again, i made a mech using HF parts that's also a combiner. this time i'm using parts from Stormer XL and Fire Lord only. except the pilot, of course.
so, i present to you, SF-1 heavy armored mech.
front:
this mech's body is covered with an armor made from strongest substance.
side 1:
in one if its hand, it's equipped with a sword that's very suitable for close combat. this sword's blade is equipped with ultra vibration system, make it able to cut anything.
side 2:
on its other hand, this mech equipped with double cannon that has different attribute and worked simultanously. the cannon at the bottom shoots freezing bullet, that will render any opponent unable to move, and the upper cannon shoots ultra heat bullet that wil burn those opponents out.
back:
this mech has a heavy equipped booster in his back, in order to lift its heavy body.
close up on the cockpit:
cockpit opened:
reveal the pilot.
without pilot:
those yellow pins used to attach pilot's feet to the cockpit.
size comparison with the pilot:
pose shot:
that's it, C&C appreciated.
Hey let me ask you question ? from were you get these amazing ideas for MOCs :classic: l'm trying to build a transforming drone thing but still l can't get more ideas
P.S your MOC is very cool great job Bacem
thanks! the idea? well, usually the idea just kinda pop out when i'm taking a dump hahaha.
