Showing results for tags '2 apartments'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 1 result
  1. It's finally time for me to present to you my newest MOC: The Sideways Building Designed between September 2016 and January 2017, this MOC has roughly 4500 pieces. The building's name is a bit tongue in cheek and references the fact that most of the frontal facade is built using elaborate SNOT techniques. 1x1 bricks are used sideways and offset by exactly half a brick's height to the ones above and below to create a new kind of masonry effect. The basic idea was this: This technique was not easy to pull off and made the design and build very challenging. But without further ado, here are the pictures - More images are, as usual, available at flickr. The intensive snotting on the facade also leads to the absence of the usual 'stripes' that separate the individual floors of modular buildings (where tiles and plates are used at the top & bottom). Still, my building is fully modular, as this picture shows. The floors can also be interchanged freely (except for the roof, of course). The only parts of the front facade built with studs on top is the bottom-most layer of bricks, all windows, and most of the roof. Everything else has studs facing left, right, towards you or even downwards. This also creates weird offsets - the left and right windows on the upper floors are offset by 2/5 the width of a stud! (or 3/5, depending which way you look at it...) A closer look at the masonry detail. View from the back - this is built the old fashioned way with studs facing upwards. Let's take a look inside. The left hand part of the ground floor is taken up by a pizza parlor. It has two tables for patrons to sit, but it is mostly aimed at take-away (and possibly delivery). A young couple is enjoying their pizza. Pizzas are baked in a stone oven. On the other side, there is a travel agent. As usual, the walls are decorated with posters showcasing possible travel destinations. Moving up to the first floor. A couple lives here. Behind the living room, there is a small kitchen (the wall inbetween was removed for this photo). A look inside their bedroom. The green door leads to the bathroom. A picture of that can be seen on flickr. Moving up to the second floor...The owner of this flat had the wall separating kitchen and living room knocked down to create a combined living room and kitchen. The center counter with two bar stools looks very inviting. Seems like the cat found something on the floor... Note: More pictures of the second floor apartment are available on flickr. Moving up one final time, we take a look at the stairwell... As attics go, this is actually still pretty orderly...except for the giant cobweb in one corner. Apparently, someone also used the attic for his painting at some point. That's about it Again, more pictures can be found at flickr. Looking forward to your thoughts & comments! Cheers!
