Well here it is finally:
Back end - it's actually pretty stable but I put it on a transparent mount:
Business end:
Enjoy.
-CCOOK
Fantastic build CCOOK. The amount of detail you were able to incorporate into a relatively small model is respectable. I am especially intrigued by the shape and techniques used to create the wings. Care to elaborate on how you achieved this?
I can tell you put a lot of thought into this to create such wonderful details. I especially like how you've made all the gray framing on the wings connect so there is no loose parts at the corners and intersections. I took on that challenge once on a simple Tie fighter and gave up, but you have achieved the effect perfectly. Bravo!
Agreed, I never thought about using that small corner piece when framing the wings. And the fact that your pylons are rounded is especially nice. Well done!
I might need to rebuild my defender using this :wink:
Look close and you will see hinge tiles connecting with hinge plates along with support 4L bars on grabbers - the 4L bars support the grey wing framing - this same technique could easily yield the Avenger and most other TIE designs as well.
-CCOOK
Edited by CCOOK
  • 2 years later...
I played the X-Wing and Tie Fighter games to death when I was a kid and so still have a soft spot for the Tie Defender... this looks great - far better than the official retired lego set.
