all. Here is the complete mod along with an LED Kamino Landing Pad that I threw together, instructions are on Rebrickable. I've lowered the cockpit area by 2 plates and added a layer to the nose which is now slightly more substantial looking and helps the cockit blend better into the ship. I've made some minor changes to the wings, R4 and the Republic crest are closer to the centre and I also moved the black inverted slopes to the edges of the wings in place of landing gear. The nose of the ship now sits a whole 3 plates lower when landed and the top of the cockpit is 5 plates lower. Rather than towering over the minifigures the ship looks much closer to scale. I've also rearranged the notched-wedge pieces from the tail to create the point over the cockpit canopy, which can't be hinged open but can still be easily removed. The landing pad in the photo above is buildable but the circle shape is slightly illegal, putting the wedge plates under stress, and so the build is hard to pick up once assembled. It is however cheap, compact and compatible with the cheap USB LED kits on eBay consisting of a string of six 1x4 plates. The landing pad instructions and Studio model (use this for parts list) are in a seperate zip file on my 75333 mod Rebrickable page. Thanks and I hope you like the mod!
