This weekend I was planning on taking 9495 Y-Wing Starfighter off of display (fantastic set by the way) and putting it into storage for a month or two. But once I started disassembling the top turret, I found that I could not separate the light bluish grey pin double with axle hole (part 32138) with the two flick missles (part 61184). Does anyone have any suggestions for taking these three pieces apart?
That's child's play.
I actually tried doing it myself, and if you just pull them stronger they should be able to de-attach. Use anti-slip stuff if you're desperate.
If you are just storing it, it probalbly won't matter a lot if you let those pieces attached, right? ;)
