Showing results for tags '207'.
Hi all, I'd like to present you something I did two years ago, and that I continue to improve. It is a small workhorse very popular here in Italy. Probably it is known in Europe as Breuer Type IV, here in Italy it was produced under Breuer license from a workshop in Lecco, the "Antonio Badoni Lecco" or simply ABL. This apparently small company built the Ataturk bridge in Istanbul and part of the Milan Central station, plus a lot of other surprisingly complex infrastructures. Therefore the locomotive section began with this kind of licensed product. A small shunter, which was broadly used in nearly all Italian railway stations, and got the Italian nickname of "sogliola" ("sole"), due to its flattened cabin. I sincerely love this little thing (and all other ABL shunters), since I saw it in an old station, left abandoned on a dead track. FS marked these small locomotives as 207/208 and there was a bigger version too (210/211). I represented the last version of the ABL Type IV, with normal puffers and standard headlights. The real one has a chain on one side which drives the small wheels. I chose a central masked wheel (made with vintage slick tyres). A 9v red micro-motor powers the two central wheels. It is 9-wide, and scale is not particularly accurate. Maybe some suggestions can help me to correct its proportions. It is slow as it should be and not very powerful, but it can shunt properly. It cannot host batteries inside, so it needs a battery box on a pulled car, or a dummy car with an empty 9v motor to pick-up electricity from track. I hope you like this little thing!
