Brawl Posted September 21, 2013 Posted September 21, 2013 While working on a model my power went out. I had saved the model roughly 5 minutes before the power failure. After letting the weather clear I restarted my computer and launched LDD, but when I tried to load my model I was informed that there was an error and the file could not be loaded. I restarted LDD hoping it was just a temporary bug, but I got the same message again. I've been working on this model for about a week, so I'm quite frustrated. The last backup I have was from 2 days ago, and I have made a lot of changes since then. I'm fine with having to rebuild, I'm pretty sure I can make it almost the same, but I would like to fix the file if possible. Download (106KB) I'm no expert, but I assume the power failed before the file was closed in the program causing data to be incorrectly written, or something like that. I've also tried loading the model in LeoCAD, but it failed too. Quote
Jason C. Hand Posted September 21, 2013 Posted September 21, 2013 (edited) While working on a model my power went out. I had saved the model roughly 5 minutes before the power failure. After letting the weather clear I restarted my computer and launched LDD, but when I tried to load my model I was informed that there was an error and the file could not be loaded. I restarted LDD hoping it was just a temporary bug, but I got the same message again. I've been working on this model for about a week, so I'm quite frustrated. The last backup I have was from 2 days ago, and I have made a lot of changes since then. I'm fine with having to rebuild, I'm pretty sure I can make it almost the same, but I would like to fix the file if possible. Download (106KB) I'm no expert, but I assume the power failed before the file was closed in the program causing data to be incorrectly written, or something like that. I've also tried loading the model in LeoCAD, but it failed too. Hi Brawl, Is the file you linked to on here the backup from 2 or so days ago? If so, I just attempted to open the file in LDD and got a message saying the file was unable to load due to an error in parsing the file. Edited September 21, 2013 by Jason C. Hand Quote
Brawl Posted September 21, 2013 Author Posted September 21, 2013 The file I linked was the corrupted file. Uploading the outdated backup wouldn't really help, would it? Quote
pbat Posted September 21, 2013 Posted September 21, 2013 (edited) I'm no expert, but I assume the power failed before the file was closed in the program causing data to be incorrectly written, or something like that. I've also tried loading the model in LeoCAD, but it failed too. As LXF files are simple ZIP files, you may use a freeware like ZIP-Repair from DiskInternals to obtain its content, namely the IMAGE100.LXFML file. This is a plain text file containing some sort of XML which LDD uses to display your model. You'll get something like the code hidden in the spoiler below. Copy this code to Notepad (or the text editor of your choice), save it to a text file (the name does not matter, but the extension must be ".LXFML") and import it in LDD. Voila. (Obviously brickshelf.com is down at the moment, so I can't upload that file for you.) <?xml version="1.0" encoding="UTF-8" standalone="no" ?><LXFML versionMajor="5" versionMinor="0" name="Liger Zero"> <Meta> <Application name="LEGO Digital Designer" versionMajor="4" versionMinor="3"/> <Brand name="LDD"/> <BrickSet version="1182"/> </Meta> <Cameras> <Camera refID="0" fieldOfView="80" distance="25.998851776123047" transformation="-0.070181466639041901,0,-0.99753433465957642,-0.64234828948974609,0.76507943868637085,0.045192375779151917,0.76319289207458496,0.64393603801727295,-0.053694389760494232,31.387081146240234,51.682376861572266,-19.158662796020508"/> </Cameras> <Bricks cameraRef="0"> <Brick refID="0" designID="3705" itemNos="370526"> <Part refID="0" designID="3705" materials="26"> <Bone refID="0" transformation="-0.0048284507356584072,-0.015325308777391911,0.9998708963394165,0.004831037949770689,0.99987059831619263,0.015348625369369984,-0.99997669458389282,0.0049045304767787457,-0.0047538066282868385,2.4049468040466309,4.825718879699707,-4.5759091377258301"> </Bone> </Part> </Brick> <Brick refID="1" designID="32291" itemNos="4140430"> <Part refID="1" designID="32291" materials="26"> <Bone refID="1" transformation="0.99997669458389282,-0.0049045304767787457,0.0047538066282868385,0.0048310365527868271,0.99987053871154785,0.015348619781434536,-0.0048284567892551422,-0.015325306914746761,0.9998708963394165,3.5991232395172119,4.0138068199157715,-4.1825351715087891"> </Bone> </Part> </Brick> <Brick refID="2" designID="32006" itemNos="4107136"> <Part refID="2" designID="32006" materials="26"> <Bone refID="2" transformation="0.0048290346749126911,0.99987059831619263,0.015349003486335278,-0.0048288889229297638,-0.015325686894357204,0.9998708963394165,0.99997669458389282,-0.004902535118162632,0.0047542722895741463,5.5971465110778809,3.2102298736572266,-4.5852537155151367"> </Bone> </Part> </Brick> <Brick refID="3" designID="32073" itemNos="4114740"> <Part refID="3" designID="32073" materials="26"> <Bone refID="3" transformation="-0.004828890785574913,-0.015325685031712055,0.99987083673477173,0.0048290346749126911,0.99987053871154785,0.015349006280303001,-0.99997663497924805,0.0049025341868400574,-0.0047542727552354336,2.0088160037994385,5.6275696754455566,-4.5655322074890137"> </Bone> </Part> </Brick> <Brick refID="4" designID="50923" itemNos="4242297"> <Part refID="4" designID="50923" materials="26"> <Bone refID="4" transformation="-0.004828890785574913,-0.015325685031712055,0.99987083673477173,-0.0048290346749126911,-0.99987053871154785,-0.015349003486335278,0.99997663497924805,-0.0049025337211787701,0.0047542722895741463,4.0203537940979004,6.4421610832214355,-6.1420793533325195"> </Bone> </Part> </Brick> <Brick refID="5" designID="3705" itemNos="370526"> <Part refID="5" designID="3705" materials="26"> <Bone refID="5" transformation="-0.0048288912512362003,-0.015325684100389481,0.99987083673477173,0.0048290351405739784,0.99987053871154785,0.015349004417657852,-0.99997663497924805,0.0049025337211787701,-0.0047542722895741463,2.4126691818237305,5.6378698348999023,-5.3635330200195312"> </Bone> </Part> </Brick> <Brick refID="6" designID="32039" itemNos="4107081"> <Part refID="6" designID="32039" materials="26"> <Bone refID="6" transformation="0.99997663497924805,-0.0049025332555174828,0.0047542722895741463,-0.0048288912512362003,-0.015325685031712055,0.99987083673477173,-0.0048290351405739784,-0.99987053871154785,-0.015348996035754681,5.2068119049072266,4.4242978096008301,-5.3686423301696777"> </Bone> </Part> </Brick> <Brick refID="7" designID="32249" itemNos="4140328"> <Part refID="7" designID="32249" materials="26"> <Bone refID="7" transformation="-0.0048288903199136257,-0.01532568596303463,0.99987083673477173,0.0048290346749126911,0.99987053871154785,0.015349005348980427,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,4.4126272201538086,4.052793025970459,-6.9783768653869629"> </Bone> </Part> </Brick> <Brick refID="8" designID="42074" itemNos="4612590"> <Part refID="8" designID="42074" materials="26"> <Bone refID="8" transformation="0.0048288912512362003,0.015325685031712055,-0.99987083673477173,-0.0048290351405739784,-0.99987053871154785,-0.015348998829722404,-0.99997663497924805,0.0049025332555174828,-0.0047542727552354336,5.2106752395629883,5.2241950035095215,-5.3563628196716309"> </Bone> </Part> </Brick> <Brick refID="9" designID="32249" itemNos="4140328"> <Part refID="9" designID="32249" materials="26"> <Bone refID="9" transformation="-0.0048288898542523384,-0.015325686894357204,0.99987083673477173,0.0048290346749126911,0.99987053871154785,0.015349004417657852,-0.99997663497924805,0.0049025337211787701,-0.0047542736865580082,3.2126526832580566,4.0586762428283691,-6.9840812683105469"> </Bone> </Part> </Brick> <Brick refID="10" designID="32039" itemNos="4107081"> <Part refID="10" designID="32039" materials="26"> <Bone refID="10" transformation="0.99997663497924805,-0.0049025332555174828,0.0047542736865580082,-0.0048288903199136257,-0.015325686894357204,0.99987083673477173,-0.0048290351405739784,-0.99987053871154785,-0.015348996967077255,2.8068654537200928,4.4360642433166504,-5.3800520896911621"> </Bone> </Part> </Brick> <Brick refID="11" designID="3706" itemNos="370626"> <Part refID="11" designID="3706" materials="26"> <Bone refID="11" transformation="-0.0048034829087555408,-0.015325769782066345,0.99987101554870605,0.0048031187616288662,0.99987059831619263,0.015348830260336399,-0.99997693300247192,0.0048762327060103416,-0.0047292676754295826,1.6126904487609863,4.0665202140808105,-6.9916887283325195"> </Bone> </Part> </Brick> <Brick refID="12" designID="32123" itemNos="4270046"> <Part refID="12" designID="32123" materials="26"> <Bone refID="12" transformation="-0.0047045559622347355,1.1391475709388033E-005,0.99998891353607178,0.0048507633619010448,0.99998825788497925,1.1423368960095104E-005,-0.99997711181640625,0.0048507689498364925,-0.0047045731917023659,5.2126078605651855,4.0489654541015625,-6.9746627807617187"> </Bone> </Part> </Brick> <Brick refID="13" designID="32249" itemNos="4140328"> <Part refID="13" designID="32249" materials="26"> <Bone refID="13" transformation="0.0047968439757823944,0.99987071752548218,0.01534899789839983,0.0047967373393476009,0.015325992368161678,-0.99987107515335083,-0.99997693300247192,0.0048698573373258114,-0.0047226189635694027,5.5971698760986328,2.4225881099700928,-5.3974595069885254"> </Bone> </Part> </Brick> <Brick refID="14" designID="32249" itemNos="4140328"> <Part refID="14" designID="32249" materials="26"> <Bone refID="14" transformation="0.0047968444414436817,0.99987071752548218,0.01534899789839983,0.0047967382706701756,0.015325992368161678,-0.99987107515335083,-0.99997693300247192,0.0048698568716645241,-0.0047226184979081154,5.9972400665283203,2.4207501411437988,-5.3956451416015625"> </Bone> </Part> </Brick> <Brick refID="15" designID="41677" itemNos="4164133"> <Part refID="15" designID="41677" materials="26"> <Bone refID="15" transformation="-0.0048290346749126911,-0.99987053871154785,-0.015349004417657852,-0.0048288898542523384,-0.015325686894357204,0.99987083673477173,-0.99997663497924805,0.0049025337211787701,-0.0047542736865580082,4.8126168251037598,4.0508322715759277,-6.9764766693115234"> </Bone> </Part> </Brick> <Brick refID="16" designID="6590" itemNos="4177421"> <Part refID="16" designID="6590" materials="26"> <Bone refID="16" transformation="-0.0047045559622347355,1.1391475709388033E-005,0.99998891353607178,0.0048507633619010448,0.99998825788497925,1.1423368960095104E-005,-0.99997711181640625,0.0048507689498364925,-0.0047045731917023659,3.6126441955566406,4.056767463684082,-6.9822292327880859"> </Bone> </Part> </Brick> <Brick refID="17" designID="3705" itemNos="370526"> <Part refID="17" designID="3705" materials="26"> <Bone refID="17" transformation="-0.0048288898542523384,-0.015325686894357204,0.99987083673477173,0.0048290346749126911,0.99987053871154785,0.015349007211625576,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,2.3972179889678955,3.2259182929992676,-4.600468635559082"> </Bone> </Part> </Brick> <Brick refID="18" designID="41678" itemNos="4162857"> <Part refID="18" designID="41678" materials="26"> <Bone refID="18" transformation="0.99997663497924805,-0.0049025337211787701,0.0047542732208967209,0.0048288898542523384,0.015325686894357204,-0.99987083673477173,0.0048290346749126911,0.99987053871154785,0.015349007211625576,3.5952868461608887,3.6077234745025635,-3.7887258529663086"> </Bone> </Part> </Brick> <Brick refID="19" designID="32006" itemNos="4107136"> <Part refID="19" designID="32006" materials="26"> <Bone refID="19" transformation="0.0048290346749126911,0.99987053871154785,0.015349007211625576,0.0048288898542523384,0.015325686894357204,-0.99987083673477173,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,2.3972170352935791,3.2259187698364258,-4.6004681587219238"> </Bone> </Part> </Brick> <Brick refID="20" designID="4519" itemNos="451926"> <Part refID="20" designID="4519" materials="26"> <Bone refID="20" transformation="-0.004828890785574913,-0.015325685031712055,0.99987083673477173,0.0048290356062352657,0.99987053871154785,0.015349006280303001,-0.99997663497924805,0.0049025337211787701,-0.0047542727552354336,2.8088259696960449,3.2607383728027344,-6.9982185363769531"> </Bone> </Part> </Brick> <Brick refID="21" designID="50923" itemNos="4242297"> <Part refID="21" designID="50923" materials="26"> <Bone refID="21" transformation="-0.004828890785574913,-0.015325685031712055,0.99987083673477173,-0.0048290356062352657,-0.99987053871154785,-0.015349006280303001,0.99997663497924805,-0.0049025337211787701,0.0047542727552354336,4.0203838348388672,4.0792503356933594,-8.5785665512084961"> </Bone> </Part> </Brick> <Brick refID="22" designID="42074" itemNos="4612590"> <Part refID="22" designID="42074" materials="26"> <Bone refID="22" transformation="0.0048288903199136257,0.015325686894357204,-0.99987083673477173,-0.0048290351405739784,-0.99987053871154785,-0.015348996967077255,-0.99997663497924805,0.0049025332555174828,-0.0047542736865580082,2.8107287883758545,5.2359600067138672,-5.367772102355957"> </Bone> </Part> </Brick> <Brick refID="23" designID="32062" itemNos="4109810"> <Part refID="23" designID="32062" materials="26"> <Bone refID="23" transformation="-0.004828890785574913,-0.015325685031712055,0.99987083673477173,0.0048290356062352657,0.99987053871154785,0.015349006280303001,-0.99997663497924805,0.0049025337211787701,-0.0047542727552354336,3.2126798629760742,3.2710380554199219,-7.7962179183959961"> </Bone> </Part> </Brick> <Brick refID="24" designID="6632" itemNos="663226"> <Part refID="24" designID="6632" materials="26"> <Bone refID="24" transformation="0.0048290351405739784,0.99987053871154785,0.015349005348980427,0.0048288903199136257,0.01532568596303463,-0.99987083673477173,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,4.4049258232116699,1.6653616428375244,-7.8150725364685059"> </Bone> </Part> </Brick> <Brick refID="25" designID="41678" itemNos="4162857"> <Part refID="25" designID="41678" materials="26"> <Bone refID="25" transformation="-0.99997663497924805,0.0049025332555174828,-0.0047542722895741463,0.0048290346749126911,0.99987053871154785,0.015349007211625576,0.0048288903199136257,0.015325690619647503,-0.99987083673477173,4.4068603515625,2.4591279029846191,-7.4028372764587402"> </Bone> </Part> </Brick> <Brick refID="26" designID="41677" itemNos="4164133"> <Part refID="26" designID="41677" materials="26"> <Bone refID="26" transformation="-0.0048290351405739784,-0.99987053871154785,-0.015349005348980427,-0.0048288903199136257,-0.01532568596303463,0.99987083673477173,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,2.8126621246337891,4.0606374740600586,-6.9859862327575684"> </Bone> </Part> </Brick> <Brick refID="27" designID="32123" itemNos="4270046"> <Part refID="27" designID="32123" materials="26"> <Bone refID="27" transformation="-0.0047045559622347355,1.1391475709388033E-005,0.99998891353607178,0.0048507633619010448,0.99998825788497925,1.1423368960095104E-005,-0.99997711181640625,0.0048507689498364925,-0.0047045731917023659,2.4126715660095215,4.0626192092895508,-6.9879050254821777"> </Bone> </Part> </Brick> <Brick refID="28" designID="32249" itemNos="4140328"> <Part refID="28" designID="32249" materials="26"> <Bone refID="28" transformation="0.0047967568971216679,0.99987071752548218,0.015348996967077255,0.0047967517748475075,0.015325991436839104,-0.99987107515335083,-0.99997693300247192,0.0048697702586650848,-0.0047226338647305965,1.9972516298294067,2.4401829242706299,-5.4145221710205078"> </Bone> </Part> </Brick> <Brick refID="29" designID="6632" itemNos="663226"> <Part refID="29" designID="6632" materials="26"> <Bone refID="29" transformation="0.0048290351405739784,0.99987053871154785,0.015349005348980427,0.0048288903199136257,0.01532568596303463,-0.99987083673477173,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,3.2049548625946045,1.6712461709976196,-7.8208103179931641"> </Bone> </Part> </Brick> <Brick refID="30" designID="32062" itemNos="4109810"> <Part refID="30" designID="32062" materials="26"> <Bone refID="30" transformation="-0.0048288903199136257,-0.01532568596303463,0.99987083673477173,0.0048290351405739784,0.99987053871154785,0.015349005348980427,-0.99997663497924805,0.0049025337211787701,-0.0047542732208967209,3.2049548625946045,1.6712461709976196,-7.8208103179931641"> </Bone> </Part> </Brick> <Brick refID="31" designID="32249" itemNos="4140328"> <Part refID="31" designID="32249" materials="26"> <Bone refID="31" transformation="0.0047907303087413311,0.99987071752548218,0.015348877757787704,0.0048028663732111454,0.015325876884162426,-0.99987095594406128,-0.99997693300247192,0.0048638368025422096,-0.0047288401983678341,1.5973402261734009,2.4422059059143066,-5.4164538383483887"> </Bone> </Part> </Brick> <Brick refID="32" designID="32291" itemNos="4140430"> <Part refID="32" designID="32291" materials="26"> <Bone refID="32" transformation="0.99997663497924805,-0.0049025337211787701,0.0047542732208967209,0.0048290351405739784,0.99987053871154785,0.015349005348980427,-0.0048288903199136257,-0.01532568596303463,0.99987083673477173,3.5991504192352295,0.86325746774673462,-7.431239128112793"> </Bone> </Part> </Brick> <Brick refID="33" designID="32062" itemNos="4109810"> <Part refID="33" designID="32062" materials="26"> <Bone refID="33" transformation="-0.0048288879916071892,-0.01532568596303463,0.99987083673477173,-0.99997663497924805,0.0049025327898561954,-0.0047542680986225605,-0.0048290356062352657,-0.99987053871154785,-0.015348991379141808,4.7990961074829102,4.4017362594604492,-3.7707421779632568"> </Bone> </Part> </Brick> <Brick refID="34" designID="41677" itemNos="4164133"> <Part refID="34" designID="41677" materials="26"> <Bone refID="34" transformation="-0.0048288875259459019,-0.01532568596303463,0.99987077713012695,-0.99997657537460327,0.0049025327898561954,-0.0047542667016386986,-0.0048290351405739784,-0.99987047910690308,-0.015348987653851509,4.801027774810791,4.8016843795776367,-3.7646005153656006"> </Bone> </Part> </Brick> <Brick refID="35" designID="41678" itemNos="4162857"> <Part refID="35" designID="41678" materials="26"> <Bone refID="35" transformation="0.0048290351405739784,0.99987047910690308,0.015348989516496658,-0.0048288875259459019,-0.015325685031712055,0.99987077713012695,0.99997657537460327,-0.0049025323241949081,0.0047542671672999859,5.2048821449279785,4.8119850158691406,-4.5625972747802734"> </Bone> </Part> </Brick> <Brick refID="36" designID="43093" itemNos="4168884"> <Part refID="36" designID="43093" materials="26"> <Bone refID="36" transformation="-0.0048288893885910511,-0.015325686894357204,0.99987095594406128,0.9999767541885376,-0.0049025332555174828,0.0047542680986225605,0.0048290370032191277,0.9998706579208374,0.01534898579120636,4.8010272979736328,5.5893216133117676,-2.9524257183074951"> </Bone> </Part> </Brick> <Brick refID="37" designID="32123" itemNos="4270046"> <Part refID="37" designID="32123" materials="26"> <Bone refID="37" transformation="-0.0048288889229297638,-0.015325699932873249,0.99987095594406128,0.9999767541885376,-0.004902535118162632,0.0047542722895741463,0.0048290351405739784,0.9998706579208374,0.015348994173109531,4.8010268211364746,5.5893206596374512,-2.9524266719818115"> </Bone> </Part> </Brick> <Brick refID="38" designID="6632" itemNos="663226"> <Part refID="38" designID="6632" materials="26"> <Bone refID="38" transformation="-0.9999767541885376,0.0049025337211787701,-0.0047542685642838478,0.0048288889229297638,0.015325687825679779,-0.99987095594406128,-0.0048290365375578403,-0.9998706579208374,-0.015348992310464382,4.8029594421386719,5.2016329765319824,-3.7584621906280518"> </Bone> </Part> </Brick> <Brick refID="39" designID="32062" itemNos="4109810"> <Part refID="39" designID="32062" materials="26"> <Bone refID="39" transformation="-0.0048288889229297638,-0.015325687825679779,0.99987095594406128,-0.9999767541885376,0.0049025337211787701,-0.0047542685642838478,-0.0048290365375578403,-0.9998706579208374,-0.015348992310464382,3.1991333961486816,4.4095802307128906,-3.7783482074737549"> </Bone> </Part> </Brick> <Brick refID="40" designID="41677" itemNos="4164133"> <Part refID="40" designID="41677" materials="26"> <Bone refID="40" transformation="-0.0048288898542523384,-0.015325684100389481,0.99987095594406128,-0.9999767541885376,0.0049025341868400574,-0.0047542699612677097,-0.0048290346749126911,-0.9998706579208374,-0.01534899789839983,3.2010624408721924,4.8095297813415527,-3.7722084522247314"> </Bone> </Part> </Brick> <Brick refID="41" designID="41678" itemNos="4162857"> <Part refID="41" designID="41678" materials="26"> <Bone refID="41" transformation="0.004829036071896553,0.9998706579208374,0.015348986722528934,-0.0048288875259459019,-0.015325687825679779,0.99987095594406128,0.9999767541885376,-0.0049025323241949081,0.0047542667016386986,3.6049184799194336,4.819828987121582,-4.5702042579650879"> </Bone> </Part> </Brick> <Brick refID="42" designID="43093" itemNos="4168884"> <Part refID="42" designID="43093" materials="26"> <Bone refID="42" transformation="-0.0048288903199136257,-0.015325682237744331,0.99987095594406128,0.9999767541885376,-0.0049025337211787701,0.0047542690299451351,0.0048290351405739784,0.9998706579208374,0.015348991379141808,3.2010624408721924,5.5971651077270508,-2.9600324630737305"> </Bone> </Part> </Brick> <Brick refID="43" designID="32123" itemNos="4270046"> <Part refID="43" designID="32123" materials="26"> <Bone refID="43" transformation="-0.0048288889229297638,-0.015325699932873249,0.99987095594406128,0.9999767541885376,-0.0049025337211787701,0.0047542680986225605,0.0048290365375578403,0.9998706579208374,0.015348989516496658,3.2010633945465088,5.5971651077270508,-2.960033655166626"> </Bone> </Part> </Brick> <Brick refID="44" designID="61069" itemNos="4529162"> <Part refID="44" designID="61069" materials="1"> <Bone refID="44" transformation="0.99997663497924805,-0.0049025346525013447,0.0047542722895741463,0.0048288875259459019,0.015325692482292652,-0.99987083673477173,0.0048290332779288292,0.99987053871154785,0.015349001623690128,3.1972012519836426,4.7972679138183594,-2.9723122119903564"> </Bone> </Part> </Brick> <Brick refID="45" designID="32140" itemNos="4120017"> <Part refID="45" designID="32140" materials="26"> <Bone refID="45" transformation="-0.0048288884572684765,-0.015325689688324928,0.99987083673477173,0.99997663497924805,-0.0049025341868400574,0.004754271823912859,0.0048290346749126911,0.99987053871154785,0.015348996035754681,4.3952703475952148,2.8161649703979492,-4.5970973968505859"> </Bone> </Part> </Brick> <Brick refID="46" designID="4519" itemNos="451926"> <Part refID="46" designID="4519" materials="26"> <Bone refID="46" transformation="0.99997657537460327,-0.0049025337211787701,0.0047542708925902843,0.0048288884572684765,0.015325690619647503,-0.99987077713012695,0.0048290356062352657,0.99987047910690308,0.015348999761044979,4.3952703475952148,2.8161652088165283,-4.5970983505249023"> </Bone> </Part> </Brick> <Brick refID="47" designID="6553" itemNos="4107765"> <Part refID="47" designID="6553" materials="26"> <Bone refID="47" transformation="-0.0048290356062352657,-0.99987047910690308,-0.015348999761044979,-0.99997657537460327,0.0049025337211787701,-0.0047542708925902843,0.0048288884572684765,0.015325690619647503,-0.99987077713012695,4.3952703475952148,0.84707623720169067,-6.6275382041931152"> </Bone> </Part> </Brick> <Brick refID="48" designID="59443" itemNos="4512363"> <Part refID="48" designID="59443" materials="26"> <Bone refID="48" transformation="0.99997657537460327,-0.0049025337211787701,0.0047542708925902843,0.0048290356062352657,0.99987047910690308,0.015348999761044979,-0.0048288884572684765,-0.015325690619647503,0.99987077713012695,4.3914074897766113,0.83481472730636597,-5.827641487121582"> </Bone> </Part> </Brick> <Brick refID="49" designID="43093" itemNos="4168884"> <Part refID="49" designID="43093" materials="26"> <Bone refID="49" transformation="0.99997657537460327,-0.0049025337211787701,0.0047542708925902843,0.0048290356062352657,0.99987047910690308,0.015348999761044979,-0.0048288884572684765,-0.015325690619647503,0.99987077713012695,4.3952703475952148,0.84707432985305786,-6.627537727355957"> </Bone> </Part> </Brick> <Brick refID="50" designID="32054" itemNos="4107742"> <Part refID="50" designID="32054" materials="26"> <Bone refID="50" transformation="0.99997663497924805,-0.0049025346525013447,0.0047542667016386986,0.0048290351405739784,0.99987053871154785,0.015349005348980427,-0.0048288921825587749,-0.015325679443776608,0.99987083673477173,5.1875267028808594,2.3939030170440674,-3.3995475769042969"> </Bone> </Part> </Brick> <Brick refID="51" designID="3705" itemNos="370526"> <Part refID="51" designID="3705" materials="26"> <Bone refID="51" transformation="0.99997657537460327,-0.0049025327898561954,0.004754265770316124,0.0048290337435901165,0.99987047910690308,0.015348996035754681,-0.0048288912512362003,-0.015325671993196011,0.99987077713012695,5.1952528953552246,2.4184238910675049,-4.9993433952331543"> </Bone> </Part> </Brick> <Brick refID="52" designID="32039" itemNos="4107081"> <Part refID="52" designID="32039" materials="26"> <Bone refID="52" transformation="-0.0048288917168974876,-0.015325685031712055,0.99987077713012695,-0.99997657537460327,0.0049025341868400574,-0.004754265770316124,-0.0048290342092514038,-0.99987047910690308,-0.01534899789839983,5.1991157531738281,1.249229907989502,-7.0175032615661621"> </Bone> </Part> </Brick> <Brick refID="53" designID="32449" itemNos="4142236"> <Part refID="53" designID="32449" materials="26"> <Bone refID="53" transformation="0.99997657537460327,-0.0049025323241949081,0.0047542653046548367,0.0048290342092514038,0.99987047910690308,0.015348988585174084,-0.0048288912512362003,-0.015325671993196011,0.99987077713012695,2.799170970916748,2.4424505233764648,-5.8106503486633301"> </Bone> </Part> </Brick> <Brick refID="54" designID="41669" itemNos="4177441"> <Part refID="54" designID="41669" materials="26"> <Bone refID="54" transformation="-0.0048290342092514038,-0.99987047910690308,-0.015348998829722404,0.0048288921825587749,0.015325689688324928,-0.99987077713012695,0.99997657537460327,-0.0049025332555174828,0.0047542653046548367,5.2068419456481934,2.4552056789398193,-7.3990345001220703"> </Bone> </Part> </Brick> <Brick refID="55" designID="32449" itemNos="4142236"> <Part refID="55" designID="32449" materials="26"> <Bone refID="55" transformation="0.99997657537460327,-0.0049025327898561954,0.004754265770316124,0.0048290337435901165,0.99987047910690308,0.015348996035754681,-0.0048288912512362003,-0.015325671993196011,0.99987077713012695,2.8011033535003662,2.4485812187194824,-6.2105979919433594"> </Bone> </Part> </Brick> <Brick refID="56" designID="43093" itemNos="4168884"> <Part refID="56" designID="43093" materials="26"> <Bone refID="56" transformation="0.0048288921825587749,0.015325689688324928,-0.99987077713012695,-0.99997657537460327,0.0049025332555174828,-0.0047542653046548367,0.0048290342092514038,0.99987047910690308,0.015348998829722404,5.2029786109924316,2.0491268634796143,-7.0052237510681152"> </Bone> </Part> </Brick> <Brick refID="57" designID="3705" itemNos="370526"> <Part refID="57" designID="3705" materials="26"> <Bone refID="57" transformation="0.99997657537460327,-0.0049025323241949081,0.0047542653046548367,0.0048290342092514038,0.99987047910690308,0.015348988585174084,-0.0048288912512362003,-0.015325671993196011,0.99987077713012695,2.79530930519104,2.4301900863647461,-5.0107536315917969"> </Bone> </Part> </Brick> <Brick refID="58" designID="32054" itemNos="4107742"> <Part refID="58" designID="32054" materials="26"> <Bone refID="58" transformation="0.99997657537460327,-0.0049025323241949081,0.0047542653046548367,0.0048290342092514038,0.99987047910690308,0.015348988585174084,-0.0048288912512362003,-0.015325671993196011,0.99987077713012695,2.7875819206237793,2.4056687355041504,-3.4109585285186768"> </Bone> </Part> </Brick> <Brick refID="59" designID="32039" itemNos="4107081"> <Part refID="59" designID="32039" materials="26"> <Bone refID="59" transformation="-0.0048288912512362003,-0.015325685031712055,0.99987077713012695,-0.99997657537460327,0.0049025346525013447,-0.0047542694956064224,-0.0048290342092514038,-0.99987047910690308,-0.015348996967077255,2.7991707324981689,1.2609957456588745,-7.0289130210876465"> </Bone> </Part> </Brick> <Brick refID="60" designID="41669" itemNos="4177441"> <Part refID="60" designID="41669" materials="26"> <Bone refID="60" transformation="-0.0048290328122675419,-0.99987047910690308,-0.015348995104432106,0.004828890785574913,0.015325690619647503,-0.99987077713012695,0.99997657537460327,-0.0049025341868400574,0.0047542690299451351,2.8068983554840088,2.4669721126556396,-7.4104447364807129"> </Bone> </Part> </Brick> <Brick refID="61" designID="43093" itemNos="4168884"> <Part refID="61" designID="43093" materials="26"> <Bone refID="61" transformation="0.0048288903199136257,0.015325691550970078,-0.99987077713012695,-0.99997657537460327,0.0049025341868400574,-0.004754270426928997,0.0048290328122675419,0.99987047910690308,0.015348994173109531,2.8030354976654053,2.0608928203582764,-7.016634464263916"> </Bone> </Part> </Brick> <Brick refID="62" designID="6536" itemNos="653626"> <Part refID="62" designID="6536" materials="26"> <Bone refID="62" transformation="0.0048290351405739784,0.99987047910690308,0.015348989516496658,-0.0048288884572684765,-0.015325681306421757,0.99987077713012695,0.99997657537460327,-0.0049025332555174828,0.0047542713582515717,5.5855860710144043,1.5981767177581787,-3.8099157810211182"> </Bone> </Part> </Brick> <Brick refID="63" designID="3705" itemNos="370526"> <Part refID="63" designID="3705" materials="26"> <Bone refID="63" transformation="-0.0048288879916071892,-0.015325686894357204,0.99987071752548218,0.0048290337435901165,0.9998704195022583,0.015349002555012703,-0.9999765157699585,0.0049025327898561954,-0.0047542671672999859,2.3856604099273682,1.613864541053772,-3.8251285552978516"> </Bone> </Part> </Brick> <Brick refID="64" designID="32291" itemNos="4140430"> <Part refID="64" designID="32291" materials="26"> <Bone refID="64" transformation="0.9999765157699585,-0.0049025327898561954,0.0047542671672999859,-0.0048288879916071892,-0.015325686894357204,0.99987071752548218,-0.0048290337435901165,-0.9998704195022583,-0.015349002555012703,3.5875639915466309,1.2202938795089722,-4.625460147857666"> </Bone> </Part> </Brick> <Brick refID="65" designID="41678" itemNos="4162857"> <Part refID="65" designID="41678" materials="26"> <Bone refID="65" transformation="0.9999765157699585,-0.0049025327898561954,0.0047542667016386986,0.0048290337435901165,0.9998704195022583,0.015349004417657852,-0.0048288884572684765,-0.015325691550970078,0.99987071752548218,3.5798368453979492,0.80195516347885132,-3.4317545890808105"> </Bone> </Part> </Brick> <Brick refID="66" designID="6536" itemNos="653626"> <Part refID="66" designID="6536" materials="26"> <Bone refID="66" transformation="0.0048290346749126911,0.9998704195022583,0.015348988585174084,-0.0048288884572684765,-0.015325680375099182,0.99987071752548218,0.9999765157699585,-0.0049025323241949081,0.0047542667016386986,3.1856434345245361,1.6099427938461304,-3.8213260173797607"> </Bone> </Part> </Brick> <Brick refID="67" designID="32140" itemNos="4120017"> <Part refID="67" designID="32140" materials="26"> <Bone refID="67" transformation="-0.0048288884572684765,-0.015325691550970078,0.99987083673477173,-0.99997663497924805,0.0049025341868400574,-0.004754271823912859,-0.0048290342092514038,-0.99987053871154785,-0.015349000692367554,3.5914261341094971,2.0201945304870605,-4.6131806373596191"> </Bone> </Part> </Brick> <Brick refID="68" designID="4519" itemNos="451926"> <Part refID="68" designID="4519" materials="26"> <Bone refID="68" transformation="0.99997657537460327,-0.0049025337211787701,0.0047542713582515717,0.0048288889229297638,0.015325693413615227,-0.99987077713012695,0.0048290356062352657,0.99987047910690308,0.015349004417657852,3.5952889919281006,2.8200876712799072,-4.6009016036987305"> </Bone> </Part> </Brick> <Brick refID="69" designID="6553" itemNos="4107765"> <Part refID="69" designID="6553" materials="26"> <Bone refID="69" transformation="-0.0048290356062352657,-0.99987047910690308,-0.015349004417657852,-0.99997657537460327,0.0049025337211787701,-0.0047542713582515717,0.0048288889229297638,0.015325693413615227,-0.99987077713012695,3.5952889919281006,0.85099709033966064,-6.6313443183898926"> </Bone> </Part> </Brick> <Brick refID="70" designID="59443" itemNos="4512363"> <Part refID="70" designID="59443" materials="26"> <Bone refID="70" transformation="0.99997657537460327,-0.0049025337211787701,0.0047542713582515717,0.0048290356062352657,0.99987047910690308,0.015349004417657852,-0.0048288889229297638,-0.015325693413615227,0.99987077713012695,3.591425895690918,0.83873665332794189,-5.8314471244812012"> </Bone> </Part> </Brick> <Brick refID="71" designID="43093" itemNos="4168884"> <Part refID="71" designID="43093" materials="26"> <Bone refID="71" transformation="0.99997657537460327,-0.0049025341868400574,0.0047542713582515717,0.0048290346749126911,0.99987047910690308,0.015349006280303001,-0.0048288884572684765,-0.015325693413615227,0.99987077713012695,3.5952889919281006,0.85099804401397705,-6.6313443183898926"> </Bone> </Part> </Brick> <Brick refID="72" designID="2780" itemNos="278026"> <Part refID="72" designID="2780" materials="26"> <Bone refID="72" transformation="0.99997669458389282,-0.0049025099724531174,0.0047542997635900974,0.0048289145343005657,0.015325658954679966,-0.9998708963394165,0.0048290085978806019,0.99987059831619263,0.015348968096077442,4.3952698707580566,3.6038010120391846,-3.7849240303039551"> </Bone> </Part> </Brick> <Brick refID="73" designID="6558" itemNos="655826"> <Part refID="73" designID="6558" materials="26"> <Bone refID="73" transformation="-0.0047288616187870502,1.1508171155583113E-005,0.99998879432678223,0.0048763430677354336,0.99998819828033447,1.1542603715497535E-005,-0.99997693300247192,0.0048763495869934559,-0.0047288802452385426,4.0087728500366211,4.0424938201904297,-6.1803827285766602"> </Bone> </Part> </Brick> <Brick refID="74" designID="50746" itemNos="4263949"> <Part refID="74" designID="50746" materials="26"> <Bone refID="74" transformation="0.99997669458389282,-0.0049025677144527435,0.004754235502332449,0.00482906773686409,0.99987059831619263,0.015348934568464756,-0.0048288512043654919,-0.01532562542706728,0.9998708963394165,3.9971816539764404,4.7933454513549805,-2.968508243560791"> </Bone> </Part> </Brick> <Brick refID="75" designID="4274" itemNos="4211483"> <Part refID="75" designID="4274" materials="194"> <Bone refID="75" transformation="0.99997663497924805,-0.0049025672487914562,0.0047542350366711617,-0.0048288502730429173,-0.015325628221035004,0.99987083673477173,-0.00482906773686409,-0.99987053871154785,-0.015348923392593861,3.9933183193206787,3.9934508800506592,-2.9807875156402588"> </Bone> </Part> </Brick> <Brick refID="76" designID="2780" itemNos="278026"> <Part refID="76" designID="2780" materials="26"> <Bone refID="76" transformation="-0.0047288248315453529,1.1508433999551926E-005,0.99998879432678223,0.004876249935477972,0.99998819828033447,1.1541720596142113E-005,-0.99997693300247192,0.0048762564547359943,-0.0047288434579968452,4.8010263442993164,3.2263855934143066,-5.3889636993408203"> </Bone> </Part> </Brick> <Brick refID="77" designID="2780" itemNos="278026"> <Part refID="77" designID="2780" materials="26"> <Bone refID="77" transformation="0.99997669458389282,-0.0049036024138331413,0.0047541060484945774,0.0048301056958734989,0.99987059831619263,0.015348619781434536,-0.0048287361860275269,-0.015325306914746761,0.9998708963394165,5.995234489440918,3.9897758960723877,-3.3712294101715088"> </Bone> </Part> </Brick> <Brick refID="78" designID="44352" itemNos="4183398"> <Part refID="78" designID="44352" materials="1"> <Bone refID="78" transformation="0.0048298225738108158,0.99987059831619263,0.015348724089562893,-0.0048285713419318199,-0.015325413085520267,0.9998708963394165,0.99997669458389282,-0.004903317429125309,0.0047539449296891689,6.0068240165710449,4.8141922950744629,-4.9587440490722656"> </Bone> </Part> </Brick> <Brick refID="79" designID="2780" itemNos="278026"> <Part refID="79" designID="2780" materials="26"> <Bone refID="79" transformation="0.99997669458389282,-0.0049027646891772747,0.0047539351508021355,0.0048292698338627815,0.99987059831619263,0.015348761342465878,-0.0048285531811416149,-0.015325453132390976,0.9998708963394165,5.9759163856506348,0.77792972326278687,-2.6204471588134766"> </Bone> </Part> </Brick> <Brick refID="80" designID="2780" itemNos="278026"> <Part refID="80" designID="2780" materials="26"> <Bone refID="80" transformation="0.99997669458389282,-0.0049036052078008652,0.0047539155930280685,0.0048301112838089466,0.99987059831619263,0.015348626300692558,-0.004828545730561018,-0.015325314365327358,0.9998708963394165,5.9990992546081543,4.7896718978881836,-3.3589503765106201"> </Bone> </Part> </Brick> <Brick refID="81" designID="60484" itemNos="4535772"> <Part refID="81" designID="60484" materials="194"> <Bone refID="81" transformation="-0.004830608144402504,-0.99987059831619263,-0.015348636545240879,-0.99997669458389282,0.0049041025340557098,-0.0047539430670440197,0.0048285806551575661,0.015325321815907955,-0.9998708963394165,6.0029616355895996,4.8019323348999023,-4.1588473320007324"> </Bone> </Part> </Brick> <Brick refID="82" designID="2780" itemNos="278026"> <Part refID="82" designID="2780" materials="26"> <Bone refID="82" transformation="0.99997669458389282,-0.0049042887985706329,0.0047539286315441132,0.0048307948745787144,0.99987059831619263,0.015348577871918678,-0.0048285690136253834,-0.01532526221126318,0.9998708963394165,4.3952417373657227,3.9976227283477783,-3.3788354396820068"> </Bone> </Part> </Brick> <Brick refID="83" designID="32054" itemNos="4193409"> <Part refID="83" designID="32054" materials="1"> <Bone refID="83" transformation="0.99997669458389282,-0.0049026040360331535,0.0047539700753986835,0.0048291082493960857,0.99987059831619263,0.015348916873335838,-0.0048285862430930138,-0.015325608663260937,0.9998708963394165,5.9797801971435547,1.5778259038925171,-2.6081705093383789"> </Bone> </Part> </Brick> <Brick refID="84" designID="42074" itemNos="4163132"> <Part refID="84" designID="42074" materials="1"> <Bone refID="84" transformation="-0.99997663497924805,0.0049026035703718662,-0.0047539696097373962,0.0048285862430930138,0.015325607731938362,-0.99987083673477173,-0.0048291082493960857,-0.99987053871154785,-0.015348907560110092,5.9875054359436035,1.6023467779159546,-4.2079648971557617"> </Bone> </Part> </Brick> <Brick refID="85" designID="32062" itemNos="4109810"> <Part refID="85" designID="32062" materials="26"> <Bone refID="85" transformation="-0.0048286453820765018,-0.01532556489109993,0.9998708963394165,0.0048287287354469299,0.99987059831619263,0.015348871238529682,-0.99997669458389282,0.0049022254534065723,-0.0047540352679789066,4.789466381072998,3.1896317005157471,-2.9892647266387939"> </Bone> </Part> </Brick> <Brick refID="86" designID="42003" itemNos="4211779"> <Part refID="86" designID="42003" materials="194"> <Bone refID="86" transformation="0.0048287296667695045,0.99987059831619263,0.015348871238529682,0.99997681379318237,-0.0049022259190678596,0.0047540352679789066,0.0048286458477377892,0.01532556489109993,-0.9998708963394165,5.9836444854736328,1.5900849103927612,-3.4080660343170166"> </Bone> </Part> </Brick> <Brick refID="87" designID="32013" itemNos="4118981"> <Part refID="87" designID="32013" materials="1"> <Bone refID="87" transformation="-0.99997681379318237,0.0049022254534065723,-0.0047540352679789066,0.0048287287354469299,0.99987059831619263,0.015348882414400578,0.0048286453820765018,0.015325571410357952,-0.9998708963394165,5.5894479751586914,3.1857101917266846,-2.9854614734649658"> </Bone> </Part> </Brick> <Brick refID="88" designID="2780" itemNos="278026"> <Part refID="88" designID="2780" materials="26"> <Bone refID="88" transformation="0.99997669458389282,-0.0049023386090993881,0.0047541819512844086,0.0048287943936884403,0.015325690619647503,-0.9998708963394165,0.0048288390971720219,0.99987059831619263,0.01534899789839983,4.3914070129394531,3.5915405750274658,-2.9850256443023682"> </Bone> </Part> </Brick> <Brick refID="89" designID="2780" itemNos="278026"> <Part refID="89" designID="2780" materials="26"> <Bone refID="89" transformation="0.99997669458389282,-0.0049021863378584385,0.0047535807825624943,0.0048286975361406803,0.99987059831619263,0.015348670072853565,-0.0048281894996762276,-0.015325366519391537,0.9998708963394165,3.5952610969543457,4.0015468597412109,-3.3826379776000977"> </Bone> </Part> </Brick> <Brick refID="90" designID="6562" itemNos="4191056"> <Part refID="90" designID="6562" materials="1"> <Bone refID="90" transformation="-0.96715354919433594,0.00076888891635462642,0.25419169664382935,0.0048290742561221123,0.99987059831619263,0.015349320136010647,-0.25414705276489258,0.016072669997811317,-0.96703213453292847,5.287257194519043,3.1689808368682861,-1.8006534576416016"> </Bone> </Part> </Brick> <Brick refID="91" designID="32013" itemNos="4118981"> <Part refID="91" designID="32013" materials="1"> <Bone refID="91" transformation="-0.25415021181106567,0.016072669997811317,-0.96703112125396729,0.0048290831036865711,0.99987053871154785,0.01534933689981699,0.96715265512466431,-0.00076883262954652309,-0.2541949450969696,5.4905743598937988,3.1561229228973389,-1.0270285606384277"> </Bone> </Part> </Brick> <Brick refID="92" designID="3070" itemNos="307001"> <Part refID="92" designID="3070" materials="1,0" decoration="0"> <Bone refID="92" transformation="0.96715366840362549,-0.00076990161323919892,-0.25419163703918457,0.0048300959169864655,0.99987059831619263,0.015349230729043484,0.25414693355560303,-0.016072841361165047,0.96703207492828369,5.5940685272216797,3.5296452045440674,-0.6343841552734375"> </Bone> </Part> </Brick> <Brick refID="93" designID="6541" itemNos="654101"> <Part refID="93" designID="6541" materials="1"> <Bone refID="93" transformation="0.96715348958969116,-0.00076989736407995224,-0.25419160723686218,0.0048300949856638908,0.99987053871154785,0.015349226072430611,0.25414693355560303,-0.016072843223810196,0.96703201532363892,5.5894317626953125,2.5697696208953857,-0.649120032787323"> </Bone> </Part> </Brick> <Brick refID="94" designID="44301" itemNos="4183035"> <Part refID="94" designID="44301" materials="1"> <Bone refID="94" transformation="-0.25414693355560303,0.016072843223810196,-0.96703201532363892,0.0048300963826477528,0.99987053871154785,0.015349227003753185,0.96715342998504639,-0.00076989695662632585,-0.25419184565544128,5.5878849029541016,2.2498109340667725,-0.65403145551681519"> </Bone> </Part> </Brick> <Brick refID="95" designID="3023" itemNos="302301"> <Part refID="95" designID="3023" materials="1"> <Bone refID="95" transformation="0.25414690375328064,-0.016072839498519897,0.96703201532363892,0.0048300949856638908,0.99987053871154785,0.015349226072430611,-0.96715348958969116,0.00076989876106381416,0.25419160723686218,5.3830218315124512,1.9427103996276855,-1.432569146156311"> </Bone> </Part> </Brick> <Brick refID="96" designID="6541" itemNos="654101"> <Part refID="96" designID="6541" materials="1"> <Bone refID="96" transformation="0.96715348958969116,-0.00076989736407995224,-0.25419160723686218,0.0048300949856638908,0.99987053871154785,0.015349226072430611,0.25414693355560303,-0.016072843223810196,0.96703201532363892,5.5817050933837891,0.96997720003128052,-0.67367708683013916"> </Bone> </Part> </Brick> <Brick refID="97" designID="50950" itemNos="4247771"> <Part refID="97" designID="50950" materials="24"> <Bone refID="97" transformation="0.21768979728221893,-0.51380842924118042,0.8298264741897583,0.13124468922615051,0.85790461301803589,0.49676418304443359,-0.96715354919433594,0.00076983083272352815,0.25419166684150696,6.150153636932373,1.7245956659317017,1.4868918657302856"> </Bone> </Part> </Brick> <Brick refID="98" designID="3069" itemNos="306924"> <Part refID="98" designID="3069" materials="24,0" decoration="0"> <Bone refID="98" transformation="0.2176896333694458,-0.51380842924118042,0.82982665300369263,0.13124457001686096,0.85790467262268066,0.49676397442817688,-0.96715366840362549,0.00076980120502412319,0.25419157743453979,5.8438014984130859,2.8213341236114502,0.31794771552085876"> </Bone> </Part> </Brick> <Brick refID="99" designID="3024" itemNos="302424"> <Part refID="99" designID="3024" materials="24"> <Bone refID="99" transformation="0.96715366840362549,-0.00076977303251624107,-0.25419160723686218,0.13124457001686096,0.85790455341339111,0.49676403403282166,0.21768964827060699,-0.5138084888458252,0.82982677221298218,5.9760026931762695,2.1356427669525146,0.82303035259246826"> </Bone> </Part> </Brick> <Brick refID="100" designID="44302" itemNos="4183981"> <Part refID="100" designID="44302" materials="24"> <Bone refID="100" transformation="0.21768967807292938,-0.5138084888458252,0.82982659339904785,0.13124458491802216,0.85790473222732544,0.49676406383514404,-0.96715366840362549,0.00076975114643573761,0.25419160723686218,5.9340047836303711,1.8611123561859131,0.66406619548797607"> </Bone> </Part> </Brick> <Brick refID="101" designID="4287" itemNos="428724"> <Part refID="101" designID="4287" materials="24"> <Bone refID="101" transformation="0.96715366840362549,-0.00076977268327027559,-0.25419160723686218,0.13124458491802216,0.85790473222732544,0.49676406383514404,0.21768967807292938,-0.5138084888458252,0.82982659339904785,5.8080096244812012,1.0375226736068726,0.18717125058174133"> </Bone> </Part> </Brick> <Brick refID="102" designID="6558" itemNos="655826"> <Part refID="102" designID="6558" materials="26"> <Bone refID="102" transformation="-0.0048288637772202492,-0.015325718559324741,0.9998708963394165,0.99997669458389282,-0.0049025225453078747,0.0047542480751872063,0.0048290216363966465,0.99987059831619263,0.015349027700722218,5.1875252723693848,3.5753581523895264,-2.181326150894165"> </Bone> </Part> </Brick> <Brick refID="103" designID="6562" itemNos="4191056"> <Part refID="103" designID="6562" materials="1"> <Bone refID="103" transformation="-0.96715366840362549,0.00076903699664399028,0.25419163703918457,0.0048292018473148346,0.99987059831619263,0.015349230729043484,-0.25414693355560303,0.016072614118456841,-0.96703207492828369,5.2795305252075195,1.5691882371902466,-1.8252125978469849"> </Bone> </Part> </Brick> <Brick refID="104" designID="32013" itemNos="4107085"> <Part refID="104" designID="32013" materials="26"> <Bone refID="104" transformation="-0.25415033102035522,0.016072608530521393,-0.96703112125396729,0.004829206969588995,0.99987053871154785,0.015349239110946655,0.96715271472930908,-0.0007689796038903296,-0.25419485569000244,5.4828476905822754,1.5563302040100098,-1.0515861511230469"> </Bone> </Part> </Brick> <Brick refID="105" designID="3070" itemNos="307001"> <Part refID="105" designID="3070" materials="1,0" decoration="0"> <Bone refID="105" transformation="0.99671286344528198,-0.0035728011280298233,-0.080937527120113373,0.004830564372241497,0.99987059831619263,0.015349510125815868,0.080872222781181335,-0.015690034255385399,0.99660104513168335,4.5168557167053223,3.5341789722442627,-0.59087592363357544"> </Bone> </Part> </Brick> <Brick refID="106" designID="6541" itemNos="654101"> <Part refID="106" designID="6541" materials="1"> <Bone refID="106" transformation="0.99671286344528198,-0.0035728015936911106,-0.080937542021274567,0.004830564372241497,0.99987059831619263,0.015349519439041615,0.080872200429439545,-0.015690034255385399,0.99660104513168335,4.5122194290161133,2.5743041038513184,-0.60561156272888184"> </Bone> </Part> </Brick> <Brick refID="107" designID="44301" itemNos="4183035"> <Part refID="107" designID="44301" materials="1"> <Bone refID="107" transformation="-0.080872207880020142,0.015690036118030548,-0.99660104513168335,0.0048305634409189224,0.99987059831619263,0.015349510125815868,0.99671286344528198,-0.0035728011280298233,-0.080937549471855164,4.5106730461120605,2.254345178604126,-0.61052298545837402"> </Bone> </Part> </Brick> <Brick refID="108" designID="3023" itemNos="302301"> <Part refID="108" designID="3023" materials="1"> <Bone refID="108" transformation="0.080872148275375366,-0.015690034255385399,0.99660104513168335,0.004830564372241497,0.99987059831619263,0.015349519439041615,-0.99671286344528198,0.0035728046204894781,0.080937452614307404,4.4444293975830078,1.9469383955001831,-1.4127156734466553"> </Bone> </Part> </Brick> <Brick refID="109" designID="6541" itemNos="654101"> <Part refID="109" designID="6541" materials="1"> <Bone refID="109" transformation="0.99671286344528198,-0.0035728015936911106,-0.080937549471855164,0.004830564372241497,0.99987059831619263,0.015349519439041615,0.080872207880020142,-0.015690034255385399,0.99660104513168335,4.5044927597045898,0.97451096773147583,-0.63016867637634277"> </Bone> </Part> </Brick> <Brick refID="110" designID="6562" itemNos="4191056"> <Part refID="110" designID="6562" materials="1"> <Bone refID="110" transformation="-0.99671286344528198,0.003571315435692668,0.080937549471855164,0.0048290700651705265,0.99987059831619263,0.015349461697041988,-0.080872267484664917,0.015689864754676819,-0.99660104513168335,4.4179744720458984,3.1730556488037109,-1.7926276922225952"> </Bone> </Part> </Brick> <Brick refID="111" designID="32013" itemNos="4118981"> <Part refID="111" designID="32013" materials="1"> <Bone refID="111" transformation="-0.080880388617515564,0.01568988524377346,-0.99660027027130127,0.0048290719278156757,0.99987047910690308,0.015349457040429115,0.99671220779418945,-0.0035711878444999456,-0.080945558845996857,4.4826688766479492,3.1605041027069092,-0.99534916877746582"> </Bone> </Part> </Brick> <Brick refID="112" designID="6558" itemNos="655826"> <Part refID="112" designID="6558" materials="26"> <Bone refID="112" transformation="-0.0054832049645483494,-0.015322507359087467,0.99986755847930908,0.99997329711914063,-0.0049125622026622295,0.0054085203446447849,0.0048290342092514038,0.99987059831619263,0.015349027700722218,4.3875441551208496,3.5792796611785889,-2.1851296424865723"> </Bone> </Part> </Brick> <Brick refID="113" designID="50950" itemNos="4247771"> <Part refID="113" designID="50950" materials="24"> <Bone refID="113" transformation="0.067624621093273163,-0.51347589492797852,0.85543531179428101,0.044615693390369415,0.8580966591835022,0.51154637336730957,-0.99671286344528198,0.0035727156791836023,0.080937512218952179,4.6879806518554687,1.7299829721450806,1.5960904359817505"> </Bone> </Part> </Brick> <Brick refID="114" designID="3069" itemNos="306924"> <Part refID="114" designID="3069" materials="24,0" decoration="0"> <Bone refID="114" transformation="0.067624598741531372,-0.51347625255584717,0.85543513298034668,0.044615708291530609,0.85809671878814697,0.51154631376266479,-0.99671286344528198,0.0035727045033127069,0.080937519669532776,4.5940423011779785,2.8262515068054199,0.39089706540107727"> </Bone> </Part> </Brick> <Brick refID="115" designID="3024" itemNos="302424"> <Part refID="115" designID="3024" materials="24"> <Bone refID="115" transformation="0.99671298265457153,-0.0035727089270949364,-0.08093755692243576,0.044615700840950012,0.85809677839279175,0.51154619455337524,0.067624658346176147,-0.51347649097442627,0.85543513298034668,4.6338796615600586,2.1407637596130371,0.91174250841140747"> </Bone> </Part> </Brick> <Brick refID="116" designID="44302" itemNos="4183981"> <Part refID="116" designID="44302" materials="24"> <Bone refID="116" transformation="0.067624643445014954,-0.51347631216049194,0.85543525218963623,0.044615689665079117,0.85809677839279175,0.51154619455337524,-0.99671298265457153,0.0035727093927562237,0.080937549471855164,4.6196026802062988,1.8661714792251587,0.74804812669754028"> </Bone> </Part> </Brick> <Brick refID="117" designID="4287" itemNos="428724"> <Part refID="117" designID="4287" materials="24"> <Bone refID="117" transformation="0.99671298265457153,-0.0035727077629417181,-0.080937542021274567,0.044615693390369415,0.85809677839279175,0.51154619455337524,0.06762462854385376,-0.51347631216049194,0.85543525218963623,4.5767722129821777,1.0423989295959473,0.25696215033531189"> </Bone> </Part> </Brick> <Brick refID="118" designID="6562" itemNos="4191056"> <Part refID="118" designID="6562" materials="1"> <Bone refID="118" transformation="-0.99671286344528198,0.003571417648345232,0.080937467515468597,0.0048291562125086784,0.99987059831619263,0.01534927636384964,-0.080872185528278351,0.015689685940742493,-0.99660098552703857,4.410247802734375,1.5732630491256714,-1.817186713218689"> </Bone> </Part> </Brick> <Brick refID="119" designID="32013" itemNos="4107085"> <Part refID="119" designID="32013" materials="26"> <Bone refID="119" transformation="-0.080880306661128998,0.01568971760571003,-0.99660032987594604,0.0048291562125086784,0.99987059831619263,0.015349258668720722,0.99671220779418945,-0.0035712881945073605,-0.080945432186126709,4.474942684173584,1.5607117414474487,-1.0199074745178223"> </Bone> </Part> </Brick> <Brick refID="120" designID="60484" itemNos="4535772"> <Part refID="120" designID="60484" materials="194"> <Bone refID="120" transformation="0.0048265052028000355,0.99987059831619263,0.015348486602306366,0.99997669458389282,-0.0048999860882759094,0.0047531267628073692,0.0048277010209858418,0.015325195156037807,-0.9998708963394165,1.9952712059020996,3.2217516899108887,-4.2024192810058594"> </Bone> </Part> </Brick> <Brick refID="121" designID="2780" itemNos="278026"> <Part refID="121" designID="2780" materials="26"> <Bone refID="121" transformation="0.99997574090957642,-0.0051024807617068291,0.0047472217120230198,0.0050290636718273163,0.99986958503723145,0.015349620021879673,-0.0048249056562781334,-0.015325380489230156,0.9998708963394165,1.9991309642791748,4.8092846870422363,-3.3779644966125488"> </Bone> </Part> </Brick> <Brick refID="122" designID="44353" itemNos="4183399"> <Part refID="122" designID="44353" materials="1"> <Bone refID="122" transformation="-0.0048132883384823799,-0.99987071752548218,-0.015348002314567566,-0.0048258872702717781,-0.015324782580137253,0.9998708963394165,-0.9999767541885376,0.0048867403529584408,-0.0047515183687210083,2.0068490505218506,4.8338055610656738,-4.9777584075927734"> </Bone> </Part> </Brick> <Brick refID="123" designID="2780" itemNos="278026"> <Part refID="123" designID="2780" materials="26"> <Bone refID="123" transformation="0.99997669458389282,-0.0049025029875338078,0.004754264373332262,0.004828878678381443,0.015325593762099743,-0.9998708963394165,0.0048290025442838669,0.99987059831619263,0.015348901972174644,3.5952882766723633,3.6077263355255127,-3.7887279987335205"> </Bone> </Part> </Brick> <Brick refID="124" designID="32523" itemNos="4142822"> <Part refID="124" designID="32523" materials="26"> <Bone refID="124" transformation="0.99997669458389282,-0.0049013379029929638,0.0047539938241243362,0.0048278416506946087,0.99987059831619263,0.015348910354077816,-0.0048285904340445995,-0.015325608663260937,0.9998708963394165,4.3759546279907227,0.78577178716659546,-2.6280550956726074"> </Bone> </Part> </Brick> <Brick refID="125" designID="6558" itemNos="655826"> <Part refID="125" designID="6558" materials="26"> <Bone refID="125" transformation="0.0047543877735733986,1.1547072972462047E-005,-0.99998867511749268,0.0048899650573730469,0.99998807907104492,3.478707731119357E-005,0.9999767541885376,-0.0048900814726948738,0.0047542932443320751,4.0087714195251465,4.0424938201904297,-6.180382251739502"> </Bone> </Part> </Brick> <Brick refID="126" designID="6558" itemNos="655826"> <Part refID="126" designID="6558" materials="26"> <Bone refID="126" transformation="-0.99997669458389282,0.0049025560729205608,-0.0047543924301862717,0.0048290528357028961,0.99987059831619263,0.015349051915109158,0.0048290085978806019,0.015325742773711681,-0.9998708963394165,4.4068603515625,2.4591274261474609,-7.4028363227844238"> </Bone> </Part> </Brick> <Brick refID="127" designID="44809" itemNos="4195022"> <Part refID="127" designID="44809" materials="26"> <Bone refID="127" transformation="0.0048288330435752869,0.015325712971389294,-0.9998708963394165,0.00482904352247715,0.99987059831619263,0.015349021181464195,0.99997669458389282,-0.0049025439657270908,0.004754217341542244,3.1895029544830322,1.6222022771835327,-4.6211824417114258"> </Bone> </Part> </Brick> <Brick refID="128" designID="2780" itemNos="278026"> <Part refID="128" designID="2780" materials="26"> <Bone refID="128" transformation="0.99997669458389282,-0.0049040256999433041,0.0047531710006296635,0.0048305424861609936,0.99987059831619263,0.015348735265433788,-0.0048278081230819225,-0.015325424261391163,0.9998708963394165,3.5759737491607666,0.78969353437423706,-2.6318566799163818"> </Bone> </Part> </Brick> <Brick refID="129" designID="44809" itemNos="4195022"> <Part refID="129" designID="44809" materials="26"> <Bone refID="129" transformation="0.0048288339748978615,0.015325905755162239,-0.9998708963394165,0.0048290425911545753,0.99987059831619263,0.015349213965237141,0.99997669458389282,-0.0049025439657270908,0.004754217341542244,5.5894474983215332,1.6104365587234497,-4.6097726821899414"> </Bone> </Part> </Brick> <Brick refID="130" designID="2780" itemNos="278026"> <Part refID="130" designID="2780" materials="26"> <Bone refID="130" transformation="0.99997669458389282,-0.0049025090411305428,0.004754143301397562,0.0048287590034306049,0.015325779095292091,-0.9998708963394165,0.0048290095292031765,0.99987059831619263,0.015349087305366993,5.1952524185180664,2.024606466293335,-5.4054322242736816"> </Bone> </Part> </Brick> <Brick refID="131" designID="2780" itemNos="278026"> <Part refID="131" designID="2780" materials="26"> <Bone refID="131" transformation="0.99997568130493164,-0.0051026763394474983,0.0047504594549536705,0.0050292103551328182,0.99986958503723145,0.01534951850771904,-0.0048281452618539333,-0.01532526221126318,0.9998708963394165,1.9952707290649414,4.0093879699707031,-3.3902430534362793"> </Bone> </Part> </Brick> <Brick refID="132" designID="2780" itemNos="278026"> <Part refID="132" designID="2780" materials="26"> <Bone refID="132" transformation="0.99997669458389282,-0.0049031777307391167,0.0047527430579066277,0.0048273666761815548,0.015325248241424561,-0.9998708963394165,0.0048297024331986904,0.99987059831619263,0.015348552726209164,3.5914251804351807,3.5954651832580566,-2.9888310432434082"> </Bone> </Part> </Brick> <Brick refID="133" designID="32013" itemNos="4118981"> <Part refID="133" designID="32013" materials="1"> <Bone refID="133" transformation="0.99997669458389282,-0.0049050459638237953,0.0047502131201326847,0.0048316088505089283,0.99987059831619263,0.015348616056144238,-0.0048248656094074249,-0.015325314365327358,0.9998708963394165,2.3895187377929687,3.2014017105102539,-3.0006704330444336"> </Bone> </Part> </Brick> <Brick refID="134" designID="32062" itemNos="4109810"> <Part refID="134" designID="32062" materials="26"> <Bone refID="134" transformation="-0.0048248660750687122,-0.015325314365327358,0.99987101554870605,0.0048316097818315029,0.99987053871154785,0.015348620712757111,-0.99997663497924805,0.0049050459638237953,-0.0047502131201326847,1.5895360708236694,3.2053256034851074,-3.004469633102417"> </Bone> </Part> </Brick> <Brick refID="135" designID="42003" itemNos="4211779"> <Part refID="135" designID="42003" materials="194"> <Bone refID="135" transformation="0.0048316097818315029,0.99987053871154785,0.015348620712757111,0.99997663497924805,-0.0049050459638237953,0.0047502131201326847,0.0048248660750687122,0.015325314365327358,-0.99987101554870605,1.9837260246276855,1.6097003221511841,-3.4270761013031006"> </Bone> </Part> </Brick> <Brick refID="136" designID="3070" itemNos="307001"> <Part refID="136" designID="3070" materials="1,0" decoration="0"> <Bone refID="136" transformation="0.99588507413864136,-0.0062009920366108418,0.090412892401218414,0.004832239355891943,0.99987053871154785,0.015349896624684334,-0.090496346354484558,-0.014849841594696045,0.99578607082366943,3.4426636695861816,3.5394484996795654,-0.59598225355148315"> </Bone> </Part> </Brick> <Brick refID="137" designID="6541" itemNos="654101"> <Part refID="137" designID="6541" materials="1"> <Bone refID="137" transformation="0.99588507413864136,-0.0062009952962398529,0.090412944555282593,0.0048322351649403572,0.9998706579208374,0.015349899418652058,-0.090496346354484558,-0.014849843457341194,0.99578619003295898,3.4380247592926025,2.5795717239379883,-0.61071830987930298"> </Bone> </Part> </Brick> <Brick refID="138" designID="44301" itemNos="4183035"> <Part refID="138" designID="44301" materials="1"> <Bone refID="138" transformation="0.090496338903903961,0.014849845319986343,-0.99578619003295898,0.0048322370275855064,0.9998706579208374,0.015349892899394035,0.99588507413864136,-0.0062009948305785656,0.090412929654121399,3.4364771842956543,2.2596125602722168,-0.61563068628311157"> </Bone> </Part> </Brick> <Brick refID="139" designID="3023" itemNos="302301"> <Part refID="139" designID="3023" materials="1"> <Bone refID="139" transformation="-0.090496428310871124,-0.014849838800728321,0.99578619003295898,0.0048322351649403572,0.9998706579208374,0.015349899418652058,-0.99588507413864136,0.0062009952962398529,-0.090413019061088562,3.507328987121582,1.9515335559844971,-1.4171715974807739"> </Bone> </Part> </Brick> <Brick refID="140" designID="6541" itemNos="654101"> <Part refID="140" designID="6541" materials="1"> <Bone refID="140" transformation="0.99588507413864136,-0.0062009948305785656,0.090412944555282593,0.0048322351649403572,0.9998706579208374,0.015349899418652058,-0.090496346354484558,-0.014849843457341194,0.99578619003295898,3.4302952289581299,0.97977805137634277,-0.63527733087539673"> </Bone> </Part> </Brick> <Brick refID="141" designID="6562" itemNos="4191056"> <Part refID="141" designID="6562" materials="1"> <Bone refID="141" transformation="-0.99588513374328613,0.006197748240083456,-0.090412870049476624,0.0048290318809449673,0.99987059831619263,0.015349355526268482,0.090496279299259186,0.014849593862891197,-0.99578613042831421,3.5494229793548584,3.1773171424865723,-1.7967573404312134"> </Bone> </Part> </Brick> <Brick refID="142" designID="32013" itemNos="4118981"> <Part refID="142" designID="32013" materials="1"> <Bone refID="142" transformation="0.090501874685287476,0.01484956406056881,-0.99578559398651123,0.0048290365375578403,0.99987071752548218,0.015349362045526505,0.99588459730148315,-0.006197839044034481,0.09041847288608551,3.47702956199646,3.1654374599456787,-1.0001291036605835"> </Bone> </Part> </Brick> <Brick refID="143" designID="6562" itemNos="4191056"> <Part refID="143" designID="6562" materials="1"> <Bone refID="143" transformation="-0.99588513374328613,0.0061978395096957684,-0.090412966907024384,0.004829120822250843,0.99987059831619263,0.015349367633461952,0.090496368706226349,0.014849596656858921,-0.99578607082366943,3.5416934490203857,1.5775244235992432,-1.8213163614273071"> </Bone> </Part> </Brick> <Brick refID="144" designID="32013" itemNos="4107085"> <Part refID="144" designID="32013" materials="26"> <Bone refID="144" transformation="0.090503357350826263,0.014849564991891384,-0.9957854151725769,0.004829120822250843,0.99987059831619263,0.0153493732213974,0.9958844780921936,-0.0061979447491466999,0.090419933199882507,3.4693014621734619,1.5656447410583496,-1.024687647819519"> </Bone> </Part> </Brick> <Brick refID="145" designID="6558" itemNos="655826"> <Part refID="145" designID="6558" materials="26"> <Bone refID="145" transformation="-0.0041718240827322006,-0.015328943729400635,0.9998738169670105,0.99997961521148682,-0.0048924903385341167,0.0040972777642309666,0.004829060286283493,0.99987059831619263,0.015349035151302814,3.5875625610351562,3.5832052230834961,-2.1889331340789795"> </Bone> </Part> </Brick> <Brick refID="146" designID="50950" itemNos="4247771"> <Part refID="146" designID="50950" materials="24"> <Bone refID="146" transformation="-0.08079046756029129,-0.5127485990524292,0.8547290563583374,-0.041059009730815887,0.85851645469665527,0.51113975048065186,-0.99588507413864136,0.0062008961103856564,-0.090412907302379608,3.233057975769043,1.7371178865432739,1.5891721248626709"> </Bone> </Part> </Brick> <Brick refID="147" designID="3069" itemNos="306924"> <Part refID="147" designID="3069" materials="24,0" decoration="0"> <Bone refID="147" transformation="-0.080790534615516663,-0.5127485990524292,0.8547290563583374,-0.041058994829654694,0.8585163950920105,0.51113969087600708,-0.99588501453399658,0.0062008760869503021,-0.090412959456443787,3.3492016792297363,2.8323554992675781,0.38498193025588989"> </Bone> </Part> </Brick> <Brick refID="148" designID="3024" itemNos="302424"> <Part refID="148" designID="3024" materials="24"> <Bone refID="148" transformation="0.99588495492935181,-0.0062008574604988098,0.090412899851799011,-0.041058957576751709,0.8585163950920105,0.51113957166671753,-0.080790460109710693,-0.51274842023849487,0.8547290563583374,3.2976899147033691,2.1473174095153809,0.90539032220840454"> </Bone> </Part> </Brick> <Brick refID="149" designID="44302" itemNos="4183981"> <Part refID="149" designID="44302" materials="24"> <Bone refID="149" transformation="-0.080790460109710693,-0.51274853944778442,0.85472899675369263,-0.041058961302042007,0.8585163950920105,0.51113951206207275,-0.99588495492935181,0.0062008597888052464,-0.090412899851799011,3.310828685760498,1.8725918531417847,0.74182569980621338"> </Bone> </Part> </Brick> <Brick refID="150" designID="4287" itemNos="428724"> <Part refID="150" designID="4287" materials="24"> <Bone refID="150" transformation="0.99588501453399658,-0.0062008537352085114,0.090412922203540802,-0.041058961302042007,0.8585163950920105,0.51113951206207275,-0.080790512263774872,-0.5127485990524292,0.8547290563583374,3.350245475769043,1.0484157800674438,0.25113233923912048"> </Bone> </Part> </Brick> <Brick refID="151" designID="32316" itemNos="4140429"> <Part refID="151" designID="32316" materials="26"> <Bone refID="151" transformation="-0.0048286938108503819,-0.015325690619647503,0.9998708963394165,0.99997669458389282,-0.0049024969339370728,0.0047540790401399136,0.0048289988189935684,0.99987059831619263,0.01534899789839983,5.1991152763366699,1.2492311000823975,-7.0175046920776367"> </Bone> </Part> </Brick> <Brick refID="152" designID="32013" itemNos="4118981"> <Part refID="152" designID="32013" materials="1"> <Bone refID="152" transformation="0.2634732723236084,0.013534775003790855,-0.96457183361053467,0.0048290267586708069,0.99987059831619263,0.015349129214882851,0.96465468406677246,-0.0087020415812730789,0.2633737325668335,2.469482421875,3.1709370613098145,-1.0413883924484253"> </Bone> </Part> </Brick> <Brick refID="153" designID="6562" itemNos="4191056"> <Part refID="153" designID="6562" materials="1"> <Bone refID="153" transformation="-0.96465551853179932,0.0087020006030797958,-0.26337063312530518,0.0048290384002029896,0.99987053871154785,0.015349123626947403,0.26347002387046814,0.013534795492887497,-0.96457260847091675,2.6802566051483154,3.1817648410797119,-1.8130453824996948"> </Bone> </Part> </Brick> <Brick refID="154" designID="3070" itemNos="307001"> <Part refID="154" designID="3070" materials="1,0" decoration="0"> <Bone refID="154" transformation="0.96465545892715454,-0.0087027354165911674,0.26337069272994995,0.0048297382891178131,0.99987059831619263,0.015349347144365311,-0.26347014307975769,-0.013534825295209885,0.96457260847091675,2.3659276962280273,3.5454738140106201,-0.64972782135009766"> </Bone> </Part> </Brick> <Brick refID="155" designID="6541" itemNos="654101"> <Part refID="155" designID="6541" materials="1"> <Bone refID="155" transformation="0.96465539932250977,-0.008702743798494339,0.26337066292762756,0.0048297340981662273,0.99987053871154785,0.015349347144365311,-0.2634701132774353,-0.013534828089177608,0.96457260847091675,2.3612909317016602,2.5855982303619385,-0.6644631028175354"> </Bone> </Part> </Brick> <Brick refID="156" designID="44301" itemNos="4183035"> <Part refID="156" designID="44301" materials="1"> <Bone refID="156" transformation="0.26347008347511292,0.013534826226532459,-0.96457254886627197,0.0048297327011823654,0.99987053871154785,0.015349348075687885,0.96465539932250977,-0.0087027428671717644,0.26337066292762756,2.359745979309082,2.2656381130218506,-0.66937547922134399"> </Bone> </Part> </Brick> <Brick refID="157" designID="3023" itemNos="302301"> <Part refID="157" designID="3023" materials="1"> <Bone refID="157" transformation="-0.26347020268440247,-0.013534819707274437,0.96457260847091675,0.0048297340981662273,0.99987053871154785,0.015349347144365311,-0.96465545892715454,0.0087027354165911674,-0.26337075233459473,2.5689759254455566,1.9565082788467407,-1.4459447860717773"> </Bone> </Part> </Brick> <Brick refID="158" designID="6541" itemNos="654101"> <Part refID="158" designID="6541" materials="1"> <Bone refID="158" transformation="0.96465539932250977,-0.008702743798494339,0.26337066292762756,0.0048297340981662273,0.99987053871154785,0.015349347144365311,-0.2634701132774353,-0.013534828089177608,0.96457260847091675,2.3535656929016113,0.98580342531204224,-0.68902027606964111"> </Bone> </Part> </Brick> <Brick refID="159" designID="32013" itemNos="4107085"> <Part refID="159" designID="32013" materials="26"> <Bone refID="159" transformation="0.26347255706787109,0.013534697704017162,-0.96457195281982422,0.0048291278071701527,0.99987059831619263,0.015349075198173523,0.96465480327606201,-0.0087021104991436005,0.26337304711341858,2.4617562294006348,1.5711442232131958,-1.0659475326538086"> </Bone> </Part> </Brick> <Brick refID="160" designID="6562" itemNos="4191056"> <Part refID="160" designID="6562" materials="1"> <Bone refID="160" transformation="-0.96465545892715454,0.0087020751088857651,-0.26337072253227234,0.0048291292041540146,0.99987047910690308,0.015349069610238075,0.26347014307975769,0.013534716330468655,-0.96457254886627197,2.6725318431854248,1.5819723606109619,-1.8376045227050781"> </Bone> </Part> </Brick> <Brick refID="161" designID="6558" itemNos="655826"> <Part refID="161" designID="6558" materials="26"> <Bone refID="161" transformation="-0.0048277056775987148,-0.015325731597840786,0.9998708963394165,0.99997669458389282,-0.0049025435000658035,0.0047530895099043846,0.004829060286283493,0.99987059831619263,0.015349035151302814,2.7875816822052002,3.5871272087097168,-2.1927366256713867"> </Bone> </Part> </Brick> <Brick refID="162" designID="41678" itemNos="4162857"> <Part refID="162" designID="41678" materials="26"> <Bone refID="162" transformation="0.99997669458389282,-0.004902559332549572,0.0047545195557177067,-0.004829054232686758,-0.99987059831619263,-0.015349104069173336,0.0048291357234120369,0.015325793996453285,-0.9998708963394165,3.5991523265838623,2.438528299331665,-5.8068461418151855"> </Bone> </Part> </Brick> <Brick refID="163" designID="32062" itemNos="4109810"> <Part refID="163" designID="32062" materials="26"> <Bone refID="163" transformation="-0.0048291352577507496,-0.015325795859098434,0.99987083673477173,0.0048290537670254707,0.99987053871154785,0.01534910686314106,-0.99997669458389282,0.0049025588668882847,-0.0047545190900564194,3.1933674812316895,1.6344623565673828,-5.421076774597168"> </Bone> </Part> </Brick> <Brick refID="164" designID="2780" itemNos="278026"> <Part refID="164" designID="2780" materials="26"> <Bone refID="164" transformation="0.99997669458389282,-0.0049019199796020985,0.0047541833482682705,0.0048284209333360195,0.99987059831619263,0.015348884277045727,-0.0048287888057529926,-0.015325578860938549,0.9998708963394165,4.3759546279907227,0.78577178716659546,-2.6280550956726074"> </Bone> </Part> </Brick> <Brick refID="165" designID="6558" itemNos="655826"> <Part refID="165" designID="6558" materials="26"> <Bone refID="165" transformation="-0.99997669458389282,0.0049025560729205608,-0.0047543966211378574,0.0048290528357028961,0.99987059831619263,0.015349051915109158,0.0048290127888321877,0.015325742773711681,-0.9998708963394165,3.6068785190582275,2.4630491733551025,-7.406639575958252"> </Bone> </Part> </Brick> <Brick refID="166" designID="50950" itemNos="4247771"> <Part refID="166" designID="50950" materials="24"> <Bone refID="166" transformation="-0.23059342801570892,-0.51161152124404907,0.82769578695297241,-0.12754039466381073,0.85917288064956665,0.49553570151329041,-0.96465545892715454,0.0087026329711079597,-0.26337075233459473,1.7720359563827515,1.7460619211196899,1.4660823345184326"> </Bone> </Part> </Brick> <Brick refID="167" designID="3069" itemNos="306924"> <Part refID="167" designID="3069" materials="24,0" decoration="0"> <Bone refID="167" transformation="-0.23059344291687012,-0.51161152124404907,0.82769578695297241,-0.12754033505916595,0.85917294025421143,0.49553558230400085,-0.96465545892715454,0.008702598512172699,-0.26337075233459473,2.1002233028411865,2.8396902084350586,0.30015355348587036"> </Bone> </Part> </Brick> <Brick refID="168" designID="3024" itemNos="302424"> <Part refID="168" designID="3024" materials="24"> <Bone refID="168" transformation="0.96465545892715454,-0.0087026525288820267,0.26337075233459473,-0.1275402307510376,0.85917294025421143,0.49553561210632324,-0.23059333860874176,-0.5116117000579834,0.82769584655761719,1.956510066986084,2.1553516387939453,0.80392557382583618"> </Bone> </Part> </Brick> <Brick refID="169" designID="44302" itemNos="4183981"> <Part refID="169" designID="44302" materials="24"> <Bone refID="169" transformation="-0.23059326410293579,-0.51161152124404907,0.82769572734832764,-0.12754024565219879,0.85917294025421143,0.49553561210632324,-0.96465545892715454,0.0087026637047529221,-0.26337075233459473,1.9973235130310059,1.8804157972335815,0.64535433053970337"> </Bone> </Part> </Brick> <Brick refID="170" designID="4287" itemNos="428724"> <Part refID="170" designID="4287" materials="24"> <Bone refID="170" transformation="0.96465545892715454,-0.0087026543915271759,0.26337075233459473,-0.12754026055335999,0.85917288064956665,0.49553570151329041,-0.23059329390525818,-0.5116117000579834,0.82769584655761719,2.1197612285614014,1.0556091070175171,0.16964022815227509"> </Bone> </Part> </Brick> <Brick refID="171" designID="2780" itemNos="278026"> <Part refID="171" designID="2780" materials="26"> <Bone refID="171" transformation="-0.0047289147041738033,1.1508681382110808E-005,0.99998879432678223,0.0048762918449938297,0.99998819828033447,1.1542109859874472E-005,-0.99997693300247192,0.004876298364251852,-0.0047289333306252956,1.6010984182357788,3.2420303821563721,-5.4041357040405273"> </Bone> </Part> </Brick> <Brick refID="172" designID="32523" itemNos="4142822"> <Part refID="172" designID="32523" materials="26"> <Bone refID="172" transformation="0.99997669458389282,-0.0049060583114624023,0.0047524287365376949,0.0048325872048735619,0.99987059831619263,0.015348609536886215,-0.0048270965926349163,-0.015325292013585567,0.9998708963394165,1.9760110378265381,0.79754328727722168,-2.6394598484039307"> </Bone> </Part> </Brick> <Brick refID="173" designID="32054" itemNos="4193409"> <Part refID="173" designID="32054" materials="1"> <Bone refID="173" transformation="0.99997669458389282,-0.0049001104198396206,0.0047507863491773605,0.004826666321605444,0.99987059831619263,0.015348364599049091,-0.004825362004339695,-0.015325084328651428,0.9998708963394165,1.9798665046691895,1.5974404811859131,-2.6271812915802002"> </Bone> </Part> </Brick> <Brick refID="174" designID="42074" itemNos="4163132"> <Part refID="174" designID="42074" materials="1"> <Bone refID="174" transformation="0.99997669458389282,-0.0049001160077750683,0.0047507914714515209,0.0048253634013235569,0.01532508060336113,-0.99987101554870605,0.0048266705125570297,0.99987059831619263,0.015348359942436218,1.9875876903533936,1.6219602823257446,-4.2269763946533203"> </Bone> </Part> </Brick> <Brick refID="175" designID="2780" itemNos="278026"> <Part refID="175" designID="2780" materials="26"> <Bone refID="175" transformation="0.99997669458389282,-0.004902510903775692,0.004754270426928997,0.0048288856633007526,0.015325696207582951,-0.9998708963394165,0.0048290099948644638,0.99987059831619263,0.015349005348980427,2.7953071594238281,2.036372184753418,-5.416841983795166"> </Bone> </Part> </Brick> <Brick refID="176" designID="32316" itemNos="4140429"> <Part refID="176" designID="32316" materials="26"> <Bone refID="176" transformation="-0.0048289545811712742,-0.015325740911066532,0.9998708963394165,0.99997669458389282,-0.0049025006592273712,0.0047543393447995186,0.0048289983533322811,0.99987059831619263,0.015349050052464008,2.7991702556610107,1.26099693775177,-7.0289149284362793"> </Bone> </Part> </Brick> <Brick refID="177" designID="2780" itemNos="278026"> <Part refID="177" designID="2780" materials="26"> <Bone refID="177" transformation="0.99997669458389282,-0.0048965872265398502,0.0047527020797133446,0.0048231147229671478,0.9998706579208374,0.015348252840340137,-0.0048272227868437767,-0.015324980020523071,0.9998708963394165,1.9760115146636963,0.79754328727722168,-2.6394598484039307"> </Bone> </Part> </Brick> <Brick refID="178" designID="32249" itemNos="4140328"> <Part refID="178" designID="32249" materials="26"> <Bone refID="178" transformation="0.004828836303204298,0.99987053871154785,0.015349049121141434,-0.0048289401456713676,-0.015325733460485935,0.9998708963394165,0.99997669458389282,-0.0049023325555026531,0.0047543095424771309,5.6241793632507324,4.8713064193725586,-8.5587234497070312"> </Bone> </Part> </Brick> <Brick refID="179" designID="32062" itemNos="4109810"> <Part refID="179" designID="32062" materials="26"> <Bone refID="179" transformation="0.0048281406052410603,0.015325885266065598,-0.9998708963394165,0.0048281238414347172,0.99987053871154785,0.015349193476140499,0.99997669458389282,-0.0049016084522008896,0.0047535207122564316,5.624180793762207,6.4465775489807129,-6.9343724250793457"> </Bone> </Part> </Brick> <Brick refID="180" designID="32249" itemNos="4140328"> <Part refID="180" designID="32249" materials="26"> <Bone refID="180" transformation="0.0048281238414347172,0.99987053871154785,0.015349193476140499,-0.0048281415365636349,-0.015325885266065598,0.9998708963394165,0.99997669458389282,-0.0049016089178621769,0.0047535207122564316,5.2242178916931152,4.8732657432556152,-8.560582160949707"> </Bone> </Part> </Brick> <Brick refID="181" designID="93571" itemNos="4610948"> <Part refID="181" designID="93571" materials="26"> <Bone refID="181" transformation="0.0048281415365636349,0.015325886197388172,-0.9998708963394165,0.0048281238414347172,0.99987053871154785,0.015349193476140499,0.99997669458389282,-0.0049016089178621769,0.0047535216435790062,4.0203561782836914,6.4421591758728027,-6.1420812606811523"> </Bone> </Part> </Brick> <Brick refID="182" designID="32062" itemNos="4109810"> <Part refID="182" designID="32062" materials="26"> <Bone refID="182" transformation="-0.0048281415365636349,-0.015325885266065598,0.9998708963394165,0.0048281238414347172,0.99987053871154785,0.015349193476140499,-0.99997669458389282,0.0049016089178621769,-0.0047535207122564316,4.0242466926574707,4.8791470527648926,-8.5662860870361328"> </Bone> </Part> </Brick> <Brick refID="183" designID="3706" itemNos="370626"> <Part refID="183" designID="3706" materials="26"> <Bone refID="183" transformation="-0.0048289373517036438,-0.015325690619647503,0.9998708963394165,0.0048288237303495407,0.99987053871154785,0.015349004417657852,-0.99997669458389282,0.0049023204483091831,-0.0047543062828481197,1.6319999694824219,6.4907093048095703,-8.5531835556030273"> </Bone> </Part> </Brick> <Brick refID="184" designID="53585" itemNos="4286267"> <Part refID="184" designID="53585" materials="26"> <Bone refID="184" transformation="0.0047543975524604321,-1.1589953828661237E-005,-0.99998867511749268,0.0049023204483091831,0.99998801946640015,1.1719698704837356E-005,0.99997669458389282,-0.0049023199826478958,0.0047543970867991447,6.011897087097168,6.4692373275756836,-8.5323581695556641"> </Bone> </Part> </Brick> <Brick refID="185" designID="32062" itemNos="4109810"> <Part refID="185" designID="32062" materials="26"> <Bone refID="185" transformation="0.0048281406052410603,0.015325885266065598,-0.9998708963394165,0.0048281238414347172,0.99987053871154785,0.015349193476140499,0.99997669458389282,-0.0049016084522008896,0.0047535211779177189,4.0242180824279785,6.4544205665588379,-6.9419775009155273"> </Bone> </Part> </Brick> <Brick refID="186" designID="93571" itemNos="4610948"> <Part refID="186" designID="93571" materials="26"> <Bone refID="186" transformation="0.0048281243070960045,0.99987053871154785,0.015349193476140499,-0.0048281420022249222,-0.015325885266065598,0.9998708963394165,0.99997669458389282,-0.0049016089178621769,0.0047535216435790062,4.0203847885131836,4.0792508125305176,-8.5785646438598633"> </Bone> </Part> </Brick> <Brick refID="187" designID="32249" itemNos="4140328"> <Part refID="187" designID="32249" materials="26"> <Bone refID="187" transformation="0.0048281238414347172,0.99987053871154785,0.015349193476140499,-0.0048281415365636349,-0.015325885266065598,0.9998708963394165,0.99997669458389282,-0.0049016089178621769,0.0047535207122564316,3.2242660522460937,4.8830680847167969,-8.5700883865356445"> </Bone> </Part> </Brick> <Brick refID="188" designID="32062" itemNos="4109810"> <Part refID="188" designID="32062" materials="26"> <Bone refID="188" transformation="-0.0048281415365636349,-0.015325885266065598,0.9998708963394165,0.0048281238414347172,0.99987053871154785,0.015349193476140499,-0.99997669458389282,0.0049016089178621769,-0.0047535207122564316,2.4242830276489258,4.8869895935058594,-8.5738906860351562"> </Bone> </Part> </Brick> <Brick refID="189" designID="32249" itemNos="4140328"> <Part refID="189" designID="32249" materials="26"> <Bone refID="189" transformation="0.0048285005614161491,0.015325780026614666,-0.9998708963394165,-0.0048286612145602703,-0.99987053871154785,-0.015349091030657291,-0.99997669458389282,0.0049021509476006031,-0.0047538718208670616,2.4242544174194336,6.4622635841369629,-6.9495830535888672"> </Bone> </Part> </Brick> <Brick refID="190" designID="53585" itemNos="4286267"> <Part refID="190" designID="53585" materials="26"> <Bone refID="190" transformation="0.0047543975524604321,-1.1589953828661237E-005,-0.99998867511749268,0.0049023204483091831,0.99998801946640015,1.1719698704837356E-005,0.99997669458389282,-0.0049023199826478958,0.0047543970867991447,2.0119898319244385,6.4888472557067871,-8.5513772964477539"> </Bone> </Part> </Brick> <Brick refID="191" designID="43093" itemNos="4168884"> <Part refID="191" designID="43093" materials="26"> <Bone refID="191" transformation="0.9999883770942688,-3.6966408515581861E-005,0.0048259994946420193,-3.6965830076951534E-005,0.99988263845443726,0.01531889196485281,-0.004825999028980732,-0.01531889196485281,0.99987101554870605,4.0261802673339844,5.6729187965393066,-8.1540584564208984"> </Bone> </Part> </Brick> <Brick refID="192" designID="72039" itemNos="4113010"> <Part refID="192" designID="72039" materials="26"> <Bone refID="192" transformation="-0.057335361838340759,-0.82053923606872559,0.56870752573013306,0.99828344583511353,-0.053943540900945663,0.022813398391008377,0.011958806775510311,0.56903922557830811,0.82222342491149902,4.0851807594299316,13.104366302490234,-16.053497314453125"> </Bone> <Bone refID="193" transformation="-0.097959436476230621,-0.95083010196685791,0.29381293058395386,0.99502182006835938,-0.088141389191150665,0.046506769955158234,-0.018322957679629326,0.29690605401992798,0.95473098754882813,4.0393123626708984,12.447931289672852,-15.598526954650879"> </Bone> <Bone refID="194" transformation="-0.11335434019565582,-0.99268907308578491,0.041465442627668381,0.99238103628158569,-0.11109388619661331,0.053273528814315796,-0.048277489840984344,0.047188300639390945,0.9977186918258667,3.9609444141387939,11.687265396118164,-15.363475799560547"> </Bone> <Bone refID="195" transformation="-0.10982836782932281,-0.98408299684524536,-0.13970828056335449,0.9915422797203064,-0.11825324594974518,0.053479567170143127,-0.069149293005466461,-0.13265310227870941,0.98874747753143311,3.8702607154846191,10.89311408996582,-15.330304145812988"> </Bone> <Bone refID="196" transformation="-0.093521937727928162,-0.96893304586410522,-0.22895941138267517,0.99254721403121948,-0.10878035426139832,0.054926507174968719,-0.078126400709152222,-0.22211621701717377,0.97188520431518555,3.7823975086212158,10.105847358703613,-15.442070960998535"> </Bone> <Bone refID="197" transformation="-0.06865035742521286,-0.97219103574752808,-0.22390121221542358,0.99458140134811401,-0.084256798028945923,0.060898911207914352,-0.078070573508739471,-0.21850724518299103,0.97270733118057251,3.7075796127319336,9.3306999206542969,-15.625238418579102"> </Bone> <Bone refID="198" transformation="-0.036809399724006653,-0.99159610271453857,-0.12402525544166565,0.99650490283966064,-0.04573473334312439,0.069902196526527405,-0.074987009167671204,-0.12101873010396957,0.98981392383575439,3.6526591777801514,8.5529470443725586,-15.804360389709473"> </Bone> <Bone refID="199" transformation="0.0010671811178326607,-0.99765831232070923,0.068386688828468323,0.9970555305480957,0.006305221002548933,0.076424479484558105,-0.076676703989505768,0.068103760480880737,0.99472737312316895,3.6232116222381592,7.7596688270568848,-15.903580665588379"> </Bone> <Bone refID="200" transformation="0.04156920313835144,-0.94190728664398193,0.33329096436500549,0.99499088525772095,0.069378875195980072,0.071971617639064789,-0.090913929045200348,0.32862961292266846,0.94007301330566406,3.6240653991699219,6.9615416526794434,-15.848871231079102"> </Bone> <Bone refID="201" transformation="0.076306089758872986,-0.78824919462203979,0.61060672998428345,0.989815354347229,0.13369607925415039,0.048897083848714828,-0.12017881870269775,0.60065680742263794,0.79042297601699829,3.6573207378387451,6.208014965057373,-15.58223819732666"> </Bone> <Bone refID="202" transformation="0.096752539277076721,-0.54185855388641357,0.83488219976425171,0.98238843679428101,0.18670636415481567,0.0073302164673805237,-0.15984976291656494,0.8194693922996521,0.55037987232208252,3.7183656692504883,5.5774154663085937,-15.093752861022949"> </Bone> <Bone refID="203" transformation="0.09841986745595932,-0.25376042723655701,0.96224695444107056,0.97494322061538696,0.21843104064464569,-0.042114581912755966,-0.19949761033058167,0.94228112697601318,0.26889997720718384,3.7957680225372314,5.143928050994873,-14.425846099853516"> </Bone> <Bone refID="204" transformation="0.0833330899477005,0.0096863424405455589,0.99647468328475952,0.96977812051773071,0.22931757569313049,-0.083329617977142334,-0.2293163388967514,0.97330355644226074,0.0097161391749978065,3.8745038509368896,4.9409198760986328,-13.656048774719238"> </Bone> <Bone refID="205" transformation="0.060260239988565445,0.19433361291885376,0.97908282279968262,0.96761423349380493,0.22950994968414307,-0.10510874539613724,-0.24513541162014008,0.95370835065841675,-0.17420963943004608,3.9411704540252686,4.9486689567565918,-12.858868598937988"> </Bone> <Bone refID="206" transformation="0.036631539463996887,0.28413063287734985,0.95808553695678711,0.96745580434799194,0.23011994361877441,-0.10523436218500137,-0.25037488341331482,0.93076032400131226,-0.26645419001579285,3.9893786907196045,5.1041359901428223,-12.075602531433105"> </Bone> <Bone refID="207" transformation="0.016663938760757446,0.27886536717414856,0.96018564701080322,0.96783334016799927,0.23661291599273682,-0.085515819489955902,-0.25103971362113953,0.93072468042373657,-0.26595228910446167,4.018683910369873,5.3314404487609863,-11.309133529663086"> </Bone> <Bone refID="208" transformation="0.0023584545124322176,0.17861936986446381,0.98391544818878174,0.96755099296569824,0.24819454550743103,-0.047376304864883423,-0.25266477465629578,0.95210009813308716,-0.17223799228668213,4.032015323638916,5.5545330047607422,-10.540985107421875"> </Bone> <Bone refID="209" transformation="-0.0048260306939482689,-0.015318823046982288,0.99987101554870605,0.96590733528137207,0.25874468684196472,0.0086262747645378113,-0.25884342193603516,0.96582430601119995,0.013547852635383606,4.0339021682739258,5.6974282264709473,-9.7538528442382812"> </Bone> <Bone refID="210" transformation="-0.25884345173835754,0.96582430601119995,0.01354785542935133,0.96590733528137207,0.25874468684196472,0.0086262347176671028,0.0048260721378028393,0.015318772755563259,-0.99987101554870605,4.0300426483154297,5.6851730346679687,-8.9539575576782227"> </Bone> </Part> </Brick> <Brick refID="193" designID="6558" itemNos="655826"> <Part refID="193" designID="6558" materials="26"> <Bone refID="211" transformation="0.99997329711914063,-0.00716830650344491,0.0014258463634178042,-0.0014263755874708295,-0.38274195790290833,-0.92385417222976685,0.0071682012639939785,0.92382746934890747,-0.38274195790290833,2.556466817855835,22.871852874755859,-16.478963851928711"> </Bone> </Part> </Brick> <Brick refID="194" designID="32062" itemNos="4109810"> <Part refID="194" designID="32062" materials="26"> <Bone refID="212" transformation="-0.0013227767776697874,-0.38274356722831726,-0.92385369539260864,0.0078249424695968628,0.92382222414016724,-0.38274174928665161,0.99996852874755859,-0.0077353836968541145,0.0017729356186464429,2.1651754379272461,23.983011245727539,-16.939409255981445"> </Bone> </Part> </Brick> <Brick refID="195" designID="32177" itemNos="4120182"> <Part refID="195" designID="32177" materials="26"> <Bone refID="213" transformation="0.0072019612416625023,0.92382699251174927,-0.38274261355400085,0.0029706242494285107,0.38273113965988159,0.92385494709014893,0.99996966123580933,-0.0077905505895614624,1.2073021935066208E-005,1.3306317329406738,19.554876327514648,-15.102255821228027"> </Bone> </Part> </Brick> <Brick refID="196" designID="43093" itemNos="4168884"> <Part refID="196" designID="43093" materials="26"> <Bone refID="214" transformation="0.0029705977067351341,0.38273113965988159,0.92385494709014893,0.0071707922033965588,0.92382717132568359,-0.38274270296096802,-0.9999699592590332,0.007761745247989893,0,0.53065580129623413,19.561105728149414,-15.102263450622559"> </Bone> </Part> </Brick> <Brick refID="197" designID="32039" itemNos="4107081"> <Part refID="197" designID="32039" materials="26"> <Bone refID="215" transformation="-0.9999690055847168,0.0076961475424468517,-0.0017566507449373603,-0.0013227947056293488,-0.38274246454238892,-0.92385417222976685,-0.0077824648469686508,-0.92382311820983887,0.38274079561233521,1.7558503150939941,22.877500534057617,-16.480823516845703"> </Bone> </Part> </Brick> <Brick refID="198" designID="32073" itemNos="4114740"> <Part refID="198" designID="32073" materials="26"> <Bone refID="216" transformation="0.0029694896657019854,0.3827301561832428,0.92385542392730713,0.99997001886367798,-0.0077589950524270535,0,0.0071682841517031193,0.92382752895355225,-0.382741779088974,1.7622225284576416,23.616653442382812,-16.786298751831055"> </Bone> </Part> </Brick> <Brick refID="199" designID="32016" itemNos="4107082"> <Part refID="199" designID="32016" materials="26"> <Bone refID="217" transformation="0.0077741951681673527,0.9999697208404541,-6.3907114963512868E-005,0,-6.3858467910904437E-005,-1,-0.99996989965438843,0.0077741886489093304,0,1.7212910652160645,18.351835250854492,-15.102197647094727"> </Bone> </Part> </Brick> <Brick refID="200" designID="43093" itemNos="4168884"> <Part refID="200" designID="43093" materials="26"> <Bone refID="218" transformation="0.9999699592590332,-0.0077651161700487137,-5.955022425041534E-005,-5.9974940086249262E-005,-6.385786400642246E-005,-0.99999994039535522,0.0077651203610002995,0.99996984004974365,-6.3918487285263836E-005,1.7275031805038452,19.151809692382812,-15.102241516113281"> </Bone> </Part> </Brick> <Brick refID="201" designID="60483" itemNos="4515185"> <Part refID="201" designID="60483" materials="26"> <Bone refID="219" transformation="0.99997341632843018,-0.0071683106943964958,0.0014259722083806992,-0.001426259521394968,-0.38274168968200684,-0.92385435104370117,0.0071682599373161793,0.92382752895355225,-0.382741779088974,1.7564878463745117,22.877590179443359,-16.480104446411133"> </Bone> </Part> </Brick> <Brick refID="202" designID="60483" itemNos="4515185"> <Part refID="202" designID="60483" materials="26"> <Bone refID="220" transformation="0.99997341632843018,-0.0071683111600577831,0.001425972324796021,-0.0014262594049796462,-0.38274168968200684,-0.92385435104370117,0.0071682599373161793,0.92382752895355225,-0.382741779088974,1.7450187206268311,21.399467468261719,-15.867717742919922"> </Bone> </Part> </Brick> <Brick refID="203" designID="32524" itemNos="3252426"> <Part refID="203" designID="32524" materials="26"> <Bone refID="221" transformation="0,6.3950865296646953E-005,1,0.99996984004974365,-0.0077665788121521473,0,0.0077665788121521473,0.99996984004974365,-6.3948937167879194E-005,2.5212781429290771,18.345306396484375,-19.902198791503906"> </Bone> </Part> </Brick> <Brick refID="204" designID="6590" itemNos="4177421"> <Part refID="204" designID="6590" materials="26"> <Bone refID="222" transformation="0.99996978044509888,-0.0077742794528603554,0,0.0077742813155055046,0.99996989965438843,-6.3948740717023611E-005,0,6.395066884579137E-005,1,2.1119482517242432,17.148532867431641,-18.702125549316406"> </Bone> </Part> </Brick> <Brick refID="205" designID="44294" itemNos="4185111"> <Part refID="205" designID="44294" materials="26"> <Bone refID="223" transformation="0.9999697208404541,-0.0077742789871990681,0,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,0,6.395066884579137E-005,1,2.1119503974914551,17.148788452148437,-14.70212459564209"> </Bone> </Part> </Brick> <Brick refID="206" designID="32039" itemNos="4107081"> <Part refID="206" designID="32039" materials="26"> <Bone refID="224" transformation="-0.9999697208404541,0.0077742785215377808,0,0.00777428038418293,0.99996984004974365,-6.3948740717023611E-005,0,-6.3950676121748984E-005,-1,2.1119499206542969,17.148736953735352,-15.502124786376953"> </Bone> </Part> </Brick> <Brick refID="207" designID="3706" itemNos="370626"> <Part refID="207" designID="3706" materials="26"> <Bone refID="225" transformation="0,6.3951105403248221E-005,1,0.0077204401604831219,0.99997025728225708,-6.3949199102353305E-005,-0.99997013807296753,0.0077204392291605473,0,1.7119631767272949,17.151924133300781,-14.302126884460449"> </Bone> </Part> </Brick> <Brick refID="208" designID="6590" itemNos="4177421"> <Part refID="208" designID="6590" materials="26"> <Bone refID="226" transformation="0,6.3951010815799236E-005,1,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,-0.9999697208404541,0.0077742789871990681,0,4.9118671417236328,17.127218246459961,-14.302126884460449"> </Bone> </Part> </Brick> <Brick refID="209" designID="6590" itemNos="4177421"> <Part refID="209" designID="6590" materials="26"> <Bone refID="227" transformation="0,6.3951010815799236E-005,1,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,-0.9999697208404541,0.0077742789871990681,0,2.5119392871856689,17.145748138427734,-14.302127838134766"> </Bone> </Part> </Brick> <Brick refID="210" designID="32039" itemNos="4107081"> <Part refID="210" designID="32039" materials="26"> <Bone refID="228" transformation="-0.99996978044509888,0.0077665774151682854,0,0.0077665792778134346,0.99996989965438843,-6.3948747992981225E-005,0,-6.3950676121748984E-005,-1,6.1118297576904297,17.117795944213867,-15.502126693725586"> </Bone> </Part> </Brick> <Brick refID="211" designID="44294" itemNos="4185111"> <Part refID="211" designID="44294" materials="26"> <Bone refID="229" transformation="0.9999697208404541,-0.0077742789871990681,0,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,0,6.395066884579137E-005,1,6.1118292808532715,17.11756706237793,-14.70212459564209"> </Bone> </Part> </Brick> <Brick refID="212" designID="6590" itemNos="4177421"> <Part refID="212" designID="6590" materials="26"> <Bone refID="230" transformation="0.9999697208404541,-0.0077742789871990681,0,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,0,6.395066884579137E-005,1,6.1118268966674805,17.117311477661133,-18.702123641967773"> </Bone> </Part> </Brick> <Brick refID="213" designID="6590" itemNos="4177421"> <Part refID="213" designID="6590" materials="26"> <Bone refID="231" transformation="0.9999697208404541,-0.0077742789871990681,0,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,0,6.395066884579137E-005,1,6.1118288040161133,17.117515563964844,-15.502124786376953"> </Bone> </Part> </Brick> <Brick refID="214" designID="32138" itemNos="4119589"> <Part refID="214" designID="32138" materials="26"> <Bone refID="232" transformation="0.99999994039535522,0,0,0,1,-6.3950908952392638E-005,0,6.3950865296646953E-005,1,5.711970329284668,15.917510032653809,-18.301433563232422"> </Bone> </Part> </Brick> <Brick refID="215" designID="32138" itemNos="4119589"> <Part refID="215" designID="32138" materials="26"> <Bone refID="233" transformation="0.9999697208404541,-0.0077742049470543861,0,0.0077742068096995354,0.99996984004974365,-6.3948944443836808E-005,0,6.3950865296646953E-005,1,5.7025413513183594,15.920814514160156,-16.70134162902832"> </Bone> </Part> </Brick> <Brick refID="216" designID="32140" itemNos="4120017"> <Part refID="216" designID="32140" materials="26"> <Bone refID="234" transformation="-0.9999697208404541,0.0077731986530125141,0,0,6.3950865296646953E-005,1,0.0077732005156576633,0.99996984004974365,-6.3948944443836808E-005,7.3087124824523926,16.708354949951172,-16.701391220092773"> </Bone> </Part> </Brick> <Brick refID="217" designID="32062" itemNos="4109810"> <Part refID="217" designID="32062" materials="26"> <Bone refID="235" transformation="0.99996966123580933,-0.0077855959534645081,0,0,-6.3950865296646953E-005,-1,0.0077855964191257954,0.9999697208404541,-6.3948937167879194E-005,7.3087143898010254,16.708356857299805,-16.701391220092773"> </Bone> </Part> </Brick> <Brick refID="218" designID="32184" itemNos="4121667"> <Part refID="218" designID="32184" materials="26"> <Bone refID="236" transformation="-7.6614094723481685E-005,6.3950865296646953E-005,1,-0.9999697208404541,0.007774141151458025,-7.7696749940514565E-005,-0.007774153258651495,-0.99996984004974365,6.3948944443836808E-005,7.2963967323303223,15.108304023742676,-18.301288604736328"> </Bone> </Part> </Brick> <Brick refID="219" designID="43093" itemNos="4168884"> <Part refID="219" designID="43093" materials="26"> <Bone refID="237" transformation="0.9999697208404541,-0.0077733946964144707,0,0,6.3950865296646953E-005,1,-0.0077733956277370453,-0.99996984004974365,6.3948944443836808E-005,7.2963967323303223,15.108304023742676,-18.301288604736328"> </Bone> </Part> </Brick> <Brick refID="220" designID="93571" itemNos="4610948"> <Part refID="220" designID="93571" materials="26"> <Bone refID="238" transformation="0.0079557802528142929,0.99996840953826904,-6.3948857132345438E-005,-7.713138620601967E-005,6.3950865296646953E-005,1,0.99996829032897949,-0.0079557737335562706,7.8127362939994782E-005,6.0993356704711914,15.517616271972656,-17.501405715942383"> </Bone> </Part> </Brick> <Brick refID="221" designID="32062" itemNos="4109810"> <Part refID="221" designID="32062" materials="26"> <Bone refID="239" transformation="-7.7102675277274102E-005,6.3950865296646953E-005,1,0.0079602347686886787,0.99996829032897949,-6.3948849856387824E-005,-0.99996829032897949,0.0079602301120758057,-7.8099379607010633E-005,6.1057000160217285,16.317590713500977,-17.501455307006836"> </Bone> </Part> </Brick> <Brick refID="222" designID="6536" itemNos="653626"> <Part refID="222" designID="6536" materials="26"> <Bone refID="240" transformation="0,-6.3950865296646953E-005,-1,0.0077302847057580948,0.9999701976776123,-6.3948966271709651E-005,0.99997007846832275,-0.0077302842400968075,0,7.7057337760925293,16.30518913269043,-17.501359939575195"> </Bone> </Part> </Brick> <Brick refID="223" designID="32073" itemNos="4114740"> <Part refID="223" designID="32073" materials="26"> <Bone refID="241" transformation="-7.7017386502120644E-005,6.3950865296646953E-005,1,0.0079728281125426292,0.99996829032897949,-6.3948849856387824E-005,-0.99996817111968994,0.0079728215932846069,-7.8014854807406664E-005,2.1058275699615479,16.349411010742188,-17.501768112182617"> </Bone> </Part> </Brick> <Brick refID="224" designID="93571" itemNos="4610948"> <Part refID="224" designID="93571" materials="26"> <Bone refID="242" transformation="0.0079557802528142929,0.99996840953826904,-6.3948857132345438E-005,-7.7131415309850127E-005,6.3950865296646953E-005,1,0.99996829032897949,-0.0079557755962014198,7.8127355664037168E-005,2.099606990814209,15.548371315002441,-17.501899719238281"> </Bone> </Part> </Brick> <Brick refID="225" designID="32062" itemNos="4109810"> <Part refID="225" designID="32062" materials="26"> <Bone refID="243" transformation="-7.7102697105146945E-005,6.3950865296646953E-005,1,0.0079602347686886787,0.99996840953826904,-6.3948857132345438E-005,-0.99996829032897949,0.0079602301120758057,-7.8099343227222562E-005,0.50602281093597412,16.361080169677734,-17.502073287963867"> </Bone> </Part> </Brick> <Brick refID="226" designID="6536" itemNos="653626"> <Part refID="226" designID="6536" materials="26"> <Bone refID="244" transformation="0,-6.3950865296646953E-005,-1,0.0077302842400968075,0.9999701976776123,-6.3948966271709651E-005,0.99997007846832275,-0.0077302847057580948,0,1.3060004711151123,16.354896545410156,-17.502073287963867"> </Bone> </Part> </Brick> <Brick refID="227" designID="32039" itemNos="4107081"> <Part refID="227" designID="32039" materials="26"> <Bone refID="245" transformation="-0.99997025728225708,0.0077049387618899345,0,0,6.3906838477123529E-005,1,0.0077049406245350838,0.99997037649154663,-6.3905528804752976E-005,4.1211376190185547,18.333366394042969,-14.302203178405762"> </Bone> </Part> </Brick> <Brick refID="228" designID="32062" itemNos="4109810"> <Part refID="228" designID="32062" materials="26"> <Bone refID="246" transformation="0,6.3915402279235423E-005,1,0.99997031688690186,-0.0076971990056335926,0,0.0076972008682787418,0.99997043609619141,-6.3913525082170963E-005,4.1273016929626465,19.133342742919922,-14.302253723144531"> </Bone> </Part> </Brick> <Brick refID="229" designID="6538" itemNos="4107083"> <Part refID="229" designID="6538" materials="26"> <Bone refID="247" transformation="0.9999699592590332,-0.0077435239218175411,0,0,6.3889019656926394E-005,1,-0.0077435257844626904,-0.99997007846832275,6.3887106080073863E-005,4.1211419105529785,18.333366394042969,-14.302202224731445"> </Bone> </Part> </Brick> <Brick refID="230" designID="32062" itemNos="4109810"> <Part refID="230" designID="32062" materials="26"> <Bone refID="248" transformation="0.9999699592590332,-0.0077435239218175411,0,0,6.3889019656926394E-005,1,-0.0077435257844626904,-0.99997007846832275,6.3887106080073863E-005,4.1273369789123535,19.133342742919922,-14.302253723144531"> </Bone> </Part> </Brick> <Brick refID="231" designID="6538" itemNos="4107083"> <Part refID="231" designID="6538" materials="26"> <Bone refID="249" transformation="0.9999699592590332,-0.0077435239218175411,0,0,6.3889019656926394E-005,1,-0.0077435257844626904,-0.99997007846832275,6.3887106080073863E-005,4.1335320472717285,19.933317184448242,-14.302305221557617"> </Bone> </Part> </Brick> <Brick refID="232" designID="44294" itemNos="4185111"> <Part refID="232" designID="44294" materials="26"> <Bone refID="250" transformation="0,6.3984414737205952E-005,1,0.99997037649154663,-0.0076973168179392815,0,0.0076973172836005688,0.99997043609619141,-6.3982530264183879E-005,4.1830778121948242,26.3331298828125,-14.302714347839355"> </Bone> </Part> </Brick> <Brick refID="233" designID="32054" itemNos="4107742"> <Part refID="233" designID="32054" materials="26"> <Bone refID="251" transformation="0,6.3932937337085605E-005,1,0.99997055530548096,-0.0076663224026560783,0,0.0076663242653012276,0.99997067451477051,-6.3931074691936374E-005,4.1953434944152832,27.933082580566406,-14.302816390991211"> </Bone> </Part> </Brick> <Brick refID="234" designID="6143" itemNos="614326"> <Part refID="234" designID="6143" materials="26"> <Bone refID="252" transformation="-0.99997055530548096,0.007666365709155798,0,-0.0076663675718009472,-0.99997067451477051,6.3992680225055665E-005,0,6.3994535594247282E-005,1,4.5781478881835937,25.690109252929688,-13.902673721313477"> </Bone> </Part> </Brick> <Brick refID="235" designID="6143" itemNos="614326"> <Part refID="235" designID="6143" materials="26"> <Bone refID="253" transformation="-0.99997055530548096,0.007666365709155798,0,-0.0076663675718009472,-0.99997067451477051,6.3992672949098051E-005,0,6.3994535594247282E-005,1,4.5707879066467285,24.730136871337891,-13.90261173248291"> </Bone> </Part> </Brick> <Brick refID="236" designID="6143" itemNos="614326"> <Part refID="236" designID="6143" materials="26"> <Bone refID="254" transformation="-0.99997055530548096,0.007666365709155798,0,-0.0076663675718009472,-0.99997067451477051,6.3992672949098051E-005,0,6.3994535594247282E-005,1,4.5633974075317383,23.770164489746094,-13.90255069732666"> </Bone> </Part> </Brick> <Brick refID="237" designID="6590" itemNos="4177421"> <Part refID="237" designID="6590" materials="26"> <Bone refID="255" transformation="0,6.3984436565078795E-005,1,0.99997049570083618,-0.0076739336363971233,0,0.0076739354990422726,0.99997061491012573,-6.398256664397195E-005,4.1522884368896484,22.333248138427734,-14.302458763122559"> </Bone> </Part> </Brick> <Brick refID="238" designID="32138" itemNos="4119589"> <Part refID="238" designID="32138" materials="26"> <Bone refID="256" transformation="0.9999697208404541,-0.0077742789871990681,0,0.0077742808498442173,0.99996984004974365,-6.3948944443836808E-005,0,6.3950865296646953E-005,1,1.7026324272155762,15.951704978942871,-18.30204963684082"> </Bone> </Part> </Brick> <Brick refID="239" designID="32524" itemNos="3252426"> <Part refID="239" designID="32524" materials="26"> <Bone refID="257" transformation="0.9999697208404541,-0.0077742789871990681,0,0,-6.3907158619258553E-005,-1,0.0077742808498442173,0.99996984004974365,-6.3905230490490794E-005,1.7088519334793091,16.751680374145508,-18.302101135253906"> </Bone> </Part> </Brick> <Brick refID="240" designID="32138" itemNos="4119589"> <Part refID="240" designID="32138" materials="26"> <Bone refID="258" transformation="0.99996978044509888,-0.0077665336430072784,0,0.0077665355056524277,0.99996989965438843,-6.388713518390432E-005,0,6.3889056036714464E-005,1,1.7026518583297729,15.951807975769043,-16.702049255371094"> </Bone> </Part> </Brick> <Brick refID="241" designID="32140" itemNos="4120017"> <Part refID="241" designID="32140" materials="26"> <Bone refID="259" transformation="0.99996912479400635,-0.0078599806874990463,0,0,6.3950865296646953E-005,1,-0.0078599816188216209,-0.99996918439865112,6.3948900788091123E-005,0.90265810489654541,15.958088874816895,-16.702053070068359"> </Bone> </Part> </Brick> <Brick refID="242" designID="32062" itemNos="4109810"> <Part refID="242" designID="32062" materials="26"> <Bone refID="260" transformation="0.9999697208404541,-0.0077857188880443573,0,0,-6.3950865296646953E-005,-1,0.0077857198193669319,0.9999697208404541,-6.3948937167879194E-005,0.90886890888214111,16.758062362670898,-16.70210075378418"> </Bone> </Part> </Brick> <Brick refID="243" designID="32184" itemNos="4121667"> <Part refID="243" designID="32184" materials="26"> <Bone refID="261" transformation="-0.00014808807463850826,6.3950865296646953E-005,1,0.99996989965438843,-0.0077615352347493172,0.00014919023669790477,0.0077615510672330856,0.9999699592590332,-6.3948951719794422E-005,0.90289759635925293,15.957984924316406,-18.302051544189453"> </Bone> </Part> </Brick> <Brick refID="244" designID="43093" itemNos="4168884"> <Part refID="244" designID="43093" materials="26"> <Bone refID="262" transformation="0.99997007846832275,-0.0077365199103951454,0,0,6.3950865296646953E-005,1,-0.0077365217730402946,-0.99997013807296753,6.3948966271709651E-005,0.8967244029045105,15.158010482788086,-18.301996231079102"> </Bone> </Part> </Brick> <Brick refID="245" designID="6590" itemNos="4177421"> <Part refID="245" designID="6590" materials="26"> <Bone refID="263" transformation="0.99996978044509888,-0.0077742794528603554,0,0.0077742808498442173,0.99996984004974365,-6.3948740717023611E-005,0,6.395066884579137E-005,1,2.1119499206542969,17.148736953735352,-15.502124786376953"> </Bone> </Part> </Brick> <Brick refID="246" designID="6590" itemNos="4177421"> <Part refID="246" designID="6590" materials="26"> <Bone refID="264" transformation="1,0,0,0,1,0,0,0,1,2.111947774887085,17.148481369018555,-19.502124786376953"> </Bone> </Part> </Brick> <Brick refID="247" designID="6590" itemNos="4177421"> <Part refID="247" designID="6590" materials="26"> <Bone refID="265" transformation="1,0,0,0,1,0,0,0,1,6.1118268966674805,17.117259979248047,-19.502124786376953"> </Bone> </Part> </Brick> <Brick refID="248" designID="32524" itemNos="3252426"> <Part refID="248" designID="32524" materials="26"> <Bone refID="266" transformation="0,6.3950865296646953E-005,1,0.99996984004974365,-0.0077665788121521473,0,0.0077665788121521473,0.99996984004974365,-6.3948937167879194E-005,1.721290111541748,18.351530075073242,-19.902202606201172"> </Bone> </Part> </Brick> <Brick refID="249" designID="43093" itemNos="4168884"> <Part refID="249" designID="43093" materials="26"> <Bone refID="267" transformation="-0.9999699592590332,0.0077512413263320923,0,0,6.3950879848562181E-005,1,0.0077512422576546669,0.99997007846832275,-6.3948937167879194E-005,1.7274799346923828,19.151655197143555,-17.502260208129883"> </Bone> </Part> </Brick> <Brick refID="250" designID="6538" itemNos="4107083"> <Part refID="250" designID="6538" materials="26"> <Bone refID="268" transformation="0.99997001886367798,-0.0077358949929475784,0,0,6.3950879848562181E-005,1,-0.007735895924270153,-0.99997013807296753,6.3948944443836808E-005,1.7212790250778198,18.351678848266602,-17.502208709716797"> </Bone> </Part> </Brick> <Brick refID="251" designID="32062" itemNos="4109810"> <Part refID="251" designID="32062" materials="26"> <Bone refID="269" transformation="-0.99997001886367798,0.0077359387651085854,0,0,6.3950879848562181E-005,1,0.00773593969643116,0.99997013807296753,-6.3948944443836808E-005,1.7398451566696167,20.751607894897461,-17.502361297607422"> </Bone> </Part> </Brick> <Brick refID="252" designID="6538" itemNos="4107083"> <Part refID="252" designID="6538" materials="26"> <Bone refID="270" transformation="0,-6.3950879848562181E-005,-1,-0.9999699592590332,0.0077435215935111046,0,0.0077435225248336792,0.99997007846832275,-6.3948937167879194E-005,1.7460399866104126,21.551584243774414,-17.502410888671875"> </Bone> </Part> </Brick> <Brick refID="253" designID="32062" itemNos="4109810"> <Part refID="253" designID="32062" materials="26"> <Bone refID="271" transformation="0.99997001886367798,-0.0077358954586088657,0,0,6.3950879848562181E-005,1,-0.0077358963899314404,-0.99997013807296753,6.3948944443836808E-005,1.7398451566696167,20.751607894897461,-17.502361297607422"> </Bone> </Part> </Brick> <Brick refID="254" designID="6538" itemNos="4107083"> <Part refID="254" designID="6538" materials="26"> <Bone refID="272" transformation="0,-6.3950879848562181E-005,-1,-0.99997013807296753,0.0077204424887895584,0,0.007720443420112133,0.99997025728225708,-6.3948951719794422E-005,1.7583990097045898,23.151535034179688,-17.502513885498047"> </Bone> </Part> </Brick> <Brick refID="255" designID="32073" itemNos="4114740"> <Part refID="255" designID="32073" materials="26"> <Bone refID="273" transformation="0.9999701976776123,-0.0077127697877585888,0,0,6.3950879848562181E-005,1,-0.0077127707190811634,-0.99997031688690186,6.3948958995752037E-005,1.7522226572036743,22.351558685302734,-17.502462387084961"> </Bone> </Part> </Brick> <Brick refID="256" designID="6553" itemNos="4107765"> <Part refID="256" designID="6553" materials="26"> <Bone refID="274" transformation="-0.0077204424887895584,-0.99997025728225708,6.3948951719794422E-005,0,6.3950879848562181E-005,1,-0.99997013807296753,0.007720443420112133,0,-0.22612512111663818,25.166919708251953,-17.502639770507813"> </Bone> </Part> </Brick> <Brick refID="257" designID="4019" itemNos="401926"> <Part refID="257" designID="4019" materials="26"> <Bone refID="275" transformation="-7.6288342825137079E-005,6.3950879848562181E-005,1,0.0079332040622830391,0.99996858835220337,-6.3948849856387824E-005,-0.99996846914291382,0.0079331975430250168,-7.7292344940360636E-005,0.20386271178722382,25.163599014282227,-17.502639770507813"> </Bone> </Part> </Brick> <Brick refID="258" designID="32123" itemNos="4270046"> <Part refID="258" designID="32123" materials="26"> <Bone refID="276" transformation="0,6.3950879848562181E-005,1,0.0076738917268812656,0.99997061491012573,-6.3948973547667265E-005,-0.99997049570083618,0.007673890795558691,0,-0.22612512111663818,25.166919708251953,-17.502639770507813"> </Bone> </Part> </Brick> <Brick refID="259" designID="43093" itemNos="4168884"> <Part refID="259" designID="43093" materials="26"> <Bone refID="277" transformation="-7.6354117481969297E-005,9.2488429800141603E-005,1,0.007963213138282299,0.99996829032897949,-9.1770285507664084E-005,-0.99996823072433472,0.0079632038250565529,-7.7584263635799289E-005,2.1825487613677979,25.949066162109375,-17.502378463745117"> </Bone> </Part> </Brick> <Brick refID="260" designID="32039" itemNos="4107081"> <Part refID="260" designID="32039" materials="26"> <Bone refID="278" transformation="-0.0079558230936527252,-0.99996834993362427,9.1814545157831162E-005,7.6274634920991957E-005,-9.2531474365387112E-005,-1,0.99996829032897949,-0.0079558119177818298,7.7504446380771697E-005,2.9825232028961182,25.942695617675781,-17.502317428588867"> </Bone> </Part> </Brick> <Brick refID="261" designID="32278" itemNos="4128603"> <Part refID="261" designID="32278" materials="26"> <Bone refID="279" transformation="-0.0079917227849364281,-0.99996805191040039,6.3948806200642139E-005,-7.6774405897594988E-005,6.4568390371277928E-005,1,-0.99996811151504517,0.0079917199909687042,-7.7784628956578672E-005,2.9889171123504639,26.742692947387695,-17.502363204956055"> </Bone> </Part> </Brick> <Brick refID="262" designID="32184" itemNos="4121667"> <Part refID="262" designID="32184" materials="26"> <Bone refID="280" transformation="0.999969482421875,-0.0078092524781823158,0,0,6.3514758949168026E-005,1,-0.0078092543408274651,-0.999969482421875,6.3507017330266535E-005,3.2963337898254395,15.139372825622559,-18.301998138427734"> </Bone> </Part> </Brick> <Brick refID="263" designID="43093" itemNos="4168884"> <Part refID="263" designID="43093" materials="26"> <Bone refID="281" transformation="0.9999697208404541,-0.00779371103271842,0,0,6.3712206610944122E-005,1,-0.0077937119640409946,-0.9999697208404541,6.370451592374593E-005,4.8962850570678711,15.12687873840332,-18.301996231079102"> </Bone> </Part> </Brick> <Brick refID="264" designID="43093" itemNos="4168884"> <Part refID="264" designID="43093" materials="26"> <Bone refID="282" transformation="0.9999699592590332,-0.0077629568986594677,0,0,6.3930958276614547E-005,1,-0.0077629568986594677,-0.99996984004974365,6.3923282141331583E-005,3.2963826656341553,15.139286994934082,-18.301996231079102"> </Bone> </Part> </Brick> <Brick refID="265" designID="42003" itemNos="4173970"> <Part refID="265" designID="42003" materials="26"> <Bone refID="283" transformation="-0.0079917237162590027,-0.99996805191040039,6.3948806200642139E-005,-7.6774405897594988E-005,6.4568390371277928E-005,1,-0.99996811151504517,0.0079917209222912788,-7.7784628956578672E-005,3.7121703624725342,17.136627197265625,-17.501703262329102"> </Bone> </Part> </Brick> <Brick refID="266" designID="43093" itemNos="4168884"> <Part refID="266" designID="43093" materials="26"> <Bone refID="284" transformation="0.99996811151504517,-0.007991706021130085,0,-0.0079917041584849358,-0.99996805191040039,6.3948806200642139E-005,0,-6.4568390371277928E-005,-1,4.0994019508361816,15.533456802368164,-17.901571273803711"> </Bone> </Part> </Brick> <Brick refID="267" designID="32278" itemNos="4128603"> <Part refID="267" designID="32278" materials="26"> <Bone refID="285" transformation="-0.0079917227849364281,-0.99996805191040039,6.3948806200642139E-005,-7.6774405897594988E-005,6.4568390371277928E-005,1,-0.99996811151504517,0.0079917199909687042,-7.7784628956578672E-005,4.5888662338256836,26.729938507080078,-17.502241134643555"> </Bone> </Part> </Brick> <Brick refID="268" designID="32524" itemNos="3252426"> <Part refID="268" designID="32524" materials="26"> <Bone refID="286" transformation="0,6.3950879848562181E-005,1,0.9999699592590332,-0.0077665806747972965,0,0.0077665788121521473,0.99996984004974365,-6.394892989192158E-005,6.5211753845214844,18.314319610595703,-19.901500701904297"> </Bone> </Part> </Brick> <Brick refID="269" designID="43093" itemNos="4168884"> <Part refID="269" designID="43093" materials="26"> <Bone refID="287" transformation="-0.99997007846832275,0.0077512431889772415,0,0,6.3950887124519795E-005,1,0.0077512413263320923,0.9999699592590332,-6.3948922615963966E-005,6.5273652076721191,19.114442825317383,-17.501552581787109"> </Bone> </Part> </Brick> <Brick refID="270" designID="6538" itemNos="4107083"> <Part refID="270" designID="6538" materials="26"> <Bone refID="288" transformation="0.99997013807296753,-0.0077358963899314404,0,0,6.3950879848562181E-005,1,-0.0077358954586088657,-0.99997001886367798,6.394892989192158E-005,6.5211644172668457,18.31446647644043,-17.501501083374023"> </Bone> </Part> </Brick> <Brick refID="271" designID="32062" itemNos="4109810"> <Part refID="271" designID="32062" materials="26"> <Bone refID="289" transformation="-0.99997013807296753,0.0077359401620924473,0,0,6.3950879848562181E-005,1,0.007735938299447298,0.99997001886367798,-6.394892989192158E-005,6.5397305488586426,20.714395523071289,-17.501653671264648"> </Bone> </Part> </Brick> <Brick refID="272" designID="6538" itemNos="4107083"> <Part refID="272" designID="6538" materials="26"> <Bone refID="290" transformation="0,-6.3950879848562181E-005,-1,-0.99997013807296753,0.0077358223497867584,0,0.0077358204871416092,0.99997001886367798,-6.394892989192158E-005,6.5459194183349609,21.514371871948242,-17.501703262329102"> </Bone> </Part> </Brick> <Brick refID="273" designID="32062" itemNos="4109810"> <Part refID="273" designID="32062" materials="26"> <Bone refID="291" transformation="0.9999701976776123,-0.0077282674610614777,0,0,6.3950879848562181E-005,1,-0.007728266529738903,-0.99997007846832275,6.3948937167879194E-005,6.5397310256958008,20.714395523071289,-17.501653671264648"> </Bone> </Part> </Brick> <Brick refID="274" designID="6538" itemNos="4107083"> <Part refID="274" designID="6538" materials="26"> <Bone refID="292" transformation="0,-6.3950879848562181E-005,-1,-0.99997025728225708,0.0077204438857734203,0,0.0077204420231282711,0.99997013807296753,-6.3948944443836808E-005,6.5582728385925293,23.114322662353516,-17.501806259155273"> </Bone> </Part> </Brick> <Brick refID="275" designID="32073" itemNos="4114740"> <Part refID="275" designID="32073" materials="26"> <Bone refID="293" transformation="0.99997031688690186,-0.0077127711847424507,0,0,6.3950879848562181E-005,1,-0.0077127693220973015,-0.9999701976776123,6.3948944443836808E-005,6.5520963668823242,22.314348220825195,-17.501754760742188"> </Bone> </Part> </Brick> <Brick refID="276" designID="6553" itemNos="4107765"> <Part refID="276" designID="6553" materials="26"> <Bone refID="294" transformation="-0.0077127255499362946,-0.9999701976776123,6.3948944443836808E-005,0,-6.3950879848562181E-005,-1,0.99997031688690186,-0.0077127274125814438,0,8.5736331939697266,25.098838806152344,-17.501930236816406"> </Bone> </Part> </Brick> <Brick refID="277" designID="4019" itemNos="401926"> <Part refID="277" designID="4019" materials="26"> <Bone refID="295" transformation="-7.6287768024485558E-005,6.3950879848562181E-005,1,0.0079332021996378899,0.99996846914291382,-6.3948835304472595E-005,-0.99996858835220337,0.007933199405670166,-7.7291777415666729E-005,7.3736677169799805,25.10809326171875,-17.501928329467773"> </Bone> </Part> </Brick> <Brick refID="278" designID="32123" itemNos="4270046"> <Part refID="278" designID="32123" materials="26"> <Bone refID="296" transformation="0,6.3950879848562181E-005,1,0.007681775838136673,0.99997043609619141,-6.3948958995752037E-005,-0.99997055530548096,0.0076817777007818222,0,8.17364501953125,25.101922988891602,-17.501930236816406"> </Bone> </Part> </Brick> <Brick refID="279" designID="43093" itemNos="4168884"> <Part refID="279" designID="43093" materials="26"> <Bone refID="297" transformation="7.6353193435352296E-005,-9.2488779046107084E-005,-1,0.0079632019624114037,0.99996823072433472,-9.1770627477671951E-005,0.99996834993362427,-0.0079631935805082321,7.7583332313224673E-005,6.1824216842651367,25.917215347290039,-17.502071380615234"> </Bone> </Part> </Brick> <Brick refID="280" designID="32039" itemNos="4107081"> <Part refID="280" designID="32039" materials="26"> <Bone refID="298" transformation="-0.0079558230936527252,-0.99996846914291382,9.1727473773062229E-005,-7.6273936429060996E-005,9.2444402980618179E-005,1,-0.99996840953826904,0.0079558119177818298,-7.7503049396909773E-005,5.3824467658996582,25.923585891723633,-17.502130508422852"> </Bone> </Part> </Brick> <Brick refID="281" designID="41239" itemNos="4164422"> <Part refID="281" designID="41239" materials="26"> <Bone refID="299" transformation="-0.0067561478354036808,-0.70709031820297241,0.70709091424942017,0.00010351972741773352,0.70710659027099609,0.70710694789886475,-0.99997717142105103,0.0048505170270800591,-0.0047041187062859535,3.6818888187408447,13.833662033081055,-15.817666053771973"> </Bone> </Part> </Brick> <Brick refID="282" designID="32291" itemNos="4140430"> <Part refID="282" designID="32291" materials="26"> <Bone refID="300" transformation="0.99997681379318237,-0.004902274813503027,0.0047543682157993317,0.0068282773718237877,0.70709061622619629,-0.70709007978439331,0.00010458358883624896,0.70710623264312744,0.70710748434066772,5.2224979400634766,7.8861241340637207,-9.3046731948852539"> </Bone> </Part> </Brick> <Brick refID="283" designID="32073" itemNos="4114740"> <Part refID="283" designID="32073" materials="26"> <Bone refID="301" transformation="0.00010474187001818791,0.70710670948028564,0.70710700750350952,0.0068282517604529858,0.70709025859832764,-0.70709061622619629,-0.99997681379318237,0.0049023674800992012,-0.0047542429529130459,2.0279886722564697,8.1846437454223633,-10.168402671813965"> </Bone> </Part> </Brick> <Brick refID="284" designID="32291" itemNos="4140430"> <Part refID="284" designID="32291" materials="26"> <Bone refID="302" transformation="0.99997681379318237,-0.0049022352322936058,0.0047544683329761028,0.0068283160217106342,0.70709025859832764,-0.70709031820297241,0.00010448664397699758,0.70710653066635132,0.70710718631744385,2.0225696563720703,7.9018125534057617,-9.3198871612548828"> </Bone> </Part> </Brick> <Brick refID="285" designID="32184" itemNos="4121667"> <Part refID="285" designID="32184" materials="26"> <Bone refID="303" transformation="-0.0068282503634691238,-0.70709025859832764,0.70709043741226196,0.00010467103129485622,0.70710659027099609,0.70710712671279907,-0.99997681379318237,0.0049023162573575974,-0.0047542895190417767,2.8388965129852295,9.3120660781860352,-11.295944213867188"> </Bone> </Part> </Brick> <Brick refID="286" designID="32073" itemNos="4114740"> <Part refID="286" designID="32073" materials="26"> <Bone refID="304" transformation="0.00010473903967067599,0.70710641145706177,0.7071073055267334,0.0068175988271832466,0.70709049701690674,-0.70709031820297241,-0.99997687339782715,0.0048948349431157112,-0.0047467099502682686,2.0389142036437988,9.3159866333007813,-11.299746513366699"> </Bone> </Part> </Brick> <Brick refID="287" designID="32184" itemNos="4121667"> <Part refID="287" designID="32184" materials="26"> <Bone refID="305" transformation="-0.0068282489664852619,-0.70709019899368286,0.70709037780761719,0.00010467162064742297,0.70710659027099609,0.70710712671279907,-0.99997669458389282,0.0049023162573575974,-0.0047542895190417767,4.4388594627380371,9.3042230606079102,-11.288337707519531"> </Bone> </Part> </Brick> <Brick refID="288" designID="6575" itemNos="4144134"> <Part refID="288" designID="6575" materials="1"> <Bone refID="306" transformation="-0.0068264571018517017,-0.70709043741226196,0.70709019899368286,0.00010466980893397704,0.70710629224777222,0.70710742473602295,-0.99997669458389282,0.0049010477960109711,-0.0047530201263725758,2.0498380661010742,10.447333335876465,-12.43109130859375"> </Bone> </Part> </Brick> <Brick refID="289" designID="32062" itemNos="4109810"> <Part refID="289" designID="32062" materials="26"> <Bone refID="307" transformation="0.00010473991278558969,0.70710635185241699,0.70710736513137817,0.006826404482126236,0.70709043741226196,-0.70709013938903809,-0.99997669458389282,0.0049010599032044411,-0.0047529330477118492,1.2498571872711182,10.451255798339844,-12.434895515441895"> </Bone> </Part> </Brick> <Brick refID="290" designID="32249" itemNos="3224901"> <Part refID="290" designID="32249" materials="1"> <Bone refID="308" transformation="-0.00010463353828527033,-0.70710641145706177,-0.7071073055267334,0.0068176025524735451,0.70709043741226196,-0.70709025859832764,0.99997681379318237,-0.0048947632312774658,0.0047467853873968124,2.0500049591064453,11.578704833984375,-11.299721717834473"> </Bone> </Part> </Brick> <Brick refID="291" designID="44294" itemNos="4185111"> <Part refID="291" designID="44294" materials="26"> <Bone refID="309" transformation="0.00010468376422068104,0.70710623264312744,0.70710748434066772,0.0068088038824498653,0.70709067583084106,-0.70709025859832764,-0.99997687339782715,0.0048885769210755825,-0.0047405273653566837,1.2607656717300415,11.582586288452148,-13.566226959228516"> </Bone> </Part> </Brick> <Brick refID="292" designID="32291" itemNos="4140430"> <Part refID="292" designID="32291" materials="26"> <Bone refID="310" transformation="0.99997693300247192,-0.004882332868874073,0.0047344495542347431,0.00010460487101227045,0.70710611343383789,0.70710760354995728,-0.0068000508472323418,-0.70709091424942017,0.70708996057510376,5.2578682899475098,10.714509010314941,-13.830114364624023"> </Bone> </Part> </Brick> <Brick refID="293" designID="32291" itemNos="4140430"> <Part refID="293" designID="32291" materials="26"> <Bone refID="311" transformation="0.99997693300247192,-0.004882332868874073,0.0047344495542347431,0.00010460487101227045,0.70710611343383789,0.70710760354995728,-0.0068000508472323418,-0.70709091424942017,0.70708996057510376,2.0579428672790527,10.730154037475586,-13.845284461975098"> </Bone> </Part> </Brick> <Brick refID="294" designID="32249" itemNos="3224901"> <Part refID="294" designID="32249" materials="1"> <Bone refID="312" transformation="-0.00010463419312145561,-0.70710641145706177,-0.7071073055267334,0.0068176025524735451,0.70709043741226196,-0.70709025859832764,0.99997681379318237,-0.0048947627656161785,0.0047467849217355251,6.8498926162719727,11.555197715759277,-11.276926040649414"> </Bone> </Part> </Brick> <Brick refID="295" designID="32062" itemNos="4109810"> <Part refID="295" designID="32062" materials="26"> <Bone refID="313" transformation="0.00010473929432919249,0.70710635185241699,0.70710736513137817,0.0068264040164649487,0.70709049701690674,-0.70709019899368286,-0.9999767541885376,0.0049010603688657284,-0.0047529335133731365,5.249763011932373,10.431659698486328,-12.415892601013184"> </Bone> </Part> </Brick> <Brick refID="296" designID="32249" itemNos="3224901"> <Part refID="296" designID="32249" materials="1"> <Bone refID="314" transformation="-0.00010463457147125155,-0.70710641145706177,-0.7071073055267334,0.0068176020868122578,0.70709043741226196,-0.70709031820297241,0.99997681379318237,-0.0048947622999548912,0.0047467853873968124,6.4499025344848633,11.557158470153809,-11.278826713562012"> </Bone> </Part> </Brick> <Brick refID="297" designID="32062" itemNos="4109810"> <Part refID="297" designID="32062" materials="26"> <Bone refID="315" transformation="0.00011322450882289559,0.70710641145706177,0.7071073055267334,0.0068052643910050392,0.70709055662155151,-0.70709031820297241,-0.99997687339782715,0.0048921108245849609,-0.0047320420853793621,6.0499119758605957,11.559113502502441,-11.280723571777344"> </Bone> </Part> </Brick> <Brick refID="298" designID="32184" itemNos="3218401"> <Part refID="298" designID="32184" materials="1"> <Bone refID="316" transformation="-0.00011297862511128187,-0.70710635185241699,-0.70710736513137817,0.0067911026999354362,0.70709061622619629,-0.70709031820297241,0.9999769926071167,-0.0048819235526025295,0.0047222021967172623,7.6500554084777832,12.682656288146973,-10.141779899597168"> </Bone> </Part> </Brick> <Brick refID="299" designID="4519" itemNos="451926"> <Part refID="299" designID="4519" materials="26"> <Bone refID="317" transformation="0.00012129625247325748,0.70710623264312744,0.70710766315460205,0.0067790178582072258,0.70709067583084106,-0.70709049701690674,-0.99997717142105103,0.0048792618326842785,-0.0047077168710529804,5.2501111030578613,12.69437313079834,-10.153114318847656"> </Bone> </Part> </Brick> <Brick refID="300" designID="6590" itemNos="4198121"> <Part refID="300" designID="6590" materials="1"> <Bone refID="318" transformation="0.00012129532115068287,0.70710611343383789,0.70710760354995728,0.0067468904890120029,0.70709091424942017,-0.70709055662155151,-0.99997729063034058,0.0048565440811216831,-0.0046850000508129597,6.0500926971435547,12.690468788146973,-10.149348258972168"> </Bone> </Part> </Brick> <Brick refID="301" designID="6575" itemNos="4144134"> <Part refID="301" designID="6575" materials="1"> <Bone refID="319" transformation="-0.0068264571018517017,-0.70709043741226196,0.70709019899368286,0.00010466980893397704,0.70710629224777222,0.70710742473602295,-0.99997669458389282,0.0049010477960109711,-0.0047530201263725758,5.249763011932373,10.431671142578125,-12.415902137756348"> </Bone> </Part> </Brick> <Brick refID="302" designID="3706" itemNos="370626"> <Part refID="302" designID="3706" materials="26"> <Bone refID="320" transformation="0.00010473371366970241,0.70710587501525879,0.70710784196853638,0.0067911748774349689,0.70709115266799927,-0.70708978176116943,-0.99997693300247192,0.0048761484213173389,-0.0047280793078243732,1.6443862915039063,9.8836097717285156,-11.867310523986816"> </Bone> </Part> </Brick> <Brick refID="303" designID="32056" itemNos="4112287"> <Part refID="303" designID="32056" materials="26"> <Bone refID="321" transformation="0.0068090157583355904,0.70709115266799927,-0.70708972215652466,0.00010475167073309422,0.70710587501525879,0.70710784196853638,0.99997687339782715,-0.0048887771554291248,0.0047406833618879318,6.4332122802734375,7.5974879264831543,-11.844643592834473"> </Bone> </Part> </Brick> <Brick refID="304" designID="32056" itemNos="4112287"> <Part refID="304" designID="32056" materials="26"> <Bone refID="322" transformation="0.0068090143613517284,0.70709115266799927,-0.70708978176116943,0.00010475110320840031,0.70710587501525879,0.70710784196853638,0.99997681379318237,-0.0048887771554291248,0.0047406842932105064,2.0333139896392822,7.6189446449279785,-11.865447044372559"> </Bone> </Part> </Brick> <Brick refID="305" designID="6575" itemNos="4144134"> <Part refID="305" designID="6575" materials="1"> <Bone refID="323" transformation="-0.0068264571018517017,-0.70709043741226196,0.70709019899368286,0.0001046696343109943,0.70710635185241699,0.70710736513137817,-0.99997669458389282,0.0049010482616722584,-0.0047530201263725758,2.4498288631439209,10.445374488830566,-12.429191589355469"> </Bone> </Part> </Brick> <Brick refID="306" designID="6575" itemNos="4144134"> <Part refID="306" designID="6575" materials="1"> <Bone refID="324" transformation="-0.0068264571018517017,-0.70709043741226196,0.70709019899368286,0.00010466980893397704,0.70710629224777222,0.70710742473602295,-0.99997669458389282,0.0049010477960109711,-0.0047530201263725758,5.6497540473937988,10.429712295532227,-12.414004325866699"> </Bone> </Part> </Brick> <Brick refID="307" designID="32249" itemNos="3224901"> <Part refID="307" designID="32249" materials="1"> <Bone refID="325" transformation="-0.0001046338802552782,-0.70710641145706177,-0.7071073055267334,0.0068176025524735451,0.70709043741226196,-0.70709025859832764,0.99997681379318237,-0.0048947627656161785,0.0047467849217355251,1.6500155925750732,11.58066463470459,-11.30162239074707"> </Bone> </Part> </Brick> <Brick refID="308" designID="32062" itemNos="4109810"> <Part refID="308" designID="32062" materials="26"> <Bone refID="326" transformation="0.00011322450882289559,0.70710641145706177,0.7071073055267334,0.0068052643910050392,0.70709055662155151,-0.70709031820297241,-0.99997687339782715,0.0048921108245849609,-0.0047320420853793621,0.45004278421401978,11.586535453796387,-11.307316780090332"> </Bone> </Part> </Brick> <Brick refID="309" designID="32184" itemNos="3218401"> <Part refID="309" designID="32184" materials="1"> <Bone refID="327" transformation="0.00011297769378870726,0.70710623264312744,0.70710748434066772,0.0067910444922745228,0.70709073543548584,-0.70709019899368286,-0.9999769926071167,0.0048818835057318211,-0.0047221616841852665,0.45004326105117798,11.586535453796387,-11.307316780090332"> </Bone> </Part> </Brick> <Brick refID="310" designID="4519" itemNos="451926"> <Part refID="310" designID="4519" materials="26"> <Bone refID="328" transformation="0.00012137634621467441,0.70710605382919312,0.7071077823638916,0.0067789298482239246,0.70709079504013062,-0.70709037780761719,-0.99997717142105103,0.0048792576417326927,-0.0047075976617634296,0.45022442936897278,12.717904090881348,-10.175944328308105"> </Bone> </Part> </Brick> <Brick refID="311" designID="6590" itemNos="4198121"> <Part refID="311" designID="6590" materials="1"> <Bone refID="329" transformation="0.00012137497105868533,0.70710587501525879,0.70710784196853638,0.0067468886263668537,0.70709109306335449,-0.70709031820297241,-0.99997729063034058,0.0048566008917987347,-0.0046849413774907589,1.2502063512802124,12.71399974822998,-10.172178268432617"> </Bone> </Part> </Brick> <Brick refID="312" designID="6536" itemNos="653601"> <Part refID="312" designID="6536" materials="1"> <Bone refID="330" transformation="-0.00012759257515426725,-0.70708990097045898,-0.70712399482727051,0.0067850397899746895,0.70710694789886475,-0.70707416534423828,0.99997711181640625,-0.0048880814574658871,0.0047074118629097939,2.8501696586608887,12.706192970275879,-10.164646148681641"> </Bone> </Part> </Brick> <Brick refID="313" designID="6536" itemNos="653601"> <Part refID="313" designID="6536" materials="1"> <Bone refID="331" transformation="-0.0001319251605309546,-0.70708996057510376,-0.70712387561798096,0.0067893923260271549,0.70710676908493042,-0.70707422494888306,0.9999769926071167,-0.0048942230641841888,0.004707427229732275,6.0500926971435547,12.690470695495605,-10.149347305297852"> </Bone> </Part> </Brick> <Brick refID="314" designID="43093" itemNos="4168884"> <Part refID="314" designID="43093" materials="26"> <Bone refID="332" transformation="-0.99997681379318237,0.0049021723680198193,-0.0047543388791382313,0.0068281847052276134,0.7070888876914978,-0.70709162950515747,-0.00010454846051288769,-0.70710784196853638,-0.70710569620132446,2.0225307941436768,7.6189703941345215,-9.6027307510375977"> </Bone> </Part> </Brick> <Brick refID="315" designID="92907" itemNos="4610371"> <Part refID="315" designID="92907" materials="26"> <Bone refID="333" transformation="-0.00010448763350723311,-0.70710653066635132,-0.70710712671279907,0.0068282997235655785,0.70709025859832764,-0.70709025859832764,0.99997681379318237,-0.0049022221937775612,0.0047544557601213455,3.2170422077178955,7.0475559234619141,-9.0314950942993164"> </Bone> </Part> </Brick> <Brick refID="316" designID="43093" itemNos="4168884"> <Part refID="316" designID="43093" materials="26"> <Bone refID="334" transformation="-0.99997681379318237,0.0049021742306649685,-0.0047543398104608059,0.0068281828425824642,0.7070888876914978,-0.70709162950515747,-0.00010454818402649835,-0.70710790157318115,-0.70710575580596924,2.822512149810791,7.6150493621826172,-9.5989265441894531"> </Bone> </Part> </Brick> <Brick refID="317" designID="43093" itemNos="4168884"> <Part refID="317" designID="43093" materials="26"> <Bone refID="335" transformation="0.99997669458389282,-0.0049021649174392223,0.0047544706612825394,0.0068282694555819035,0.70709031820297241,-0.70709037780761719,0.00010443651990499347,0.70710670948028564,0.70710718631744385,2.8225102424621582,7.6150507926940918,-9.5989274978637695"> </Bone> </Part> </Brick> <Brick refID="318" designID="43093" itemNos="4168884"> <Part refID="318" designID="43093" materials="26"> <Bone refID="336" transformation="0.99997669458389282,-0.0049021649174392223,0.0047544706612825394,0.0068282694555819035,0.70709031820297241,-0.70709037780761719,0.00010443646897329018,0.70710664987564087,0.70710700750350952,2.0225293636322021,7.6189718246459961,-9.6027317047119141"> </Bone> </Part> </Brick> <Brick refID="319" designID="32140" itemNos="4120017"> <Part refID="319" designID="32140" materials="26"> <Bone refID="337" transformation="0.0068282429128885269,0.70709019899368286,-0.70709031820297241,0.99997681379318237,-0.0049021979793906212,0.0047543961554765701,-0.00010451439447933808,-0.70710659027099609,-0.70710694789886475,2.0059752464294434,4.7905821800231934,-9.0370864868164062"> </Bone> </Part> </Brick> <Brick refID="320" designID="32062" itemNos="4109810"> <Part refID="320" designID="32062" materials="26"> <Bone refID="338" transformation="0.99997657537460327,-0.0049022175371646881,0.0047543058171868324,-0.0068281916901469231,-0.70709019899368286,0.70709031820297241,-0.00010459226905368268,-0.70710659027099609,-0.7071068286895752,2.0059750080108643,4.790583610534668,-9.0370874404907227"> </Bone> </Part> </Brick> <Brick refID="321" designID="93571" itemNos="4610948"> <Part refID="321" designID="93571" materials="26"> <Bone refID="339" transformation="-0.0068282554857432842,-0.70708966255187988,0.70709085464477539,0.99997657537460327,-0.0049023241735994816,0.0047542848624289036,0.00010468852269696072,0.70710700750350952,0.70710641145706177,2.0116050243377686,6.4876279830932617,-8.4713888168334961"> </Bone> </Part> </Brick> <Brick refID="322" designID="32062" itemNos="4109810"> <Part refID="322" designID="32062" materials="26"> <Bone refID="340" transformation="-0.99997657537460327,0.0049021737650036812,-0.0047542676329612732,0.0068281353451311588,0.70708894729614258,-0.7070915699005127,-0.00010459873010404408,-0.70710766315460205,-0.70710575580596924,2.0061426162719727,5.9219570159912109,-7.9057130813598633"> </Bone> </Part> </Brick> <Brick refID="323" designID="32140" itemNos="4120017"> <Part refID="323" designID="32140" materials="26"> <Bone refID="341" transformation="0.0068281744606792927,0.70708906650543213,-0.70709145069122314,0.99997657537460327,-0.0049022198654711246,0.0047542769461870193,-0.00010462443606229499,-0.7071075439453125,-0.70710587501525879,2.0062260627746582,6.487642765045166,-7.3400287628173828"> </Bone> </Part> </Brick> <Brick refID="324" designID="4519" itemNos="451926"> <Part refID="324" designID="4519" materials="26"> <Bone refID="342" transformation="0.00010470746929058805,0.70710629224777222,0.70710712671279907,0.0067646191455423832,0.70709055662155151,-0.70709037780761719,-0.9999769926071167,0.0048573478125035763,-0.0047092693857848644,0.00072649068897590041,5.3660874366760254,-7.3495502471923828"> </Bone> </Part> </Brick> <Brick refID="325" designID="32140" itemNos="4120017"> <Part refID="325" designID="32140" materials="26"> <Bone refID="343" transformation="0.0067561017349362373,0.70709049701690674,-0.70709049701690674,0.00010465608647791669,0.70710641145706177,0.70710700750350952,0.99997705221176147,-0.0048512881621718407,0.0047032823786139488,1.6006897687911987,5.3583154678344727,-7.3420157432556152"> </Bone> </Part> </Brick> <Brick refID="326" designID="32250" itemNos="4144132"> <Part refID="326" designID="32250" materials="1"> <Bone refID="344" transformation="0.0067114690318703651,0.70709055662155151,-0.70709127187728882,0.00012418739788699895,0.70710676908493042,0.70710694789886475,0.9999774694442749,-0.0048335385508835316,0.0046579712070524693,0.79537481069564819,4.7965273857116699,-6.7801089286804199"> </Bone> </Part> </Brick> <Brick refID="327" designID="43093" itemNos="4168884"> <Part refID="327" designID="43093" materials="26"> <Bone refID="345" transformation="0.00012416791287250817,0.70710664987564087,0.7071070671081543,0.0067025823518633842,0.70709091424942017,-0.70709115266799927,-0.99997752904891968,0.004827241413295269,-0.0046516992151737213,0.016869517043232918,7.0630826950073242,-9.0465278625488281"> </Bone> </Part> </Brick> <Brick refID="328" designID="32250" itemNos="4144132"> <Part refID="328" designID="32250" materials="1"> <Bone refID="346" transformation="0.0067114676348865032,0.70709049701690674,-0.70709127187728882,0.00012418544793035835,0.70710670948028564,0.70710688829421997,0.9999774694442749,-0.004833537619560957,0.0046579698100686073,0.39538455009460449,4.7984704971313477,-6.7819948196411133"> </Bone> </Part> </Brick> <Brick refID="329" designID="43093" itemNos="4168884"> <Part refID="329" designID="43093" materials="26"> <Bone refID="347" transformation="-0.99997681379318237,0.0049020731821656227,-0.0047543798573315144,0.0068281432613730431,0.7070891261100769,-0.70709139108657837,-0.00010444670624565333,-0.70710766315460205,-0.70710605382919312,6.0224370956420898,7.5993595123291016,-9.5837116241455078"> </Bone> </Part> </Brick> <Brick refID="330" designID="92907" itemNos="4610371"> <Part refID="330" designID="92907" materials="26"> <Bone refID="348" transformation="0.00010458666656631976,0.70710653066635132,0.7071073055267334,0.0068282936699688435,0.70709025859832764,-0.70709025859832764,-0.9999767541885376,0.0049022892490029335,-0.0047543826512992382,4.8170027732849121,7.0397124290466309,-9.0238866806030273"> </Bone> </Part> </Brick> <Brick refID="331" designID="43093" itemNos="4168884"> <Part refID="331" designID="43093" materials="26"> <Bone refID="349" transformation="-0.9999767541885376,0.0049020750448107719,-0.0047543817199766636,0.0068281413987278938,0.7070891261100769,-0.70709139108657837,-0.00010444730287417769,-0.70710772275924683,-0.70710611343383789,5.2224545478820801,7.6032829284667969,-9.5875148773193359"> </Bone> </Part> </Brick> <Brick refID="332" designID="43093" itemNos="4168884"> <Part refID="332" designID="43093" materials="26"> <Bone refID="350" transformation="0.99997669458389282,-0.0049022058956325054,0.0047543719410896301,0.0068282284773886204,0.70709055662155151,-0.70709013938903809,0.00010453413415234536,0.70710635185241699,0.70710736513137817,6.0224361419677734,7.599362850189209,-9.5837125778198242"> </Bone> </Part> </Brick> <Brick refID="333" designID="43093" itemNos="4168884"> <Part refID="333" designID="43093" materials="26"> <Bone refID="351" transformation="0.99997669458389282,-0.0049022058956325054,0.0047543719410896301,0.0068282284773886204,0.70709055662155151,-0.70709013938903809,0.00010453413415234536,0.70710635185241699,0.70710736513137817,5.2224550247192383,7.6032848358154297,-9.5875158309936523"> </Bone> </Part> </Brick> <Brick refID="334" designID="32062" itemNos="4109810"> <Part refID="334" designID="32062" materials="26"> <Bone refID="352" transformation="0.99997681379318237,-0.0049022603780031204,0.0047542075626552105,-0.0068281544372439384,-0.70709025859832764,0.70709043741226196,-0.00010469139670021832,-0.70710670948028564,-0.70710700750350952,6.0058817863464355,4.7709736824035645,-9.01806640625"> </Bone> </Part> </Brick> <Brick refID="335" designID="32140" itemNos="4120017"> <Part refID="335" designID="32140" materials="26"> <Bone refID="353" transformation="0.0068282373249530792,0.70709043741226196,-0.70709043741226196,-0.99997681379318237,0.0049022655002772808,-0.0047543225809931755,0.00010461300553288311,0.70710659027099609,0.70710712671279907,6.0059652328491211,5.3366594314575195,-8.4523811340332031"> </Bone> </Part> </Brick> <Brick refID="336" designID="93571" itemNos="4610948"> <Part refID="336" designID="93571" materials="26"> <Bone refID="354" transformation="-0.0068282573483884335,-0.70708966255187988,0.70709091424942017,0.99997669458389282,-0.0049023251049220562,0.0047542857937514782,0.00010468721302459016,0.70710712671279907,0.70710659027099609,6.011512279510498,6.4680171012878418,-8.4523687362670898"> </Bone> </Part> </Brick> <Brick refID="337" designID="32062" itemNos="4109810"> <Part refID="337" designID="32062" materials="26"> <Bone refID="355" transformation="0.9999767541885376,-0.0049022706225514412,0.004754356574267149,-0.0068282675929367542,-0.70708894729614258,0.70709162950515747,-0.00010460303747095168,-0.70710784196853638,-0.70710587501525879,6.0060491561889648,5.902346134185791,-7.8866944313049316"> </Bone> </Part> </Brick> <Brick refID="338" designID="32140" itemNos="4120017"> <Part refID="338" designID="32140" materials="26"> <Bone refID="356" transformation="0.0068281725980341434,0.70708918571472168,-0.70709139108657837,-0.9999767541885376,0.0049021495506167412,-0.0047543458640575409,0.00010452308924868703,0.70710760354995728,0.70710611343383789,6.0062160491943359,7.0337190628051758,-6.7553234100341797"> </Bone> </Part> </Brick> <Brick refID="339" designID="4519" itemNos="451926"> <Part refID="339" designID="4519" materials="26"> <Bone refID="357" transformation="0.00012521287135314196,0.70710533857345581,0.70710831880569458,0.0067201927304267883,0.70709192752838135,-0.70708972215652466,-0.9999774694442749,0.0048404396511614323,-0.0046633458696305752,5.6805944442749023,5.3382430076599121,-7.3225445747375488"> </Bone> </Part> </Brick> <Brick refID="340" designID="32140" itemNos="4120017"> <Part refID="340" designID="32140" materials="26"> <Bone refID="358" transformation="0.0067215091548860073,0.70709192752838135,-0.70708972215652466,0.00012426673492882401,0.70710539817810059,0.7071082592010498,0.99997740983963013,-0.0048406990244984627,0.00466494495049119,7.2005600929260254,5.3309082984924316,-7.3154268264770508"> </Bone> </Part> </Brick> <Brick refID="341" designID="32250" itemNos="4144132"> <Part refID="341" designID="32250" materials="1"> <Bone refID="359" transformation="0.0067114699631929398,0.70709055662155151,-0.70709127187728882,0.00012418786354828626,0.70710676908493042,0.70710694789886475,0.9999774694442749,-0.0048335380852222443,0.0046579712070524693,7.5951924324035645,4.7632908821105957,-6.7478804588317871"> </Bone> </Part> </Brick> <Brick refID="342" designID="43093" itemNos="4168884"> <Part refID="342" designID="43093" materials="26"> <Bone refID="360" transformation="-0.00012416853860486299,-0.70710676908493042,-0.70710712671279907,0.0066935773938894272,0.70709073543548584,-0.70709115266799927,0.99997758865356445,-0.0048208734951913357,0.0046453322283923626,8.0166587829589844,7.0240473747253418,-9.0087080001831055"> </Bone> </Part> </Brick> <Brick refID="343" designID="32250" itemNos="4144132"> <Part refID="343" designID="32250" materials="1"> <Bone refID="361" transformation="0.0067114690318703651,0.70709055662155151,-0.70709121227264404,0.00012418616097420454,0.70710659027099609,0.70710694789886475,0.9999774694442749,-0.0048335390165448189,0.0046579712070524693,7.9951820373535156,4.7613539695739746,-6.7460122108459473"> </Bone> </Part> </Brick> <Brick refID="344" designID="92907" itemNos="4610371"> <Part refID="344" designID="92907" materials="26"> <Bone refID="362" transformation="-0.99997752904891968,0.0048099886626005173,-0.0046696271747350693,9.9253011285327375E-005,0.70710670948028564,0.70710700750350952,0.0067031001672148705,0.70709073543548584,-0.70709097385406494,4.0844812393188477,13.549041748046875,-16.664192199707031"> </Bone> </Part> </Brick> <Brick refID="345" designID="32062" itemNos="4109810"> <Part refID="345" designID="32062" materials="26"> <Bone refID="363" transformation="-0.0067030736245214939,-0.70709079504013062,0.70709085464477539,0.00010277650289935991,0.70710676908493042,0.7071068286895752,-0.9999774694442749,0.0048124636523425579,-0.0046671177260577679,3.2764923572540283,13.269929885864258,-15.253872871398926"> </Bone> </Part> </Brick> <Brick refID="346" designID="3706" itemNos="370626"> <Part refID="346" designID="3706" materials="26"> <Bone refID="364" transformation="0,0.70710557699203491,0.70710813999176025,0.0072997403331100941,0.70708966255187988,-0.70708614587783813,-0.99997329711914063,0.0051616611890494823,-0.0051617887802422047,1.6819344758987427,13.843361854553223,-15.827070236206055"> </Bone> </Part> </Brick> <Brick refID="347" designID="32291" itemNos="4140430"> <Part refID="347" designID="32291" materials="26"> <Bone refID="365" transformation="0.99997341632843018,-0.0051615973934531212,0.0051616872660815716,0,-0.70710563659667969,-0.7071080207824707,0.0072996201924979687,0.70708978176116943,-0.70708614587783813,4.8728780746459961,14.676932334899902,-15.527295112609863"> </Bone> </Part> </Brick> <Brick refID="348" designID="32291" itemNos="4140430"> <Part refID="348" designID="32291" materials="26"> <Bone refID="366" transformation="0.9999733567237854,-0.0051615973934531212,0.0051616868004202843,0,-0.70710563659667969,-0.7071080207824707,0.0072996187955141068,0.70708972215652466,-0.70708614587783813,2.4724395275115967,14.685935020446777,-15.542611122131348"> </Bone> </Part> </Brick> <Brick refID="349" designID="64276" itemNos="4537514"> <Part refID="349" designID="64276" materials="26"> <Bone refID="367" transformation="-0.0072998027317225933,-0.70707130432128906,0.70710456371307373,0,0.70712405443191528,0.70708960294723511,-0.9999733567237854,0.0051617352291941643,-0.0051618083380162716,6.0993361473083496,15.517621040344238,-17.501409530639648"> </Bone> </Part> </Brick> <Brick refID="350" designID="64276" itemNos="4537514"> <Part refID="350" designID="64276" materials="26"> <Bone refID="368" transformation="-0.0072998041287064552,-0.70707130432128906,0.70710450410842896,0,0.70712411403656006,0.70708960294723511,-0.99997341632843018,0.005161734763532877,-0.005161807406693697,2.0994436740875244,15.53826904296875,-17.522056579589844"> </Bone> </Part> </Brick> <Brick refID="351" designID="32014" itemNos="4107767"> <Part refID="351" designID="32014" materials="26"> <Bone refID="369" transformation="0.99997687339782715,-0.0048954873345792294,0.0047475406900048256,0.006818610243499279,0.70709043741226196,-0.70709019899368286,0.00010465405648574233,0.70710635185241699,0.70710736513137817,2.0335381031036377,9.3159999847412109,-10.168388366699219"> </Bone> </Part> </Brick> <Brick refID="352" designID="32062" itemNos="4109810"> <Part refID="352" designID="32062" materials="26"> <Bone refID="370" transformation="0.0068281339481472969,0.70708972215652466,-0.70709073543548584,-0.00010463462967891246,-0.70710688829421997,-0.7071068286895752,-0.9999767541885376,0.0049022035673260689,-0.0047542927786707878,1.2335561513900757,9.3199214935302734,-10.172191619873047"> </Bone> </Part> </Brick> <Brick refID="353" designID="32054" itemNos="4107742"> <Part refID="353" designID="32054" materials="26"> <Bone refID="371" transformation="-0.0068284044973552227,-0.70708948373794556,0.70709097385406494,0.00010479793854756281,0.70710718631744385,0.70710653066635132,-0.99997681379318237,0.0049025095067918301,-0.0047543714754283428,-0.36640584468841553,9.3277654647827148,-10.17979907989502"> </Bone> </Part> </Brick> <Brick refID="354" designID="44294" itemNos="4185111"> <Part refID="354" designID="44294" materials="26"> <Bone refID="372" transformation="0.9999735951423645,-0.0044352216646075249,0.0057642459869384766,-0.0009397082612849772,0.70710998773574829,0.70710307359695435,-0.0072120754048228264,-0.70708978176116943,0.70708686113357544,3.2210609912872314,9.5897655487060547,-10.444355964660645"> </Bone> </Part> </Brick> <Brick refID="355" designID="32054" itemNos="4107742"> <Part refID="355" designID="32054" materials="26"> <Bone refID="373" transformation="-0.00093969638692215085,0.70710998773574829,0.70710307359695435,0.99997377395629883,-0.0044266604818403721,0.0057556680403649807,0.0071999547071754932,0.70708996057510376,-0.70708698034286499,3.2729227542877197,14.682930946350098,-15.537501335144043"> </Bone> </Part> </Brick> <Brick refID="356" designID="6536" itemNos="653626"> <Part refID="356" designID="6536" materials="26"> <Bone refID="374" transformation="0,0.70710515975952148,0.70710861682891846,-0.99997419118881226,0.0050919800996780396,-0.0050920974463224411,-0.0072012287564575672,-0.70709002017974854,0.70708674192428589,3.2268481254577637,10.15758228302002,-11.007965087890625"> </Bone> </Part> </Brick> <Brick refID="357" designID="6590" itemNos="4177421"> <Part refID="357" designID="6590" materials="26"> <Bone refID="375" transformation="0.99997419118881226,-0.0050920108333230019,0.0050920667126774788,0,0.70710515975952148,0.70710861682891846,-0.0072012287564575672,-0.70709007978439331,0.70708680152893066,3.2326087951660156,10.723255157470703,-11.573635101318359"> </Bone> </Part> </Brick> <Brick refID="358" designID="6590" itemNos="4177421"> <Part refID="358" designID="6590" materials="26"> <Bone refID="376" transformation="0.99997413158416748,-0.0050920117646455765,0.0050920676440000534,0,0.70710515975952148,0.70710861682891846,-0.0072012296877801418,-0.70709007978439331,0.70708680152893066,3.2383699417114258,11.28678035736084,-12.141364097595215"> </Bone> </Part> </Brick> <Brick refID="359" designID="6536" itemNos="653626"> <Part refID="359" designID="6536" materials="26"> <Bone refID="377" transformation="0,0.70710521936416626,0.70710855722427368,-0.99997419118881226,0.0050919814966619015,-0.0050920983776450157,-0.0072012296877801418,-0.70709007978439331,0.70708668231964111,3.2441384792327881,11.854599952697754,-12.704975128173828"> </Bone> </Part> </Brick> <Brick refID="360" designID="42003" itemNos="4173970"> <Part refID="360" designID="42003" materials="26"> <Bone refID="378" transformation="0.99997413158416748,-0.0050947205163538456,0.0050948299467563629,0.0072050984017550945,0.70708990097045898,-0.70708692073822021,0,0.70710539817810059,0.70710819959640503,1.6528326272964478,12.99195671081543,-13.280848503112793"> </Bone> </Part> </Brick> <Brick refID="361" designID="32316" itemNos="4140429"> <Part refID="361" designID="32316" materials="26"> <Bone refID="379" transformation="0.99997270107269287,-0.003750805975869298,0.006380186416208744,-0.0018591167172417045,0.70711386203765869,0.70709735155105591,-0.0071636638604104519,-0.70709007978439331,0.70708715915679932,2.4614815711975098,13.554590225219727,-14.41126823425293"> </Bone> </Part> </Brick> <Brick refID="362" designID="32054" itemNos="4107742"> <Part refID="362" designID="32054" materials="26"> <Bone refID="380" transformation="-0.0068282266147434711,-0.70709002017974854,0.70709055662155151,-0.00010484465747140348,-0.7071068286895752,-0.70710688829421997,0.99997681379318237,-0.0049024177715182304,0.0047542089596390724,8.4333915710449219,9.2846250534057617,-10.137961387634277"> </Bone> </Part> </Brick> <Brick refID="363" designID="32062" itemNos="4109810"> <Part refID="363" designID="32062" materials="26"> <Bone refID="381" transformation="0.0068283588625490665,0.70708996057510376,-0.70709061622619629,-0.0001047281184582971,-0.70710688829421997,-0.7071068286895752,-0.99997681379318237,0.0049024280160665512,-0.0047543845139443874,5.233466625213623,9.3003120422363281,-10.153175354003906"> </Bone> </Part> </Brick> <Brick refID="364" designID="32014" itemNos="4107767"> <Part refID="364" designID="32014" materials="26"> <Bone refID="382" transformation="-0.0068282708525657654,-0.70709007978439331,0.70709049701690674,0.99997681379318237,-0.0048979786224663258,0.0047587128356099129,9.8521268228068948E-005,0.70710676908493042,0.70710694789886475,4.8416910171508789,10.15081787109375,-11.003633499145508"> </Bone> </Part> </Brick> <Brick refID="365" designID="44294" itemNos="4185111"> <Part refID="365" designID="44294" materials="26"> <Bone refID="383" transformation="0.99997371435165405,-0.0044352216646075249,0.0057642464525997639,-0.00093970797024667263,0.70711004734039307,0.70710313320159912,-0.0072120744735002518,-0.70708996057510376,0.70708686113357544,4.8210201263427734,9.5837650299072266,-10.434149742126465"> </Bone> </Part> </Brick> <Brick refID="366" designID="32054" itemNos="4107742"> <Part refID="366" designID="32054" materials="26"> <Bone refID="384" transformation="-0.00093969586305320263,0.70710998773574829,0.70710307359695435,0.9999738335609436,-0.0044266600161790848,0.0057556671090424061,0.0071999556384980679,0.70709002017974854,-0.70708692073822021,4.8728809356689453,14.676932334899902,-15.527295112609863"> </Bone> </Part> </Brick> <Brick refID="367" designID="6536" itemNos="653626"> <Part refID="367" designID="6536" materials="26"> <Bone refID="385" transformation="0,0.70710515975952148,0.70710861682891846,-0.99997419118881226,0.0050919791683554649,-0.0050920969806611538,-0.0072012296877801418,-0.70709013938903809,0.70708686113357544,4.8268074989318848,10.149436950683594,-10.999818801879883"> </Bone> </Part> </Brick> <Brick refID="368" designID="6590" itemNos="4177421"> <Part refID="368" designID="6590" materials="26"> <Bone refID="386" transformation="0.99997425079345703,-0.0050920108333230019,0.0050920667126774788,0,0.70710515975952148,0.70710861682891846,-0.0072012296877801418,-0.70709013938903809,0.70708680152893066,4.8325686454772949,10.715108871459961,-11.565487861633301"> </Bone> </Part> </Brick> <Brick refID="369" designID="6590" itemNos="4177421"> <Part refID="369" designID="6590" materials="26"> <Bone refID="387" transformation="0.99997425079345703,-0.0050920122303068638,0.0050920681096613407,0,0.70710515975952148,0.70710861682891846,-0.0072012310847640038,-0.70709013938903809,0.70708680152893066,4.8383297920227051,11.278635025024414,-12.133216857910156"> </Bone> </Part> </Brick> <Brick refID="370" designID="6536" itemNos="653626"> <Part refID="370" designID="6536" materials="26"> <Bone refID="388" transformation="0,0.70710521936416626,0.70710855722427368,-0.99997425079345703,0.0050919814966619015,-0.0050920983776450157,-0.0072012310847640038,-0.70709013938903809,0.70708674192428589,4.8440985679626465,11.846452713012695,-12.69682788848877"> </Bone> </Part> </Brick> <Brick refID="371" designID="42003" itemNos="4173970"> <Part refID="371" designID="42003" materials="26"> <Bone refID="389" transformation="-0.99997425079345703,0.0050978600047528744,-0.0050978795625269413,0.0072094746865332127,0.70708996057510376,-0.70708680152893066,0,-0.70710527896881104,-0.70710843801498413,6.4527101516723633,12.403962135314941,-13.820018768310547"> </Bone> </Part> </Brick> <Brick refID="372" designID="32062" itemNos="4109810"> <Part refID="372" designID="32062" materials="26"> <Bone refID="390" transformation="1,-4.3210675357840955E-005,-0.00010442444181535393,-4.3326272134436294E-005,0.70710659027099609,-0.70710700750350952,0.00010443997598486021,0.70710718631744385,0.70710635185241699,2.0113742351531982,7.3361425399780273,-11.016966819763184"> </Bone> </Part> </Brick> <Brick refID="373" designID="41669" itemNos="4177441"> <Part refID="373" designID="41669" materials="26"> <Bone refID="391" transformation="-4.3363623262848705E-005,0.70710617303848267,-0.70710742473602295,0.00010443518840475008,-0.70710760354995728,-0.70710593461990356,-1,-0.00010451324487803504,-4.3246400309726596E-005,2.0112905502319336,6.7704558372497559,-11.582651138305664"> </Bone> </Part> </Brick> <Brick refID="374" designID="43093" itemNos="4168884"> <Part refID="374" designID="43093" materials="26"> <Bone refID="392" transformation="4.3374169763410464E-005,-0.70710688829421997,0.70710670948028564,-1,4.3231390009168535E-005,0.00010451291018398479,-0.00010451725393068045,-0.70710688829421997,-0.70710676908493042,2.0113530158996582,4.7905569076538086,-10.168438911437988"> </Bone> </Part> </Brick> <Brick refID="375" designID="32006" itemNos="4107136"> <Part refID="375" designID="32006" materials="26"> <Bone refID="393" transformation="4.3282288970658556E-005,0.70710659027099609,-0.70710700750350952,-1,-4.31886910519097E-005,-0.00010445774387335405,-0.00010435506555950269,0.70710724592208862,0.70710664987564087,2.0168652534484863,5.3562307357788086,-9.6027374267578125"> </Bone> </Part> </Brick> <Brick refID="376" designID="32123" itemNos="4270046"> <Part refID="376" designID="32123" materials="26"> <Bone refID="394" transformation="1,-4.3210653529968113E-005,-0.0001044244272634387,-4.3326250306563452E-005,0.70710676908493042,-0.7071068286895752,0.0001044399687089026,0.7071070671081543,0.70710659027099609,2.011394739151001,5.073399543762207,-9.8855962753295898"> </Bone> </Part> </Brick> <Brick refID="377" designID="32062" itemNos="4109810"> <Part refID="377" designID="32062" materials="26"> <Bone refID="395" transformation="1,-4.3251420720480382E-005,-0.00010452247806824744,-4.3367177568143234E-005,0.7071070671081543,-0.70710653066635132,0.00010453814320499077,0.70710676908493042,0.70710694789886475,6.0112814903259277,7.3165364265441895,-10.997945785522461"> </Bone> </Part> </Brick> <Brick refID="378" designID="41669" itemNos="4177441"> <Part refID="378" designID="41669" materials="26"> <Bone refID="396" transformation="-4.3425716285128146E-005,0.70710623264312744,-0.70710736513137817,0.00010455879237269983,-0.7071077823638916,-0.70710599422454834,-1,-0.00010464427759870887,-4.3290256144246086E-005,6.0111980438232422,6.750849723815918,-11.563632011413574"> </Bone> </Part> </Brick> <Brick refID="379" designID="43093" itemNos="4168884"> <Part refID="379" designID="43093" materials="26"> <Bone refID="397" transformation="4.343644468463026E-005,-0.70710700750350952,0.70710659027099609,-1,4.3220807128818706E-005,0.00010458956967340782,-0.00010456410382175818,-0.70710676908493042,-0.70710694789886475,6.0112605094909668,4.7709507942199707,-10.149418830871582"> </Bone> </Part> </Brick> <Brick refID="380" designID="32006" itemNos="4107136"> <Part refID="380" designID="32006" materials="26"> <Bone refID="398" transformation="4.3075404391856864E-005,0.70710712671279907,-0.70710647106170654,-1,-4.3403975723776966E-005,-0.0001043810261762701,-0.00010445321822771803,0.70710659027099609,0.70710718631744385,6.0167717933654785,5.3366241455078125,-9.5837202072143555"> </Bone> </Part> </Brick> <Brick refID="381" designID="32123" itemNos="4270046"> <Part refID="381" designID="32123" materials="26"> <Bone refID="399" transformation="1,-4.3210780859226361E-005,-0.00010442428902024403,-4.3326541344868019E-005,0.70710670948028564,-0.70710688829421997,0.00010443995415698737,0.7071070671081543,0.70710664987564087,6.0113024711608887,5.0537939071655273,-9.8665761947631836"> </Bone> </Part> </Brick> <Brick refID="382" designID="4266" itemNos="426621"> <Part refID="382" designID="4266" materials="21"> <Bone refID="400" transformation="-0.0068279663100838661,-0.70708984136581421,0.70709079504013062,-0.0001043399897753261,-0.70710676908493042,-0.7071068286895752,0.99997669458389282,-0.0049018794670701027,0.0047543235123157501,7.7413210868835449,8.7223310470581055,-10.706938743591309"> </Bone> </Part> </Brick> <Brick refID="383" designID="32054" itemNos="4107742"> <Part refID="383" designID="32054" materials="26"> <Bone refID="401" transformation="0.0068285386078059673,0.70708966255187988,-0.70709091424942017,0.00010458508040755987,0.70710688829421997,0.70710664987564087,0.99997669458389282,-0.004902456421405077,0.0047545558772981167,8.4332218170166016,8.1532535552978516,-11.269333839416504"> </Bone> </Part> </Brick> <Brick refID="384" designID="32062" itemNos="4109810"> <Part refID="384" designID="32062" materials="26"> <Bone refID="402" transformation="0.0068283770233392715,0.70708996057510376,-0.70709061622619629,-0.00010467613901710138,-0.70710653066635132,-0.70710700750350952,-0.99997663497924805,0.0049024075269699097,-0.0047543784603476524,5.2332992553710937,8.1689414978027344,-11.284547805786133"> </Bone> </Part> </Brick> <Brick refID="385" designID="6558" itemNos="655826"> <Part refID="385" designID="6558" materials="26"> <Bone refID="403" transformation="0.00038926512934267521,-0.70710980892181396,-0.7071036696434021,0.99997669458389282,-0.0045468579046428204,0.0050973906181752682,-0.0068195145577192307,-0.7070891261100769,0.70709151029586792,0.8473963737487793,11.867429733276367,-10.456906318664551"> </Bone> </Part> </Brick> <Brick refID="386" designID="32528" itemNos="4144130"> <Part refID="386" designID="32528" materials="1"> <Bone refID="404" transformation="0.9999767541885376,-0.0048213494010269642,0.0048213652335107327,0.0068184291012585163,0.70708918571472168,-0.70709151029586792,0,0.70710796117782593,0.70710563659667969,0.052870728075504303,12.436957359313965,-11.026436805725098"> </Bone> </Part> </Brick> <Brick refID="387" designID="2780" itemNos="278026"> <Part refID="387" designID="2780" materials="26"> <Bone refID="405" transformation="0.99997586011886597,-0.004206046462059021,0.0055350768379867077,-0.00093973625916987658,0.70711183547973633,0.70710110664367676,-0.0068880179896950722,-0.70708918571472168,0.70709079504013062,0.052871227264404297,12.436957359313965,-11.026436805725098"> </Bone> </Part> </Brick> <Brick refID="388" designID="87080" itemNos="4558878"> <Part refID="388" designID="87080" materials="1"> <Bone refID="406" transformation="-0.00093975133495405316,0.70711213350296021,0.70710080862045288,0.0068750442005693913,0.70708894729614258,-0.70709115266799927,-0.99997591972351074,0.0041968594305217266,-0.0055259149521589279,0.8583076000213623,12.998772621154785,-11.588252067565918"> </Bone> </Part> </Brick> <Brick refID="389" designID="2780" itemNos="278026"> <Part refID="389" designID="2780" materials="26"> <Bone refID="407" transformation="-0.0047095422632992268,1.1438976798672229E-005,0.99998891353607178,0.0048576276749372482,0.99998819828033447,1.1438487490522675E-005,-0.99997711181640625,0.0048576276749372482,-0.0047095422632992268,0.0061313631013035774,5.931757926940918,-7.9152216911315918"> </Bone> </Part> </Brick> <Brick refID="390" designID="4266" itemNos="426621"> <Part refID="390" designID="4266" materials="21"> <Bone refID="408" transformation="-0.0068284468725323677,-0.70708966255187988,0.70709091424942017,0.00010434175783302635,0.70710688829421997,0.70710664987564087,-0.99997669458389282,0.0049022193998098373,-0.0047546629793941975,0.32549309730529785,8.7586860656738281,-10.742196083068848"> </Bone> </Part> </Brick> <Brick refID="391" designID="32054" itemNos="4107742"> <Part refID="391" designID="32054" materials="26"> <Bone refID="409" transformation="-0.0068284561857581139,-0.70708966255187988,0.70709091424942017,0.00010477507021278143,0.70710688829421997,0.70710664987564087,-0.99997669458389282,0.0049025323241949081,-0.0047543630935251713,-0.36657413840293884,8.1963939666748047,-11.31117057800293"> </Bone> </Part> </Brick> <Brick refID="392" designID="32062" itemNos="4109810"> <Part refID="392" designID="32062" materials="26"> <Bone refID="410" transformation="0.0068281525745987892,0.70709002017974854,-0.70709067583084106,-0.00010458174074301496,-0.70710659027099609,-0.70710694789886475,-0.99997669458389282,0.00490218261256814,-0.0047542820684611797,1.2333875894546509,8.1885499954223633,-11.303564071655273"> </Bone> </Part> </Brick> <Brick refID="393" designID="6558" itemNos="655826"> <Part refID="393" designID="6558" materials="26"> <Bone refID="411" transformation="-0.0068282741121947765,-0.70709037780761719,0.70709019899368286,0.99997669458389282,-0.0049023148603737354,0.0047543230466544628,0.00010464239312568679,0.70710617303848267,0.70710736513137817,4.8335332870483398,9.5851507186889648,-9.872283935546875"> </Bone> </Part> </Brick> <Brick refID="394" designID="32014" itemNos="4107767"> <Part refID="394" designID="32014" materials="26"> <Bone refID="412" transformation="-1,4.332900425652042E-005,0.00010462144564371556,-4.334018740337342E-005,0.7071075439453125,-0.70710599422454834,-0.00010461681085871533,-0.70710599422454834,-0.7071075439453125,6.0333042144775391,8.1708507537841797,-11.286574363708496"> </Bone> </Part> </Brick> <Brick refID="395" designID="32062" itemNos="4109810"> <Part refID="395" designID="32062" materials="26"> <Bone refID="413" transformation="1,4.3423369788797572E-005,-1.802929000405129E-005,1.7956266674445942E-005,-0.70710593461990356,-0.70710760354995728,-4.3453605030663311E-005,0.7071075439453125,-0.70710599422454834,4.8331575393676758,9.5851039886474609,-12.70064640045166"> </Bone> </Part> </Brick> <Brick refID="396" designID="32184" itemNos="4121667"> <Part refID="396" designID="32184" materials="26"> <Bone refID="414" transformation="1,4.3401974835433066E-005,-1.7977661627810448E-005,1.7977643437916413E-005,-0.70710575580596924,-0.70710796117782593,-4.3401989387348294E-005,0.7071077823638916,-0.70710563659667969,3.2331564426422119,9.5850343704223633,-12.700617790222168"> </Bone> </Part> </Brick> <Brick refID="397" designID="32062" itemNos="4109810"> <Part refID="397" designID="32062" materials="26"> <Bone refID="415" transformation="1,4.3335985537851229E-005,-1.7993084838963114E-005,1.7920086975209415E-005,-0.70710617303848267,-0.7071075439453125,-4.3366209865780547E-005,0.70710736513137817,-0.70710605382919312,3.233314037322998,9.5929470062255859,-12.708254814147949"> </Bone> </Part> </Brick> <Brick refID="398" designID="32014" itemNos="4107767"> <Part refID="398" designID="32014" materials="26"> <Bone refID="416" transformation="1,-4.330341107561253E-005,-0.0001046470642904751,-4.3376410758355632E-005,0.70710736513137817,-0.70710617303848267,0.00010461682541063055,0.70710617303848267,0.70710748434066772,2.0333418846130371,8.1787986755371094,-11.293931007385254"> </Bone> </Part> </Brick> <Brick refID="399" designID="6558" itemNos="655826"> <Part refID="399" designID="6558" materials="26"> <Bone refID="417" transformation="-0.0068282745778560638,-0.70709037780761719,0.70709025859832764,0.99997669458389282,-0.0049023143947124481,0.0047543235123157501,0.00010464242222951725,0.70710623264312744,0.70710736513137817,3.2335512638092041,9.5929584503173828,-9.8798418045043945"> </Bone> </Part> </Brick> <Brick refID="400" designID="6558" itemNos="655826"> <Part refID="400" designID="6558" materials="26"> <Bone refID="418" transformation="0.00038926521665416658,-0.70710980892181396,-0.7071036696434021,0.99997669458389282,-0.0045468579046428204,0.0050973910838365555,-0.0068195145577192307,-0.7070891261100769,0.70709151029586792,7.247246265411377,11.836053848266602,-10.426487922668457"> </Bone> </Part> </Brick> <Brick refID="401" designID="87086" itemNos="4558874"> <Part refID="401" designID="87086" materials="1"> <Bone refID="419" transformation="0.00093971745809540153,-0.7071118950843811,-0.70710098743438721,0.0068750437349081039,0.70708918571472168,-0.70709097385406494,0.99997591972351074,-0.0041968845762312412,0.005525889340788126,7.2581577301025391,12.967395782470703,-11.557834625244141"> </Bone> </Part> </Brick> <Brick refID="402" designID="2780" itemNos="278026"> <Part refID="402" designID="2780" materials="26"> <Bone refID="420" transformation="0.99997586011886597,-0.0042060450650751591,0.0055350759066641331,-0.00093973625916987658,0.7071118950843811,0.70710104703903198,-0.0068880170583724976,-0.70708918571472168,0.70709085464477539,8.0526809692382812,12.397651672363281,-10.98808765411377"> </Bone> </Part> </Brick> <Brick refID="403" designID="32527" itemNos="4144129"> <Part refID="403" designID="32527" materials="1"> <Bone refID="421" transformation="0.99997407197952271,-0.0050918986089527607,0.0050918743945658207,0.007201015017926693,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,8.0526809692382812,12.397651672363281,-10.98808765411377"> </Bone> </Part> </Brick> <Brick refID="404" designID="2780" itemNos="278026"> <Part refID="404" designID="2780" materials="26"> <Bone refID="422" transformation="0.99997669458389282,-0.0049023707397282124,0.0047543086111545563,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283029831945896,-0.70708924531936646,0.70709133148193359,2.4473628997802734,11.859663009643555,-10.449427604675293"> </Bone> </Part> </Brick> <Brick refID="405" designID="32316" itemNos="4140465"> <Part refID="405" designID="32316" materials="1"> <Bone refID="423" transformation="0.99997687339782715,-0.0048090354539453983,0.0048091243952512741,0,-0.7071077823638916,-0.70710575580596924,0.0068010659888386726,0.70708942413330078,-0.70709145069122314,2.4582803249359131,12.990673065185547,-11.580864906311035"> </Bone> </Part> </Brick> <Brick refID="406" designID="2780" itemNos="278026"> <Part refID="406" designID="2780" materials="26"> <Bone refID="424" transformation="0.99997669458389282,-0.0049023698084056377,0.0047543076798319817,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.006828302051872015,-0.70708924531936646,0.70709133148193359,4.8472986221313477,11.84778881072998,-10.437975883483887"> </Bone> </Part> </Brick> <Brick refID="407" designID="32523" itemNos="4157532"> <Part refID="407" designID="32523" materials="1"> <Bone refID="425" transformation="0.99997693300247192,-0.0048028221353888512,0.0048029106110334396,0,0.70710772275924683,0.70710581541061401,-0.0067922784946858883,-0.70708954334259033,0.70709145069122314,3.2473347187042236,11.855472564697266,-10.445660591125488"> </Bone> </Part> </Brick> <Brick refID="408" designID="2780" itemNos="278026"> <Part refID="408" designID="2780" materials="26"> <Bone refID="426" transformation="0.99997669458389282,-0.0049023693427443504,0.0047543072141706944,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283015862107277,-0.70708924531936646,0.70709133148193359,3.2473363876342773,11.855483055114746,-10.445671081542969"> </Bone> </Part> </Brick> <Brick refID="409" designID="2780" itemNos="278026"> <Part refID="409" designID="2780" materials="26"> <Bone refID="427" transformation="0.99997669458389282,-0.004902370274066925,0.004754308145493269,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283025175333023,-0.70708924531936646,0.70709133148193359,5.6472806930541992,11.843941688537598,-10.434128761291504"> </Bone> </Part> </Brick> <Brick refID="410" designID="6558" itemNos="655826"> <Part refID="410" designID="6558" materials="26"> <Bone refID="428" transformation="0.0072011854499578476,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,0.99997407197952271,-0.0050919796340167522,0.0050920345820486546,5.2469272613525391,12.692935943603516,-12.411938667297363"> </Bone> </Part> </Brick> <Brick refID="411" designID="32016" itemNos="4107082"> <Part refID="411" designID="32016" materials="26"> <Bone refID="429" transformation="0.0072010708972811699,0.70709007978439331,-0.70708680152893066,0,0.70710515975952148,0.70710843801498413,0.99997407197952271,-0.005091911181807518,0.0050919409841299057,4.0383172035217285,11.850537300109863,-11.569545745849609"> </Bone> </Part> </Brick> <Brick refID="412" designID="32062" itemNos="4109810"> <Part refID="412" designID="32062" materials="26"> <Bone refID="430" transformation="0.9999769926071167,-0.00665286835283041,0.0013232985511422157,0.0013232255587354302,0.38266345858573914,0.92388683557510376,-0.0066528627648949623,-0.92386394739151001,0.3826633095741272,4.0496196746826172,13.06859302520752,-12.571118354797363"> </Bone> </Part> </Brick> <Brick refID="413" designID="6590" itemNos="4177421"> <Part refID="413" designID="6590" materials="26"> <Bone refID="431" transformation="0.9999769926071167,-0.0066528571769595146,0.0013232942437753081,0.0013232218334451318,0.38266292214393616,0.92388725280761719,-0.0066528520546853542,-0.92386418581008911,0.38266265392303467,4.0549421310424805,13.807683944702148,-12.877248764038086"> </Bone> </Part> </Brick> <Brick refID="414" designID="6558" itemNos="655826"> <Part refID="414" designID="6558" materials="26"> <Bone refID="432" transformation="0.0072011854499578476,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,0.99997407197952271,-0.0050919796340167522,0.0050920345820486546,5.2296361923217773,10.995918273925781,-10.714929580688477"> </Bone> </Part> </Brick> <Brick refID="415" designID="32013" itemNos="4107085"> <Part refID="415" designID="32013" materials="26"> <Bone refID="433" transformation="-0.0072094360366463661,-0.70709013938903809,0.70708662271499634,0.99997401237487793,-0.0050978534854948521,0.0050978283397853374,0,0.70710504055023193,0.70710855722427368,4.0383186340332031,11.85053825378418,-11.569546699523926"> </Bone> </Part> </Brick> <Brick refID="416" designID="2780" itemNos="278026"> <Part refID="416" designID="2780" materials="26"> <Bone refID="434" transformation="0,0.70710849761962891,-0.70710510015487671,-1,0,0,0,0.70710510015487671,0.70710849761962891,6.4527091979980469,12.969646453857422,-13.254331588745117"> </Bone> </Part> </Brick> <Brick refID="417" designID="32527" itemNos="4144129"> <Part refID="417" designID="32527" materials="1"> <Bone refID="435" transformation="0,-0.7071082592010498,0.70710533857345581,-2.4912687877076678E-005,-0.70710533857345581,-0.7071082592010498,1,-1.7602345906198025E-005,-1.7629516150918789E-005,6.4527297019958496,12.408026695251465,-13.82411003112793"> </Bone> </Part> </Brick> <Brick refID="418" designID="43093" itemNos="4168884"> <Part refID="418" designID="43093" materials="26"> <Bone refID="436" transformation="1,-1.0267523975926451E-005,-2.4891305656637996E-005,-1.0340522749174852E-005,0.7071082592010498,-0.70710527896881104,2.4861068595782854E-005,0.70710527896881104,0.7071082592010498,6.4527492523193359,13.539397239685059,-13.82410717010498"> </Bone> </Part> </Brick> <Brick refID="419" designID="6536" itemNos="653626"> <Part refID="419" designID="6536" materials="26"> <Bone refID="437" transformation="-1,1.0293126251781359E-005,2.4865697923814878E-005,-1.0304303941666149E-005,0.70710843801498413,-0.70710510015487671,-2.4861063138814643E-005,-0.70710510015487671,-0.70710843801498413,6.4527292251586914,12.973712921142578,-14.389793395996094"> </Bone> </Part> </Brick> <Brick refID="420" designID="6558" itemNos="655826"> <Part refID="420" designID="6558" materials="26"> <Bone refID="438" transformation="1,1.24658145068679E-005,0,0,-0.70710498094558716,-0.70710861682891846,-1.0314501196262427E-005,0.70710861682891846,-0.70710498094558716,5.6527185440063477,14.670808792114258,-15.52116870880127"> </Bone> </Part> </Brick> <Brick refID="421" designID="2780" itemNos="278026"> <Part refID="421" designID="2780" materials="26"> <Bone refID="439" transformation="0,0.70710837841033936,-0.70710515975952148,-1,0,0,0,0.70710515975952148,0.70710837841033936,1.6528327465057373,12.99195671081543,-13.280848503112793"> </Bone> </Part> </Brick> <Brick refID="422" designID="32528" itemNos="4144130"> <Part refID="422" designID="32528" materials="1"> <Bone refID="440" transformation="0,0.70710837841033936,-0.70710521936416626,1.7354712326778099E-005,-0.70710521936416626,-0.70710837841033936,-1,-1.2396577403706033E-005,-1.2146692824899219E-005,1.6528327465057373,12.426272392272949,-13.846534729003906"> </Bone> </Part> </Brick> <Brick refID="423" designID="43093" itemNos="4168884"> <Part refID="423" designID="43093" materials="26"> <Bone refID="441" transformation="1,0,2.0996167222619988E-005,1.2286724995647091E-005,0.70710837841033936,-0.70710515975952148,-1.7406327970093116E-005,0.70710515975952148,0.70710837841033936,1.6528185606002808,13.557643890380859,-13.846531867980957"> </Bone> </Part> </Brick> <Brick refID="424" designID="6536" itemNos="653626"> <Part refID="424" designID="6536" materials="26"> <Bone refID="442" transformation="1,0,2.0996163584641181E-005,1.2286724995647091E-005,0.70710855722427368,-0.70710498094558716,-1.7406326151103713E-005,0.70710492134094238,0.70710861682891846,1.6528185606002808,13.557642936706543,-13.846530914306641"> </Bone> </Part> </Brick> <Brick refID="425" designID="6558" itemNos="655826"> <Part refID="425" designID="6558" materials="26"> <Bone refID="443" transformation="0.9999772310256958,-0.0047414647415280342,0.00480262516066432,4.3245108827250078E-005,-0.7071070671081543,-0.70710647106170654,0.0067486907355487347,0.70709061622619629,-0.70709079504013062,4.0899538993835449,14.114714622497559,-17.229866027832031"> </Bone> </Part> </Brick> <Brick refID="426" designID="2780" itemNos="278026"> <Part refID="426" designID="2780" materials="26"> <Bone refID="444" transformation="0.99997669458389282,-0.0049021416343748569,0.0047543011605739594,-0.0068281358107924461,-0.70708900690078735,0.7070915699005127,-0.00010454887524247169,-0.7071075439453125,-0.70710599422454834,6.0170578956604004,7.5993738174438477,-8.4523525238037109"> </Bone> </Part> </Brick> <Brick refID="427" designID="44809" itemNos="4227074"> <Part refID="427" designID="44809" materials="1"> <Bone refID="445" transformation="-0.99997669458389282,0.0049021821469068527,-0.0047544147819280624,-0.0068282447755336761,-0.7070888876914978,0.70709168910980225,0.00010449837282067165,0.70710766315460205,0.70710587501525879,6.0172252655029297,8.7307462692260742,-7.3209829330444336"> </Bone> </Part> </Brick> <Brick refID="428" designID="2780" itemNos="278026"> <Part refID="428" designID="2780" materials="26"> <Bone refID="446" transformation="-0.99995326995849609,0,-0.0096659790724515915,0.0068345260806381702,-0.70712471008300781,-0.70705580711364746,-0.0068352320231497288,-0.7070888876914978,0.70709168910980225,5.214470386505127,8.1689891815185547,-7.3247928619384766"> </Bone> </Part> </Brick> <Brick refID="429" designID="87080" itemNos="4558878"> <Part refID="429" designID="87080" materials="1"> <Bone refID="447" transformation="-0.99997639656066895,0.004888645838946104,-0.004827483557164669,-0.0068703410215675831,-0.7070886492729187,0.7070915699005127,4.3261410610284656E-005,0.7071080207824707,0.70710551738739014,5.2254071235656738,9.3003311157226562,-8.4561395645141602"> </Bone> </Part> </Brick> <Brick refID="430" designID="43093" itemNos="4168884"> <Part refID="430" designID="43093" materials="26"> <Bone refID="448" transformation="0.00010392918920842931,0.70710712671279907,0.70710629224777222,0.0067913546226918697,0.70708924531936646,-0.70709174871444702,-0.99997693300247192,0.0048756976611912251,-0.0047287284396588802,4.006230354309082,7.8922781944274902,-5.9164977073669434"> </Bone> </Part> </Brick> <Brick refID="431" designID="32140" itemNos="4118980"> <Part refID="431" designID="32140" materials="1"> <Bone refID="449" transformation="0.0067913848906755447,0.7070920467376709,-0.70708894729614258,-0.00010741042933659628,-0.7071041464805603,-0.70710927248001099,-0.99997687339782715,0.0048782019875943661,-0.0047262716107070446,4.0062942504882812,7.8923273086547852,-5.9166154861450195"> </Bone> </Part> </Brick> <Brick refID="432" designID="43093" itemNos="4168884"> <Part refID="432" designID="43093" materials="26"> <Bone refID="450" transformation="-0.99997657537460327,0.004839905072003603,-0.004840014036744833,0,0.70710515975952148,0.70710843801498413,0.006844736635684967,0.70709186792373657,-0.70708858966827393,6.8308234214782715,9.858184814453125,-9.0140838623046875"> </Bone> </Part> </Brick> <Brick refID="433" designID="6538" itemNos="4100407"> <Part refID="433" designID="6538" materials="1"> <Bone refID="451" transformation="0.99997609853744507,-0.0048829722218215466,0.0048828902654349804,0,0.70710498094558716,0.70710849761962891,-0.0069055068306624889,-0.70709168910980225,0.70708823204040527,6.825347900390625,9.292510986328125,-8.4484119415283203"> </Bone> </Part> </Brick> <Brick refID="434" designID="32062" itemNos="4109810"> <Part refID="434" designID="32062" materials="26"> <Bone refID="452" transformation="0.99997603893280029,-0.0048950915224850178,0.0048951273784041405,0,0.70710504055023193,0.70710843801498413,-0.0069227283820509911,-0.70709145069122314,0.70708811283111572,6.8308725357055664,9.8581838607788086,-9.0140829086303711"> </Bone> </Part> </Brick> <Brick refID="435" designID="6538" itemNos="4100407"> <Part refID="435" designID="6538" materials="1"> <Bone refID="453" transformation="0.99997615814208984,-0.0048829722218215466,0.0048828902654349804,0,0.70710498094558716,0.70710849761962891,-0.0069055049680173397,-0.70709168910980225,0.70708823204040527,6.8364105224609375,10.423856735229492,-9.5797538757324219"> </Bone> </Part> </Brick> <Brick refID="436" designID="2780" itemNos="278026"> <Part refID="436" designID="2780" materials="26"> <Bone refID="454" transformation="-0.0048763127997517586,1.2039567081956193E-005,0.9999881386756897,0.0049379416741430759,0.99998778104782104,1.2039670764352195E-005,-0.99997591972351074,0.0049379416741430759,-0.0048763127997517586,4.0117325782775879,8.4580469131469727,-6.4824056625366211"> </Bone> </Part> </Brick> <Brick refID="437" designID="32002" itemNos="4211050"> <Part refID="437" designID="32002" materials="199"> <Bone refID="455" transformation="1,-4.3210937292315066E-005,-0.00010442379425512627,-4.3283936975058168E-005,0.70710736513137817,-0.70710617303848267,0.00010439355537528172,0.70710617303848267,0.70710736513137817,2.0169835090637207,6.4876108169555664,-9.6027450561523437"> </Bone> </Part> </Brick> <Brick refID="438" designID="2780" itemNos="278026"> <Part refID="438" designID="2780" materials="26"> <Bone refID="456" transformation="0.99997669458389282,-0.0049022408202290535,0.0047542601823806763,-0.0068281772546470165,-0.70708948373794556,0.70709109306335449,-0.00010464352817507461,-0.7071070671081543,-0.70710647106170654,2.0171499252319336,7.6189818382263184,-8.4713726043701172"> </Bone> </Part> </Brick> <Brick refID="439" designID="44809" itemNos="4227074"> <Part refID="439" designID="44809" materials="1"> <Bone refID="457" transformation="-0.0068282773718237877,-0.70708942413330078,0.70709121227264404,0.99997669458389282,-0.0049022440798580647,0.0047543980181217194,0.00010454921721247956,0.70710718631744385,0.70710641145706177,2.0173170566558838,8.7503528594970703,-7.3400020599365234"> </Bone> </Part> </Brick> <Brick refID="440" designID="2780" itemNos="278026"> <Part refID="440" designID="2780" materials="26"> <Bone refID="458" transformation="0.99997669458389282,-0.0049023707397282124,0.0047543086111545563,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283029831945896,-0.70708924531936646,0.70709133148193359,2.8145256042480469,8.1807518005371094,-7.3362045288085938"> </Bone> </Part> </Brick> <Brick refID="441" designID="43093" itemNos="4168884"> <Part refID="441" designID="43093" materials="26"> <Bone refID="459" transformation="0.0067913341335952282,0.70709228515625,-0.7070886492729187,0.00010397551523055881,0.70710444450378418,0.70710909366607666,0.99997693300247192,-0.0048757339827716351,0.0047286623157560825,4.0063896179199219,7.8923416137695313,-5.9166140556335449"> </Bone> </Part> </Brick> <Brick refID="442" designID="32140" itemNos="4118980"> <Part refID="442" designID="32140" materials="1"> <Bone refID="460" transformation="0.0067913858219981194,0.70709234476089478,-0.70708858966827393,-0.00010742824815679342,-0.70710432529449463,-0.70710921287536621,-0.99997693300247192,0.0048782113008201122,-0.0047262562438845634,3.2064080238342285,7.8962421417236328,-5.9203968048095703"> </Bone> </Part> </Brick> <Brick refID="443" designID="87086" itemNos="4558874"> <Part refID="443" designID="87086" materials="1"> <Bone refID="461" transformation="-0.99997669458389282,0.0049023814499378204,-0.0047544687986373901,-0.0068284254521131516,-0.70709210634231567,0.70708847045898438,0.00010458449105499312,0.70710420608520508,0.70710933208465576,2.8254506587982178,9.3120956420898438,-8.4675512313842773"> </Bone> </Part> </Brick> <Brick refID="444" designID="43093" itemNos="4168884"> <Part refID="444" designID="43093" materials="26"> <Bone refID="462" transformation="-0.99997657537460327,0.0048399046063423157,-0.0048400135710835457,0,0.70710515975952148,0.70710843801498413,0.0068447361700236797,0.70709186792373657,-0.70708858966827393,1.2309765815734863,9.8856134414672852,-9.0408287048339844"> </Bone> </Part> </Brick> <Brick refID="445" designID="6538" itemNos="4100407"> <Part refID="445" designID="6538" materials="1"> <Bone refID="463" transformation="0.99997615814208984,-0.0048767328262329102,0.0048766522668302059,0,0.70710504055023193,0.70710843801498413,-0.00689668208360672,-0.70709162950515747,0.70708829164505005,1.2255008220672607,9.3199405670166016,-8.4751577377319336"> </Bone> </Part> </Brick> <Brick refID="446" designID="32062" itemNos="4109810"> <Part refID="446" designID="32062" materials="26"> <Bone refID="464" transformation="0.99997603893280029,-0.0048950905911624432,0.0048951264470815659,0,0.70710504055023193,0.70710843801498413,-0.0069227274507284164,-0.70709145069122314,0.70708811283111572,1.23101806640625,9.8856143951416016,-9.0408287048339844"> </Bone> </Part> </Brick> <Brick refID="447" designID="6538" itemNos="4100407"> <Part refID="447" designID="6538" materials="1"> <Bone refID="465" transformation="0.99997609853744507,-0.0048829722218215466,0.0048828902654349804,0,0.70710498094558716,0.70710849761962891,-0.0069055035710334778,-0.70709168910980225,0.70708823204040527,1.2365560531616211,10.451287269592285,-9.6064996719360352"> </Bone> </Part> </Brick> <Brick refID="448" designID="2780" itemNos="278026"> <Part refID="448" designID="2780" materials="26"> <Bone refID="466" transformation="-0.0047287489287555218,1.1528226423251908E-005,0.99998879432678223,0.0048757363110780716,0.9999881386756897,1.1528172763064504E-005,-0.99997693300247192,0.0048757363110780716,-0.0047287489287555218,2.4118893146514893,8.4658164978027344,-6.4898500442504883"> </Bone> </Part> </Brick> <Brick refID="449" designID="2780" itemNos="278026"> <Part refID="449" designID="2780" materials="26"> <Bone refID="467" transformation="-0.0046704122796654701,1.1317273674649186E-005,0.9999890923500061,0.0048463051207363605,0.99998825788497925,1.1317225471429992E-005,-0.99997735023498535,0.0048463051207363605,-0.0046704122796654701,6.4059562683105469,5.90045166015625,-7.884829044342041"> </Bone> </Part> </Brick> <Brick refID="450" designID="32123" itemNos="4270046"> <Part refID="450" designID="32123" materials="26"> <Bone refID="468" transformation="0,0.69617867469787598,0.71786856651306152,0.0068290866911411285,0.71785181760787964,-0.69616240262985229,-0.99997669458389282,0.0049023334868252277,-0.0047543193213641644,4.4170117378234863,7.0416698455810547,-9.0257892608642578"> </Bone> </Part> </Brick> <Brick refID="451" designID="3705" itemNos="370526"> <Part refID="451" designID="3705" materials="26"> <Bone refID="469" transformation="-0.0068290634080767632,-0.71785199642181396,0.69616216421127319,0,0.69617855548858643,0.7178688645362854,-0.99997663497924805,0.0049023451283574104,-0.0047542843967676163,2.4170584678649902,7.0514779090881348,-9.0352973937988281"> </Bone> </Part> </Brick> <Brick refID="452" designID="32123" itemNos="4270046"> <Part refID="452" designID="32123" materials="26"> <Bone refID="470" transformation="0,0.69617867469787598,0.71786856651306152,0.0068290834315121174,0.71785181760787964,-0.69616240262985229,-0.99997663497924805,0.004902335349470377,-0.0047543211840093136,3.2170393466949463,7.0475559234619141,-9.031494140625"> </Bone> </Part> </Brick> <Brick refID="453" designID="2780" itemNos="278026"> <Part refID="453" designID="2780" materials="26"> <Bone refID="471" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,6.0524082183837891,10.144929885864258,-13.260654449462891"> </Bone> </Part> </Brick> <Brick refID="454" designID="32527" itemNos="4143417"> <Part refID="454" designID="32527" materials="26"> <Bone refID="472" transformation="0.99997693300247192,-0.0048028165474534035,0.0048028100281953812,-0.0067922035232186317,-0.70709097385406494,0.70709002017974854,0,-0.70710629224777222,-0.70710724592208862,6.0578498840332031,10.710666656494141,-13.826271057128906"> </Bone> </Part> </Brick> <Brick refID="455" designID="2780" itemNos="278026"> <Part refID="455" designID="2780" materials="26"> <Bone refID="473" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,5.2524271011352539,10.148836135864258,-13.26444149017334"> </Bone> </Part> </Brick> <Brick refID="456" designID="2780" itemNos="278026"> <Part refID="456" designID="2780" materials="26"> <Bone refID="474" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,2.8524823188781738,10.16057300567627,-13.275822639465332"> </Bone> </Part> </Brick> <Brick refID="457" designID="32528" itemNos="4143419"> <Part refID="457" designID="32528" materials="26"> <Bone refID="475" transformation="0.99997681379318237,-0.0048151216469705105,0.0048151160590350628,-0.0068096062168478966,-0.70709079504013062,0.70708996057510376,0,-0.70710635185241699,-0.70710718631744385,2.0579419136047363,10.730152130126953,-13.845283508300781"> </Bone> </Part> </Brick> <Brick refID="458" designID="2780" itemNos="278026"> <Part refID="458" designID="2780" materials="26"> <Bone refID="476" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.0068009323440492153,-0.70709079504013062,0.70709002017974854,2.0525012016296387,10.16447925567627,-13.279611587524414"> </Bone> </Part> </Brick> <Brick refID="459" designID="32002" itemNos="4211050"> <Part refID="459" designID="32002" materials="199"> <Bone refID="477" transformation="1,-4.3251558963675052E-005,-0.0001045218959916383,-4.3324573198333383E-005,0.70710742473602295,-0.70710611343383789,0.00010449164983583614,0.70710611343383789,0.70710742473602295,6.0168900489807129,6.4680023193359375,-9.5837249755859375"> </Bone> </Part> </Brick> <Brick refID="460" designID="6558" itemNos="655826"> <Part refID="460" designID="6558" materials="26"> <Bone refID="478" transformation="0.99997347593307495,-0.0051515777595341206,0.0051473476924002171,0,-0.70710510015487671,-0.70710843801498413,0.0072824400849640369,0.70708972215652466,-0.70708638429641724,2.4724395275115967,14.685935020446777,-15.542611122131348"> </Bone> </Part> </Brick> <Brick refID="461" designID="32525" itemNos="4156150"> <Part refID="461" designID="32525" materials="26"> <Bone refID="479" transformation="0,6.4048224885482341E-005,1,0.99997085332870483,-0.007634955458343029,0,0.007634955458343029,0.99997085332870483,-6.4046354964375496E-005,4.1893267631530762,27.132505416870117,-21.505762100219727"> </Bone> </Part> </Brick> <Brick refID="462" designID="43093" itemNos="4168884"> <Part refID="462" designID="43093" materials="26"> <Bone refID="480" transformation="0.99997109174728394,-0.0076034036464989185,0,0,-6.4020910940598696E-005,-1,0.0076034055091440678,0.99997133016586304,-6.4020139689091593E-005,4.1953816413879395,27.93299674987793,-13.505813598632813"> </Bone> </Part> </Brick> <Brick refID="463" designID="32014" itemNos="4107767"> <Part refID="463" designID="32014" materials="26"> <Bone refID="481" transformation="0,-6.3790263084229082E-005,-0.99999988079071045,-0.0075719845481216908,-0.99997144937515259,6.3790597778279334E-005,-0.99997144937515259,0.0075719831511378288,0,4.1983857154846191,28.333042144775391,-12.305778503417969"> </Bone> </Part> </Brick> <Brick refID="464" designID="43093" itemNos="4168884"> <Part refID="464" designID="43093" materials="26"> <Bone refID="482" transformation="-1.0000001192092896,0,0,0,1,0,0,0,-1,4.1983857154846191,28.332990646362305,-13.105778694152832"> </Bone> </Part> </Brick> <Brick refID="465" designID="6558" itemNos="655826"> <Part refID="465" designID="6558" materials="26"> <Bone refID="483" transformation="7.7408250945154577E-005,0,-1,0.0079556992277503014,0.99996834993362427,0,0.99996834993362427,-0.0079556992277503014,7.7408250945154577E-005,5.3983726501464844,28.323005676269531,-13.505653381347656"> </Bone> </Part> </Brick> <Brick refID="466" designID="41239" itemNos="4164422"> <Part refID="466" designID="41239" materials="26"> <Bone refID="484" transformation="0,0,1,0.0075803068466484547,0.99997127056121826,0,-0.99997127056121826,0.0075803068466484547,0,4.5984086990356445,28.329948425292969,-22.305841445922852"> </Bone> </Part> </Brick> <Brick refID="467" designID="6558" itemNos="655826"> <Part refID="467" designID="6558" materials="26"> <Bone refID="485" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.3983850479125977,28.323884963989258,-21.505842208862305"> </Bone> </Part> </Brick> <Brick refID="468" designID="41239" itemNos="4164422"> <Part refID="468" designID="41239" materials="26"> <Bone refID="486" transformation="-7.7314616646617651E-005,0,1,0.0079407021403312683,0.99996846914291382,0,-0.99996846914291382,0.0079407021403312683,-7.7314616646617651E-005,2.9991283416748047,28.342098236083984,-22.305839538574219"> </Bone> </Part> </Brick> <Brick refID="469" designID="6558" itemNos="655826"> <Part refID="469" designID="6558" materials="26"> <Bone refID="487" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.398381233215332,28.323886871337891,-15.905842781066895"> </Bone> </Part> </Brick> <Brick refID="470" designID="32054" itemNos="4107742"> <Part refID="470" designID="32054" materials="26"> <Bone refID="488" transformation="1,0,0,0,1,0,0,0,1,4.2044887542724609,29.132944107055664,-11.505843162536621"> </Bone> </Part> </Brick> <Brick refID="471" designID="32062" itemNos="4109810"> <Part refID="471" designID="32062" materials="26"> <Bone refID="489" transformation="1,0,0,0,1,0,0,0,1,4.2044887542724609,29.132944107055664,-13.105843544006348"> </Bone> </Part> </Brick> <Brick refID="472" designID="32039" itemNos="4107081"> <Part refID="472" designID="32039" materials="26"> <Bone refID="490" transformation="0.0075802505016326904,0.99997115135192871,0,-0.99997115135192871,0.0075802505016326904,0,0,0,0.99999988079071045,4.2044887542724609,29.132944107055664,-13.905843734741211"> </Bone> </Part> </Brick> <Brick refID="473" designID="32062" itemNos="4109810"> <Part refID="473" designID="32062" materials="26"> <Bone refID="491" transformation="0,0,-0.99999988079071045,0.99997115135192871,-0.0075801517814397812,0,-0.0075801517814397812,-0.99997115135192871,0,4.1953926086425781,27.932977676391602,-15.105843544006348"> </Bone> </Part> </Brick> <Brick refID="474" designID="42003" itemNos="4173970"> <Part refID="474" designID="42003" materials="26"> <Bone refID="492" transformation="0,0,1,0.0075564822182059288,0.99997133016586304,0,-0.99997144937515259,0.0075564831495285034,0,3.7984278202056885,28.335988998413086,-16.705842971801758"> </Bone> </Part> </Brick> <Brick refID="475" designID="32013" itemNos="4107085"> <Part refID="475" designID="32013" materials="26"> <Bone refID="493" transformation="1,0,0,0,0,1,0,-1,0,3.0044887065887451,29.132944107055664,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="476" designID="43093" itemNos="4168884"> <Part refID="476" designID="43093" materials="26"> <Bone refID="494" transformation="0,0,-1.0000001192092896,0,1,0,1.0000001192092896,0,0,3.8044888973236084,29.132944107055664,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="477" designID="32525" itemNos="4156150"> <Part refID="477" designID="32525" materials="26"> <Bone refID="495" transformation="0,-1,0,0,0,-1,1,0,0,3.0044887065887451,32.332950592041016,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="478" designID="2780" itemNos="278026"> <Part refID="478" designID="2780" materials="26"> <Bone refID="496" transformation="0,0,1,0,1,0,-1,0,0,1.4044873714447021,32.332950592041016,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="479" designID="2780" itemNos="278026"> <Part refID="479" designID="2780" materials="26"> <Bone refID="497" transformation="0,0,1,0,1,0,-1,0,0,1.4044873714447021,24.332950592041016,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="480" designID="44353" itemNos="4183399"> <Part refID="480" designID="44353" materials="1"> <Bone refID="498" transformation="0,-0.40673643350601196,-0.91354554891586304,1,0,0,0,-0.91354554891586304,0.40673643350601196,0.60448646545410156,25.959897994995117,-9.0516605377197266"> </Bone> </Part> </Brick> <Brick refID="481" designID="6558" itemNos="655826"> <Part refID="481" designID="6558" materials="26"> <Bone refID="499" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,3.004486083984375,25.959897994995117,-9.0516605377197266"> </Bone> </Part> </Brick> <Brick refID="482" designID="32013" itemNos="4118981"> <Part refID="482" designID="32013" materials="1"> <Bone refID="500" transformation="0,1,0,1,0,0,0,0,-1,1.8044872283935547,29.570192337036133,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="483" designID="32073" itemNos="4114740"> <Part refID="483" designID="32073" materials="26"> <Bone refID="501" transformation="0.99999988079071045,0,0,0,0,1,0,-1,0,1.8044869899749756,26.37019157409668,-9.050816535949707"> </Bone> </Part> </Brick> <Brick refID="484" designID="32140" itemNos="4118980"> <Part refID="484" designID="32140" materials="1"> <Bone refID="502" transformation="-0.99999988079071045,0,0,0,0,-0.99999988079071045,0,-1,0,1.8044869899749756,28.770193099975586,-9.050816535949707"> </Bone> </Part> </Brick> <Brick refID="485" designID="32140" itemNos="4118980"> <Part refID="485" designID="32140" materials="1"> <Bone refID="503" transformation="-0.99999988079071045,0,0,0,0,-0.99999988079071045,0,-1,0,1.8044869899749756,27.970191955566406,-9.0508127212524414"> </Bone> </Part> </Brick> <Brick refID="486" designID="32013" itemNos="4118981"> <Part refID="486" designID="32013" materials="1"> <Bone refID="504" transformation="0,-1.0000003576278687,0,1,0,0,0,0,1.0000004768371582,1.8044869899749756,27.159900665283203,-9.0516595840454102"> </Bone> </Part> </Brick> <Brick refID="487" designID="32140" itemNos="4118980"> <Part refID="487" designID="32140" materials="1"> <Bone refID="505" transformation="-0.99999988079071045,0,0,0,0,-0.99999988079071045,0,-1,0,1.8044869899749756,27.170190811157227,-9.0508127212524414"> </Bone> </Part> </Brick> <Brick refID="488" designID="32192" itemNos="4144136"> <Part refID="488" designID="32192" materials="1"> <Bone refID="506" transformation="0,0.99999988079071045,0,0,0,-0.99999970197677612,-0.9999997615814209,0,0,0.20448684692382813,29.570188522338867,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="489" designID="32062" itemNos="4109810"> <Part refID="489" designID="32062" materials="26"> <Bone refID="507" transformation="0,-0.70710629224777222,-0.7071070671081543,0.9999997615814209,0,0,0,-0.70710694789886475,0.70710647106170654,0.20448608696460724,31.048032760620117,-9.3386564254760742"> </Bone> </Part> </Brick> <Brick refID="490" designID="43093" itemNos="4168884"> <Part refID="490" designID="43093" materials="26"> <Bone refID="508" transformation="0,0,-0.99999994039535522,-0.9999997615814209,0,0,0,1,0,0.20448608696460724,30.370189666748047,-9.0508184432983398"> </Bone> </Part> </Brick> <Brick refID="491" designID="32192" itemNos="4144136"> <Part refID="491" designID="32192" materials="1"> <Bone refID="509" transformation="0,0,0.99999970197677612,0,-0.99999982118606567,0,0.99999970197677612,0,0,0.20448608696460724,32.467239379882813,-11.947871208190918"> </Bone> </Part> </Brick> <Brick refID="492" designID="43093" itemNos="4168884"> <Part refID="492" designID="43093" materials="26"> <Bone refID="510" transformation="0.99999988079071045,0,0,0,0.99999982118606567,0,0,0,0.99999982118606567,0.20448608696460724,32.467239379882813,-11.147868156433105"> </Bone> </Part> </Brick> <Brick refID="493" designID="42003" itemNos="4173970"> <Part refID="493" designID="42003" materials="26"> <Bone refID="511" transformation="0.99999988079071045,0,0,0,1,0,0,0,0.99999988079071045,-0.59551239013671875,32.467243194580078,-11.947866439819336"> </Bone> </Part> </Brick> <Brick refID="494" designID="32192" itemNos="4144136"> <Part refID="494" designID="32192" materials="1"> <Bone refID="512" transformation="0,0.99999988079071045,0,0,0,-0.99999982118606567,-0.99999988079071045,0,0,-0.59551239013671875,29.570188522338867,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="495" designID="32062" itemNos="4109810"> <Part refID="495" designID="32062" materials="26"> <Bone refID="513" transformation="0,-0.70710635185241699,-0.70710700750350952,1,0,0,0,-0.70710700750350952,0.70710647106170654,-0.5955129861831665,31.048032760620117,-9.3386564254760742"> </Bone> </Part> </Brick> <Brick refID="496" designID="43093" itemNos="4168884"> <Part refID="496" designID="43093" materials="26"> <Bone refID="514" transformation="0,0,-1,-1,0,0,0,1,0,-0.5955129861831665,30.37019157409668,-9.0508184432983398"> </Bone> </Part> </Brick> <Brick refID="497" designID="32192" itemNos="4144136"> <Part refID="497" designID="32192" materials="1"> <Bone refID="515" transformation="0,0,0.99999982118606567,0,-0.9999997615814209,0,0.99999988079071045,0,0,-0.5955129861831665,32.467243194580078,-11.947867393493652"> </Bone> </Part> </Brick> <Brick refID="498" designID="43093" itemNos="4168884"> <Part refID="498" designID="43093" materials="26"> <Bone refID="516" transformation="1.0000001192092896,0,0,0,0.99999988079071045,0,0,0,1,-0.5955129861831665,32.467243194580078,-11.147871971130371"> </Bone> </Part> </Brick> <Brick refID="499" designID="2780" itemNos="278026"> <Part refID="499" designID="2780" materials="26"> <Bone refID="517" transformation="0,0,0.99999988079071045,0,1,0,-0.99999988079071045,0,0,-0.99551200866699219,32.467243194580078,-10.747869491577148"> </Bone> </Part> </Brick> <Brick refID="500" designID="2780" itemNos="278026"> <Part refID="500" designID="2780" materials="26"> <Bone refID="518" transformation="0,0,0.99999988079071045,0,1,0,-0.99999988079071045,0,0,-0.99551200866699219,30.77018928527832,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="501" designID="6558" itemNos="655826"> <Part refID="501" designID="6558" materials="26"> <Bone refID="519" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,3.004486083984375,30.770191192626953,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="502" designID="32524" itemNos="4142969"> <Part refID="502" designID="32524" materials="1"> <Bone refID="520" transformation="0,-1,0,0,0,1,-1,0,0,2.2044868469238281,30.770191192626953,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="503" designID="44352" itemNos="4183398"> <Part refID="503" designID="44352" materials="1"> <Bone refID="521" transformation="0,-0.40673685073852539,0.91354542970657349,1,0,0,0,0.91354542970657349,0.40673685073852539,0.60448646545410156,30.770191192626953,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="504" designID="43093" itemNos="4168884"> <Part refID="504" designID="43093" materials="26"> <Bone refID="522" transformation="0.99999982118606567,0,0,0,0,0.9999997615814209,0,-0.9999997615814209,0,0.20448684692382813,26.37019157409668,-9.0508136749267578"> </Bone> </Part> </Brick> <Brick refID="505" designID="32192" itemNos="4144136"> <Part refID="505" designID="32192" materials="1"> <Bone refID="523" transformation="0,-0.99999964237213135,0,0,0,-0.9999997615814209,0.9999997615814209,0,0,0.20448632538318634,27.170194625854492,-9.0508146286010742"> </Bone> </Part> </Brick> <Brick refID="506" designID="32062" itemNos="4109810"> <Part refID="506" designID="32062" materials="26"> <Bone refID="524" transformation="0,0.70710700750350952,-0.70710623264312744,0.99999982118606567,0,0,0,-0.70710635185241699,-0.70710694789886475,0.20448632538318634,24.560979843139648,-10.470023155212402"> </Bone> </Part> </Brick> <Brick refID="507" designID="32192" itemNos="4144136"> <Part refID="507" designID="32192" materials="1"> <Bone refID="525" transformation="0,0,0.9999997615814209,0,0.99999964237213135,0,-0.99999982118606567,0,0,0.20448632538318634,24.273143768310547,-11.947867393493652"> </Bone> </Part> </Brick> <Brick refID="508" designID="43093" itemNos="4168884"> <Part refID="508" designID="43093" materials="26"> <Bone refID="526" transformation="0,0.99999988079071045,0,-0.99999982118606567,0,0,0,0,0.99999988079071045,0.20448632538318634,24.273141860961914,-11.147868156433105"> </Bone> </Part> </Brick> <Brick refID="509" designID="2780" itemNos="278026"> <Part refID="509" designID="2780" materials="26"> <Bone refID="527" transformation="0,-0.99999982118606567,0,0,0,0.99999994039535522,-0.99999982118606567,0,0,-0.99551200866699219,25.970195770263672,-9.0508136749267578"> </Bone> </Part> </Brick> <Brick refID="510" designID="43093" itemNos="4168884"> <Part refID="510" designID="43093" materials="26"> <Bone refID="528" transformation="1,0,0,0,0,0.99999982118606567,0,-1,0,-0.59551239013671875,26.370195388793945,-9.0508136749267578"> </Bone> </Part> </Brick> <Brick refID="511" designID="32192" itemNos="4144136"> <Part refID="511" designID="32192" materials="1"> <Bone refID="529" transformation="0,-0.9999997615814209,0,0,0,-0.99999982118606567,0.99999982118606567,0,0,-0.59551239013671875,27.170190811157227,-9.0508146286010742"> </Bone> </Part> </Brick> <Brick refID="512" designID="32062" itemNos="4109810"> <Part refID="512" designID="32062" materials="26"> <Bone refID="530" transformation="0,0.70710700750350952,-0.70710629224777222,0.99999994039535522,0,0,0,-0.70710641145706177,-0.70710700750350952,-0.59551239013671875,24.560979843139648,-10.470023155212402"> </Bone> </Part> </Brick> <Brick refID="513" designID="32192" itemNos="4144136"> <Part refID="513" designID="32192" materials="1"> <Bone refID="531" transformation="0,0,0.99999982118606567,0,0.9999997615814209,0,-0.99999982118606567,0,0,-0.59551239013671875,24.273143768310547,-11.947871208190918"> </Bone> </Part> </Brick> <Brick refID="514" designID="43093" itemNos="4168884"> <Part refID="514" designID="43093" materials="26"> <Bone refID="532" transformation="0,1,0,-0.99999994039535522,0,0,0,0,0.99999994039535522,-0.59551239013671875,24.273141860961914,-11.14786434173584"> </Bone> </Part> </Brick> <Brick refID="515" designID="2780" itemNos="278026"> <Part refID="515" designID="2780" materials="26"> <Bone refID="533" transformation="0,-0.99999982118606567,0,0,0,0.99999994039535522,-0.99999982118606567,0,0,-0.99551200866699219,24.273143768310547,-10.747865676879883"> </Bone> </Part> </Brick> <Brick refID="516" designID="42003" itemNos="4173970"> <Part refID="516" designID="42003" materials="26"> <Bone refID="534" transformation="0.99999988079071045,0,0,0,1,0,0,0,0.99999988079071045,-0.59551239013671875,24.273141860961914,-11.947866439819336"> </Bone> </Part> </Brick> <Brick refID="517" designID="43093" itemNos="4168884"> <Part refID="517" designID="43093" materials="26"> <Bone refID="535" transformation="1,0,0,0,0,1,0,-1,0,1.0044879913330078,26.370189666748047,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="518" designID="6590" itemNos="4198121"> <Part refID="518" designID="6590" materials="1"> <Bone refID="536" transformation="0,0,-0.99999988079071045,-1,0,0,0,0.99999988079071045,0,1.0044879913330078,27.170188903808594,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="519" designID="6590" itemNos="4198121"> <Part refID="519" designID="6590" materials="1"> <Bone refID="537" transformation="0,0,-0.99999988079071045,-1,0,0,0,0.99999988079071045,0,1.0044879913330078,30.37019157409668,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="520" designID="43093" itemNos="4168884"> <Part refID="520" designID="43093" materials="26"> <Bone refID="538" transformation="1,0,0,0,0,-1,0,1,0,1.0044881105422974,30.370189666748047,-9.0508174896240234"> </Bone> </Part> </Brick> <Brick refID="521" designID="32013" itemNos="4107085"> <Part refID="521" designID="32013" materials="26"> <Bone refID="539" transformation="1,0,0,0,0,1,0,-1,0,3.004486083984375,27.532943725585938,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="522" designID="43093" itemNos="4168884"> <Part refID="522" designID="43093" materials="26"> <Bone refID="540" transformation="0,0,-1.0000001192092896,0,1,0,1.0000001192092896,0,0,3.8044860363006592,27.532943725585938,-12.705842971801758"> </Bone> </Part> </Brick> <Brick refID="523" designID="2780" itemNos="278026"> <Part refID="523" designID="2780" materials="26"> <Bone refID="541" transformation="1,0,0,0,1,0,0,0,1,4.2044887542724609,27.532943725585938,-11.505843162536621"> </Bone> </Part> </Brick> <Brick refID="524" designID="61073" itemNos="4527518"> <Part refID="524" designID="61073" materials="1"> <Bone refID="542" transformation="0,-1,0,-1,0,0,0,0,-1,4.2044892311096191,29.132944107055664,-12.305843353271484"> </Bone> </Part> </Brick> <Brick refID="525" designID="6558" itemNos="655826"> <Part refID="525" designID="6558" materials="26"> <Bone refID="543" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.3983817100524902,28.323884963989258,-16.705841064453125"> </Bone> </Part> </Brick> <Brick refID="526" designID="2780" itemNos="278026"> <Part refID="526" designID="2780" materials="26"> <Bone refID="544" transformation="-7.7220633102115244E-005,0,1,0.0079257674515247345,0.99996858835220337,0,-0.99996858835220337,0.0079257674515247345,-7.7220633102115244E-005,2.1984109878540039,28.348430633544922,-12.705902099609375"> </Bone> </Part> </Brick> <Brick refID="527" designID="43093" itemNos="4168884"> <Part refID="527" designID="43093" materials="26"> <Bone refID="545" transformation="0.99997097253799438,-0.0076190405525267124,0,0,-6.3887382566463202E-005,-1,0.0076190405525267124,0.99997097253799438,-6.3887382566463202E-005,4.1954092979431152,27.93248176574707,-21.505813598632812"> </Bone> </Part> </Brick> <Brick refID="528" designID="32013" itemNos="4107085"> <Part refID="528" designID="32013" materials="26"> <Bone refID="546" transformation="0.0075566484592854977,0.99997138977050781,0,0.99997144937515259,-0.007556648924946785,0,0,0,-0.99999994039535522,4.1893515586853027,27.132991790771484,-21.505844116210937"> </Bone> </Part> </Brick> <Brick refID="529" designID="43093" itemNos="4168884"> <Part refID="529" designID="43093" materials="26"> <Bone refID="547" transformation="0.99997097253799438,-0.0076190405525267124,0,0,-6.3887382566463202E-005,-1,0.0076190405525267124,0.99997097253799438,-6.3887382566463202E-005,4.1954092979431152,27.932737350463867,-17.505813598632812"> </Bone> </Part> </Brick> <Brick refID="530" designID="32013" itemNos="4107085"> <Part refID="530" designID="32013" materials="26"> <Bone refID="548" transformation="0.0076114539988338947,0.99997097253799438,-6.3797349866945297E-005,0.99997103214263916,-0.007611454464495182,0,0,-6.3797699112910777E-005,-1,4.1893138885498047,27.132761001586914,-17.505762100219727"> </Bone> </Part> </Brick> <Brick refID="531" designID="2780" itemNos="278026"> <Part refID="531" designID="2780" materials="26"> <Bone refID="549" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1893301010131836,27.132863998413086,-15.905763626098633"> </Bone> </Part> </Brick> <Brick refID="532" designID="32034" itemNos="4107783"> <Part refID="532" designID="32034" materials="26"> <Bone refID="550" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1801486015319824,25.9326171875,-20.305685043334961"> </Bone> </Part> </Brick> <Brick refID="533" designID="4519" itemNos="451926"> <Part refID="533" designID="4519" materials="26"> <Bone refID="551" transformation="0.99997073411941528,-0.0076502799056470394,0,0.0076502799056470394,0.99997073411941528,-6.4182619098573923E-005,0,6.4184503571595997E-005,1,4.1801495552062988,25.93287467956543,-16.305686950683594"> </Bone> </Part> </Brick> <Brick refID="534" designID="32013" itemNos="4107085"> <Part refID="534" designID="32013" materials="26"> <Bone refID="552" transformation="0,6.4184838265646249E-005,1,0.007650280836969614,0.99997085332870483,-6.4182626374531537E-005,-0.99997073411941528,0.0076502799056470394,0,4.1801495552062988,25.932823181152344,-17.105686187744141"> </Bone> </Part> </Brick> <Brick refID="535" designID="43093" itemNos="4168884"> <Part refID="535" designID="43093" materials="26"> <Bone refID="553" transformation="0.99997061491012573,-0.0076502999290823936,0,0.0076503008604049683,0.99997073411941528,0,0,0,1,4.1801486015319824,25.932668685913086,-19.505685806274414"> </Bone> </Part> </Brick> <Brick refID="536" designID="72039" itemNos="4113010"> <Part refID="536" designID="72039" materials="26"> <Bone refID="554" transformation="0,1,0,0.97724610567092896,0,0.21210856735706329,0.21210856735706329,0,-0.97724610567092896,4.0994329452514648,16.733137130737305,-19.102024078369141"> </Bone> <Bone refID="555" transformation="0.0090677319094538689,0.94516867399215698,-0.32645663619041443,0.97531169652938843,0.063677802681922913,0.2114526778459549,0.22064648568630219,-0.32031437754631042,-0.9212566614151001,4.0994329452514648,17.533136367797852,-19.102024078369141"> </Bone> <Bone refID="556" transformation="0.012672026641666889,0.81673604249954224,-0.57687228918075562,0.97434544563293457,0.11955852061510086,0.19067424535751343,0.22470052540302277,-0.56448912620544434,-0.79426801204681396,4.106687068939209,18.289272308349609,-19.363189697265625"> </Bone> <Bone refID="557" transformation="0.01146106980741024,0.67316782474517822,-0.73940092325210571,0.9741513729095459,0.15931785106658936,0.16014650464057922,0.22560523450374603,-0.72212386131286621,-0.65394139289855957,4.1168246269226074,18.942661285400391,-19.824687957763672"> </Bone> <Bone refID="558" transformation="0.0071502458304166794,0.55954504013061523,-0.82876908779144287,0.97443407773971558,0.18221896886825562,0.13143245875835419,0.22455982863903046,-0.8085206151008606,-0.54393684864044189,4.1259937286376953,19.481195449829102,-20.416210174560547"> </Bone> <Bone refID="559" transformation="0.0015389150939881802,0.50095546245574951,-0.86547172069549561,0.97495663166046143,0.19172094762325287,0.11270619928836823,0.2223898321390152,-0.84397077560424805,-0.48811477422714233,4.1317138671875,19.928831100463867,-21.079225540161133"> </Bone> <Bone refID="560" transformation="-0.0038440851494669914,0.50712835788726807,-0.8618619441986084,0.97556191682815552,0.19124799966812134,0.10818105936050415,0.21969105303287506,-0.84038382768630981,-0.49547028541564941,4.1329450607299805,20.329595565795898,-21.771602630615234"> </Bone> <Bone refID="561" transformation="-0.0076259621419012547,0.57705950736999512,-0.81666648387908936,0.97611570358276367,0.18161872029304504,0.11921756714582443,0.2171175628900528,-0.79625183343887329,-0.56466186046600342,4.1298699378967285,20.735298156738281,-22.461093902587891"> </Bone> <Bone refID="562" transformation="-0.0083373971283435822,0.69850528240203857,-0.71555632352828979,0.97641521692276001,0.16007164120674133,0.14488045871257782,0.21574003994464874,-0.69747215509414673,-0.68336576223373413,4.1237688064575195,21.196945190429688,-23.114425659179688"> </Bone> <Bone refID="563" transformation="-0.0043158857151865959,0.84288686513900757,-0.53807353973388672,0.97606867551803589,0.12054077535867691,0.18099689483642578,0.21741969883441925,-0.52441555261611938,-0.82323569059371948,4.1170988082885742,21.755748748779297,-23.686870574951172"> </Bone> <Bone refID="564" transformation="0.0017700818134471774,0.96316355466842651,-0.26891037821769714,0.97457271814346313,0.058591932058334351,0.21627534925937653,0.22406452894210815,-0.26245555281639099,-0.93856924772262573,4.1136460304260254,22.430059432983398,-24.117330551147461"> </Bone> <Bone refID="565" transformation="0.0067826411686837673,0.99720340967178345,0.07442648708820343,0.97175151109695435,-0.024131596088409424,0.23476949334144592,0.23590897023677826,0.070731692016124725,-0.96919757127761841,4.1150622367858887,23.200590133666992,-24.33245849609375"> </Bone> <Bone refID="566" transformation="0.010428120382130146,0.91158312559127808,0.41098356246948242,0.96845734119415283,-0.11153726279735565,0.22282229363918304,0.24896101653575897,0.39569643139839172,-0.88399249315261841,4.120488166809082,23.99835205078125,-24.272916793823242"> </Bone> <Bone refID="567" transformation="0.014432007446885109,0.71600443124771118,0.69794648885726929,0.96470528841018677,-0.19352434575557709,0.17858339846134186,0.26293614506721497,0.67073535919189453,-0.69352620840072632,4.1288309097290039,24.727621078491211,-23.944129943847656"> </Bone> <Bone refID="568" transformation="0.017832579091191292,0.4685671329498291,0.88324791193008423,0.96171313524246216,-0.24966342747211456,0.11303083598613739,0.2734772264957428,0.8474155068397522,-0.45507931709289551,4.1403765678405762,25.300424575805664,-23.385772705078125"> </Bone> <Bone refID="569" transformation="0.018402224406599998,0.24181070923805237,0.97014892101287842,0.96057170629501343,-0.27350842952728271,0.049951720982789993,0.27742275595664978,0.93097835779190063,-0.23730967938899994,4.1546425819396973,25.675277709960938,-22.679172515869141"> </Bone> <Bone refID="570" transformation="0.013481179252266884,0.079927742481231689,0.99670946598052979,0.96152621507644653,-0.27456527948379517,0.0090125324204564095,0.27438217401504517,0.958240807056427,-0.080554082989692688,4.1693644523620605,25.86872673034668,-21.903053283691406"> </Bone> <Bone refID="571" transformation="0,0,1,0.96391975879669189,-0.26619300246238708,0,0.26619300246238708,0.96391975879669189,0,4.1801495552062988,25.932668685913086,-21.105686187744141"> </Bone> <Bone refID="572" transformation="0.26619303226470947,0.96391975879669189,0,0.96391969919204712,-0.2661929726600647,0,0,0,-1,4.180150032043457,25.932668685913086,-20.305686950683594"> </Bone> </Part> </Brick> <Brick refID="537" designID="32013" itemNos="4107085"> <Part refID="537" designID="32013" materials="26"> <Bone refID="573" transformation="0,-1,0,0,0,-1,1,0,0,4.0994329452514648,16.733139038085938,-19.102024078369141"> </Bone> </Part> </Brick> <Brick refID="538" designID="43093" itemNos="4168884"> <Part refID="538" designID="43093" materials="26"> <Bone refID="574" transformation="1,0,0,0,0,1,0,-1,0,4.0994329452514648,15.933138847351074,-19.102024078369141"> </Bone> </Part> </Brick> <Brick refID="539" designID="2780" itemNos="278026"> <Part refID="539" designID="2780" materials="26"> <Bone refID="575" transformation="1,0,0,0,1,0,0,0,1,4.0994329452514648,15.533139228820801,-17.902023315429688"> </Bone> </Part> </Brick> <Brick refID="540" designID="2780" itemNos="278026"> <Part refID="540" designID="2780" materials="26"> <Bone refID="576" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1893291473388672,27.132658004760742,-19.10576057434082"> </Bone> </Part> </Brick> <Brick refID="541" designID="43093" itemNos="4168884"> <Part refID="541" designID="43093" materials="26"> <Bone refID="577" transformation="0,-6.4123945776373148E-005,-1,-0.99997073411941528,0.0076502272859215736,0,0.0076502272859215736,0.99997073411941528,-6.4122068579308689E-005,4.1954631805419922,27.932891845703125,-15.105814933776855"> </Bone> </Part> </Brick> <Brick refID="542" designID="43093" itemNos="4168884"> <Part refID="542" designID="43093" materials="26"> <Bone refID="578" transformation="0,-6.4123945776373148E-005,-1,-0.99997073411941528,0.0076502272859215736,0,0.0076502272859215736,0.99997073411941528,-6.4122068579308689E-005,4.195460319519043,27.932584762573242,-19.905813217163086"> </Bone> </Part> </Brick> <Brick refID="543" designID="6553" itemNos="4107765"> <Part refID="543" designID="6553" materials="26"> <Bone refID="579" transformation="-0.0076658888719975948,-0.99997061491012573,6.4305218984372914E-005,0.99997061491012573,-0.0076658888719975948,0,0,6.4308442233595997E-005,1,4.1923942565917969,27.532724380493164,-17.905788421630859"> </Bone> </Part> </Brick> <Brick refID="544" designID="32123" itemNos="4270046"> <Part refID="544" designID="32123" materials="26"> <Bone refID="580" transformation="0.99997061491012573,-0.0076657976023852825,0,0.0076657976023852825,0.99997061491012573,0,0,0,1,4.1923942565917969,27.532724380493164,-17.905788421630859"> </Bone> </Part> </Brick> <Brick refID="545" designID="32316" itemNos="4140429"> <Part refID="545" designID="32316" materials="26"> <Bone refID="581" transformation="1,0,0,0,1,0,0,0,1,2.5952339172363281,27.520332336425781,-18.302145004272461"> </Bone> </Part> </Brick> <Brick refID="546" designID="43093" itemNos="4168884"> <Part refID="546" designID="43093" materials="26"> <Bone refID="582" transformation="-0.0079856542870402336,-0.99996811151504517,0,7.7279175457078964E-005,0,-1,0.99996811151504517,-0.0079856542870402336,7.7281642006710172E-005,6.1888151168823242,26.717170715332031,-17.502111434936523"> </Bone> </Part> </Brick> <Brick refID="547" designID="93571" itemNos="4610948"> <Part refID="547" designID="93571" materials="26"> <Bone refID="583" transformation="-0.0080079762265086174,-0.99996793270111084,0,0.99996805191040039,-0.008007977157831192,7.7523036452475935E-005,-7.751916564302519E-005,0,1,5.801640510559082,28.320304870605469,-17.502141952514648"> </Bone> </Part> </Brick> <Brick refID="548" designID="43093" itemNos="4168884"> <Part refID="548" designID="43093" materials="26"> <Bone refID="584" transformation="0.99996793270111084,-0.0080079175531864166,0,0.0080079175531864166,0.99996793270111084,0,0,0,1,5.795234203338623,27.520330429077148,-17.502141952514648"> </Bone> </Part> </Brick> <Brick refID="549" designID="43093" itemNos="4168884"> <Part refID="549" designID="43093" materials="26"> <Bone refID="585" transformation="-1.0000001192092896,0,0,0,1,0,0,0,-1,5.795234203338623,27.520330429077148,-17.502141952514648"> </Bone> </Part> </Brick> <Brick refID="550" designID="32316" itemNos="4140429"> <Part refID="550" designID="32316" materials="26"> <Bone refID="586" transformation="1,0,0,0,1,0,0,0,1,2.5953357219696045,27.545858383178711,-15.902390480041504"> </Bone> </Part> </Brick> <Brick refID="551" designID="43093" itemNos="4168884"> <Part refID="551" designID="43093" materials="26"> <Bone refID="587" transformation="-0.0079855667427182198,-0.99996811151504517,0,-7.7277400123421103E-005,0,1,-0.99996811151504517,0.0079855667427182198,-7.7279866673052311E-005,2.1889426708221436,26.749088287353516,-17.502420425415039"> </Bone> </Part> </Brick> <Brick refID="552" designID="93571" itemNos="4610948"> <Part refID="552" designID="93571" materials="26"> <Bone refID="588" transformation="-0.0080079259350895882,-0.99996793270111084,0,0.99996805191040039,-0.0080079259350895882,7.7522621722891927E-005,-7.7519456681329757E-005,0,1,2.6017425060272217,28.345832824707031,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="553" designID="43093" itemNos="4168884"> <Part refID="553" designID="43093" materials="26"> <Bone refID="589" transformation="0.99996793270111084,-0.0080079175531864166,0,0.0080079175531864166,0.99996793270111084,0,0,0,1,2.5953361988067627,27.545858383178711,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="554" designID="43093" itemNos="4168884"> <Part refID="554" designID="43093" materials="26"> <Bone refID="590" transformation="-1,0,0,0,1,0,0,0,-1,2.5953361988067627,27.545858383178711,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="555" designID="53585" itemNos="4286267"> <Part refID="555" designID="53585" materials="26"> <Bone refID="591" transformation="0,0,1,0,1.0000001192092896,0,-1,0,0,2.6017422676086426,28.345832824707031,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="556" designID="3708" itemNos="370826"> <Part refID="556" designID="3708" materials="26"> <Bone refID="592" transformation="0,0,1,0,1.0000001192092896,0,-1,0,0,-0.17825794219970703,28.345832824707031,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="557" designID="41677" itemNos="4164133"> <Part refID="557" designID="41677" materials="26"> <Bone refID="593" transformation="0,0,1,0,1,0,-1,0,0,6.5984683036804199,28.314212799072266,-18.305845260620117"> </Bone> </Part> </Brick> <Brick refID="558" designID="32062" itemNos="4109810"> <Part refID="558" designID="32062" materials="26"> <Bone refID="594" transformation="0,0,1,0,1.0000002384185791,0,-1,0,0,6.1984682083129883,28.314212799072266,-18.305843353271484"> </Bone> </Part> </Brick> <Brick refID="559" designID="32123" itemNos="4270046"> <Part refID="559" designID="32123" materials="26"> <Bone refID="595" transformation="0,0,1,0,1,0,-1,0,0,6.1984682083129883,28.314212799072266,-18.305843353271484"> </Bone> </Part> </Brick> <Brick refID="560" designID="32054" itemNos="4107742"> <Part refID="560" designID="32054" materials="26"> <Bone refID="596" transformation="0,0,-1,0,1.0000002384185791,0,1,0,0,9.3984689712524414,28.314212799072266,-18.305845260620117"> </Bone> </Part> </Brick> <Brick refID="561" designID="41677" itemNos="4164133"> <Part refID="561" designID="41677" materials="26"> <Bone refID="597" transformation="0,0,1,0,1,0,-1,0,0,6.1983480453491211,28.314662933349609,-17.502849578857422"> </Bone> </Part> </Brick> <Brick refID="562" designID="32062" itemNos="4109810"> <Part refID="562" designID="32062" materials="26"> <Bone refID="598" transformation="0,0,1,0,1.0000002384185791,0,-1,0,0,6.1983480453491211,28.314662933349609,-16.702850341796875"> </Bone> </Part> </Brick> <Brick refID="563" designID="32123" itemNos="4270046"> <Part refID="563" designID="32123" materials="26"> <Bone refID="599" transformation="0,0,1,0,1,0,-1,0,0,6.5983481407165527,28.314662933349609,-16.702850341796875"> </Bone> </Part> </Brick> <Brick refID="564" designID="32054" itemNos="4107742"> <Part refID="564" designID="32054" materials="26"> <Bone refID="600" transformation="0,0,-1,0,1.0000002384185791,0,1,0,0,9.3983488082885742,28.314662933349609,-16.702850341796875"> </Bone> </Part> </Brick> <Brick refID="565" designID="32138" itemNos="4119589"> <Part refID="565" designID="32138" materials="26"> <Bone refID="601" transformation="0,0,-1,0,1,0,1,0,0,1.821742057800293,27.145832061767578,-17.102390289306641"> </Bone> </Part> </Brick> <Brick refID="566" designID="4266" itemNos="426621"> <Part refID="566" designID="4266" materials="21"> <Bone refID="602" transformation="0,1.0000002384185791,-0.00016204429266508669,0,0.00016204419080168009,1,1,0,0,8.7064733505249023,28.314342498779297,-17.505840301513672"> </Bone> </Part> </Brick> <Brick refID="567" designID="53585" itemNos="4286267"> <Part refID="567" designID="53585" materials="26"> <Bone refID="603" transformation="0,0,1,0,1.0000001192092896,0,-1,0,0,5.8016400337219238,28.320304870605469,-17.502141952514648"> </Bone> </Part> </Brick> <Brick refID="568" designID="32474" itemNos="4143539"> <Part refID="568" designID="32474" materials="26"> <Bone refID="604" transformation="0,0,-1,0,0.99999994039535522,0,1,0,0,0.60434114933013916,28.345832824707031,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="569" designID="32034" itemNos="4107783"> <Part refID="569" designID="32034" materials="26"> <Bone refID="605" transformation="0,0,1,0,1,0,-1,0,0,1.0217422246932983,28.345832824707031,-18.702390670776367"> </Bone> </Part> </Brick> <Brick refID="570" designID="32062" itemNos="4109810"> <Part refID="570" designID="32062" materials="26"> <Bone refID="606" transformation="1,0,0,0,1,0,0,0,1,1.0217419862747192,28.345832824707031,-15.50239086151123"> </Bone> </Part> </Brick> <Brick refID="571" designID="93571" itemNos="4610948"> <Part refID="571" designID="93571" materials="26"> <Bone refID="607" transformation="1,0,0,0,0.99999988079071045,0,0,0,1,0.22174201905727386,28.345832824707031,-15.50239086151123"> </Bone> </Part> </Brick> <Brick refID="572" designID="32062" itemNos="4109810"> <Part refID="572" designID="32062" materials="26"> <Bone refID="608" transformation="1,0,0,0,1,0,0,0,1,1.0217422246932983,28.345832824707031,-17.90239143371582"> </Bone> </Part> </Brick> <Brick refID="573" designID="93571" itemNos="4610948"> <Part refID="573" designID="93571" materials="26"> <Bone refID="609" transformation="1,0,0,0,0.99999988079071045,0,0,0,1,0.22174200415611267,28.345832824707031,-19.502391815185547"> </Bone> </Part> </Brick> <Brick refID="574" designID="43093" itemNos="4168884"> <Part refID="574" designID="43093" materials="26"> <Bone refID="610" transformation="0.99999988079071045,0,0,0,0,1,0,-1.0000001192092896,0,1.821742057800293,27.945833206176758,-19.502391815185547"> </Bone> </Part> </Brick> <Brick refID="575" designID="43093" itemNos="4168884"> <Part refID="575" designID="43093" materials="26"> <Bone refID="611" transformation="0.99999988079071045,0,0,0,0,1,0,-1.0000001192092896,0,1.821742057800293,27.945833206176758,-15.50239086151123"> </Bone> </Part> </Brick> <Brick refID="576" designID="32523" itemNos="4142822"> <Part refID="576" designID="32523" materials="26"> <Bone refID="612" transformation="0,0,1,0.99999994039535522,0,0,0,1.0000001192092896,0,1.821742057800293,29.545833587646484,-19.502391815185547"> </Bone> </Part> </Brick> <Brick refID="577" designID="32523" itemNos="4142822"> <Part refID="577" designID="32523" materials="26"> <Bone refID="613" transformation="0,0,1,0.99999988079071045,0,0,0,1.0000001192092896,0,1.821742057800293,29.545833587646484,-17.102390289306641"> </Bone> </Part> </Brick> <Brick refID="578" designID="60483" itemNos="4515185"> <Part refID="578" designID="60483" materials="26"> <Bone refID="614" transformation="0,0,1,0.99999988079071045,0,0,0,0.99999994039535522,0,1.8217421770095825,27.945831298828125,-18.702388763427734"> </Bone> </Part> </Brick> <Brick refID="579" designID="32062" itemNos="4109810"> <Part refID="579" designID="32062" materials="26"> <Bone refID="615" transformation="-0.99999988079071045,0,0,0,0,-0.99999988079071045,0,-1,0,1.821742057800293,27.145830154418945,-18.702388763427734"> </Bone> </Part> </Brick> <Brick refID="580" designID="32054" itemNos="4107742"> <Part refID="580" designID="32054" materials="26"> <Bone refID="616" transformation="0,0,0.99999988079071045,0.99999988079071045,0,0,0,1.0000001192092896,0,1.8217417001724243,30.345830917358398,-18.702388763427734"> </Bone> </Part> </Brick> <Brick refID="581" designID="60483" itemNos="4515185"> <Part refID="581" designID="60483" materials="26"> <Bone refID="617" transformation="0,0,-1,-0.99999988079071045,0,0,0,1,0,1.821742057800293,27.945831298828125,-16.302391052246094"> </Bone> </Part> </Brick> <Brick refID="582" designID="32062" itemNos="4109810"> <Part refID="582" designID="32062" materials="26"> <Bone refID="618" transformation="-0.99999988079071045,0,0,0,0,-0.99999988079071045,0,-1,0,1.8217421770095825,27.145832061767578,-16.302391052246094"> </Bone> </Part> </Brick> <Brick refID="583" designID="32054" itemNos="4107742"> <Part refID="583" designID="32054" materials="26"> <Bone refID="619" transformation="0,0,0.99999988079071045,0.99999988079071045,0,0,0,1.0000001192092896,0,1.8217418193817139,30.345830917358398,-16.302391052246094"> </Bone> </Part> </Brick> <Brick refID="584" designID="64276" itemNos="4537514"> <Part refID="584" designID="64276" materials="26"> <Bone refID="620" transformation="-1,0,0,0,1,0,0,0,-1,0.22174200415611267,28.345832824707031,-19.502391815185547"> </Bone> </Part> </Brick> <Brick refID="585" designID="3705" itemNos="370526"> <Part refID="585" designID="3705" materials="26"> <Bone refID="621" transformation="1,0,0,0,1,0,0,0,1,-2.178257942199707,28.345832824707031,-17.90239143371582"> </Bone> </Part> </Brick> <Brick refID="586" designID="32034" itemNos="4107783"> <Part refID="586" designID="32034" materials="26"> <Bone refID="622" transformation="0,0,0.99999994039535522,-0.99999994039535522,0,0,0,-1.0000001192092896,0,-2.178257942199707,28.345832824707031,-18.702390670776367"> </Bone> </Part> </Brick> <Brick refID="587" designID="64276" itemNos="4537514"> <Part refID="587" designID="64276" materials="26"> <Bone refID="623" transformation="-1,0,0,0,1,0,0,0,-1,0.22174201905727386,28.345832824707031,-15.50239086151123"> </Bone> </Part> </Brick> <Brick refID="588" designID="3705" itemNos="370526"> <Part refID="588" designID="3705" materials="26"> <Bone refID="624" transformation="1,0,0,0,1,0,0,0,1,-2.178257942199707,28.345832824707031,-13.90239143371582"> </Bone> </Part> </Brick> <Brick refID="589" designID="6558" itemNos="655826"> <Part refID="589" designID="6558" materials="26"> <Bone refID="625" transformation="1,0,0,0,0,-1,0,1,0,-2.178257942199707,29.545833587646484,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="590" designID="93571" itemNos="4610948"> <Part refID="590" designID="93571" materials="26"> <Bone refID="626" transformation="-1,0,0,0,1,0,0,0,-1,0.23616513609886169,28.344837188720703,-17.501209259033203"> </Bone> </Part> </Brick> <Brick refID="591" designID="4519" itemNos="451926"> <Part refID="591" designID="4519" materials="26"> <Bone refID="627" transformation="0.99999988079071045,0,0,0,0,1,0,-1.0000001192092896,0,-1.3638348579406738,27.144838333129883,-17.501209259033203"> </Bone> </Part> </Brick> <Brick refID="592" designID="32140" itemNos="4120017"> <Part refID="592" designID="32140" materials="26"> <Bone refID="628" transformation="-0.99999988079071045,0,0,0,0,0.99999988079071045,0,1.0000001192092896,0,-1.3782579898834229,29.545833587646484,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="593" designID="32140" itemNos="4120017"> <Part refID="593" designID="32140" materials="26"> <Bone refID="629" transformation="-0.99999988079071045,0,0,0,0,0.99999988079071045,0,1.0000001192092896,0,-1.3782579898834229,27.945833206176758,-17.502389907836914"> </Bone> </Part> </Brick> <Brick refID="594" designID="6553" itemNos="4107765"> <Part refID="594" designID="6553" materials="26"> <Bone refID="630" transformation="0,-1,0,-1,0,0,0,0,-1,4.195335865020752,27.545858383178711,-17.102390289306641"> </Bone> </Part> </Brick> <Brick refID="595" designID="32123" itemNos="4270046"> <Part refID="595" designID="32123" materials="26"> <Bone refID="631" transformation="1,0,0,0,1,0,0,0,1,4.195335865020752,27.545858383178711,-16.702390670776367"> </Bone> </Part> </Brick> <Brick refID="596" designID="2780" itemNos="278026"> <Part refID="596" designID="2780" materials="26"> <Bone refID="632" transformation="0,-6.3947409216780216E-005,-1,-0.99996984004974365,0.0077665792778134346,0,0.0077665792778134346,0.99996984004974365,-6.3945481088012457E-005,2.527475118637085,19.145540237426758,-15.902251243591309"> </Bone> </Part> </Brick> <Brick refID="597" designID="32528" itemNos="4143419"> <Part refID="597" designID="32528" materials="26"> <Bone refID="633" transformation="0,-6.3886524003464729E-005,-1,0.0078124259598553181,0.999969482421875,-6.388847396010533E-005,0.999969482421875,-0.0078124259598553181,0,2.5212621688842773,18.345615386962891,-15.102201461791992"> </Bone> </Part> </Brick> <Brick refID="598" designID="2780" itemNos="278026"> <Part refID="598" designID="2780" materials="26"> <Bone refID="634" transformation="0,-6.3946892623789608E-005,-1,-0.99996966123580933,0.007789581548422575,0,0.007789581548422575,0.99996966123580933,-6.3944949943106622E-005,2.5275120735168457,19.145587921142578,-15.102252006530762"> </Bone> </Part> </Brick> <Brick refID="599" designID="2780" itemNos="278026"> <Part refID="599" designID="2780" materials="26"> <Bone refID="635" transformation="0,-6.3946870795916766E-005,-1,-0.99996966123580933,0.0077895685099065304,0,0.0077895685099065304,0.99996966123580933,-6.3944928115233779E-005,2.5275096893310547,19.145286560058594,-19.902250289916992"> </Bone> </Part> </Brick> <Brick refID="600" designID="32527" itemNos="4143417"> <Part refID="600" designID="32527" materials="26"> <Bone refID="636" transformation="0,-6.3886524003464729E-005,-1,0.00782005675137043,0.99996942281723022,-6.388847396010533E-005,0.99996942281723022,-0.00782005675137043,0,2.521277904510498,18.345312118530273,-19.902200698852539"> </Bone> </Part> </Brick> <Brick refID="601" designID="2780" itemNos="278026"> <Part refID="601" designID="2780" materials="26"> <Bone refID="637" transformation="0,-6.3946892623789608E-005,-1,-0.99996966123580933,0.007789581548422575,0,0.007789581548422575,0.99996966123580933,-6.3944949943106622E-005,2.5275099277496338,19.14533805847168,-19.102249145507813"> </Bone> </Part> </Brick> <Brick refID="602" designID="32054" itemNos="4107742"> <Part refID="602" designID="32054" materials="26"> <Bone refID="638" transformation="-0.00016239013348240405,-3.7772384530398995E-005,1,-0.0077750235795974731,-0.99996978044509888,-3.9033828215906397E-005,0.99996978044509888,-0.0077750300988554955,0.00016209154273383319,1.2996652126312256,15.554940223693848,-17.501960754394531"> </Bone> </Part> </Brick> <Brick refID="603" designID="32062" itemNos="4109810"> <Part refID="603" designID="32062" materials="26"> <Bone refID="639" transformation="0.00016230266191996634,3.777554229600355E-005,-1,-0.0077750245109200478,-0.99996989965438843,-3.9030703192111105E-005,-0.99996978044509888,0.0077750273048877716,-0.00016200399841181934,-1.9002436399459839,15.579819679260254,-17.502477645874023"> </Bone> </Part> </Brick> <Brick refID="604" designID="4266" itemNos="426621"> <Part refID="604" designID="4266" materials="21"> <Bone refID="640" transformation="0.00018232721777167171,3.6828321754001081E-005,-1,-0.0077446377836167812,-0.99997013807296753,-3.9151498640421778E-005,-0.99997001886367798,0.0077446391806006432,-0.00018202599312644452,-1.6602532863616943,15.577949523925781,-17.502439498901367"> </Bone> </Part> </Brick> <Brick refID="605" designID="55817" itemNos="4515961"> <Part refID="605" designID="55817" materials="26"> <Bone refID="641" transformation="-0.0077616320922970772,-0.99996989965438843,4.1238756239181384E-005,-0.00014843921235296875,4.2392162868054584E-005,1,-0.99996984004974365,0.0077616255730390549,-0.00014876376371830702,0.49868771433830261,15.561156272888184,-17.502079010009766"> </Bone> </Part> </Brick> <Brick refID="606" designID="43093" itemNos="4168884"> <Part refID="606" designID="43093" materials="26"> <Bone refID="642" transformation="0.9999687671661377,-0.007903609424829483,0,0,6.3953048083931208E-005,1,-0.007903609424829483,-0.9999687671661377,6.3955048972275108E-005,3.2962276935577393,15.13925838470459,-16.701997756958008"> </Bone> </Part> </Brick> <Brick refID="607" designID="32062" itemNos="4109810"> <Part refID="607" designID="32062" materials="26"> <Bone refID="643" transformation="0.0045106946490705013,0.382600337266922,-0.92390292882919312,0.0072072679176926613,0.92387592792510986,0.38262432813644409,0.99996387958526611,-0.0083847176283597946,0.001409818883985281,2.1649582386016846,23.982765197753906,-18.065105438232422"> </Bone> </Part> </Brick> <Brick refID="608" designID="32039" itemNos="4107081"> <Part refID="608" designID="32039" materials="26"> <Bone refID="644" transformation="-0.99996429681777954,0.008345460519194603,-0.0014260491589084268,0.0045106769539415836,0.3826015293598175,-0.92390257120132446,-0.0071647819131612778,-0.92387592792510986,-0.38262537121772766,1.7563760280609131,22.877450942993164,-18.52482795715332"> </Bone> </Part> </Brick> <Brick refID="609" designID="32073" itemNos="4114740"> <Part refID="609" designID="32073" materials="26"> <Bone refID="645" transformation="0.0029675434343516827,0.38261428475379944,-0.92390352487564087,-0.99997007846832275,0.0077549945563077927,0,0.0071647469885647297,0.92387580871582031,0.38262578845024109,1.7621080875396729,23.616552352905273,-18.218727111816406"> </Bone> </Part> </Brick> <Brick refID="610" designID="32016" itemNos="4107082"> <Part refID="610" designID="32016" materials="26"> <Bone refID="646" transformation="0.00775505555793643,0.99997007846832275,-6.4075502450577915E-005,0,6.3966770539991558E-005,1,0.99997007846832275,-0.0077550564892590046,0,1.7212772369384766,18.351535797119141,-19.902204513549805"> </Bone> </Part> </Brick> <Brick refID="611" designID="43093" itemNos="4168884"> <Part refID="611" designID="43093" materials="26"> <Bone refID="647" transformation="0.9999699592590332,-0.0077511542476713657,0,0,-6.3966770539991558E-005,-1,0.007751154713332653,0.99997007846832275,-6.4048741478472948E-005,1.7274783849716187,19.151508331298828,-19.902254104614258"> </Bone> </Part> </Brick> <Brick refID="612" designID="32177" itemNos="4120182"> <Part refID="612" designID="32177" materials="26"> <Bone refID="648" transformation="0.0065842862240970135,0.92388087511062622,0.38262361288070679,-0.0028628488071262836,-0.3826129138469696,0.92390447854995728,0.99997431039810181,-0.0071786460466682911,0.00012569899263326079,1.3333758115768433,19.553878784179687,-19.901798248291016"> </Bone> </Part> </Brick> <Brick refID="613" designID="43093" itemNos="4168884"> <Part refID="613" designID="43093" materials="26"> <Bone refID="649" transformation="-0.0028628746513277292,-0.38261285424232483,0.92390435934066772,0.0065531199797987938,0.92388129234313965,0.38262355327606201,-0.99997448921203613,0.0071498588658869267,-0.00013765000039711595,0.53339600563049316,19.559621810913086,-19.901901245117188"> </Bone> </Part> </Brick> <Brick refID="614" designID="60483" itemNos="4515185"> <Part refID="614" designID="60483" materials="26"> <Bone refID="650" transformation="0.99997347593307495,-0.0071647036820650101,-0.0014251179527491331,0.0014247669605538249,0.38262578845024109,-0.92390233278274536,0.0071647721342742443,0.92387568950653076,0.38262569904327393,1.7449126243591309,21.399250030517578,-19.137027740478516"> </Bone> </Part> </Brick> <Brick refID="615" designID="60483" itemNos="4515185"> <Part refID="615" designID="60483" materials="26"> <Bone refID="651" transformation="0.99997347593307495,-0.0071647032164037228,-0.0014251177199184895,0.0014247671933844686,0.38262578845024109,-0.92390233278274536,0.0071647725999355316,0.92387568950653076,0.38262569904327393,1.7563762664794922,22.877450942993164,-18.52482795715332"> </Bone> </Part> </Brick> <Brick refID="616" designID="6558" itemNos="655826"> <Part refID="616" designID="6558" materials="26"> <Bone refID="652" transformation="0.99997329711914063,-0.0071647241711616516,-0.0014252136461436749,0.0014246914070099592,0.38262620568275452,-0.92390215396881104,0.0071648280136287212,0.92387545108795166,0.38262620568275452,2.5563554763793945,22.871719360351563,-18.525968551635742"> </Bone> </Part> </Brick> <Brick refID="617" designID="32524" itemNos="3252426"> <Part refID="617" designID="32524" materials="26"> <Bone refID="653" transformation="0,6.3947409216780216E-005,1,0.99996984004974365,-0.00776657834649086,0,0.00776657834649086,0.99996984004974365,-6.3945481088012457E-005,5.7212004661560059,18.320547103881836,-19.901498794555664"> </Bone> </Part> </Brick> <Brick refID="618" designID="2780" itemNos="278026"> <Part refID="618" designID="2780" materials="26"> <Bone refID="654" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.7274222373962402,19.120820999145508,-15.101546287536621"> </Bone> </Part> </Brick> <Brick refID="619" designID="32527" itemNos="4143417"> <Part refID="619" designID="32527" materials="26"> <Bone refID="655" transformation="0,6.3886524003464729E-005,1,0.0078124264255166054,0.999969482421875,-6.388847396010533E-005,-0.999969482421875,0.0078124264255166054,0,5.7212028503417969,18.320844650268555,-15.101497650146484"> </Bone> </Part> </Brick> <Brick refID="620" designID="2780" itemNos="278026"> <Part refID="620" designID="2780" materials="26"> <Bone refID="656" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.7274212837219238,19.120773315429688,-15.901547431945801"> </Bone> </Part> </Brick> <Brick refID="621" designID="2780" itemNos="278026"> <Part refID="621" designID="2780" materials="26"> <Bone refID="657" transformation="0,-6.3947409216780216E-005,-1,-0.99996984004974365,0.0077665788121521473,0,0.0077665788121521473,0.99996984004974365,-6.3945481088012457E-005,5.7274074554443359,19.120573043823242,-19.101547241210938"> </Bone> </Part> </Brick> <Brick refID="622" designID="32528" itemNos="4143419"> <Part refID="622" designID="32528" materials="26"> <Bone refID="658" transformation="0,6.3886516727507114E-005,1,0.00782768614590168,0.99996936321258545,-6.388847396010533E-005,-0.99996936321258545,0.00782768614590168,0,5.7211999893188477,18.320545196533203,-19.901496887207031"> </Bone> </Part> </Brick> <Brick refID="623" designID="2780" itemNos="278026"> <Part refID="623" designID="2780" materials="26"> <Bone refID="659" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.727419376373291,19.120519638061523,-19.901546478271484"> </Bone> </Part> </Brick> <Brick refID="624" designID="4266" itemNos="426621"> <Part refID="624" designID="4266" materials="21"> <Bone refID="660" transformation="0.00015848374459892511,0.00016136292833834887,1,-0.0080464892089366913,-0.99996763467788696,0.00016263294673990458,0.99996763467788696,-0.0080465152859687805,-0.00015718021313659847,9.8593683242797852,15.488069534301758,-17.501432418823242"> </Bone> </Part> </Brick> <Brick refID="625" designID="32062" itemNos="4109810"> <Part refID="625" designID="32062" materials="26"> <Bone refID="661" transformation="0.00015768606681376696,6.3881096139084548E-005,1,0.008043200708925724,0.99996781349182129,-6.3880528614390641E-005,-0.99996775388717651,0.0080432137474417686,0.00015718866779934615,8.4994134902954102,15.499008178710938,-17.501218795776367"> </Bone> </Part> </Brick> <Brick refID="626" designID="32054" itemNos="4107742"> <Part refID="626" designID="32054" materials="26"> <Bone refID="662" transformation="-7.6660318882204592E-005,6.388111796695739E-005,1,0.0077797039411962032,0.9999697208404541,-6.3880506786517799E-005,-0.99996978044509888,0.0077796997502446175,-7.7158125350251794E-005,6.8994593620300293,15.511456489562988,-17.501344680786133"> </Bone> </Part> </Brick> <Brick refID="627" designID="55817" itemNos="4515961"> <Part refID="627" designID="55817" materials="26"> <Bone refID="663" transformation="-7.6428812462836504E-005,8.4757331933360547E-005,1,-0.0077740596607327461,-0.99996978044509888,8.4160608821548522E-005,0.99996978044509888,-0.0077740531414747238,7.7085409429855645E-005,7.7004532814025879,15.503826141357422,-17.501235961914062"> </Bone> </Part> </Brick> <Brick refID="628" designID="43093" itemNos="4168884"> <Part refID="628" designID="43093" materials="26"> <Bone refID="664" transformation="0.9999697208404541,-0.0077855968847870827,0,0,6.3935265643522143E-005,1,-0.0077855964191257954,-0.99996966123580933,6.3937201048247516E-005,4.8963303565979004,15.127063751220703,-16.701292037963867"> </Bone> </Part> </Brick> <Brick refID="629" designID="32039" itemNos="4107081"> <Part refID="629" designID="32039" materials="26"> <Bone refID="665" transformation="0.99996805191040039,-0.0078023364767432213,0.0017378346528857946,-0.0045909029431641102,-0.382598876953125,0.92390316724777222,-0.0065437094308435917,-0.92388159036636353,-0.38262248039245605,6.556797981262207,22.840169906616211,-18.523447036743164"> </Bone> </Part> </Brick> <Brick refID="630" designID="32062" itemNos="4109810"> <Part refID="630" designID="32062" materials="26"> <Bone refID="666" transformation="-0.0045909378677606583,-0.38260003924369812,0.92390269041061401,0.0065012229606509209,0.9238814115524292,0.38262346386909485,-0.99996834993362427,0.0077630970627069473,-0.0017541140550747514,6.1646647453308105,23.951948165893555,-18.064992904663086"> </Bone> </Part> </Brick> <Brick refID="631" designID="32177" itemNos="4120182"> <Part refID="631" designID="32177" materials="26"> <Bone refID="667" transformation="0.0071242046542465687,0.92387652397155762,0.3826242983341217,0.0029430952854454517,0.38261306285858154,-0.9239039421081543,-0.99997031688690186,0.0077081797644495964,0,6.9304437637329102,19.511177062988281,-19.901594161987305"> </Bone> </Part> </Brick> <Brick refID="632" designID="43093" itemNos="4168884"> <Part refID="632" designID="43093" materials="26"> <Bone refID="668" transformation="0.0029431225266307592,0.38261312246322632,-0.92390388250350952,0.0071553713642060757,0.92387616634368896,0.38262432813644409,0.99997007846832275,-0.0077369869686663151,-1.865651756816078E-005,7.7304201126098633,19.505008697509766,-19.901599884033203"> </Bone> </Part> </Brick> <Brick refID="633" designID="32073" itemNos="4114740"> <Part refID="633" designID="32073" materials="26"> <Bone refID="669" transformation="0.0029630062635987997,0.38261455297470093,-0.92390334606170654,-0.9999699592590332,0.0077443318441510201,0,0.0071550821885466576,0.92387557029724121,0.38262605667114258,6.5619339942932129,23.579343795776367,-18.218015670776367"> </Bone> </Part> </Brick> <Brick refID="634" designID="32016" itemNos="4107082"> <Part refID="634" designID="32016" materials="26"> <Bone refID="670" transformation="0.0077436147257685661,0.99996989965438843,-6.3987681642174721E-005,0,6.4073909015860409E-005,1,0.9999699592590332,-0.0077436189167201519,0,6.5211629867553711,18.314325332641602,-19.901493072509766"> </Bone> </Part> </Brick> <Brick refID="635" designID="43093" itemNos="4168884"> <Part refID="635" designID="43093" materials="26"> <Bone refID="671" transformation="0.99996989965438843,-0.0077511598356068134,0,0,-6.4073909015860409E-005,-1,0.0077511565759778023,0.99996984004974365,-6.3974570366553962E-005,6.5273642539978027,19.114303588867188,-19.901544570922852"> </Bone> </Part> </Brick> <Brick refID="636" designID="60483" itemNos="4515185"> <Part refID="636" designID="60483" materials="26"> <Bone refID="672" transformation="-0.99997341632843018,0.0071550179272890091,0.0014232837129384279,0.0014227613573893905,0.38262626528739929,-0.92390209436416626,-0.007155116181820631,-0.92387539148330688,-0.38262641429901123,6.5390372276306152,20.622941970825195,-19.442417144775391"> </Bone> </Part> </Brick> <Brick refID="637" designID="60483" itemNos="4515185"> <Part refID="637" designID="60483" materials="26"> <Bone refID="673" transformation="-0.99997341632843018,0.0071550174616277218,0.0014232834801077843,0.0014227613573893905,0.38262626528739929,-0.92390209436416626,-0.0071551166474819183,-0.92387539148330688,-0.38262641429901123,6.5504856109619141,22.101142883300781,-18.830217361450195"> </Bone> </Part> </Brick> <Brick refID="638" designID="6558" itemNos="655826"> <Part refID="638" designID="6558" materials="26"> <Bone refID="674" transformation="0.99997341632843018,-0.0071549802087247372,-0.0014232388930395246,0.0014227923238649964,0.38262686133384705,-0.92390185594558716,0.0071550691500306129,0.92387527227401733,0.38262686133384705,5.7562308311462402,22.845966339111328,-18.522977828979492"> </Bone> </Part> </Brick> <Brick refID="639" designID="32062" itemNos="4109810"> <Part refID="639" designID="32062" materials="26"> <Bone refID="675" transformation="0.0014263078337535262,0.38274028897285461,0.92385488748550415,0.007125763688236475,0.92382848262786865,-0.38274034857749939,-0.9999735951423645,0.0071290773339569569,-0.0014096531085669994,6.1648964881896973,23.951833724975586,-16.939302444458008"> </Bone> </Part> </Brick> <Brick refID="640" designID="32177" itemNos="4120182"> <Part refID="640" designID="32177" materials="26"> <Bone refID="676" transformation="0.0077487477101385593,0.92382383346557617,-0.3827396035194397,-0.0030741496011614799,-0.3827272355556488,-0.92385631799697876,-0.99996531009674072,0.0083353267982602119,-0.00012568467354867607,6.92767333984375,19.510810852050781,-15.102051734924316"> </Bone> </Part> </Brick> <Brick refID="641" designID="43093" itemNos="4168884"> <Part refID="641" designID="43093" materials="26"> <Bone refID="677" transformation="-0.0030741228256374598,-0.38272720575332642,-0.92385637760162354,0.0077799148857593536,0.92382365465164185,-0.38273954391479492,0.99996501207351685,-0.0083641121163964272,0.00013763961032964289,7.7276458740234375,19.504140853881836,-15.101948738098145"> </Bone> </Part> </Brick> <Brick refID="642" designID="32039" itemNos="4107081"> <Part refID="642" designID="32039" materials="26"> <Bone refID="678" transformation="0.99997329711914063,-0.0071683353744447231,0.0014258885057643056,0.0014263432240113616,0.38274139165878296,0.92385441064834595,-0.0071682431735098362,-0.92382776737213135,0.38274136185646057,6.5562829971313477,22.840372085571289,-16.479442596435547"> </Bone> </Part> </Brick> <Brick refID="643" designID="32073" itemNos="4114740"> <Part refID="643" designID="32073" materials="26"> <Bone refID="679" transformation="0.0029694892000406981,0.38273027539253235,0.9238554835319519,0.99996989965438843,-0.0077589969150722027,0,0.0071682753041386604,0.92382758855819702,-0.38274171948432922,6.5620169639587402,23.579435348510742,-16.785636901855469"> </Bone> </Part> </Brick> <Brick refID="644" designID="32016" itemNos="4107082"> <Part refID="644" designID="32016" materials="26"> <Bone refID="680" transformation="0.0077589349821209908,0.99996989965438843,-6.3887215219438076E-005,0,-6.3844519900158048E-005,-1,-0.99996989965438843,0.0077589349821209908,0,6.5211658477783203,18.314624786376953,-15.101496696472168"> </Bone> </Part> </Brick> <Brick refID="645" designID="43093" itemNos="4168884"> <Part refID="645" designID="43093" materials="26"> <Bone refID="681" transformation="0.9999699592590332,-0.0077511719428002834,0,0,-6.3844519900158048E-005,-1,0.0077511733397841454,0.99997001886367798,-6.3893436163198203E-005,6.5273666381835938,19.114603042602539,-15.101546287536621"> </Bone> </Part> </Brick> <Brick refID="646" designID="60483" itemNos="4515185"> <Part refID="646" designID="60483" materials="26"> <Bone refID="682" transformation="-0.99997329711914063,0.0071683456189930439,-0.001425854628905654,0.0014263780321925879,0.38274121284484863,0.9238545298576355,0.0071682417765259743,0.9238278865814209,-0.38274127244949341,6.5448131561279297,21.362249374389648,-15.86705493927002"> </Bone> </Part> </Brick> <Brick refID="647" designID="60483" itemNos="4515185"> <Part refID="647" designID="60483" materials="26"> <Bone refID="683" transformation="-0.99997329711914063,0.0071683451533317566,-0.0014258545124903321,0.0014263781486079097,0.38274121284484863,0.9238545298576355,0.0071682422421872616,0.9238278865814209,-0.38274127244949341,6.5562825202941895,22.840372085571289,-16.479442596435547"> </Bone> </Part> </Brick> <Brick refID="648" designID="6558" itemNos="655826"> <Part refID="648" designID="6558" materials="26"> <Bone refID="684" transformation="0.99997329711914063,-0.0071682902052998543,0.0014258398441597819,-0.0014263690682128072,-0.38274115324020386,-0.9238545298576355,0.0071681849658489227,0.92382782697677612,-0.38274115324020386,5.7563033103942871,22.846107482910156,-16.480581283569336"> </Bone> </Part> </Brick> <Brick refID="649" designID="32184" itemNos="4121667"> <Part refID="649" designID="32184" materials="26"> <Bone refID="685" transformation="0.99984771013259888,-0.017452426254749298,0,0,-6.3915889768395573E-005,-1,0.017452426254749298,0.99984771013259888,-6.392562499968335E-005,3.3065063953399658,15.947439193725586,-16.701587677001953"> </Bone> </Part> </Brick> <Brick refID="650" designID="6558" itemNos="655826"> <Part refID="650" designID="6558" materials="26"> <Bone refID="686" transformation="-7.6806492870673537E-005,6.3896339270286262E-005,1,0.0079979812726378441,0.99996799230575562,-6.3280000176746398E-005,-0.99996799230575562,0.007997976616024971,-7.7315075031947345E-005,2.9121971130371094,17.143011093139648,-17.501758575439453"> </Bone> </Part> </Brick> <Brick refID="651" designID="6558" itemNos="655826"> <Part refID="651" designID="6558" materials="26"> <Bone refID="687" transformation="-0.0079932939261198044,-0.99996805191040039,9.1677502496168017E-005,-7.6621065090876073E-005,9.2292902991175652E-005,1,-0.99996805191040039,0.0079932864755392075,-7.7356344263534993E-005,2.9377708435058594,20.342945098876953,-17.501949310302734"> </Bone> </Part> </Brick> <Brick refID="652" designID="32013" itemNos="4107085"> <Part refID="652" designID="32013" materials="26"> <Bone refID="688" transformation="-0.0079932073131203651,-0.99996805191040039,9.1871224867645651E-005,0.99996805191040039,-0.0079931998625397682,7.7225093264132738E-005,-7.6488278864417225E-005,9.2485563072841614E-005,1,4.1473236083984375,21.533313751220703,-17.50196647644043"> </Bone> </Part> </Brick> <Brick refID="653" designID="3705" itemNos="370526"> <Part refID="653" designID="3705" materials="26"> <Bone refID="689" transformation="-7.6619748142547905E-005,9.2442896857392043E-005,0.99999988079071045,-0.99996799230575562,0.0079932417720556259,-7.7356220572255552E-005,-0.0079932510852813721,-0.99996799230575562,9.1827503638342023E-005,4.1409292221069336,20.733339309692383,-17.50189208984375"> </Bone> </Part> </Brick> <Brick refID="654" designID="32013" itemNos="4107085"> <Part refID="654" designID="32013" materials="26"> <Bone refID="690" transformation="0.0080005303025245667,0.99996787309646606,-9.1956528194714338E-005,0.99996799230575562,-0.0080005237832665443,7.7313277870416641E-005,7.6573938713409007E-005,-9.2572125140577555E-005,-0.99999988079071045,4.1601057052612305,23.133266448974609,-17.502115249633789"> </Bone> </Part> </Brick> <Brick refID="655" designID="6558" itemNos="655826"> <Part refID="655" designID="6558" materials="26"> <Bone refID="691" transformation="-0.0079932939261198044,-0.99996805191040039,9.1677502496168017E-005,-7.6621065090876073E-005,9.2292902991175652E-005,1,-0.99996805191040039,0.0079932864755392075,-7.7356344263534993E-005,2.9697442054748535,24.342813491821289,-17.5023193359375"> </Bone> </Part> </Brick> <Brick refID="656" designID="32013" itemNos="4107085"> <Part refID="656" designID="32013" materials="26"> <Bone refID="692" transformation="0,-0.70710676908493042,0.7071068286895752,1,0,0,0,0.70710688829421997,0.70710676908493042,11.59999942779541,1.248525857925415,-3.248528003692627"> </Bone> </Part> </Brick> <Brick refID="657" designID="3705" itemNos="370526"> <Part refID="657" designID="3705" materials="26"> <Bone refID="693" transformation="1,0,0,0,0.70710700750350952,0.70710664987564087,0,-0.70710664987564087,0.70710694789886475,11.59999942779541,0.68284040689468384,-2.682842493057251"> </Bone> </Part> </Brick> <Brick refID="658" designID="3705" itemNos="370526"> <Part refID="658" designID="3705" materials="26"> <Bone refID="694" transformation="0,0,1,0,1,0,-1,0,0,9.7599992752075195,0.39999797940254211,-2.3999998569488525"> </Bone> </Part> </Brick> <Brick refID="659" designID="75535" itemNos="4526981"> <Part refID="659" designID="75535" materials="1"> <Bone refID="695" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-26.39997673034668"> </Bone> </Part> </Brick> <Brick refID="660" designID="32039" itemNos="4144128"> <Part refID="660" designID="32039" materials="1"> <Bone refID="696" transformation="1,0,0,0,-1.0000001192092896,0,0,0,-1,16.000003814697266,7.4069232940673828,-24.799999237060547"> </Bone> </Part> </Brick> <Brick refID="661" designID="3708" itemNos="370826"> <Part refID="661" designID="3708" materials="26"> <Bone refID="697" transformation="1.0000002384185791,0,0,0,1,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-23.999977111816406"> </Bone> </Part> </Brick> <Brick refID="662" designID="32016" itemNos="4118982"> <Part refID="662" designID="32016" materials="1"> <Bone refID="698" transformation="0,0,-1.0000001192092896,0,-0.99999994039535522,0,-1.0000002384185791,0,0,16.000003814697266,7.4069828987121582,-32.799980163574219"> </Bone> </Part> </Brick> <Brick refID="663" designID="3705" itemNos="370526"> <Part refID="663" designID="3705" materials="26"> <Bone refID="699" transformation="1.0000002384185791,0,0,0,0.92387938499450684,-0.38268405199050903,0,0.38268408179283142,0.92387950420379639,16.000003814697266,7.2538509368896484,-34.369564056396484"> </Bone> </Part> </Brick> <Brick refID="664" designID="6590" itemNos="4198121"> <Part refID="664" designID="6590" materials="1"> <Bone refID="700" transformation="1.0000002384185791,0,0,0,0.92387962341308594,-0.38268351554870605,0,0.38268354535102844,0.92387974262237549,16.000003814697266,6.6415562629699707,-35.847770690917969"> </Bone> </Part> </Brick> <Brick refID="665" designID="41677" itemNos="4163533"> <Part refID="665" designID="41677" materials="1"> <Bone refID="701" transformation="1.0000002384185791,0,0,0,0.92387974262237549,-0.38268324732780457,0,0.38268327713012695,0.92387986183166504,15.200004577636719,6.7946305274963379,-35.478218078613281"> </Bone> </Part> </Brick> <Brick refID="666" designID="4519" itemNos="451926"> <Part refID="666" designID="4519" materials="26"> <Bone refID="702" transformation="0,0.92387974262237549,-0.3826831579208374,-1.0000002384185791,0,0,0,0.38268324732780457,0.92387986183166504,15.200006484985352,7.2538518905639648,-34.369560241699219"> </Bone> </Part> </Brick> <Brick refID="667" designID="41677" itemNos="4163533"> <Part refID="667" designID="41677" materials="1"> <Bone refID="703" transformation="1.0000002384185791,0,0,0,0.92387974262237549,-0.38268324732780457,0,0.38268327713012695,0.92387986183166504,15.200004577636719,6.9477038383483887,-35.108665466308594"> </Bone> </Part> </Brick> <Brick refID="668" designID="32016" itemNos="4118982"> <Part refID="668" designID="32016" materials="1"> <Bone refID="704" transformation="0,0,-1.0000001192092896,0,-0.99999994039535522,0,-1.0000002384185791,0,0,15.200006484985352,7.4069247245788574,-32.799999237060547"> </Bone> </Part> </Brick> <Brick refID="669" designID="3708" itemNos="370826"> <Part refID="669" designID="3708" materials="26"> <Bone refID="705" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-23.999996185302734"> </Bone> </Part> </Brick> <Brick refID="670" designID="32039" itemNos="4144128"> <Part refID="670" designID="32039" materials="1"> <Bone refID="706" transformation="1,0,0,0,-0.99999982118606567,0,0,0,-1,15.200006484985352,7.4069247245788574,-24.799999237060547"> </Bone> </Part> </Brick> <Brick refID="671" designID="3707" itemNos="370726"> <Part refID="671" designID="3707" materials="26"> <Bone refID="707" transformation="0,0,1,0,0.99999982118606567,0,-1,0,0,10.400004386901855,7.4069242477416992,-23.600002288818359"> </Bone> </Part> </Brick> <Brick refID="672" designID="60483" itemNos="4515185"> <Part refID="672" designID="60483" materials="26"> <Bone refID="708" transformation="0,0,-1,0,-0.99999970197677612,0,-1.0000002384185791,0,0,11.600006103515625,7.4069232940673828,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="673" designID="32039" itemNos="4144128"> <Part refID="673" designID="32039" materials="1"> <Bone refID="709" transformation="1,0,0,0,0,1.0000002384185791,0,-1,0,12.800006866455078,6.2069244384765625,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="674" designID="44294" itemNos="4211805"> <Part refID="674" designID="44294" materials="194"> <Bone refID="710" transformation="1.0000001192092896,0,0,0,0,1.0000002384185791,0,-1,0,12.800004005432129,1.4039245843887329,-23.599998474121094"> </Bone> </Part> </Brick> <Brick refID="675" designID="32039" itemNos="4144128"> <Part refID="675" designID="32039" materials="1"> <Bone refID="711" transformation="1.0000001192092896,0,0,0,0,-1.0000002384185791,0,1,0,12.80000114440918,2.2069251537322998,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="676" designID="3707" itemNos="370726"> <Part refID="676" designID="3707" materials="26"> <Bone refID="712" transformation="0,0,1,0,0.9999997615814209,0,-0.99999988079071045,0,0,10.400001525878906,1.0069255828857422,-23.600002288818359"> </Bone> </Part> </Brick> <Brick refID="677" designID="60483" itemNos="4515185"> <Part refID="677" designID="60483" materials="26"> <Bone refID="713" transformation="0,0,-0.99999988079071045,0,-0.99999970197677612,0,-1,0,0,11.600000381469727,1.0069241523742676,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="678" designID="32249" itemNos="3224901"> <Part refID="678" designID="32249" materials="1"> <Bone refID="714" transformation="0,0,1.0000002384185791,0,0.99999982118606567,0,-1.0000002384185791,0,0,16.399999618530273,1.0069243907928467,-25.200002670288086"> </Bone> </Part> </Brick> <Brick refID="679" designID="6590" itemNos="4198121"> <Part refID="679" designID="6590" materials="1"> <Bone refID="715" transformation="0,0,1.0000001192092896,-1.0000001192092896,0,0,0,-0.99999994039535522,0,12.800004005432129,2.2039239406585693,-23.599998474121094"> </Bone> </Part> </Brick> <Brick refID="680" designID="6590" itemNos="4198121"> <Part refID="680" designID="6590" materials="1"> <Bone refID="716" transformation="0,0,1.0000001192092896,-1.0000001192092896,0,0,0,-0.99999994039535522,0,12.800004959106445,5.4039244651794434,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="681" designID="32039" itemNos="4144128"> <Part refID="681" designID="32039" materials="1"> <Bone refID="717" transformation="0,-0.99999994039535522,0,0,0,0.99999988079071045,-0.99999988079071045,0,0,11.600003242492676,4.2039246559143066,-23.599998474121094"> </Bone> </Part> </Brick> <Brick refID="682" designID="43093" itemNos="4168884"> <Part refID="682" designID="43093" materials="26"> <Bone refID="718" transformation="0,0,-1,3.160343476338312E-005,0.99999982118606567,0,1,-3.1603463867213577E-005,0,12.400002479553223,4.2039241790771484,-23.599998474121094"> </Bone> </Part> </Brick> <Brick refID="683" designID="32249" itemNos="3224901"> <Part refID="683" designID="32249" materials="1"> <Bone refID="719" transformation="0,1,0,0,0,-1,-1.0000001192092896,0,0,16.400005340576172,5.8069238662719727,-23.600000381469727"> </Bone> </Part> </Brick> <Brick refID="684" designID="6590" itemNos="4198121"> <Part refID="684" designID="6590" materials="1"> <Bone refID="720" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200006484985352,7.4069247245788574,-25.600000381469727"> </Bone> </Part> </Brick> <Brick refID="685" designID="32054" itemNos="4193409"> <Part refID="685" designID="32054" materials="1"> <Bone refID="721" transformation="0,-0.92387974262237549,0.38268321752548218,-1,0,0,0,-0.38268324732780457,-0.92387974262237549,15.200008392333984,5.7231178283691406,-38.065082550048828"> </Bone> </Part> </Brick> <Brick refID="686" designID="6590" itemNos="4198121"> <Part refID="686" designID="6590" materials="1"> <Bone refID="722" transformation="1.0000002384185791,0,0,0,1,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-25.599977493286133"> </Bone> </Part> </Brick> <Brick refID="687" designID="32534" itemNos="4144140"> <Part refID="687" designID="32534" materials="1"> <Bone refID="723" transformation="1.0000001192092896,0,0,0,0,-1.0000001192092896,0,1.0000001192092896,0,16.000003814697266,7.4069828987121582,-24.799978256225586"> </Bone> </Part> </Brick> <Brick refID="688" designID="32528" itemNos="4144130"> <Part refID="688" designID="32528" materials="1"> <Bone refID="724" transformation="-1.0000001192092896,0,0,0,0.38268390297889709,0.92387944459915161,0,0.92387932538986206,-0.38268393278121948,16.000005722045898,6.0292625427246094,-37.325973510742187"> </Bone> </Part> </Brick> <Brick refID="689" designID="32140" itemNos="4118980"> <Part refID="689" designID="32140" materials="1"> <Bone refID="725" transformation="0,0,-0.99999988079071045,0,0.99999982118606567,0,0.9999997615814209,0,0,10.799999237060547,1.0069257020950317,-22.000001907348633"> </Bone> </Part> </Brick> <Brick refID="690" designID="32140" itemNos="4118980"> <Part refID="690" designID="32140" materials="1"> <Bone refID="726" transformation="0,0,-0.99999994039535522,0,-0.99999988079071045,0,-0.99999988079071045,0,0,10.000002861022949,7.4069247245788574,-22"> </Bone> </Part> </Brick> <Brick refID="691" designID="75535" itemNos="4526981"> <Part refID="691" designID="75535" materials="1"> <Bone refID="727" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-26.399995803833008"> </Bone> </Part> </Brick> <Brick refID="692" designID="75535" itemNos="4526981"> <Part refID="692" designID="75535" materials="1"> <Bone refID="728" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-29.599977493286133"> </Bone> </Part> </Brick> <Brick refID="693" designID="75535" itemNos="4526981"> <Part refID="693" designID="75535" materials="1"> <Bone refID="729" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,14.799999237060547,1.0069249868392944,-23.599996566772461"> </Bone> </Part> </Brick> <Brick refID="694" designID="75535" itemNos="4526981"> <Part refID="694" designID="75535" materials="1"> <Bone refID="730" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,13.19999885559082,1.0069249868392944,-23.599996566772461"> </Bone> </Part> </Brick> <Brick refID="695" designID="4274" itemNos="4187741"> <Part refID="695" designID="4274" materials="1"> <Bone refID="731" transformation="0,0,1,0,0.99999988079071045,0,-1,0,0,16.000005722045898,6.6069231033325195,-23.599994659423828"> </Bone> </Part> </Brick> <Brick refID="696" designID="32065" itemNos="4205157"> <Part refID="696" designID="32065" materials="1"> <Bone refID="732" transformation="0,-1,0,0,0,0.99999988079071045,-0.99999988079071045,0,0,16.000005722045898,6.6069231033325195,-23.599994659423828"> </Bone> </Part> </Brick> <Brick refID="697" designID="4274" itemNos="4187741"> <Part refID="697" designID="4274" materials="1"> <Bone refID="733" transformation="0,0,1,0,0.99999988079071045,0,-1,0,0,16,1.8069236278533936,-23.599996566772461"> </Bone> </Part> </Brick> <Brick refID="698" designID="75535" itemNos="4526981"> <Part refID="698" designID="75535" materials="1"> <Bone refID="734" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,13.200002670288086,7.4069242477416992,-23.599996566772461"> </Bone> </Part> </Brick> <Brick refID="699" designID="43093" itemNos="4168884"> <Part refID="699" designID="43093" materials="26"> <Bone refID="735" transformation="0,0.38268390297889709,0.92387932538986206,0,0.92387920618057251,-0.38268387317657471,-1,0,0,14.800004959106445,5.1370701789855957,-37.389411926269531"> </Bone> </Part> </Brick> <Brick refID="700" designID="6536" itemNos="653601"> <Part refID="700" designID="6536" materials="1"> <Bone refID="736" transformation="0,0.92387926578521729,-0.38268375396728516,0,0.38268375396728516,0.92387920618057251,1,0,0,15.600004196166992,5.1370697021484375,-37.389411926269531"> </Bone> </Part> </Brick> <Brick refID="701" designID="32192" itemNos="4144136"> <Part refID="701" designID="32192" materials="1"> <Bone refID="737" transformation="0,0.38268297910690308,-0.92387980222702026,0,0.92387974262237549,0.38268303871154785,1,0,0,16.000005722045898,4.6778512001037598,-36.280757904052734"> </Bone> </Part> </Brick> <Brick refID="702" designID="32073" itemNos="4114740"> <Part refID="702" designID="32073" materials="26"> <Bone refID="738" transformation="1.0000001192092896,0,0,0,0.92388033866882324,0.38268187642097473,0,-0.38268187642097473,0.92388039827346802,16.000003814697266,3.4532663822174072,-33.324344635009766"> </Bone> </Part> </Brick> <Brick refID="703" designID="32192" itemNos="4144136"> <Part refID="703" designID="32192" materials="1"> <Bone refID="739" transformation="0,-0.38268202543258667,0.92387992143630981,0,0.92388027906417847,0.38268205523490906,-1.0000001192092896,0,0,16.000005722045898,3.7594122886657715,-34.063446044921875"> </Bone> </Part> </Brick> <Brick refID="704" designID="32054" itemNos="4193409"> <Part refID="704" designID="32054" materials="1"> <Bone refID="740" transformation="0,-0.92387896776199341,0.38268464803695679,0.99999988079071045,0,0,0,0.38268470764160156,0.92387902736663818,16.000003814697266,6.5212712287902832,-25.19691276550293"> </Bone> </Part> </Brick> <Brick refID="705" designID="3707" itemNos="370726"> <Part refID="705" designID="3707" materials="26"> <Bone refID="741" transformation="1,0,0,0,0.92387896776199341,-0.38268497586250305,0,0.38268494606018066,0.92387908697128296,16,5.9089760780334473,-26.675115585327148"> </Bone> </Part> </Brick> <Brick refID="706" designID="75535" itemNos="4526981"> <Part refID="706" designID="75535" materials="1"> <Bone refID="742" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,15.999998092651367,4.9905328750610352,-28.892423629760742"> </Bone> </Part> </Brick> <Brick refID="707" designID="75535" itemNos="4526981"> <Part refID="707" designID="75535" materials="1"> <Bone refID="743" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,15.999998092651367,4.378237247467041,-30.370630264282227"> </Bone> </Part> </Brick> <Brick refID="708" designID="43857" itemNos="4227695"> <Part refID="708" designID="43857" materials="1"> <Bone refID="744" transformation="1,0,0,0,0.92387908697128296,-0.38268452882766724,0,0.38268452882766724,0.92387908697128296,15.200004577636719,6.2151217460632324,-25.936014175415039"> </Bone> </Part> </Brick> <Brick refID="709" designID="6590" itemNos="4198121"> <Part refID="709" designID="6590" materials="1"> <Bone refID="745" transformation="1,0,0,0,0.92388081550598145,0.3826805055141449,0,-0.38268047571182251,0.92388087511062622,15.200006484985352,4.6778464317321777,-36.280757904052734"> </Bone> </Part> </Brick> <Brick refID="710" designID="32073" itemNos="4114740"> <Part refID="710" designID="32073" materials="26"> <Bone refID="746" transformation="1.0000001192092896,0,0,0,0.92388069629669189,0.38268139958381653,0,-0.3826812207698822,0.92388069629669189,15.200008392333984,3.453265905380249,-33.3243408203125"> </Bone> </Part> </Brick> <Brick refID="711" designID="32192" itemNos="4144136"> <Part refID="711" designID="32192" materials="1"> <Bone refID="747" transformation="0,-0.38268205523490906,0.92388021945953369,0,0.92388015985488892,0.38268205523490906,-1.0000001192092896,0,0,15.200008392333984,3.7594120502471924,-34.063446044921875"> </Bone> </Part> </Brick> <Brick refID="712" designID="32054" itemNos="4193409"> <Part refID="712" designID="32054" materials="1"> <Bone refID="748" transformation="0,-0.92387944459915161,0.38268357515335083,0.99999988079071045,0,0,0,0.38268348574638367,0.92387944459915161,15.200002670288086,6.5212669372558594,-25.196907043457031"> </Bone> </Part> </Brick> <Brick refID="713" designID="3707" itemNos="370726"> <Part refID="713" designID="3707" materials="26"> <Bone refID="749" transformation="1,0,0,0,0.92387956380844116,-0.38268393278121948,0,0.38268390297889709,0.92387950420379639,15.200005531311035,5.9089736938476563,-26.675113677978516"> </Bone> </Part> </Brick> <Brick refID="714" designID="75535" itemNos="4526981"> <Part refID="714" designID="75535" materials="1"> <Bone refID="750" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.19999885559082,4.9905319213867187,-28.892423629760742"> </Bone> </Part> </Brick> <Brick refID="715" designID="75535" itemNos="4526981"> <Part refID="715" designID="75535" materials="1"> <Bone refID="751" transformation="0.99999994039535522,0,0,0,0.92388033866882324,0.38268104195594788,0,-0.38268104195594788,0.92388033866882324,15.200006484985352,3.759411096572876,-34.063449859619141"> </Bone> </Part> </Brick> <Brick refID="716" designID="75535" itemNos="4526981"> <Part refID="716" designID="75535" materials="1"> <Bone refID="752" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.200000762939453,5.6028275489807129,-27.414220809936523"> </Bone> </Part> </Brick> <Brick refID="717" designID="2780" itemNos="278026"> <Part refID="717" designID="2780" materials="26"> <Bone refID="753" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,16.400005340576172,3.3001940250396729,-32.954788208007813"> </Bone> </Part> </Brick> <Brick refID="718" designID="32527" itemNos="4144129"> <Part refID="718" designID="32527" materials="1"> <Bone refID="754" transformation="0.99999994039535522,0,0,0,-0.38268256187438965,0.92387968301773071,0,-0.92387992143630981,-0.38268265128135681,16.000003814697266,4.6778459548950195,-36.280757904052734"> </Bone> </Part> </Brick> <Brick refID="719" designID="75535" itemNos="4526981"> <Part refID="719" designID="75535" materials="1"> <Bone refID="755" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.19999885559082,4.3782362937927246,-30.370634078979492"> </Bone> </Part> </Brick> <Brick refID="720" designID="75535" itemNos="4526981"> <Part refID="720" designID="75535" materials="1"> <Bone refID="756" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,16,5.6028285026550293,-27.414216995239258"> </Bone> </Part> </Brick> <Brick refID="721" designID="75535" itemNos="4526981"> <Part refID="721" designID="75535" materials="1"> <Bone refID="757" transformation="0.99999994039535522,0,0,0,0.92388045787811279,0.38268107175827026,0,-0.38268107175827026,0.92388045787811279,16.000005722045898,3.7594101428985596,-34.063442230224609"> </Bone> </Part> </Brick> <Brick refID="722" designID="6558" itemNos="655826"> <Part refID="722" designID="6558" materials="26"> <Bone refID="758" transformation="0,0,1,0,0.99999982118606567,0,-1,0,0,10.000001907348633,7.4069242477416992,-24.399995803833008"> </Bone> </Part> </Brick> <Brick refID="723" designID="75535" itemNos="4526981"> <Part refID="723" designID="75535" materials="1"> <Bone refID="759" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-31.199979782104492"> </Bone> </Part> </Brick> <Brick refID="724" designID="75535" itemNos="4526981"> <Part refID="724" designID="75535" materials="1"> <Bone refID="760" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-27.999975204467773"> </Bone> </Part> </Brick> <Brick refID="725" designID="75535" itemNos="4526981"> <Part refID="725" designID="75535" materials="1"> <Bone refID="761" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.406923770904541,-31.19999885559082"> </Bone> </Part> </Brick> <Brick refID="726" designID="75535" itemNos="4526981"> <Part refID="726" designID="75535" materials="1"> <Bone refID="762" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-29.599996566772461"> </Bone> </Part> </Brick> <Brick refID="727" designID="6558" itemNos="655826"> <Part refID="727" designID="6558" materials="26"> <Bone refID="763" transformation="0,0,1,0,0.99999982118606567,0,-1,0,0,10,1.0069248676300049,-24.399997711181641"> </Bone> </Part> </Brick> <Brick refID="728" designID="2780" itemNos="278026"> <Part refID="728" designID="2780" materials="26"> <Bone refID="764" transformation="0,0,-1.0000002384185791,0,1,0,1.0000002384185791,0,0,16.400005340576172,7.406923770904541,-33.999996185302734"> </Bone> </Part> </Brick> <Brick refID="729" designID="75535" itemNos="4526981"> <Part refID="729" designID="75535" materials="1"> <Bone refID="765" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-27.999998092651367"> </Bone> </Part> </Brick> <Brick refID="730" designID="6536" itemNos="653601"> <Part refID="730" designID="6536" materials="1"> <Bone refID="766" transformation="1.0000001192092896,0,0,0,0,1.0000001192092896,0,-0.99999994039535522,0,5.6000056266784668,2.5998141765594482,-34"> </Bone> </Part> </Brick> <Brick refID="731" designID="6536" itemNos="653601"> <Part refID="731" designID="6536" materials="1"> <Bone refID="767" transformation="1.0000001192092896,0,0,0,0,1.0000001192092896,0,-0.99999994039535522,0,5.6000046730041504,4.1998143196105957,-34"> </Bone> </Part> </Brick> <Brick refID="732" designID="2780" itemNos="278026"> <Part refID="732" designID="2780" materials="26"> <Bone refID="768" transformation="0,0,1.0000001192092896,0,-1,0,1.0000002384185791,0,0,11.600000381469727,7.4069242477416992,-21.19999885559082"> </Bone> </Part> </Brick> <Brick refID="733" designID="32140" itemNos="4118980"> <Part refID="733" designID="32140" materials="1"> <Bone refID="769" transformation="0,1,0,0,0,-1,-1.0000001192092896,0,0,10.80000114440918,5.0069246292114258,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="734" designID="43093" itemNos="4168884"> <Part refID="734" designID="43093" materials="26"> <Bone refID="770" transformation="0,0,-1.0000001192092896,0,-0.9999997615814209,0,-1.0000005960464478,0,0,10.80000114440918,5.0069246292114258,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="735" designID="2780" itemNos="278026"> <Part refID="735" designID="2780" materials="26"> <Bone refID="771" transformation="0,0,1.0000001192092896,0,-1,0,1.0000002384185791,0,0,11.600000381469727,7.4069242477416992,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="736" designID="32524" itemNos="4142969"> <Part refID="736" designID="32524" materials="1"> <Bone refID="772" transformation="0,-1.0000001192092896,0,0,0,1.0000001192092896,-1.0000001192092896,0,0,11.600000381469727,6.6069240570068359,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="737" designID="6558" itemNos="4157765"> <Part refID="737" designID="6558" materials="1"> <Bone refID="773" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999980926513672,4.2069244384765625,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="738" designID="32013" itemNos="4118981"> <Part refID="738" designID="32013" materials="1"> <Bone refID="774" transformation="0,0,0.99999994039535522,-0.99999988079071045,0,0,0,-0.99999994039535522,0,11.199996948242188,4.2069244384765625,-21.599996566772461"> </Bone> </Part> </Brick> <Brick refID="739" designID="32524" itemNos="4142969"> <Part refID="739" designID="32524" materials="1"> <Bone refID="775" transformation="0,-1.0000001192092896,0,0,0,1.0000001192092896,-1.0000001192092896,0,0,9.9999980926513672,6.6069250106811523,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="740" designID="43093" itemNos="4168884"> <Part refID="740" designID="43093" materials="26"> <Bone refID="776" transformation="0,0,1.0000002384185791,0,0.99999982118606567,0,-1.0000002384185791,0,0,10.799997329711914,3.4069242477416992,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="741" designID="32140" itemNos="4118980"> <Part refID="741" designID="32140" materials="1"> <Bone refID="777" transformation="0,-0.99999994039535522,0,0,0,-1.0000001192092896,0.99999964237213135,0,0,11.599997520446777,3.4069242477416992,-20.399997711181641"> </Bone> </Part> </Brick> <Brick refID="742" designID="2780" itemNos="278026"> <Part refID="742" designID="2780" materials="26"> <Bone refID="778" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999961853027344,1.0069248676300049,-21.19999885559082"> </Bone> </Part> </Brick> <Brick refID="743" designID="2780" itemNos="278026"> <Part refID="743" designID="2780" materials="26"> <Bone refID="779" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999961853027344,1.0069249868392944,-20.399997711181641"> </Bone> </Part> </Brick> </Bricks> <RigidSystems> <RigidSystem> <Rigid refID="0" transformation="-0.0048284507356584072,-0.015325308777391911,0.9998708963394165,0.004831037949770689,0.99987059831619263,0.015348625369369984,-0.99997669458389282,0.0049045304767787457,-0.0047538066282868385,2.4049468040466309,4.825718879699707,-4.5759091377258301" boneRefs="0,1"/> <Rigid refID="1" transformation="0.0048290346749126911,0.99987059831619263,0.015349003486335278,-0.0048288889229297638,-0.015325686894357204,0.9998708963394165,0.99997669458389282,-0.004902535118162632,0.0047542722895741463,5.5971465110778809,3.2102298736572266,-4.5852537155151367" boneRefs="2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71"/> <Rigid refID="2" transformation="0.99997669458389282,-0.0049025099724531174,0.0047542997635900974,0.0048289145343005657,0.015325658954679966,-0.9998708963394165,0.0048290085978806019,0.99987059831619263,0.015348968096077442,4.3952698707580566,3.6038010120391846,-3.7849240303039551" boneRefs="72"/> <Rigid refID="3" transformation="-0.0047288616187870502,1.1508171155583113E-005,0.99998879432678223,0.0048763430677354336,0.99998819828033447,1.1542603715497535E-005,-0.99997693300247192,0.0048763495869934559,-0.0047288802452385426,4.0087728500366211,4.0424938201904297,-6.1803827285766602" boneRefs="73"/> <Rigid refID="4" transformation="0.99997669458389282,-0.0049025677144527435,0.004754235502332449,0.00482906773686409,0.99987059831619263,0.015348934568464756,-0.0048288512043654919,-0.01532562542706728,0.9998708963394165,3.9971816539764404,4.7933454513549805,-2.968508243560791" boneRefs="74,75"/> <Rigid refID="5" transformation="-0.0047288248315453529,1.1508433999551926E-005,0.99998879432678223,0.004876249935477972,0.99998819828033447,1.1541720596142113E-005,-0.99997693300247192,0.0048762564547359943,-0.0047288434579968452,4.8010263442993164,3.2263855934143066,-5.3889636993408203" boneRefs="76"/> <Rigid refID="6" transformation="0.99997669458389282,-0.0049036024138331413,0.0047541060484945774,0.0048301056958734989,0.99987059831619263,0.015348619781434536,-0.0048287361860275269,-0.015325306914746761,0.9998708963394165,5.995234489440918,3.9897758960723877,-3.3712294101715088" boneRefs="77"/> <Rigid refID="7" transformation="0.0048298225738108158,0.99987059831619263,0.015348724089562893,-0.0048285713419318199,-0.015325413085520267,0.9998708963394165,0.99997669458389282,-0.004903317429125309,0.0047539449296891689,6.0068240165710449,4.8141922950744629,-4.9587440490722656" boneRefs="78"/> <Rigid refID="8" transformation="0.99997669458389282,-0.0049027646891772747,0.0047539351508021355,0.0048292698338627815,0.99987059831619263,0.015348761342465878,-0.0048285531811416149,-0.015325453132390976,0.9998708963394165,5.9759163856506348,0.77792972326278687,-2.6204471588134766" boneRefs="79"/> <Rigid refID="9" transformation="0.99997669458389282,-0.0049036052078008652,0.0047539155930280685,0.0048301112838089466,0.99987059831619263,0.015348626300692558,-0.004828545730561018,-0.015325314365327358,0.9998708963394165,5.9990992546081543,4.7896718978881836,-3.3589503765106201" boneRefs="80"/> <Rigid refID="10" transformation="-0.004830608144402504,-0.99987059831619263,-0.015348636545240879,-0.99997669458389282,0.0049041025340557098,-0.0047539430670440197,0.0048285806551575661,0.015325321815907955,-0.9998708963394165,6.0029616355895996,4.8019323348999023,-4.1588473320007324" boneRefs="81"/> <Rigid refID="11" transformation="0.99997669458389282,-0.0049042887985706329,0.0047539286315441132,0.0048307948745787144,0.99987059831619263,0.015348577871918678,-0.0048285690136253834,-0.01532526221126318,0.9998708963394165,4.3952417373657227,3.9976227283477783,-3.3788354396820068" boneRefs="82"/> <Rigid refID="12" transformation="0.99997669458389282,-0.0049026040360331535,0.0047539700753986835,0.0048291082493960857,0.99987059831619263,0.015348916873335838,-0.0048285862430930138,-0.015325608663260937,0.9998708963394165,5.9797801971435547,1.5778259038925171,-2.6081705093383789" boneRefs="83,84"/> <Rigid refID="13" transformation="-0.0048286453820765018,-0.01532556489109993,0.9998708963394165,0.0048287287354469299,0.99987059831619263,0.015348871238529682,-0.99997669458389282,0.0049022254534065723,-0.0047540352679789066,4.789466381072998,3.1896317005157471,-2.9892647266387939" boneRefs="85,86,87"/> <Rigid refID="14" transformation="0.99997669458389282,-0.0049023386090993881,0.0047541819512844086,0.0048287943936884403,0.015325690619647503,-0.9998708963394165,0.0048288390971720219,0.99987059831619263,0.01534899789839983,4.3914070129394531,3.5915405750274658,-2.9850256443023682" boneRefs="88"/> <Rigid refID="15" transformation="0.99997669458389282,-0.0049021863378584385,0.0047535807825624943,0.0048286975361406803,0.99987059831619263,0.015348670072853565,-0.0048281894996762276,-0.015325366519391537,0.9998708963394165,3.5952610969543457,4.0015468597412109,-3.3826379776000977" boneRefs="89"/> <Rigid refID="16" transformation="-0.96715354919433594,0.00076888891635462642,0.25419169664382935,0.0048290742561221123,0.99987059831619263,0.015349320136010647,-0.25414705276489258,0.016072669997811317,-0.96703213453292847,5.287257194519043,3.1689808368682861,-1.8006534576416016" boneRefs="90,91"/> <Rigid refID="17" transformation="0.96715366840362549,-0.00076990161323919892,-0.25419163703918457,0.0048300959169864655,0.99987059831619263,0.015349230729043484,0.25414693355560303,-0.016072841361165047,0.96703207492828369,5.5940685272216797,3.5296452045440674,-0.6343841552734375" boneRefs="92,93,94,95,96"/> <Rigid refID="18" transformation="0.21768979728221893,-0.51380842924118042,0.8298264741897583,0.13124468922615051,0.85790461301803589,0.49676418304443359,-0.96715354919433594,0.00076983083272352815,0.25419166684150696,6.150153636932373,1.7245956659317017,1.4868918657302856" boneRefs="97,98,99,100,101"/> <Rigid refID="19" transformation="-0.0048288637772202492,-0.015325718559324741,0.9998708963394165,0.99997669458389282,-0.0049025225453078747,0.0047542480751872063,0.0048290216363966465,0.99987059831619263,0.015349027700722218,5.1875252723693848,3.5753581523895264,-2.181326150894165" boneRefs="102"/> <Rigid refID="20" transformation="-0.96715366840362549,0.00076903699664399028,0.25419163703918457,0.0048292018473148346,0.99987059831619263,0.015349230729043484,-0.25414693355560303,0.016072614118456841,-0.96703207492828369,5.2795305252075195,1.5691882371902466,-1.8252125978469849" boneRefs="103,104"/> <Rigid refID="21" transformation="0.99671286344528198,-0.0035728011280298233,-0.080937527120113373,0.004830564372241497,0.99987059831619263,0.015349510125815868,0.080872222781181335,-0.015690034255385399,0.99660104513168335,4.5168557167053223,3.5341789722442627,-0.59087592363357544" boneRefs="105,106,107,108,109"/> <Rigid refID="22" transformation="-0.99671286344528198,0.003571315435692668,0.080937549471855164,0.0048290700651705265,0.99987059831619263,0.015349461697041988,-0.080872267484664917,0.015689864754676819,-0.99660104513168335,4.4179744720458984,3.1730556488037109,-1.7926276922225952" boneRefs="110,111"/> <Rigid refID="23" transformation="-0.0054832049645483494,-0.015322507359087467,0.99986755847930908,0.99997329711914063,-0.0049125622026622295,0.0054085203446447849,0.0048290342092514038,0.99987059831619263,0.015349027700722218,4.3875441551208496,3.5792796611785889,-2.1851296424865723" boneRefs="112"/> <Rigid refID="24" transformation="0.067624621093273163,-0.51347589492797852,0.85543531179428101,0.044615693390369415,0.8580966591835022,0.51154637336730957,-0.99671286344528198,0.0035727156791836023,0.080937512218952179,4.6879806518554687,1.7299829721450806,1.5960904359817505" boneRefs="113,114,115,116,117"/> <Rigid refID="25" transformation="-0.99671286344528198,0.003571417648345232,0.080937467515468597,0.0048291562125086784,0.99987059831619263,0.01534927636384964,-0.080872185528278351,0.015689685940742493,-0.99660098552703857,4.410247802734375,1.5732630491256714,-1.817186713218689" boneRefs="118,119"/> <Rigid refID="26" transformation="0.0048265052028000355,0.99987059831619263,0.015348486602306366,0.99997669458389282,-0.0048999860882759094,0.0047531267628073692,0.0048277010209858418,0.015325195156037807,-0.9998708963394165,1.9952712059020996,3.2217516899108887,-4.2024192810058594" boneRefs="120"/> <Rigid refID="27" transformation="0.99997574090957642,-0.0051024807617068291,0.0047472217120230198,0.0050290636718273163,0.99986958503723145,0.015349620021879673,-0.0048249056562781334,-0.015325380489230156,0.9998708963394165,1.9991309642791748,4.8092846870422363,-3.3779644966125488" boneRefs="121"/> <Rigid refID="28" transformation="-0.0048132883384823799,-0.99987071752548218,-0.015348002314567566,-0.0048258872702717781,-0.015324782580137253,0.9998708963394165,-0.9999767541885376,0.0048867403529584408,-0.0047515183687210083,2.0068490505218506,4.8338055610656738,-4.9777584075927734" boneRefs="122"/> <Rigid refID="29" transformation="0.99997669458389282,-0.0049025029875338078,0.004754264373332262,0.004828878678381443,0.015325593762099743,-0.9998708963394165,0.0048290025442838669,0.99987059831619263,0.015348901972174644,3.5952882766723633,3.6077263355255127,-3.7887279987335205" boneRefs="123"/> <Rigid refID="30" transformation="0.99997669458389282,-0.0049013379029929638,0.0047539938241243362,0.0048278416506946087,0.99987059831619263,0.015348910354077816,-0.0048285904340445995,-0.015325608663260937,0.9998708963394165,4.3759546279907227,0.78577178716659546,-2.6280550956726074" boneRefs="124"/> <Rigid refID="31" transformation="0.0047543877735733986,1.1547072972462047E-005,-0.99998867511749268,0.0048899650573730469,0.99998807907104492,3.478707731119357E-005,0.9999767541885376,-0.0048900814726948738,0.0047542932443320751,4.0087714195251465,4.0424938201904297,-6.180382251739502" boneRefs="125"/> <Rigid refID="32" transformation="-0.99997669458389282,0.0049025560729205608,-0.0047543924301862717,0.0048290528357028961,0.99987059831619263,0.015349051915109158,0.0048290085978806019,0.015325742773711681,-0.9998708963394165,4.4068603515625,2.4591274261474609,-7.4028363227844238" boneRefs="126"/> <Rigid refID="33" transformation="0.0048288330435752869,0.015325712971389294,-0.9998708963394165,0.00482904352247715,0.99987059831619263,0.015349021181464195,0.99997669458389282,-0.0049025439657270908,0.004754217341542244,3.1895029544830322,1.6222022771835327,-4.6211824417114258" boneRefs="127"/> <Rigid refID="34" transformation="0.99997669458389282,-0.0049040256999433041,0.0047531710006296635,0.0048305424861609936,0.99987059831619263,0.015348735265433788,-0.0048278081230819225,-0.015325424261391163,0.9998708963394165,3.5759737491607666,0.78969353437423706,-2.6318566799163818" boneRefs="128"/> <Rigid refID="35" transformation="0.0048288339748978615,0.015325905755162239,-0.9998708963394165,0.0048290425911545753,0.99987059831619263,0.015349213965237141,0.99997669458389282,-0.0049025439657270908,0.004754217341542244,5.5894474983215332,1.6104365587234497,-4.6097726821899414" boneRefs="129"/> <Rigid refID="36" transformation="0.99997669458389282,-0.0049025090411305428,0.004754143301397562,0.0048287590034306049,0.015325779095292091,-0.9998708963394165,0.0048290095292031765,0.99987059831619263,0.015349087305366993,5.1952524185180664,2.024606466293335,-5.4054322242736816" boneRefs="130"/> <Rigid refID="37" transformation="0.99997568130493164,-0.0051026763394474983,0.0047504594549536705,0.0050292103551328182,0.99986958503723145,0.01534951850771904,-0.0048281452618539333,-0.01532526221126318,0.9998708963394165,1.9952707290649414,4.0093879699707031,-3.3902430534362793" boneRefs="131"/> <Rigid refID="38" transformation="0.99997669458389282,-0.0049031777307391167,0.0047527430579066277,0.0048273666761815548,0.015325248241424561,-0.9998708963394165,0.0048297024331986904,0.99987059831619263,0.015348552726209164,3.5914251804351807,3.5954651832580566,-2.9888310432434082" boneRefs="132"/> <Rigid refID="39" transformation="0.99997669458389282,-0.0049050459638237953,0.0047502131201326847,0.0048316088505089283,0.99987059831619263,0.015348616056144238,-0.0048248656094074249,-0.015325314365327358,0.9998708963394165,2.3895187377929687,3.2014017105102539,-3.0006704330444336" boneRefs="133,134,135"/> <Rigid refID="40" transformation="0.99588507413864136,-0.0062009920366108418,0.090412892401218414,0.004832239355891943,0.99987053871154785,0.015349896624684334,-0.090496346354484558,-0.014849841594696045,0.99578607082366943,3.4426636695861816,3.5394484996795654,-0.59598225355148315" boneRefs="136,137,138,139,140"/> <Rigid refID="41" transformation="-0.99588513374328613,0.006197748240083456,-0.090412870049476624,0.0048290318809449673,0.99987059831619263,0.015349355526268482,0.090496279299259186,0.014849593862891197,-0.99578613042831421,3.5494229793548584,3.1773171424865723,-1.7967573404312134" boneRefs="141,142"/> <Rigid refID="42" transformation="-0.99588513374328613,0.0061978395096957684,-0.090412966907024384,0.004829120822250843,0.99987059831619263,0.015349367633461952,0.090496368706226349,0.014849596656858921,-0.99578607082366943,3.5416934490203857,1.5775244235992432,-1.8213163614273071" boneRefs="143,144"/> <Rigid refID="43" transformation="-0.0041718240827322006,-0.015328943729400635,0.9998738169670105,0.99997961521148682,-0.0048924903385341167,0.0040972777642309666,0.004829060286283493,0.99987059831619263,0.015349035151302814,3.5875625610351562,3.5832052230834961,-2.1889331340789795" boneRefs="145"/> <Rigid refID="44" transformation="-0.08079046756029129,-0.5127485990524292,0.8547290563583374,-0.041059009730815887,0.85851645469665527,0.51113975048065186,-0.99588507413864136,0.0062008961103856564,-0.090412907302379608,3.233057975769043,1.7371178865432739,1.5891721248626709" boneRefs="146,147,148,149,150"/> <Rigid refID="45" transformation="-0.0048286938108503819,-0.015325690619647503,0.9998708963394165,0.99997669458389282,-0.0049024969339370728,0.0047540790401399136,0.0048289988189935684,0.99987059831619263,0.01534899789839983,5.1991152763366699,1.2492311000823975,-7.0175046920776367" boneRefs="151"/> <Rigid refID="46" transformation="0.2634732723236084,0.013534775003790855,-0.96457183361053467,0.0048290267586708069,0.99987059831619263,0.015349129214882851,0.96465468406677246,-0.0087020415812730789,0.2633737325668335,2.469482421875,3.1709370613098145,-1.0413883924484253" boneRefs="152,153"/> <Rigid refID="47" transformation="0.96465545892715454,-0.0087027354165911674,0.26337069272994995,0.0048297382891178131,0.99987059831619263,0.015349347144365311,-0.26347014307975769,-0.013534825295209885,0.96457260847091675,2.3659276962280273,3.5454738140106201,-0.64972782135009766" boneRefs="154,155,156,157,158"/> <Rigid refID="48" transformation="0.26347255706787109,0.013534697704017162,-0.96457195281982422,0.0048291278071701527,0.99987059831619263,0.015349075198173523,0.96465480327606201,-0.0087021104991436005,0.26337304711341858,2.4617562294006348,1.5711442232131958,-1.0659475326538086" boneRefs="159,160"/> <Rigid refID="49" transformation="-0.0048277056775987148,-0.015325731597840786,0.9998708963394165,0.99997669458389282,-0.0049025435000658035,0.0047530895099043846,0.004829060286283493,0.99987059831619263,0.015349035151302814,2.7875816822052002,3.5871272087097168,-2.1927366256713867" boneRefs="161"/> <Rigid refID="50" transformation="0.99997669458389282,-0.004902559332549572,0.0047545195557177067,-0.004829054232686758,-0.99987059831619263,-0.015349104069173336,0.0048291357234120369,0.015325793996453285,-0.9998708963394165,3.5991523265838623,2.438528299331665,-5.8068461418151855" boneRefs="162,163"/> <Rigid refID="51" transformation="0.99997669458389282,-0.0049019199796020985,0.0047541833482682705,0.0048284209333360195,0.99987059831619263,0.015348884277045727,-0.0048287888057529926,-0.015325578860938549,0.9998708963394165,4.3759546279907227,0.78577178716659546,-2.6280550956726074" boneRefs="164"/> <Rigid refID="52" transformation="-0.99997669458389282,0.0049025560729205608,-0.0047543966211378574,0.0048290528357028961,0.99987059831619263,0.015349051915109158,0.0048290127888321877,0.015325742773711681,-0.9998708963394165,3.6068785190582275,2.4630491733551025,-7.406639575958252" boneRefs="165"/> <Rigid refID="53" transformation="-0.23059342801570892,-0.51161152124404907,0.82769578695297241,-0.12754039466381073,0.85917288064956665,0.49553570151329041,-0.96465545892715454,0.0087026329711079597,-0.26337075233459473,1.7720359563827515,1.7460619211196899,1.4660823345184326" boneRefs="166,167,168,169,170"/> <Rigid refID="54" transformation="-0.0047289147041738033,1.1508681382110808E-005,0.99998879432678223,0.0048762918449938297,0.99998819828033447,1.1542109859874472E-005,-0.99997693300247192,0.004876298364251852,-0.0047289333306252956,1.6010984182357788,3.2420303821563721,-5.4041357040405273" boneRefs="171"/> <Rigid refID="55" transformation="0.99997669458389282,-0.0049060583114624023,0.0047524287365376949,0.0048325872048735619,0.99987059831619263,0.015348609536886215,-0.0048270965926349163,-0.015325292013585567,0.9998708963394165,1.9760110378265381,0.79754328727722168,-2.6394598484039307" boneRefs="172"/> <Rigid refID="56" transformation="0.99997669458389282,-0.0049001104198396206,0.0047507863491773605,0.004826666321605444,0.99987059831619263,0.015348364599049091,-0.004825362004339695,-0.015325084328651428,0.9998708963394165,1.9798665046691895,1.5974404811859131,-2.6271812915802002" boneRefs="173,174"/> <Rigid refID="57" transformation="0.99997669458389282,-0.004902510903775692,0.004754270426928997,0.0048288856633007526,0.015325696207582951,-0.9998708963394165,0.0048290099948644638,0.99987059831619263,0.015349005348980427,2.7953071594238281,2.036372184753418,-5.416841983795166" boneRefs="175"/> <Rigid refID="58" transformation="-0.0048289545811712742,-0.015325740911066532,0.9998708963394165,0.99997669458389282,-0.0049025006592273712,0.0047543393447995186,0.0048289983533322811,0.99987059831619263,0.015349050052464008,2.7991702556610107,1.26099693775177,-7.0289149284362793" boneRefs="176"/> <Rigid refID="59" transformation="0.99997669458389282,-0.0048965872265398502,0.0047527020797133446,0.0048231147229671478,0.9998706579208374,0.015348252840340137,-0.0048272227868437767,-0.015324980020523071,0.9998708963394165,1.9760115146636963,0.79754328727722168,-2.6394598484039307" boneRefs="177"/> <Rigid refID="60" transformation="0.004828836303204298,0.99987053871154785,0.015349049121141434,-0.0048289401456713676,-0.015325733460485935,0.9998708963394165,0.99997669458389282,-0.0049023325555026531,0.0047543095424771309,5.6241793632507324,4.8713064193725586,-8.5587234497070312" boneRefs="178,179,180,181,182,183,184,185,186,187,188,189,190,191"/> <Rigid refID="61" transformation="-0.057335361838340759,-0.82053923606872559,0.56870752573013306,0.99828344583511353,-0.053943540900945663,0.022813398391008377,0.011958806775510311,0.56903922557830811,0.82222342491149902,4.0851807594299316,13.104366302490234,-16.053497314453125" boneRefs="192"/> <Rigid refID="62" transformation="-0.097959436476230621,-0.95083010196685791,0.29381293058395386,0.99502182006835938,-0.088141389191150665,0.046506769955158234,-0.018322957679629326,0.29690605401992798,0.95473098754882813,4.0393123626708984,12.447931289672852,-15.598526954650879" boneRefs="193"/> <Rigid refID="63" transformation="-0.11335434019565582,-0.99268907308578491,0.041465442627668381,0.99238103628158569,-0.11109388619661331,0.053273528814315796,-0.048277489840984344,0.047188300639390945,0.9977186918258667,3.9609444141387939,11.687265396118164,-15.363475799560547" boneRefs="194"/> <Rigid refID="64" transformation="-0.10982836782932281,-0.98408299684524536,-0.13970828056335449,0.9915422797203064,-0.11825324594974518,0.053479567170143127,-0.069149293005466461,-0.13265310227870941,0.98874747753143311,3.8702607154846191,10.89311408996582,-15.330304145812988" boneRefs="195"/> <Rigid refID="65" transformation="-0.093521937727928162,-0.96893304586410522,-0.22895941138267517,0.99254721403121948,-0.10878035426139832,0.054926507174968719,-0.078126400709152222,-0.22211621701717377,0.97188520431518555,3.7823975086212158,10.105847358703613,-15.442070960998535" boneRefs="196"/> <Rigid refID="66" transformation="-0.06865035742521286,-0.97219103574752808,-0.22390121221542358,0.99458140134811401,-0.084256798028945923,0.060898911207914352,-0.078070573508739471,-0.21850724518299103,0.97270733118057251,3.7075796127319336,9.3306999206542969,-15.625238418579102" boneRefs="197"/> <Rigid refID="67" transformation="-0.036809399724006653,-0.99159610271453857,-0.12402525544166565,0.99650490283966064,-0.04573473334312439,0.069902196526527405,-0.074987009167671204,-0.12101873010396957,0.98981392383575439,3.6526591777801514,8.5529470443725586,-15.804360389709473" boneRefs="198"/> <Rigid refID="68" transformation="0.0010671811178326607,-0.99765831232070923,0.068386688828468323,0.9970555305480957,0.006305221002548933,0.076424479484558105,-0.076676703989505768,0.068103760480880737,0.99472737312316895,3.6232116222381592,7.7596688270568848,-15.903580665588379" boneRefs="199"/> <Rigid refID="69" transformation="0.04156920313835144,-0.94190728664398193,0.33329096436500549,0.99499088525772095,0.069378875195980072,0.071971617639064789,-0.090913929045200348,0.32862961292266846,0.94007301330566406,3.6240653991699219,6.9615416526794434,-15.848871231079102" boneRefs="200"/> <Rigid refID="70" transformation="0.076306089758872986,-0.78824919462203979,0.61060672998428345,0.989815354347229,0.13369607925415039,0.048897083848714828,-0.12017881870269775,0.60065680742263794,0.79042297601699829,3.6573207378387451,6.208014965057373,-15.58223819732666" boneRefs="201"/> <Rigid refID="71" transformation="0.096752539277076721,-0.54185855388641357,0.83488219976425171,0.98238843679428101,0.18670636415481567,0.0073302164673805237,-0.15984976291656494,0.8194693922996521,0.55037987232208252,3.7183656692504883,5.5774154663085937,-15.093752861022949" boneRefs="202"/> <Rigid refID="72" transformation="0.09841986745595932,-0.25376042723655701,0.96224695444107056,0.97494322061538696,0.21843104064464569,-0.042114581912755966,-0.19949761033058167,0.94228112697601318,0.26889997720718384,3.7957680225372314,5.143928050994873,-14.425846099853516" boneRefs="203"/> <Rigid refID="73" transformation="0.0833330899477005,0.0096863424405455589,0.99647468328475952,0.96977812051773071,0.22931757569313049,-0.083329617977142334,-0.2293163388967514,0.97330355644226074,0.0097161391749978065,3.8745038509368896,4.9409198760986328,-13.656048774719238" boneRefs="204"/> <Rigid refID="74" transformation="0.060260239988565445,0.19433361291885376,0.97908282279968262,0.96761423349380493,0.22950994968414307,-0.10510874539613724,-0.24513541162014008,0.95370835065841675,-0.17420963943004608,3.9411704540252686,4.9486689567565918,-12.858868598937988" boneRefs="205"/> <Rigid refID="75" transformation="0.036631539463996887,0.28413063287734985,0.95808553695678711,0.96745580434799194,0.23011994361877441,-0.10523436218500137,-0.25037488341331482,0.93076032400131226,-0.26645419001579285,3.9893786907196045,5.1041359901428223,-12.075602531433105" boneRefs="206"/> <Rigid refID="76" transformation="0.016663938760757446,0.27886536717414856,0.96018564701080322,0.96783334016799927,0.23661291599273682,-0.085515819489955902,-0.25103971362113953,0.93072468042373657,-0.26595228910446167,4.018683910369873,5.3314404487609863,-11.309133529663086" boneRefs="207"/> <Rigid refID="77" transformation="0.0023584545124322176,0.17861936986446381,0.98391544818878174,0.96755099296569824,0.24819454550743103,-0.047376304864883423,-0.25266477465629578,0.95210009813308716,-0.17223799228668213,4.032015323638916,5.5545330047607422,-10.540985107421875" boneRefs="208"/> <Rigid refID="78" transformation="-0.0048260306939482689,-0.015318823046982288,0.99987101554870605,0.96590733528137207,0.25874468684196472,0.0086262747645378113,-0.25884342193603516,0.96582430601119995,0.013547852635383606,4.0339021682739258,5.6974282264709473,-9.7538528442382812" boneRefs="209,210"/> <Joint type="hinge"> <RigidRef rigidRef="1" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,-0.40000000596046448"/> <RigidRef rigidRef="0" a="0,0,-1" z="1,0,0" t="0,0,-2.800001859664917"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="11" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="0" a="1,0,0" z="0,1,0" t="0.39999955892562866,-0.80000001192092896,-2.0000004768371582"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="15" a="0,0,1" z="1,0,0" t="0,0,-0.80000030994415283"/> <RigidRef rigidRef="0" a="1,0,0" z="0,1,0" t="0.40000003576278687,-0.80000001192092896,-1.200000524520874"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="5" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="0,0,-1" z="0,-1,0" t="-2.7776437491411343E-005,-0.80000853538513184,-0.80000162124633789"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="4" a="0,1,0" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="1.6000000238418579,1.6000000238418579,-1.6000015735626221"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="3" a="0,0,1" z="1,0,0" t="0,0,-0.40000048279762268"/> <RigidRef rigidRef="1" a="0,0,-1" z="1,0,0" t="0.80000185966491699,-1.6000072956085205,-1.2000000476837158"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="2" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="0.40000048279762268,0.80000007152557373,-1.1999747753143311"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="14" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="1" a="-1,0,0" z="0,-1,0" t="-1.199999213218689,1.6000009775161743,-1.1999727487564087"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="19" a="0,0,-1" z="-1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="1" a="-1,0,0" z="0,-1,0" t="-1.1999990940093994,2.400001049041748,-0.39997279644012451"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="23" a="0,0,-1" z="-1,0,0" t="0,0,-1.5999995470046997"/> <RigidRef rigidRef="1" a="-1,0,0" z="0,-1,0" t="-1.1999990940093994,2.400001049041748,-1.1999727487564087"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="29" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="0.40000095963478088,0.80000007152557373,-1.9999747276306152"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="31" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="1" a="0,0,-1" z="1,0,0" t="0.80000203847885132,-1.6000065803527832,-2.4000022411346436"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="32" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="0,-1,0" z="1,0,0" t="-0.7999996542930603,-2.7999601364135742,-1.1999717950820923"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="33" a="-1,0,0" z="0,1,0" t="-0.40000000596046448,0.80000001192092896,-0.40000000596046448"/> <RigidRef rigidRef="1" a="0,1,0" z="1,0,0" t="-0.80000007152557373,0.4000401496887207,-2.7999715805053711"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="34" a="0,0,1" z="1,0,0" t="0,0,-0.80000078678131104"/> <RigidRef rigidRef="1" a="0,1,0" z="1,0,0" t="-2.3999993801116943,1.2000000476837158,-1.999971866607666"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="35" a="-1,0,0" z="0,1,0" t="-0.40000000596046448,0.80000001192092896,-0.40000000596046448"/> <RigidRef rigidRef="1" a="0,1,0" z="1,0,0" t="-0.79999977350234985,0.40003961324691772,-0.39997079968452454"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="38" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="-0.39999669790267944,1.600000262260437,-1.9999721050262451"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="43" a="0,0,1" z="-1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="-0.39999592304229736,2.4000003337860107,-1.9999721050262451"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="45" a="0,0,1" z="0,1,0" t="0,0,-0.80000001192092896"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="-2.799999475479126,-2.3999595642089844,-0.39997109770774841"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="49" a="0,0,1" z="-1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="-0.39999616146087646,2.4000003337860107,-2.7999720573425293"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="51" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="1" a="0,1,0" z="1,0,0" t="-2.3999993801116943,1.1999993324279785,-1.1999720335006714"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="52" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="1" a="0,-1,0" z="1,0,0" t="-0.7999996542930603,-2.7999601364135742,-1.9999717473983765"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="54" a="0,0,1" z="1,0,0" t="0,0,-0.40000003576278687"/> <RigidRef rigidRef="1" a="-3.227625711588189E-005,3.2093968911794946E-005,-1" z="0,-1,-3.2094838388729841E-005" t="-5.9652327763615176E-005,-0.79997605085372925,-3.6000039577484131"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="58" a="0,0,1" z="0,1,0" t="0,0,-0.80000001192092896"/> <RigidRef rigidRef="1" a="1,0,0" z="0,-1,0" t="-2.7999997138977051,-2.3999600410461426,-2.7999701499938965"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="60" a="-0.70711332559585571,-0.70710033178329468,0" z="0.70710033178329468,-0.70711332559585571,0" t="1.5999979972839355,2.4000005722045898,-1.5999972820281982"/> <RigidRef rigidRef="1" a="-0.70711314678192139,-0.707100510597229,0" z="0.707100510597229,-0.70711314678192139,0" t="3.2000024318695068,-1.5985422134399414,-1.6000022888183594"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="7" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0,0"/> <RigidRef rigidRef="6" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="10" a="0,0,1" z="1,0,0" t="0.79999995231628418,0,-0.80000013113021851"/> <RigidRef rigidRef="6" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="7" a="0,-1,0" z="0,0,1" t="-4,0.80000144243240356,0"/> <RigidRef rigidRef="8" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="9" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="7" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="12" a="0,0,-1" z="0,1,0" t="0,0,-1.5999995470046997"/> <RigidRef rigidRef="7" a="0,-1,0" z="0,0,1" t="-3.2000000476837158,0.80000001192092896,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="30" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,0"/> <RigidRef rigidRef="8" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="10" a="0,0,1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="9" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="11" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="10" a="0,0,1" z="1,0,0" t="0.80000001192092896,1.6000299453735352,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="12" a="0,0,-1" z="0,1,0" t="0,0,-0.79999881982803345"/> <RigidRef rigidRef="13" a="-1,0,0" z="0,1,0" t="-0.39999964833259583,-1.600001335144043,-1.2000007629394531"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="14" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="13" a="0,1,0" z="1,0,0" t="0,0.3999999463558197,0.39999976754188538"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="26" a="0,0,1" z="1,0,0" t="0.79999995231628418,1.6000299453735352,-0.80000013113021851"/> <RigidRef rigidRef="15" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="17" a="0,0,1" z="1,0,0" t="0,-0.3799997866153717,0.3999994695186615"/> <RigidRef rigidRef="16" a="0,0,-1" z="1,0,0" t="0,0,-1.5999974012374878"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="19" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="16" a="0,1,0" z="1,0,0" t="0,0.40000006556510925,0.40000078082084656"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="17" a="1,0,0" z="0,0,-1" t="0,-1.0319998264312744,0.79999947547912598"/> <RigidRef rigidRef="18" a="0,0,-1" z="-1,0,0" t="-1.5999995470046997,-0.072000332176685333,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="20" a="0,0,-1" z="1,0,0" t="0,0,-1.5999994277954102"/> <RigidRef rigidRef="17" a="0,0,1" z="1,0,0" t="0,-1.979999303817749,0.40000146627426147"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="20" a="0,1,0" z="1,0,0" t="0,-0.3999999463558197,0.39999926090240479"/> <RigidRef rigidRef="19" a="0,0,1" z="-1,0,0" t="0,0,-2.3999993801116943"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="22" a="0,0,-1" z="1,0,0" t="0,0,-1.5999976396560669"/> <RigidRef rigidRef="21" a="0,0,1" z="1,0,0" t="0,-0.37999916076660156,0.39999997615814209"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="24" a="0,0,-1" z="-1,0,0" t="-1.599998950958252,-0.072000354528427124,0"/> <RigidRef rigidRef="21" a="1,0,0" z="0,0,-1" t="0,-1.0319994688034058,0.80000036954879761"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="25" a="0,0,-1" z="1,0,0" t="0,0,-1.5999995470046997"/> <RigidRef rigidRef="21" a="0,0,1" z="1,0,0" t="0,-1.9799991846084595,0.40000227093696594"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="23" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="22" a="0,1,0" z="1,0,0" t="1.286212500417605E-005,0.39999973773956299,0.40000244975090027"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="25" a="0,1,0" z="1,0,0" t="1.2490560038713738E-005,-0.39999958872795105,0.40000182390213013"/> <RigidRef rigidRef="23" a="0,0,1" z="-1,0,0" t="0,0,-2.3999991416931152"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="27" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="26" a="0,0,1" z="1,0,0" t="1.6000000238418579,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="37" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="26" a="0,0,1" z="1,0,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="27" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="28" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="37" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="28" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="56" a="0,0,-1" z="0,1,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="28" a="0,-1,0" z="0,0,1" t="3.2000000476837158,0.80000096559524536,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="59" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="28" a="0,-1,0" z="0,0,1" t="4,0.80000001192092896,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="51" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="30" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="50" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,-0.79999953508377075"/> <RigidRef rigidRef="32" a="0,0,1" z="-1,0,0" t="0,0,-2.4000000953674316"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="57" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="33" a="0,-1,0" z="-1,0,0" t="0.80000001192092896,-0.40000000596046448,-0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="55" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,0"/> <RigidRef rigidRef="34" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="36" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="35" a="0,-1,0" z="-1,0,0" t="0.80000001192092896,-0.40000000596046448,-0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="45" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,-0.80000001192092896"/> <RigidRef rigidRef="36" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="39" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> <RigidRef rigidRef="38" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="56" a="0,0,-1" z="0,1,0" t="0,0,-0.79999804496765137"/> <RigidRef rigidRef="39" a="0,0,-1" z="0,1,0" t="-0.40000137686729431,-1.6000006198883057,-0.39999935030937195"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="41" a="0,0,-1" z="1,0,0" t="0,0,-1.5999987125396729"/> <RigidRef rigidRef="40" a="0,0,1" z="1,0,0" t="0,-0.38000106811523438,0.39999991655349731"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="42" a="0,0,-1" z="1,0,0" t="0,0,-1.5999987125396729"/> <RigidRef rigidRef="40" a="0,0,1" z="1,0,0" t="0,-1.9800018072128296,0.40000057220458984"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="44" a="0,0,-1" z="-1,0,0" t="-1.5999988317489624,-0.071998871862888336,0"/> <RigidRef rigidRef="40" a="1,0,0" z="0,0,-1" t="0,-1.0320017337799072,0.79999971389770508"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="43" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="41" a="0,1,0" z="1,0,0" t="-1.0288547855452634E-005,0.40000009536743164,0.40000098943710327"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="43" a="0,0,1" z="-1,0,0" t="0,0,-1.5999994277954102"/> <RigidRef rigidRef="42" a="0,1,0" z="1,0,0" t="-1.3512034456653055E-005,0.40000006556510925,0.40000069141387939"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="47" a="0,0,1" z="1,0,0" t="0,-0.3799997866153717,0.40000012516975403"/> <RigidRef rigidRef="46" a="-1,0,0" z="0,0,-1" t="-0.79999935626983643,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="49" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="46" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.39999997615814209,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="47" a="0,0,1" z="1,0,0" t="0,-1.98000168800354,0.40000125765800476"/> <RigidRef rigidRef="48" a="-1,0,0" z="0,0,-1" t="-0.80000108480453491,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="53" a="0,0,-1" z="-1,0,0" t="-1.6000000238418579,-0.071999877691268921,0"/> <RigidRef rigidRef="47" a="1,0,0" z="0,0,-1" t="0,-1.032001256942749,0.7999994158744812"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="49" a="0,0,1" z="-1,0,0" t="0,0,-1.5999997854232788"/> <RigidRef rigidRef="48" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="52" a="0,0,1" z="-1,0,0" t="0,0,-1.5999999046325684"/> <RigidRef rigidRef="50" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="59" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="55" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="58" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,-0.80000001192092896"/> <RigidRef rigidRef="57" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="60" a="0,1,0" z="0.0048659448511898518,0,0.99998819828033447" t="0.79999792575836182,-0.39995655417442322,-1.5999701023101807"/> <RigidRef rigidRef="78" a="1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="62" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="61" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="63" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="62" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="64" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="63" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="65" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="64" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="66" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="65" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="67" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="66" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="68" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="67" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="69" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="68" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="70" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="69" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="71" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="70" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="72" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="71" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="73" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="72" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="74" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="73" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="75" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="74" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="76" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="75" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="77" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="76" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="78" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="77" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> </RigidSystem> <RigidSystem> <Rigid refID="79" transformation="0.99997329711914063,-0.00716830650344491,0.0014258463634178042,-0.0014263755874708295,-0.38274195790290833,-0.92385417222976685,0.0071682012639939785,0.92382746934890747,-0.38274195790290833,2.556466817855835,22.871852874755859,-16.478963851928711" boneRefs="211"/> <Rigid refID="80" transformation="-0.0013227767776697874,-0.38274356722831726,-0.92385369539260864,0.0078249424695968628,0.92382222414016724,-0.38274174928665161,0.99996852874755859,-0.0077353836968541145,0.0017729356186464429,2.1651754379272461,23.983011245727539,-16.939409255981445" boneRefs="212,213,214,215,216,217,218,219,220"/> <Rigid refID="81" transformation="0,6.3950865296646953E-005,1,0.99996984004974365,-0.0077665788121521473,0,0.0077665788121521473,0.99996984004974365,-6.3948937167879194E-005,2.5212781429290771,18.345306396484375,-19.902198791503906" boneRefs="221,222,223,224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239,240,241,242,243,244,245,246,247,248,249,250,251,252,253,254,255,256,257,258,259,260,261,262,263,264,265,266,267,268,269,270,271,272,273,274,275,276,277,278,279,280,281,282,283,284,285,286,287,288,289,290,291,292,293,294,295,296,297,298"/> <Rigid refID="82" transformation="-0.0067561478354036808,-0.70709031820297241,0.70709091424942017,0.00010351972741773352,0.70710659027099609,0.70710694789886475,-0.99997717142105103,0.0048505170270800591,-0.0047041187062859535,3.6818888187408447,13.833662033081055,-15.817666053771973" boneRefs="299,300,301,302,303,304,305,306,307,308,309,310,311,312,313,314,315,316,317,318,319,320,321,322,323,324,325,326,327,328,329,330,331,332,333,334,335,336,337,338,339,340,341,342,343,344,345,346,347,348,349,350,351,352,353,354,355,356,357,358,359,360,361,362,363,364,365,366,367,368,369,370,371,372,373,374,375,376,377,378,379,380,381,382,383,384,385,386,387,388,389,390,391,392,393,394,395,396,397,398,399"/> <Rigid refID="83" transformation="-0.0068279663100838661,-0.70708984136581421,0.70709079504013062,-0.0001043399897753261,-0.70710676908493042,-0.7071068286895752,0.99997669458389282,-0.0049018794670701027,0.0047543235123157501,7.7413210868835449,8.7223310470581055,-10.706938743591309" boneRefs="400"/> <Rigid refID="84" transformation="0.0068285386078059673,0.70708966255187988,-0.70709091424942017,0.00010458508040755987,0.70710688829421997,0.70710664987564087,0.99997669458389282,-0.004902456421405077,0.0047545558772981167,8.4332218170166016,8.1532535552978516,-11.269333839416504" boneRefs="401,402"/> <Rigid refID="85" transformation="0.00038926512934267521,-0.70710980892181396,-0.7071036696434021,0.99997669458389282,-0.0045468579046428204,0.0050973906181752682,-0.0068195145577192307,-0.7070891261100769,0.70709151029586792,0.8473963737487793,11.867429733276367,-10.456906318664551" boneRefs="403"/> <Rigid refID="86" transformation="0.9999767541885376,-0.0048213494010269642,0.0048213652335107327,0.0068184291012585163,0.70708918571472168,-0.70709151029586792,0,0.70710796117782593,0.70710563659667969,0.052870728075504303,12.436957359313965,-11.026436805725098" boneRefs="404"/> <Rigid refID="87" transformation="0.99997586011886597,-0.004206046462059021,0.0055350768379867077,-0.00093973625916987658,0.70711183547973633,0.70710110664367676,-0.0068880179896950722,-0.70708918571472168,0.70709079504013062,0.052871227264404297,12.436957359313965,-11.026436805725098" boneRefs="405"/> <Rigid refID="88" transformation="-0.00093975133495405316,0.70711213350296021,0.70710080862045288,0.0068750442005693913,0.70708894729614258,-0.70709115266799927,-0.99997591972351074,0.0041968594305217266,-0.0055259149521589279,0.8583076000213623,12.998772621154785,-11.588252067565918" boneRefs="406"/> <Rigid refID="89" transformation="-0.0047095422632992268,1.1438976798672229E-005,0.99998891353607178,0.0048576276749372482,0.99998819828033447,1.1438487490522675E-005,-0.99997711181640625,0.0048576276749372482,-0.0047095422632992268,0.0061313631013035774,5.931757926940918,-7.9152216911315918" boneRefs="407"/> <Rigid refID="90" transformation="-0.0068284468725323677,-0.70708966255187988,0.70709091424942017,0.00010434175783302635,0.70710688829421997,0.70710664987564087,-0.99997669458389282,0.0049022193998098373,-0.0047546629793941975,0.32549309730529785,8.7586860656738281,-10.742196083068848" boneRefs="408"/> <Rigid refID="91" transformation="-0.0068284561857581139,-0.70708966255187988,0.70709091424942017,0.00010477507021278143,0.70710688829421997,0.70710664987564087,-0.99997669458389282,0.0049025323241949081,-0.0047543630935251713,-0.36657413840293884,8.1963939666748047,-11.31117057800293" boneRefs="409,410"/> <Rigid refID="92" transformation="-0.0068282741121947765,-0.70709037780761719,0.70709019899368286,0.99997669458389282,-0.0049023148603737354,0.0047543230466544628,0.00010464239312568679,0.70710617303848267,0.70710736513137817,4.8335332870483398,9.5851507186889648,-9.872283935546875" boneRefs="411"/> <Rigid refID="93" transformation="-1,4.332900425652042E-005,0.00010462144564371556,-4.334018740337342E-005,0.7071075439453125,-0.70710599422454834,-0.00010461681085871533,-0.70710599422454834,-0.7071075439453125,6.0333042144775391,8.1708507537841797,-11.286574363708496" boneRefs="412,413,414,415,416"/> <Rigid refID="94" transformation="-0.0068282745778560638,-0.70709037780761719,0.70709025859832764,0.99997669458389282,-0.0049023143947124481,0.0047543235123157501,0.00010464242222951725,0.70710623264312744,0.70710736513137817,3.2335512638092041,9.5929584503173828,-9.8798418045043945" boneRefs="417"/> <Rigid refID="95" transformation="0.00038926521665416658,-0.70710980892181396,-0.7071036696434021,0.99997669458389282,-0.0045468579046428204,0.0050973910838365555,-0.0068195145577192307,-0.7070891261100769,0.70709151029586792,7.247246265411377,11.836053848266602,-10.426487922668457" boneRefs="418"/> <Rigid refID="96" transformation="0.00093971745809540153,-0.7071118950843811,-0.70710098743438721,0.0068750437349081039,0.70708918571472168,-0.70709097385406494,0.99997591972351074,-0.0041968845762312412,0.005525889340788126,7.2581577301025391,12.967395782470703,-11.557834625244141" boneRefs="419"/> <Rigid refID="97" transformation="0.99997586011886597,-0.0042060450650751591,0.0055350759066641331,-0.00093973625916987658,0.7071118950843811,0.70710104703903198,-0.0068880170583724976,-0.70708918571472168,0.70709085464477539,8.0526809692382812,12.397651672363281,-10.98808765411377" boneRefs="420"/> <Rigid refID="98" transformation="0.99997407197952271,-0.0050918986089527607,0.0050918743945658207,0.007201015017926693,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,8.0526809692382812,12.397651672363281,-10.98808765411377" boneRefs="421"/> <Rigid refID="99" transformation="0.99997669458389282,-0.0049023707397282124,0.0047543086111545563,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283029831945896,-0.70708924531936646,0.70709133148193359,2.4473628997802734,11.859663009643555,-10.449427604675293" boneRefs="422"/> <Rigid refID="100" transformation="0.99997687339782715,-0.0048090354539453983,0.0048091243952512741,0,-0.7071077823638916,-0.70710575580596924,0.0068010659888386726,0.70708942413330078,-0.70709145069122314,2.4582803249359131,12.990673065185547,-11.580864906311035" boneRefs="423"/> <Rigid refID="101" transformation="0.99997669458389282,-0.0049023698084056377,0.0047543076798319817,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.006828302051872015,-0.70708924531936646,0.70709133148193359,4.8472986221313477,11.84778881072998,-10.437975883483887" boneRefs="424"/> <Rigid refID="102" transformation="0.99997693300247192,-0.0048028221353888512,0.0048029106110334396,0,0.70710772275924683,0.70710581541061401,-0.0067922784946858883,-0.70708954334259033,0.70709145069122314,3.2473347187042236,11.855472564697266,-10.445660591125488" boneRefs="425"/> <Rigid refID="103" transformation="0.99997669458389282,-0.0049023693427443504,0.0047543072141706944,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283015862107277,-0.70708924531936646,0.70709133148193359,3.2473363876342773,11.855483055114746,-10.445671081542969" boneRefs="426"/> <Rigid refID="104" transformation="0.99997669458389282,-0.004902370274066925,0.004754308145493269,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283025175333023,-0.70708924531936646,0.70709133148193359,5.6472806930541992,11.843941688537598,-10.434128761291504" boneRefs="427"/> <Rigid refID="105" transformation="0.0072011854499578476,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,0.99997407197952271,-0.0050919796340167522,0.0050920345820486546,5.2469272613525391,12.692935943603516,-12.411938667297363" boneRefs="428"/> <Rigid refID="106" transformation="0.0072010708972811699,0.70709007978439331,-0.70708680152893066,0,0.70710515975952148,0.70710843801498413,0.99997407197952271,-0.005091911181807518,0.0050919409841299057,4.0383172035217285,11.850537300109863,-11.569545745849609" boneRefs="429,430,431"/> <Rigid refID="107" transformation="0.0072011854499578476,0.70709013938903809,-0.70708674192428589,0,0.70710510015487671,0.70710849761962891,0.99997407197952271,-0.0050919796340167522,0.0050920345820486546,5.2296361923217773,10.995918273925781,-10.714929580688477" boneRefs="432"/> <Rigid refID="108" transformation="-0.0072094360366463661,-0.70709013938903809,0.70708662271499634,0.99997401237487793,-0.0050978534854948521,0.0050978283397853374,0,0.70710504055023193,0.70710855722427368,4.0383186340332031,11.85053825378418,-11.569546699523926" boneRefs="433"/> <Rigid refID="109" transformation="0,0.70710849761962891,-0.70710510015487671,-1,0,0,0,0.70710510015487671,0.70710849761962891,6.4527091979980469,12.969646453857422,-13.254331588745117" boneRefs="434"/> <Rigid refID="110" transformation="0,-0.7071082592010498,0.70710533857345581,-2.4912687877076678E-005,-0.70710533857345581,-0.7071082592010498,1,-1.7602345906198025E-005,-1.7629516150918789E-005,6.4527297019958496,12.408026695251465,-13.82411003112793" boneRefs="435"/> <Rigid refID="111" transformation="1,-1.0267523975926451E-005,-2.4891305656637996E-005,-1.0340522749174852E-005,0.7071082592010498,-0.70710527896881104,2.4861068595782854E-005,0.70710527896881104,0.7071082592010498,6.4527492523193359,13.539397239685059,-13.82410717010498" boneRefs="436,437"/> <Rigid refID="112" transformation="1,1.24658145068679E-005,0,0,-0.70710498094558716,-0.70710861682891846,-1.0314501196262427E-005,0.70710861682891846,-0.70710498094558716,5.6527185440063477,14.670808792114258,-15.52116870880127" boneRefs="438"/> <Rigid refID="113" transformation="0,0.70710837841033936,-0.70710515975952148,-1,0,0,0,0.70710515975952148,0.70710837841033936,1.6528327465057373,12.99195671081543,-13.280848503112793" boneRefs="439"/> <Rigid refID="114" transformation="0,0.70710837841033936,-0.70710521936416626,1.7354712326778099E-005,-0.70710521936416626,-0.70710837841033936,-1,-1.2396577403706033E-005,-1.2146692824899219E-005,1.6528327465057373,12.426272392272949,-13.846534729003906" boneRefs="440"/> <Rigid refID="115" transformation="1,0,2.0996167222619988E-005,1.2286724995647091E-005,0.70710837841033936,-0.70710515975952148,-1.7406327970093116E-005,0.70710515975952148,0.70710837841033936,1.6528185606002808,13.557643890380859,-13.846531867980957" boneRefs="441,442"/> <Rigid refID="116" transformation="0.9999772310256958,-0.0047414647415280342,0.00480262516066432,4.3245108827250078E-005,-0.7071070671081543,-0.70710647106170654,0.0067486907355487347,0.70709061622619629,-0.70709079504013062,4.0899538993835449,14.114714622497559,-17.229866027832031" boneRefs="443"/> <Rigid refID="117" transformation="0.99997669458389282,-0.0049021416343748569,0.0047543011605739594,-0.0068281358107924461,-0.70708900690078735,0.7070915699005127,-0.00010454887524247169,-0.7071075439453125,-0.70710599422454834,6.0170578956604004,7.5993738174438477,-8.4523525238037109" boneRefs="444"/> <Rigid refID="118" transformation="-0.99997669458389282,0.0049021821469068527,-0.0047544147819280624,-0.0068282447755336761,-0.7070888876914978,0.70709168910980225,0.00010449837282067165,0.70710766315460205,0.70710587501525879,6.0172252655029297,8.7307462692260742,-7.3209829330444336" boneRefs="445"/> <Rigid refID="119" transformation="-0.99995326995849609,0,-0.0096659790724515915,0.0068345260806381702,-0.70712471008300781,-0.70705580711364746,-0.0068352320231497288,-0.7070888876914978,0.70709168910980225,5.214470386505127,8.1689891815185547,-7.3247928619384766" boneRefs="446"/> <Rigid refID="120" transformation="-0.99997639656066895,0.004888645838946104,-0.004827483557164669,-0.0068703410215675831,-0.7070886492729187,0.7070915699005127,4.3261410610284656E-005,0.7071080207824707,0.70710551738739014,5.2254071235656738,9.3003311157226562,-8.4561395645141602" boneRefs="447,448,449"/> <Rigid refID="121" transformation="-0.99997657537460327,0.004839905072003603,-0.004840014036744833,0,0.70710515975952148,0.70710843801498413,0.006844736635684967,0.70709186792373657,-0.70708858966827393,6.8308234214782715,9.858184814453125,-9.0140838623046875" boneRefs="450,451,452,453"/> <Rigid refID="122" transformation="-0.0048763127997517586,1.2039567081956193E-005,0.9999881386756897,0.0049379416741430759,0.99998778104782104,1.2039670764352195E-005,-0.99997591972351074,0.0049379416741430759,-0.0048763127997517586,4.0117325782775879,8.4580469131469727,-6.4824056625366211" boneRefs="454"/> <Rigid refID="123" transformation="1,-4.3210937292315066E-005,-0.00010442379425512627,-4.3283936975058168E-005,0.70710736513137817,-0.70710617303848267,0.00010439355537528172,0.70710617303848267,0.70710736513137817,2.0169835090637207,6.4876108169555664,-9.6027450561523437" boneRefs="455"/> <Rigid refID="124" transformation="0.99997669458389282,-0.0049022408202290535,0.0047542601823806763,-0.0068281772546470165,-0.70708948373794556,0.70709109306335449,-0.00010464352817507461,-0.7071070671081543,-0.70710647106170654,2.0171499252319336,7.6189818382263184,-8.4713726043701172" boneRefs="456"/> <Rigid refID="125" transformation="-0.0068282773718237877,-0.70708942413330078,0.70709121227264404,0.99997669458389282,-0.0049022440798580647,0.0047543980181217194,0.00010454921721247956,0.70710718631744385,0.70710641145706177,2.0173170566558838,8.7503528594970703,-7.3400020599365234" boneRefs="457"/> <Rigid refID="126" transformation="0.99997669458389282,-0.0049023707397282124,0.0047543086111545563,0.00010470336565049365,0.7071073055267334,0.70710623264312744,-0.0068283029831945896,-0.70708924531936646,0.70709133148193359,2.8145256042480469,8.1807518005371094,-7.3362045288085938" boneRefs="458"/> <Rigid refID="127" transformation="0.0067913341335952282,0.70709228515625,-0.7070886492729187,0.00010397551523055881,0.70710444450378418,0.70710909366607666,0.99997693300247192,-0.0048757339827716351,0.0047286623157560825,4.0063896179199219,7.8923416137695313,-5.9166140556335449" boneRefs="459,460,461"/> <Rigid refID="128" transformation="-0.99997657537460327,0.0048399046063423157,-0.0048400135710835457,0,0.70710515975952148,0.70710843801498413,0.0068447361700236797,0.70709186792373657,-0.70708858966827393,1.2309765815734863,9.8856134414672852,-9.0408287048339844" boneRefs="462,463,464,465"/> <Rigid refID="129" transformation="-0.0047287489287555218,1.1528226423251908E-005,0.99998879432678223,0.0048757363110780716,0.9999881386756897,1.1528172763064504E-005,-0.99997693300247192,0.0048757363110780716,-0.0047287489287555218,2.4118893146514893,8.4658164978027344,-6.4898500442504883" boneRefs="466"/> <Rigid refID="130" transformation="-0.0046704122796654701,1.1317273674649186E-005,0.9999890923500061,0.0048463051207363605,0.99998825788497925,1.1317225471429992E-005,-0.99997735023498535,0.0048463051207363605,-0.0046704122796654701,6.4059562683105469,5.90045166015625,-7.884829044342041" boneRefs="467"/> <Rigid refID="131" transformation="0,0.69617867469787598,0.71786856651306152,0.0068290866911411285,0.71785181760787964,-0.69616240262985229,-0.99997669458389282,0.0049023334868252277,-0.0047543193213641644,4.4170117378234863,7.0416698455810547,-9.0257892608642578" boneRefs="468,469,470"/> <Rigid refID="132" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,6.0524082183837891,10.144929885864258,-13.260654449462891" boneRefs="471"/> <Rigid refID="133" transformation="0.99997693300247192,-0.0048028165474534035,0.0048028100281953812,-0.0067922035232186317,-0.70709097385406494,0.70709002017974854,0,-0.70710629224777222,-0.70710724592208862,6.0578498840332031,10.710666656494141,-13.826271057128906" boneRefs="472"/> <Rigid refID="134" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,5.2524271011352539,10.148836135864258,-13.26444149017334" boneRefs="473"/> <Rigid refID="135" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.006800931878387928,-0.70709079504013062,0.70709002017974854,2.8524823188781738,10.16057300567627,-13.275822639465332" boneRefs="474"/> <Rigid refID="136" transformation="0.99997681379318237,-0.0048151216469705105,0.0048151160590350628,-0.0068096062168478966,-0.70709079504013062,0.70708996057510376,0,-0.70710635185241699,-0.70710718631744385,2.0579419136047363,10.730152130126953,-13.845283508300781" boneRefs="475"/> <Rigid refID="137" transformation="0.99997687339782715,-0.0048089954070746899,0.0048089753836393356,0,0.70710641145706177,0.70710718631744385,-0.0068009323440492153,-0.70709079504013062,0.70709002017974854,2.0525012016296387,10.16447925567627,-13.279611587524414" boneRefs="476"/> <Rigid refID="138" transformation="1,-4.3251558963675052E-005,-0.0001045218959916383,-4.3324573198333383E-005,0.70710742473602295,-0.70710611343383789,0.00010449164983583614,0.70710611343383789,0.70710742473602295,6.0168900489807129,6.4680023193359375,-9.5837249755859375" boneRefs="477"/> <Rigid refID="139" transformation="0.99997347593307495,-0.0051515777595341206,0.0051473476924002171,0,-0.70710510015487671,-0.70710843801498413,0.0072824400849640369,0.70708972215652466,-0.70708638429641724,2.4724395275115967,14.685935020446777,-15.542611122131348" boneRefs="478"/> <Rigid refID="140" transformation="0,6.4048224885482341E-005,1,0.99997085332870483,-0.007634955458343029,0,0.007634955458343029,0.99997085332870483,-6.4046354964375496E-005,4.1893267631530762,27.132505416870117,-21.505762100219727" boneRefs="479"/> <Rigid refID="141" transformation="0.0075958175584673882,0.99997115135192871,-6.3930106989573687E-005,0.99997115135192871,-0.0075958175584673882,0,0,-6.3931227487046272E-005,-1,4.1892986297607422,27.133020401000977,-13.505762100219727" boneRefs="480,481,482"/> <Rigid refID="142" transformation="7.7408250945154577E-005,0,-1,0.0079556992277503014,0.99996834993362427,0,0.99996834993362427,-0.0079556992277503014,7.7408250945154577E-005,5.3983726501464844,28.323005676269531,-13.505653381347656" boneRefs="483"/> <Rigid refID="143" transformation="0,0,1,0.0075803068466484547,0.99997127056121826,0,-0.99997127056121826,0.0075803068466484547,0,4.5984086990356445,28.329948425292969,-22.305841445922852" boneRefs="484"/> <Rigid refID="144" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.3983850479125977,28.323884963989258,-21.505842208862305" boneRefs="485"/> <Rigid refID="145" transformation="-7.7314616646617651E-005,0,1,0.0079407021403312683,0.99996846914291382,0,-0.99996846914291382,0.0079407021403312683,-7.7314616646617651E-005,2.9991283416748047,28.342098236083984,-22.305839538574219" boneRefs="486"/> <Rigid refID="146" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.398381233215332,28.323886871337891,-15.905842781066895" boneRefs="487"/> <Rigid refID="147" transformation="1,0,0,0,1,0,0,0,1,4.2044887542724609,29.132944107055664,-11.505843162536621" boneRefs="488,489,490,491,492"/> <Rigid refID="148" transformation="1,0,0,0,0,1,0,-1,0,3.0044887065887451,29.132944107055664,-12.705842971801758" boneRefs="493,494"/> <Rigid refID="149" transformation="0,-1,0,0,0,-1,1,0,0,3.0044887065887451,32.332950592041016,-12.705842971801758" boneRefs="495"/> <Rigid refID="150" transformation="0,0,1,0,1,0,-1,0,0,1.4044873714447021,32.332950592041016,-12.705842971801758" boneRefs="496"/> <Rigid refID="151" transformation="0,0,1,0,1,0,-1,0,0,1.4044873714447021,24.332950592041016,-12.705842971801758" boneRefs="497"/> <Rigid refID="152" transformation="0,-0.40673643350601196,-0.91354554891586304,1,0,0,0,-0.91354554891586304,0.40673643350601196,0.60448646545410156,25.959897994995117,-9.0516605377197266" boneRefs="498"/> <Rigid refID="153" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,3.004486083984375,25.959897994995117,-9.0516605377197266" boneRefs="499"/> <Rigid refID="154" transformation="0,1,0,1,0,0,0,0,-1,1.8044872283935547,29.570192337036133,-9.0508174896240234" boneRefs="500,501,502,503,504,505"/> <Rigid refID="155" transformation="0,0.99999988079071045,0,0,0,-0.99999970197677612,-0.9999997615814209,0,0,0.20448684692382813,29.570188522338867,-9.0508174896240234" boneRefs="506,507,508,509,510"/> <Rigid refID="156" transformation="0.99999988079071045,0,0,0,1,0,0,0,0.99999988079071045,-0.59551239013671875,32.467243194580078,-11.947866439819336" boneRefs="511"/> <Rigid refID="157" transformation="0,0.99999988079071045,0,0,0,-0.99999982118606567,-0.99999988079071045,0,0,-0.59551239013671875,29.570188522338867,-9.0508174896240234" boneRefs="512,513,514,515,516"/> <Rigid refID="158" transformation="0,0,0.99999988079071045,0,1,0,-0.99999988079071045,0,0,-0.99551200866699219,32.467243194580078,-10.747869491577148" boneRefs="517"/> <Rigid refID="159" transformation="0,0,0.99999988079071045,0,1,0,-0.99999988079071045,0,0,-0.99551200866699219,30.77018928527832,-9.0508174896240234" boneRefs="518"/> <Rigid refID="160" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,3.004486083984375,30.770191192626953,-9.0508174896240234" boneRefs="519"/> <Rigid refID="161" transformation="0,-1,0,0,0,1,-1,0,0,2.2044868469238281,30.770191192626953,-9.0508174896240234" boneRefs="520"/> <Rigid refID="162" transformation="0,-0.40673685073852539,0.91354542970657349,1,0,0,0,0.91354542970657349,0.40673685073852539,0.60448646545410156,30.770191192626953,-9.0508174896240234" boneRefs="521"/> <Rigid refID="163" transformation="0.99999982118606567,0,0,0,0,0.9999997615814209,0,-0.9999997615814209,0,0.20448684692382813,26.37019157409668,-9.0508136749267578" boneRefs="522,523,524,525,526"/> <Rigid refID="164" transformation="0,-0.99999982118606567,0,0,0,0.99999994039535522,-0.99999982118606567,0,0,-0.99551200866699219,25.970195770263672,-9.0508136749267578" boneRefs="527"/> <Rigid refID="165" transformation="1,0,0,0,0,0.99999982118606567,0,-1,0,-0.59551239013671875,26.370195388793945,-9.0508136749267578" boneRefs="528,529,530,531,532"/> <Rigid refID="166" transformation="0,-0.99999982118606567,0,0,0,0.99999994039535522,-0.99999982118606567,0,0,-0.99551200866699219,24.273143768310547,-10.747865676879883" boneRefs="533"/> <Rigid refID="167" transformation="0.99999988079071045,0,0,0,1,0,0,0,0.99999988079071045,-0.59551239013671875,24.273141860961914,-11.947866439819336" boneRefs="534"/> <Rigid refID="168" transformation="1,0,0,0,0,1,0,-1,0,1.0044879913330078,26.370189666748047,-9.0508174896240234" boneRefs="535,536"/> <Rigid refID="169" transformation="0,0,-0.99999988079071045,-1,0,0,0,0.99999988079071045,0,1.0044879913330078,30.37019157409668,-9.0508174896240234" boneRefs="537,538"/> <Rigid refID="170" transformation="1,0,0,0,0,1,0,-1,0,3.004486083984375,27.532943725585938,-12.705842971801758" boneRefs="539,540"/> <Rigid refID="171" transformation="1,0,0,0,1,0,0,0,1,4.2044887542724609,27.532943725585938,-11.505843162536621" boneRefs="541"/> <Rigid refID="172" transformation="0,-1,0,-1,0,0,0,0,-1,4.2044892311096191,29.132944107055664,-12.305843353271484" boneRefs="542"/> <Rigid refID="173" transformation="0,0,-1,0.0075644729658961296,0.99997138977050781,0,0.99997138977050781,-0.0075644729658961296,0,5.3983817100524902,28.323884963989258,-16.705841064453125" boneRefs="543"/> <Rigid refID="174" transformation="-7.7220633102115244E-005,0,1,0.0079257674515247345,0.99996858835220337,0,-0.99996858835220337,0.0079257674515247345,-7.7220633102115244E-005,2.1984109878540039,28.348430633544922,-12.705902099609375" boneRefs="544"/> <Rigid refID="175" transformation="0.99997097253799438,-0.0076190405525267124,0,0,-6.3887382566463202E-005,-1,0.0076190405525267124,0.99997097253799438,-6.3887382566463202E-005,4.1954092979431152,27.93248176574707,-21.505813598632812" boneRefs="545,546"/> <Rigid refID="176" transformation="0.99997097253799438,-0.0076190405525267124,0,0,-6.3887382566463202E-005,-1,0.0076190405525267124,0.99997097253799438,-6.3887382566463202E-005,4.1954092979431152,27.932737350463867,-17.505813598632812" boneRefs="547,548"/> <Rigid refID="177" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1893301010131836,27.132863998413086,-15.905763626098633" boneRefs="549"/> <Rigid refID="178" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1801486015319824,25.9326171875,-20.305685043334961" boneRefs="550,551,552,553"/> <Rigid refID="179" transformation="0,0,1,0.96391975879669189,-0.26619300246238708,0,0.26619300246238708,0.96391975879669189,0,4.1801495552062988,25.932668685913086,-21.105686187744141" boneRefs="571,572"/> <Rigid refID="180" transformation="0.013481179252266884,0.079927742481231689,0.99670946598052979,0.96152621507644653,-0.27456527948379517,0.0090125324204564095,0.27438217401504517,0.958240807056427,-0.080554082989692688,4.1693644523620605,25.86872673034668,-21.903053283691406" boneRefs="570"/> <Rigid refID="181" transformation="0.018402224406599998,0.24181070923805237,0.97014892101287842,0.96057170629501343,-0.27350842952728271,0.049951720982789993,0.27742275595664978,0.93097835779190063,-0.23730967938899994,4.1546425819396973,25.675277709960938,-22.679172515869141" boneRefs="569"/> <Rigid refID="182" transformation="0.017832579091191292,0.4685671329498291,0.88324791193008423,0.96171313524246216,-0.24966342747211456,0.11303083598613739,0.2734772264957428,0.8474155068397522,-0.45507931709289551,4.1403765678405762,25.300424575805664,-23.385772705078125" boneRefs="568"/> <Rigid refID="183" transformation="0.014432007446885109,0.71600443124771118,0.69794648885726929,0.96470528841018677,-0.19352434575557709,0.17858339846134186,0.26293614506721497,0.67073535919189453,-0.69352620840072632,4.1288309097290039,24.727621078491211,-23.944129943847656" boneRefs="567"/> <Rigid refID="184" transformation="0.010428120382130146,0.91158312559127808,0.41098356246948242,0.96845734119415283,-0.11153726279735565,0.22282229363918304,0.24896101653575897,0.39569643139839172,-0.88399249315261841,4.120488166809082,23.99835205078125,-24.272916793823242" boneRefs="566"/> <Rigid refID="185" transformation="0.0067826411686837673,0.99720340967178345,0.07442648708820343,0.97175151109695435,-0.024131596088409424,0.23476949334144592,0.23590897023677826,0.070731692016124725,-0.96919757127761841,4.1150622367858887,23.200590133666992,-24.33245849609375" boneRefs="565"/> <Rigid refID="186" transformation="0.0017700818134471774,0.96316355466842651,-0.26891037821769714,0.97457271814346313,0.058591932058334351,0.21627534925937653,0.22406452894210815,-0.26245555281639099,-0.93856924772262573,4.1136460304260254,22.430059432983398,-24.117330551147461" boneRefs="564"/> <Rigid refID="187" transformation="-0.0043158857151865959,0.84288686513900757,-0.53807353973388672,0.97606867551803589,0.12054077535867691,0.18099689483642578,0.21741969883441925,-0.52441555261611938,-0.82323569059371948,4.1170988082885742,21.755748748779297,-23.686870574951172" boneRefs="563"/> <Rigid refID="188" transformation="-0.0083373971283435822,0.69850528240203857,-0.71555632352828979,0.97641521692276001,0.16007164120674133,0.14488045871257782,0.21574003994464874,-0.69747215509414673,-0.68336576223373413,4.1237688064575195,21.196945190429688,-23.114425659179688" boneRefs="562"/> <Rigid refID="189" transformation="-0.0076259621419012547,0.57705950736999512,-0.81666648387908936,0.97611570358276367,0.18161872029304504,0.11921756714582443,0.2171175628900528,-0.79625183343887329,-0.56466186046600342,4.1298699378967285,20.735298156738281,-22.461093902587891" boneRefs="561"/> <Rigid refID="190" transformation="-0.0038440851494669914,0.50712835788726807,-0.8618619441986084,0.97556191682815552,0.19124799966812134,0.10818105936050415,0.21969105303287506,-0.84038382768630981,-0.49547028541564941,4.1329450607299805,20.329595565795898,-21.771602630615234" boneRefs="560"/> <Rigid refID="191" transformation="0.0015389150939881802,0.50095546245574951,-0.86547172069549561,0.97495663166046143,0.19172094762325287,0.11270619928836823,0.2223898321390152,-0.84397077560424805,-0.48811477422714233,4.1317138671875,19.928831100463867,-21.079225540161133" boneRefs="559"/> <Rigid refID="192" transformation="0.0071502458304166794,0.55954504013061523,-0.82876908779144287,0.97443407773971558,0.18221896886825562,0.13143245875835419,0.22455982863903046,-0.8085206151008606,-0.54393684864044189,4.1259937286376953,19.481195449829102,-20.416210174560547" boneRefs="558"/> <Rigid refID="193" transformation="0.01146106980741024,0.67316782474517822,-0.73940092325210571,0.9741513729095459,0.15931785106658936,0.16014650464057922,0.22560523450374603,-0.72212386131286621,-0.65394139289855957,4.1168246269226074,18.942661285400391,-19.824687957763672" boneRefs="557"/> <Rigid refID="194" transformation="0.012672026641666889,0.81673604249954224,-0.57687228918075562,0.97434544563293457,0.11955852061510086,0.19067424535751343,0.22470052540302277,-0.56448912620544434,-0.79426801204681396,4.106687068939209,18.289272308349609,-19.363189697265625" boneRefs="556"/> <Rigid refID="195" transformation="0.0090677319094538689,0.94516867399215698,-0.32645663619041443,0.97531169652938843,0.063677802681922913,0.2114526778459549,0.22064648568630219,-0.32031437754631042,-0.9212566614151001,4.0994329452514648,17.533136367797852,-19.102024078369141" boneRefs="555"/> <Rigid refID="196" transformation="0,1,0,0.97724610567092896,0,0.21210856735706329,0.21210856735706329,0,-0.97724610567092896,4.0994329452514648,16.733137130737305,-19.102024078369141" boneRefs="554"/> <Rigid refID="197" transformation="0,-1,0,0,0,-1,1,0,0,4.0994329452514648,16.733139038085938,-19.102024078369141" boneRefs="573,574"/> <Rigid refID="198" transformation="1,0,0,0,1,0,0,0,1,4.0994329452514648,15.533139228820801,-17.902023315429688" boneRefs="575"/> <Rigid refID="199" transformation="0,6.4228210248984396E-005,1,0.99997073411941528,-0.0076503236778080463,0,0.0076503236778080463,0.99997073411941528,-6.4226333051919937E-005,4.1893291473388672,27.132658004760742,-19.10576057434082" boneRefs="576"/> <Rigid refID="200" transformation="0,-6.4123945776373148E-005,-1,-0.99997073411941528,0.0076502272859215736,0,0.0076502272859215736,0.99997073411941528,-6.4122068579308689E-005,4.1954631805419922,27.932891845703125,-15.105814933776855" boneRefs="577"/> <Rigid refID="201" transformation="0,-6.4123945776373148E-005,-1,-0.99997073411941528,0.0076502272859215736,0,0.0076502272859215736,0.99997073411941528,-6.4122068579308689E-005,4.195460319519043,27.932584762573242,-19.905813217163086" boneRefs="578,579,580"/> <Rigid refID="202" transformation="0.99996775388717651,-0.0080302748829126358,0,0.0080302748829126358,0.99996775388717651,-9.2277885414659977E-005,0,9.2280861281324178E-005,1,3.3953242301940918,27.539581298828125,-17.102516174316406" boneRefs="581"/> <Rigid refID="203" transformation="-0.0079856542870402336,-0.99996811151504517,0,7.7279175457078964E-005,0,-1,0.99996811151504517,-0.0079856542870402336,7.7281642006710172E-005,6.1888151168823242,26.717170715332031,-17.502111434936523" boneRefs="582,583,584,585"/> <Rigid refID="204" transformation="0.99996775388717651,-0.0080302748829126358,0,0.0080302748829126358,0.99996775388717651,-9.2277885414659977E-005,0,9.2280861281324178E-005,1,3.3953242301940918,27.539581298828125,-17.102516174316406" boneRefs="586"/> <Rigid refID="205" transformation="-0.0079855667427182198,-0.99996811151504517,0,-7.7277400123421103E-005,0,1,-0.99996811151504517,0.0079855667427182198,-7.7279866673052311E-005,2.1889426708221436,26.749088287353516,-17.502420425415039" boneRefs="587,588,589,590"/> <Rigid refID="206" transformation="0,0,1,0,1,0,-1,0,0,1.0217422246932983,28.345832824707031,-18.702390670776367" boneRefs="591,592,593,594,595,596,597,598,599,600,601,602,603,604,605,606,607,608,609,610,611,612,613,614,615,616,617,618,619"/> <Rigid refID="207" transformation="-1,0,0,0,1,0,0,0,-1,0.22174200415611267,28.345832824707031,-19.502391815185547" boneRefs="620,621,622,623,624"/> <Rigid refID="208" transformation="1,0,0,0,0,-1,0,1,0,-2.178257942199707,29.545833587646484,-17.502389907836914" boneRefs="625"/> <Rigid refID="209" transformation="-1,0,0,0,1,0,0,0,-1,0.23616513609886169,28.344837188720703,-17.501209259033203" boneRefs="626,627,628,629"/> <Rigid refID="210" transformation="0,-1,0,-1,0,0,0,0,-1,4.195335865020752,27.545858383178711,-17.102390289306641" boneRefs="630,631"/> <Rigid refID="211" transformation="0,-6.3947409216780216E-005,-1,-0.99996984004974365,0.0077665792778134346,0,0.0077665792778134346,0.99996984004974365,-6.3945481088012457E-005,2.527475118637085,19.145540237426758,-15.902251243591309" boneRefs="632"/> <Rigid refID="212" transformation="0,-6.3886524003464729E-005,-1,0.0078124259598553181,0.999969482421875,-6.388847396010533E-005,0.999969482421875,-0.0078124259598553181,0,2.5212621688842773,18.345615386962891,-15.102201461791992" boneRefs="633"/> <Rigid refID="213" transformation="0,-6.3946892623789608E-005,-1,-0.99996966123580933,0.007789581548422575,0,0.007789581548422575,0.99996966123580933,-6.3944949943106622E-005,2.5275120735168457,19.145587921142578,-15.102252006530762" boneRefs="634"/> <Rigid refID="214" transformation="0,-6.3946870795916766E-005,-1,-0.99996966123580933,0.0077895685099065304,0,0.0077895685099065304,0.99996966123580933,-6.3944928115233779E-005,2.5275096893310547,19.145286560058594,-19.902250289916992" boneRefs="635"/> <Rigid refID="215" transformation="0,-6.3886524003464729E-005,-1,0.00782005675137043,0.99996942281723022,-6.388847396010533E-005,0.99996942281723022,-0.00782005675137043,0,2.521277904510498,18.345312118530273,-19.902200698852539" boneRefs="636"/> <Rigid refID="216" transformation="0,-6.3946892623789608E-005,-1,-0.99996966123580933,0.007789581548422575,0,0.007789581548422575,0.99996966123580933,-6.3944949943106622E-005,2.5275099277496338,19.14533805847168,-19.102249145507813" boneRefs="637"/> <Rigid refID="217" transformation="-0.00016239013348240405,-3.7772384530398995E-005,1,-0.0077750235795974731,-0.99996978044509888,-3.9033828215906397E-005,0.99996978044509888,-0.0077750300988554955,0.00016209154273383319,1.2996652126312256,15.554940223693848,-17.501960754394531" boneRefs="638,639,640"/> <Rigid refID="218" transformation="-0.0077616320922970772,-0.99996989965438843,4.1238756239181384E-005,-0.00014843921235296875,4.2392162868054584E-005,1,-0.99996984004974365,0.0077616255730390549,-0.00014876376371830702,0.49868771433830261,15.561156272888184,-17.502079010009766" boneRefs="641"/> <Rigid refID="219" transformation="0.9999687671661377,-0.007903609424829483,0,0,6.3953048083931208E-005,1,-0.007903609424829483,-0.9999687671661377,6.3955048972275108E-005,3.2962276935577393,15.13925838470459,-16.701997756958008" boneRefs="642"/> <Rigid refID="220" transformation="0.0045106946490705013,0.382600337266922,-0.92390292882919312,0.0072072679176926613,0.92387592792510986,0.38262432813644409,0.99996387958526611,-0.0083847176283597946,0.001409818883985281,2.1649582386016846,23.982765197753906,-18.065105438232422" boneRefs="643,644,645,646,647,648,649,650,651"/> <Rigid refID="221" transformation="0.99997329711914063,-0.0071647241711616516,-0.0014252136461436749,0.0014246914070099592,0.38262620568275452,-0.92390215396881104,0.0071648280136287212,0.92387545108795166,0.38262620568275452,2.5563554763793945,22.871719360351563,-18.525968551635742" boneRefs="652"/> <Rigid refID="222" transformation="0,6.3947409216780216E-005,1,0.99996984004974365,-0.00776657834649086,0,0.00776657834649086,0.99996984004974365,-6.3945481088012457E-005,5.7212004661560059,18.320547103881836,-19.901498794555664" boneRefs="653"/> <Rigid refID="223" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.7274222373962402,19.120820999145508,-15.101546287536621" boneRefs="654"/> <Rigid refID="224" transformation="0,6.3886524003464729E-005,1,0.0078124264255166054,0.999969482421875,-6.388847396010533E-005,-0.999969482421875,0.0078124264255166054,0,5.7212028503417969,18.320844650268555,-15.101497650146484" boneRefs="655"/> <Rigid refID="225" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.7274212837219238,19.120773315429688,-15.901547431945801" boneRefs="656"/> <Rigid refID="226" transformation="0,-6.3947409216780216E-005,-1,-0.99996984004974365,0.0077665788121521473,0,0.0077665788121521473,0.99996984004974365,-6.3945481088012457E-005,5.7274074554443359,19.120573043823242,-19.101547241210938" boneRefs="657"/> <Rigid refID="227" transformation="0,6.3886516727507114E-005,1,0.00782768614590168,0.99996936321258545,-6.388847396010533E-005,-0.99996936321258545,0.00782768614590168,0,5.7211999893188477,18.320545196533203,-19.901496887207031" boneRefs="658"/> <Rigid refID="228" transformation="0,-6.3947372836992145E-005,-1,-0.99996978044509888,0.0077743232250213623,0,0.0077743232250213623,0.99996978044509888,-6.3945437432266772E-005,5.727419376373291,19.120519638061523,-19.901546478271484" boneRefs="659"/> <Rigid refID="229" transformation="0.00015848374459892511,0.00016136292833834887,1,-0.0080464892089366913,-0.99996763467788696,0.00016263294673990458,0.99996763467788696,-0.0080465152859687805,-0.00015718021313659847,9.8593683242797852,15.488069534301758,-17.501432418823242" boneRefs="660,661,662"/> <Rigid refID="230" transformation="-7.6428812462836504E-005,8.4757331933360547E-005,1,-0.0077740596607327461,-0.99996978044509888,8.4160608821548522E-005,0.99996978044509888,-0.0077740531414747238,7.7085409429855645E-005,7.7004532814025879,15.503826141357422,-17.501235961914062" boneRefs="663"/> <Rigid refID="231" transformation="0.9999697208404541,-0.0077855968847870827,0,0,6.3935265643522143E-005,1,-0.0077855964191257954,-0.99996966123580933,6.3937201048247516E-005,4.8963303565979004,15.127063751220703,-16.701292037963867" boneRefs="664"/> <Rigid refID="232" transformation="0.99996805191040039,-0.0078023364767432213,0.0017378346528857946,-0.0045909029431641102,-0.382598876953125,0.92390316724777222,-0.0065437094308435917,-0.92388159036636353,-0.38262248039245605,6.556797981262207,22.840169906616211,-18.523447036743164" boneRefs="665,666,667,668,669,670,671,672,673"/> <Rigid refID="233" transformation="0.99997341632843018,-0.0071549802087247372,-0.0014232388930395246,0.0014227923238649964,0.38262686133384705,-0.92390185594558716,0.0071550691500306129,0.92387527227401733,0.38262686133384705,5.7562308311462402,22.845966339111328,-18.522977828979492" boneRefs="674"/> <Rigid refID="234" transformation="0.0014263078337535262,0.38274028897285461,0.92385488748550415,0.007125763688236475,0.92382848262786865,-0.38274034857749939,-0.9999735951423645,0.0071290773339569569,-0.0014096531085669994,6.1648964881896973,23.951833724975586,-16.939302444458008" boneRefs="675,676,677,678,679,680,681,682,683"/> <Rigid refID="235" transformation="0.99997329711914063,-0.0071682902052998543,0.0014258398441597819,-0.0014263690682128072,-0.38274115324020386,-0.9238545298576355,0.0071681849658489227,0.92382782697677612,-0.38274115324020386,5.7563033103942871,22.846107482910156,-16.480581283569336" boneRefs="684"/> <Rigid refID="236" transformation="0.99984771013259888,-0.017452426254749298,0,0,-6.3915889768395573E-005,-1,0.017452426254749298,0.99984771013259888,-6.392562499968335E-005,3.3065063953399658,15.947439193725586,-16.701587677001953" boneRefs="685"/> <Rigid refID="237" transformation="-7.6806492870673537E-005,6.3896339270286262E-005,1,0.0079979812726378441,0.99996799230575562,-6.3280000176746398E-005,-0.99996799230575562,0.007997976616024971,-7.7315075031947345E-005,2.9121971130371094,17.143011093139648,-17.501758575439453" boneRefs="686"/> <Rigid refID="238" transformation="-0.0079932939261198044,-0.99996805191040039,9.1677502496168017E-005,-7.6621065090876073E-005,9.2292902991175652E-005,1,-0.99996805191040039,0.0079932864755392075,-7.7356344263534993E-005,2.9377708435058594,20.342945098876953,-17.501949310302734" boneRefs="687"/> <Rigid refID="239" transformation="-0.0079932073131203651,-0.99996805191040039,9.1871224867645651E-005,0.99996805191040039,-0.0079931998625397682,7.7225093264132738E-005,-7.6488278864417225E-005,9.2485563072841614E-005,1,4.1473236083984375,21.533313751220703,-17.50196647644043" boneRefs="688,689,690"/> <Rigid refID="240" transformation="-0.0079932939261198044,-0.99996805191040039,9.1677502496168017E-005,-7.6621065090876073E-005,9.2292902991175652E-005,1,-0.99996805191040039,0.0079932864755392075,-7.7356344263534993E-005,2.9697442054748535,24.342813491821289,-17.5023193359375" boneRefs="691"/> <Joint type="hinge"> <RigidRef rigidRef="80" a="0,0.99999988079071045,-0.00065670273033902049" z="1,0,-0.0001034950400935486" t="-0.00061437214026227593,-1.1996829509735107,0.40069037675857544"/> <RigidRef rigidRef="79" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="4.7999958992004395,-0.80001229047775269,-0.79999047517776489"/> <RigidRef rigidRef="80" a="-0.38268321752548218,0.92387962341308594,2.9663462555618025E-005" z="0.0017043645493686199,0.00067395600490272045,0.99999839067459106" t="0.76470839977264404,-6.6479611396789551,-0.39707750082015991"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="82" a="-0.00054386252304539084,-0.00010334653779864311,0.99999982118606567" z="0.99999994039535522,0,0.0005438618827611208" t="-2.3976039886474609,0.00040213216561824083,-2.4013035297393799"/> <RigidRef rigidRef="81" a="-0.0001230282214237377,-1,-7.7507254900410771E-005" z="1,-0.00012302871618885547,0" t="2.4006123542785645,3.599912166595459,-2.7999699115753174"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="7.1999998092651367,0,0"/> <RigidRef rigidRef="81" a="0,-0.00010021432535722852,1" z="0,1,0.00010021523485193029" t="5.5999946594238281,1.5996335744857788,8.7999906539916992"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="211" a="0,0,1" z="1,0,0" t="0,0,-0.80000108480453491"/> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="4,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="213" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="4.8000001907348633,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="214" a="0,0,1" z="1,0,0" t="0,0,-0.80000489950180054"/> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="216" a="0,0,1" z="1,0,0" t="0,0,-0.80000489950180054"/> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="217" a="0,0,-1" z="0,1,0" t="0,0,-0.8000028133392334"/> <RigidRef rigidRef="81" a="-0.00014869389997329563,-1,0" z="0,0,1" t="2.3999347686767578,-1.999906063079834,-2.7999248504638672"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="219" a="0,0,-1" z="1,0,0" t="0,0,-1.5999923944473267"/> <RigidRef rigidRef="81" a="0,9.3456641479860991E-005,1" z="0,-1,9.3378926976583898E-005" t="3.1999926567077637,0.8000456690788269,-1.6001461744308472"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="220" a="0.38268300890922546,0.92387956380844116,-0.00063363026129081845" z="0.0015450225910171866,4.5950990170240402E-005,0.99999880790710449" t="-0.45921328663825989,-5.9086775779724121,-0.39903837442398071"/> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="0,-0.80001223087310791,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="222" a="0,0,1" z="0,1,0" t="3.2000000476837158,0,0"/> <RigidRef rigidRef="81" a="0,0,1" z="0,-1,0" t="3.2007021903991699,3.2000174522399902,8.3522354543674737E-005"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="229" a="0.00023438171774614602,-0.00026674228138290346,0.99999994039535522" z="9.8710515885613859E-005,-1,-0.00026676530251279473" t="-0.00019098340999335051,0.00021734833717346191,-2.160003662109375"/> <RigidRef rigidRef="81" a="7.7199620136525482E-005,1,0" z="0,0,-1" t="2.4007329940795898,5.2000575065612793,-2.7999250888824463"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="231" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="81" a="0,0,-1" z="0,1,0" t="3.2007019519805908,2.3999998569488525,-2.3999049663543701"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="0.0006956402794457972,4.0000171661376953,7.8765886428300291E-005"/> <RigidRef rigidRef="232" a="-5.1251765398774296E-005,-0.38268208503723145,-0.92388010025024414" z="0.99999856948852539,-0.0016252394998446107,0.00061763799749314785" t="-0.0027162863407284021,0.45856669545173645,4.7088527679443359"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="81" a="0,0,1" z="0,1,0" t="4.8006958961486816,4.0000171661376953,7.8784658398944885E-005"/> <RigidRef rigidRef="234" a="0.38268080353736877,0.92388045787811279,-0.00062206701841205359" z="-0.0015404586447402835,-3.5159839171683416E-005,-0.99999880790710449" t="-0.45921087265014648,-5.9086766242980957,-0.3990384042263031"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="81" a="1,0,0" z="0,1,-0.00022518575133290142" t="3.600447416305542,1.5999157428741455,-2.799635648727417"/> <RigidRef rigidRef="236" a="0,-1,0" z="0,0,1" t="0.80000001192092896,-0.39999046921730042,-0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="237" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="81" a="-7.7299264376051724E-005,-1,0.00022510114649776369" z="0,-0.00022517675824929029,-1" t="2.4003722667694092,0.40024605393409729,-1.199388861656189"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="203" a="0,0,-1" z="1,0,0" t="0,0,-1.5999999046325684"/> <RigidRef rigidRef="81" a="-7.7299264376051724E-005,-1,0.00022510114649776369" z="0,-0.00022517675824929029,-1" t="2.4004943370819092,2.0024070739746094,8.4002828598022461"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="205" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="81" a="-7.7299264376051724E-005,-1,0.00022510114649776369" z="0,-0.00022517675824929029,-1" t="2.4003722667694092,0.40240710973739624,8.4006109237670898"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="238" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="81" a="-7.7299264376051724E-005,-1,0.00022510114649776369" z="0,-0.00022517675824929029,-1" t="2.4003722667694092,0.40096646547317505,2.0006113052368164"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="240" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="81" a="-7.7299264376051724E-005,-1,0.00022510114649776369" z="0,-0.00022517675824929029,-1" t="2.4003722667694092,0.40187370777130127,6.0006008148193359"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="198" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="81" a="-1,0,0" z="0,-4.2676987504819408E-005,-1" t="1.1999975442886353,1.5999492406845093,-2.7999534606933594"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="83" a="0,0,1" z="0,1,0" t="0,-0.80000001192092896,0.69199997186660767"/> <RigidRef rigidRef="82" a="7.2119335527531803E-005,0,-1" z="0,-1,0" t="7.2005457878112793,0.79999685287475586,-4.8001742362976074"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="85" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="1,0,3.4896620491053909E-005" z="-3.4938326280098408E-005,0,1" t="5.1999979019165039,2.4000027179718018,2.7996611595153809"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="89" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="82" a="-4.4637905375566334E-005,-2.0581768694682978E-005,-1" z="0,1,-2.0622734155040234E-005" t="11.199947357177734,0,2.8001711368560791"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="90" a="0,0,1" z="0,1,0" t="0,0.80000001192092896,0.69199854135513306"/> <RigidRef rigidRef="82" a="-7.2298949817195535E-005,0,1" z="0,1,0" t="7.1999111175537109,0.80000710487365723,3.9998252391815186"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="92" a="0,0,-1" z="-1,0,0" t="0,0,-1.5999886989593506"/> <RigidRef rigidRef="82" a="0,-1,0" z="-7.2105445724446326E-005,0,1" t="7.2002849578857422,-0.39999896287918091,-1.2001720666885376"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="94" a="0,0,-1" z="-1,0,0" t="0,0,-1.5999987125396729"/> <RigidRef rigidRef="82" a="0,-1,0" z="-7.210479088826105E-005,0,1" t="7.2001700401306152,-0.39999642968177795,0.39982819557189941"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="95" a="0,0,1" z="1,0,0" t="0,0,-4.4584088755073026E-005"/> <RigidRef rigidRef="82" a="1,0,3.4954842703882605E-005" z="3.4995289752259851E-005,0,-1" t="5.2004094123840332,2.3999886512756348,-3.6003377437591553"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="99" a="0,0,-1" z="1,0,0" t="0,0,-0.79999953508377075"/> <RigidRef rigidRef="82" a="-1,2.3566095478599891E-005,-2.8827298592659645E-005" z="-2.3649554350413382E-005,-1,2.4099203074001707E-005" t="4.3999695777893066,2.3999812602996826,1.1996465921401978"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="104" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="82" a="-1,2.3355813027592376E-005,-3.3180505852214992E-005" z="-2.3493843400501646E-005,-1,2.8430846214178018E-005" t="4.4002833366394043,2.4000148773193359,-2.0003499984741211"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="105" a="0,0,-1" z="1,0,0" t="0,0,-0.79999971389770508"/> <RigidRef rigidRef="82" a="-0.00044515554327517748,-0.00010354000551160425,0.99999988079071045" z="0,1,0.00010344104521209374" t="3.2038252353668213,1.6016778945922852,-0.7865568995475769"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="107" a="0,0,-1" z="1,0,0" t="0,0,-0.79999971389770508"/> <RigidRef rigidRef="82" a="-0.00044515338959172368,-0.00010354066762374714,0.99999988079071045" z="0,1,0.00010344047768739983" t="5.6038250923156738,1.6016720533370972,-0.78548073768615723"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="109" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="82" a="0,-1,-0.00010345201735617593" z="-0.00045328694977797568,-0.00010355868289479986,0.99999988079071045" t="2.4047253131866455,0.40188699960708618,-2.7870895862579346"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="113" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="0,1,0.00010345403279643506" z="0.00044901427463628352,0.00010362226021243259,-0.99999988079071045" t="2.4026308059692383,1.1984161138534546,2.0129935741424561"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="116" a="0,0,1" z="-1,0,0" t="0,0,-0.80000120401382446"/> <RigidRef rigidRef="82" a="-1,0,5.3100695367902517E-005" z="5.3022689826320857E-005,0,1" t="-0.40003868937492371,-0.79979974031448364,-0.39998170733451843"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="117" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="0,-1,0" z="1,0,7.2077666118275374E-005" t="9.600372314453125,0.80000042915344238,-2.4000022411346436"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="123" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="0,1,0" z="1,0,7.2044887929223478E-005" t="9.6000833511352539,-0.79999923706054688,1.599998950958252"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="124" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="82" a="0,1,0" z="1,0,7.1976814069785178E-005" t="9.6000804901123047,1.6000021696090698,1.5999966859817505"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="130" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="3.4591466828715056E-005,2.0731844415422529E-005,1" z="1,0,-3.466610360192135E-005" t="11.200326919555664,2.2015068680047989E-005,-2.7998025417327881"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="131" a="0,0,1" z="0,-1,0" t="0,0,0.80000025033950806"/> <RigidRef rigidRef="82" a="0,0,1" z="0,1,0" t="9.6000003814697266,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="132" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="82" a="1,0,4.3903484765905887E-005" z="0,1,0" t="3.6002893447875977,-0.80000001192092896,-2.4004228115081787"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="134" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="82" a="1,0,4.3903484765905887E-005" z="0,1,0" t="3.600255012512207,-0.79999911785125732,-1.6004228591918945"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="135" a="0,0,1" z="1,0,0" t="0,0,-0.80000102519989014"/> <RigidRef rigidRef="82" a="1,0,4.3903484765905887E-005" z="0,1,0" t="3.600121021270752,-0.79999536275863647,0.79957675933837891"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="137" a="0,0,1" z="1,0,0" t="0,0,-0.80000036954879761"/> <RigidRef rigidRef="82" a="1,0,4.3903484765905887E-005" z="0,1,0" t="3.6000857353210449,-0.79999452829360962,1.5995768308639526"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="138" a="0,0,-1" z="1,0,0" t="0,0,-0.7999996542930603"/> <RigidRef rigidRef="82" a="0,-1,0" z="1,0,7.214105426101014E-005" t="9.600372314453125,-1.6000010967254639,-2.4000000953674316"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="139" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="82" a="-0.99999994039535522,0,-0.00054348335834220052" z="0,-1,-0.00010350728553021327" t="-0.39997443556785583,0.79701608419418335,1.2122616767883301"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="84" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="83" a="0,0,1" z="0,1,0" t="0,0.80000001192092896,0.69199997186660767"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="86" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0.80000001192092896,0"/> <RigidRef rigidRef="85" a="0,0,1" z="-1,0,0" t="0,0,-1.5999996662139893"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="88" a="0,-1,0" z="1,0,0" t="0,0.79999995231628418,0"/> <RigidRef rigidRef="85" a="0,0,1" z="-1,0,0" t="0,0,-2.3999996185302734"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="87" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="86" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="88" a="0,-1,0" z="1,0,0" t="0,0.79995501041412354,0.80000001192092896"/> <RigidRef rigidRef="87" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="91" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="90" a="0,0,1" z="0,1,0" t="0,-0.80000001192092896,0.69199991226196289"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="92" a="0,0,-1" z="-1,0,0" t="0,0,-2.3999900817871094"/> <RigidRef rigidRef="93" a="0,0,1" z="1,0,0" t="1.2000000476837158,0,0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="93" a="0,0,-1" z="-1,0,0" t="2.7999618053436279,0.010995387099683285,0.40000060200691223"/> <RigidRef rigidRef="94" a="0,0,1" z="-1,0,0" t="0,0,-2.3999998569488525"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="96" a="0,-1,0" z="1,0,0" t="0,0.79999995231628418,0"/> <RigidRef rigidRef="95" a="0,0,1" z="-1,0,0" t="0,0,-2.3999996185302734"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="98" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0.80000001192092896,0"/> <RigidRef rigidRef="95" a="0,0,1" z="-1,0,0" t="0,0,-1.5999990701675415"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="97" a="0,0,1" z="1,0,0" t="0,0,-0.80025982856750488"/> <RigidRef rigidRef="96" a="0,-1,0" z="1,0,0" t="0,0,0.80000001192092896"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="98" a="0,-1,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="97" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="100" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="99" a="0,0,-1" z="1,0,0" t="0,0,-1.5998293161392212"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="101" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="100" a="0,0,1" z="0,1,0" t="2.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="103" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="100" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="104" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="100" a="0,0,1" z="0,1,0" t="3.2000000476837158,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="102" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,0"/> <RigidRef rigidRef="101" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="103" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="102" a="0,0,1" z="0,1,0" t="0,0,-1.4846685189695563E-005"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="106" a="0,0,1" z="0,1,0" t="1.2000000476837158,0,-0.40000000596046448"/> <RigidRef rigidRef="105" a="0,0,1" z="-1,0,0" t="0,0,-1.5999996662139893"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="108" a="0,1,0" z="0,0,-1" t="1.2000000476837158,-0.40000000596046448,0"/> <RigidRef rigidRef="107" a="0,0,1" z="-1,0,0" t="0,0,-1.5999997854232788"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="110" a="0,-1,0" z="0,0,1" t="0,0.79998093843460083,0"/> <RigidRef rigidRef="109" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="111" a="0,0,1" z="1,0,0" t="0,0,-0.79999995231628418"/> <RigidRef rigidRef="110" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="112" a="0,0,1" z="-1,0,0" t="0,0,-1.5999994277954102"/> <RigidRef rigidRef="111" a="0,1,0" z="-1,0,0" t="-0.80000007152557373,0.40004047751426697,-0.39999964833259583"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="114" a="0,-1,0" z="0,0,1" t="0,0.80000001192092896,0"/> <RigidRef rigidRef="113" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="115" a="0,0,1" z="1,0,0" t="0,0,-0.79999995231628418"/> <RigidRef rigidRef="114" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="118" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="117" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="119" a="0,0,-1" z="1,0,0" t="0,0,-0.79999983310699463"/> <RigidRef rigidRef="118" a="0,-1,0" z="-1,0,0" t="0.80000001192092896,-0.40000000596046448,-0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="120" a="0,-1,0" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="119" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="121" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="120" a="0,-1,0" z="1,0,0" t="-1.6000000238418579,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="122" a="0,0,1" z="1,0,0" t="0,0,-0.80000030994415283"/> <RigidRef rigidRef="120" a="1,0,0" z="0,1,0" t="0.40000000596046448,1.9996299743652344,0.80000001192092896"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="125" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="124" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="126" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="125" a="-1,0,0" z="0,1,0" t="-0.40000000596046448,0.80000001192092896,-0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="127" a="1,0,3.709232623805292E-005" z="3.7091165722813457E-005,0,-1" t="2.7996141910552979,-0.79999929666519165,-1.1998966932296753"/> <RigidRef rigidRef="126" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="127" a="1,0,3.709232623805292E-005" z="3.7091165722813457E-005,0,-1" t="2.7996749877929687,-0.79999834299087524,-2.7998967170715332"/> <RigidRef rigidRef="128" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="129" a="0,0,-1" z="1,0,0" t="0,0,-1.5999704599380493"/> <RigidRef rigidRef="127" a="0,0,1" z="-1,0,0" t="0.79999977350234985,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="133" a="0,-1,0" z="0,0,1" t="0,0.80000001192092896,0"/> <RigidRef rigidRef="132" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="134" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="133" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="136" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0.79999399185180664,0"/> <RigidRef rigidRef="135" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="137" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="136" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="141" a="1,0,0" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="8,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="176" a="0,0,1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="4,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="177" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="5.5999999046325684,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="199" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="2.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="200" a="0,0,1" z="1,0,0" t="0,0,-0.80000019073486328"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="6.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="201" a="0,0,1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="175" a="0,0,1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="140" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="141" a="-2.3810336642782204E-005,-1,0" z="0,0,1" t="1.1999709606170654,-0.40002825856208801,-6.077787111280486E-005"/> <RigidRef rigidRef="142" a="0,0,-1" z="-1,0,0" t="0,0,-1.600028395652771"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="172" a="0,0,1" z="1,0,0" t="0.79999995231628418,0,-0.80000013113021851"/> <RigidRef rigidRef="141" a="6.3956067606341094E-005,0,1" z="-0.0075957668013870716,-0.99997121095657349,0" t="1.1998777389526367,-2.740477430052124E-005,-1.9999955892562866"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="142" a="0,0,-1" z="1,0,0" t="0,0,-0.79999840259552002"/> <RigidRef rigidRef="143" a="0,0,1" z="0,1,0" t="8.8000001907348633,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="145" a="0,0,1" z="0,1,0" t="8.8000001907348633,0,0"/> <RigidRef rigidRef="142" a="0,0,-1" z="-1,0,0" t="0,0,-2.4000000953674316"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="144" a="0,0,-1" z="1,0,0" t="0,0,-0.80000001192092896"/> <RigidRef rigidRef="143" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="146" a="0,0,-1" z="1,0,0" t="0,0,-0.79999852180480957"/> <RigidRef rigidRef="143" a="0,0,1" z="0,1,0" t="6.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="173" a="0,0,-1" z="1,0,0" t="0,0,-0.79999905824661255"/> <RigidRef rigidRef="143" a="0,0,1" z="0,1,0" t="5.5999999046325684,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="145" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> <RigidRef rigidRef="144" a="0,0,-1" z="-1,0,0" t="0,0,-2.3993875980377197"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="175" a="1,0,6.2393424741458148E-005" z="0,-1,-6.3846389821264893E-005" t="-0.4000411331653595,0,0.40046232938766479"/> <RigidRef rigidRef="144" a="0,0,1" z="-1,0,0" t="0,0,-1.5999994277954102"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="146" a="0,0,-1" z="-1,0,0" t="0,0,-2.3998169898986816"/> <RigidRef rigidRef="145" a="0,0,1" z="0,1,0" t="6.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="173" a="0,0,-1" z="-1,0,0" t="0,0,-2.3997554779052734"/> <RigidRef rigidRef="145" a="0,0,1" z="0,1,0" t="5.5999999046325684,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="174" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="145" a="0,0,1" z="0,1,0" t="9.6000003814697266,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="146" a="0,0,-1" z="-1,0,0" t="0,0,-1.6000001430511475"/> <RigidRef rigidRef="147" a="-0.99997144937515259,0.0075564575381577015,0" z="0,0,1" t="-0.40606144070625305,-0.79695510864257813,-4.4000005722045898"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="148" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> <RigidRef rigidRef="147" a="0,0,1" z="0,1,0" t="0,0,-0.80000019073486328"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="173" a="0,0,-1" z="-1,0,0" t="0,0,-1.5999997854232788"/> <RigidRef rigidRef="147" a="-0.99997144937515259,0.0075564575381577015,0" z="0,0,1" t="-0.40606093406677246,-0.79695510864257813,-5.2000007629394531"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="147" a="0,0,-1" z="0,1,0" t="0,0,-0.80000019073486328"/> <RigidRef rigidRef="172" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="149" a="0,0,1" z="0,1,0" t="3.2000000476837158,0,-0.80000001192092896"/> <RigidRef rigidRef="148" a="1,0,0" z="0,-1,0" t="-0.79999977350234985,0,-1.161811360361753E-005"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="150" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="149" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="151" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="149" a="0,0,1" z="0,1,0" t="8,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="149" a="0,0,1" z="0,1,0" t="4.8000001907348633,0,-0.80000001192092896"/> <RigidRef rigidRef="170" a="1,0,0" z="0,-1,0" t="-0.79999685287475586,0,-1.3126731573720463E-005"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="152" a="0,-1,0" z="0,0,1" t="4,0.80000120401382446,0"/> <RigidRef rigidRef="151" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="152" a="0,-1,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="153" a="0,0,-1" z="-1,0,0" t="0,0,-2.4000000953674316"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="153" a="0,0,1" z="-1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="154" a="0,1,0" z="0,0,1" t="-3.6102931499481201,0.39999997615814209,0.00084187317406758666"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="153" a="0,0,-1" z="1,0,0" t="0,0,-0.79999947547912598"/> <RigidRef rigidRef="161" a="0,0,1" z="0,1,0" t="4.8000001907348633,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-0.80000030994415283,-1.6000000238418579,0"/> <RigidRef rigidRef="155" a="1,0,0" z="0,1,0" t="-0.79999822378158569,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="0,1,0" z="0,0,-1" t="1.2000000476837158,-0.40000000596046448,0"/> <RigidRef rigidRef="160" a="0,0,1" z="-1,0,0" t="0,0,-1.5999987125396729"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-0.79999977350234985,-2.4000000953674316,0"/> <RigidRef rigidRef="157" a="1,0,0" z="0,1,0" t="-0.79999685287475586,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-1.6000007390975952,-1.6000000238418579,0"/> <RigidRef rigidRef="163" a="0,0,-1" z="1,0,0" t="0,0,-1.5999990701675415"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="165" a="0,0,-1" z="1,0,0" t="0,0,-1.5999957323074341"/> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-1.6000008583068848,-2.4000000953674316,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-1.6000010967254639,-0.80000013113021851,0"/> <RigidRef rigidRef="168" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="154" a="1,0,0" z="0,1,0" t="-0.80000019073486328,-0.80000007152557373,0"/> <RigidRef rigidRef="169" a="0,0,1" z="0,-1,0" t="0,0,-1.600001335144043"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="156" a="0,0,1" z="1,0,0" t="0.79999995231628418,0,-0.79999935626983643"/> <RigidRef rigidRef="155" a="0,-1,0" z="0,0,-1" t="2.8970527648925781,3.697052001953125,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="155" a="0,0,-1" z="-1,0,0" t="2.8970527648925781,1.6970551013946533,-0.39999905228614807"/> <RigidRef rigidRef="158" a="0,0,-1" z="1,0,0" t="0,0,-1.5999981164932251"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="155" a="0,0,1" z="0,1,0" t="1.2000000476837158,0,-0.40000000596046448"/> <RigidRef rigidRef="159" a="0,0,1" z="1,0,0" t="0,0,-1.5999981164932251"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="156" a="0,0,1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="157" a="0,-1,0" z="0,0,-1" t="2.8970532417297363,3.6970515251159668,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="157" a="0,0,-1" z="-1,0,0" t="2.8970532417297363,1.6970505714416504,0.39999988675117493"/> <RigidRef rigidRef="158" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="157" a="0,0,1" z="0,1,0" t="1.2000000476837158,0,0.40000000596046448"/> <RigidRef rigidRef="159" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="161" a="0,0,1" z="0,1,0" t="0,0,-0.79999923706054688"/> <RigidRef rigidRef="160" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="162" a="0,-1,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="160" a="0,0,-1" z="-1,0,0" t="0,0,-2.4000000953674316"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="163" a="1,0,0" z="0,-1,0" t="0.39999940991401672,0,0.39999669790267944"/> <RigidRef rigidRef="164" a="0,0,-1" z="1,0,0" t="0,0,-1.5999981164932251"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="166" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="163" a="-1,0,0" z="0,0,-1" t="-0.39999857544898987,-1.6970541477203369,2.0970492362976074"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="167" a="0,0,1" z="1,0,0" t="0.79999995231628418,0,-0.79999935626983643"/> <RigidRef rigidRef="163" a="0,1,0" z="0,0,-1" t="0,-3.6970548629760742,2.0970504283905029"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="165" a="1,0,0" z="0,-1,0" t="-0.39999908208847046,0,0.40000438690185547"/> <RigidRef rigidRef="164" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="166" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="165" a="-1,0,0" z="0,0,-1" t="-0.39999988675117493,-1.6970579624176025,2.0970516204833984"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="167" a="0,0,1" z="1,0,0" t="0,0,-0.7999955415725708"/> <RigidRef rigidRef="165" a="0,1,0" z="0,0,-1" t="0,-3.6970510482788086,2.0970535278320313"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="170" a="0,1,0" z="0,0,-1" t="1.2000000476837158,-0.40000000596046448,0"/> <RigidRef rigidRef="171" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="171" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="172" a="0,0,1" z="1,0,0" t="1.6000000238418579,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="178" a="0,0,1" z="0,1,0" t="4.3999991416931152,0,-0.39999890327453613"/> <RigidRef rigidRef="177" a="0,0,1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="179" a="1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="178" a="1,0,-6.4157131419051439E-005" z="0,1,0" t="-0.80000025033950806,0,0.00010337138519389555"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="199" a="0,0,1" z="1,0,0" t="0,0,-0.80000007152557373"/> <RigidRef rigidRef="178" a="0,0,1" z="1,0,0" t="1.2000000476837158,0,0.40000000596046448"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="179" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="180" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="180" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="181" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="181" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="182" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="182" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="183" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="183" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="184" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="184" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="185" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="185" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="186" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="186" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="187" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="187" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="188" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="188" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="189" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="189" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="190" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="190" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="191" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="191" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="192" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="192" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="193" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="193" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="194" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="194" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="195" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="195" a="-1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="196" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="196" a="-1,0,0" z="0,0,1" t="0.80000001192092896,0,0"/> <RigidRef rigidRef="197" a="1,0,0" z="0,0,1" t="-0.79999792575836182,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="197" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> <RigidRef rigidRef="198" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="202" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="0.80003750324249268,-0.012714630924165249,-1.1996287107467651"/> <RigidRef rigidRef="201" a="-1,0,0" z="0,1.5713627362856641E-005,-1" t="-1.6036437749862671,0,-0.3999999463558197"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="203" a="0,-1,7.733115489827469E-005" z="2.2212367184692994E-005,7.7255965152289718E-005,1" t="-0.79999041557312012,0.80000036954879761,-0.40004372596740723"/> <RigidRef rigidRef="202" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="2.3999860286712646,0.00013380945893004537,-1.1996275186538696"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="205" a="0,1,-7.7328681072685868E-005" z="2.2299907868728042E-005,-7.7254189818631858E-005,-1" t="-0.79998880624771118,-0.80000036954879761,-0.39995619654655457"/> <RigidRef rigidRef="202" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="-0.79991090297698975,-0.02556304819881916,-1.1998778581619263"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="203" a="0,-1,7.7331358625087887E-005" z="0.0079856030642986298,-7.725349860265851E-005,-0.99996817111968994" t="-0.7999919056892395,-1.599751353263855,-0.39985832571983337"/> <RigidRef rigidRef="204" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="2.3998847007751465,0.025438409298658371,1.200128436088562"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="206" a="0,0,-1" z="0,1,0" t="1.2002476453781128,-0.025528833270072937,-4.7798981666564941"/> <RigidRef rigidRef="203" a="1,0,-2.2366368284565397E-005" z="0,-1,0" t="-1.5999909639358521,0,-0.39996415376663208"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="205" a="0,1,-7.7328884799499065E-005" z="0.0079855155199766159,7.7251723269000649E-005,0.99996817111968994" t="-0.79999029636383057,1.5999985933303833,-0.40014162659645081"/> <RigidRef rigidRef="204" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="-0.80001211166381836,-0.00025847135111689568,1.200126051902771"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="210" a="0,0,-1" z="1,0,0" t="0,0,-1.2000000476837158"/> <RigidRef rigidRef="204" a="0,-9.2234178737271577E-005,1" z="-0.0080302748829126358,0.99996775388717651,9.2234171461313963E-005" t="0.79993629455566406,0.012589968740940094,1.2001272439956665"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="206" a="0,0,-1" z="0,1,0" t="1.1999999284744263,0,-1.5800000429153442"/> <RigidRef rigidRef="205" a="1,0,2.2403621187550016E-005" z="0,1,0" t="-1.5999894142150879,0,-0.40003582835197449"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="207" a="0,0,-1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="206" a="1,0,0" z="0,0,-1" t="-0.80000120401382446,0,0.80000019073486328"/> </Joint> <Joint type="ball"> <RigidRef rigidRef="209" a="1,0,0" z="0,0,1" t="0,0,0"/> <RigidRef rigidRef="206" a="0.0032041671220213175,-0.0027053214143961668,0.99999117851257324" z="0.99999487400054932,-0.00038649752968922257,-0.0032052979804575443" t="1.201180100440979,-0.00099643552675843239,0.78557705879211426"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="208" a="0,0,-1" z="-1,0,0" t="0,0,-1.6000006198883057"/> <RigidRef rigidRef="207" a="0,-1,0" z="0,0,-1" t="2.3999996185302734,-0.40000054240226746,-2.0000011920928955"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="209" a="0,-1,0" z="-1,0,0" t="2.4144229888916016,1.2009956836700439,0.0011804378591477871"/> <RigidRef rigidRef="208" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="212" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0.80000001192092896,0"/> <RigidRef rigidRef="211" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="213" a="0,0,-1" z="1,0,0" t="0,0,-0.79999715089797974"/> <RigidRef rigidRef="212" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="215" a="0,-1,0" z="0,0,1" t="0,0.7999987006187439,0"/> <RigidRef rigidRef="214" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="216" a="0,0,-1" z="1,0,0" t="0,0,-0.799998939037323"/> <RigidRef rigidRef="215" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="218" a="0,0,1" z="1,0,0" t="0,0,-0.0010000824695453048"/> <RigidRef rigidRef="217" a="0,0,-1" z="0,1,0" t="0,0,-0.80000162124633789"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="221" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="220" a="0,1,-4.2490082705626264E-005" z="0.99999529123306274,0,-0.0030860283877700567" t="0.0024714635219424963,-1.1999852657318115,0.40004870295524597"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="223" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="222" a="0,0,1" z="0,1,0" t="4.8000001907348633,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="225" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="222" a="0,0,1" z="0,1,0" t="4,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="226" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="222" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="228" a="0,0,1" z="1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="222" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="224" a="0,-1,0" z="0,0,1" t="0,0.80000001192092896,0"/> <RigidRef rigidRef="223" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="225" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="224" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="227" a="0,-1,0" z="0,0,1" t="0.80000001192092896,0.80000001192092896,0"/> <RigidRef rigidRef="226" a="0,0,-1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="228" a="0,0,-1" z="1,0,0" t="0,0,-0.79999881982803345"/> <RigidRef rigidRef="227" a="0,-1,0" z="0,0,1" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="230" a="0,0,1" z="1,0,0" t="0,0,-0.0010000824695453048"/> <RigidRef rigidRef="229" a="0.00023438171774614602,-0.00026674228138290346,0.99999994039535522" z="9.8710515885613859E-005,-1,-0.00026676530251279473" t="-0.00019097616313956678,0.00021734008623752743,-2.1599726676940918"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="233" a="0,0,-1" z="1,0,0" t="0,0,-0.79999935626983643"/> <RigidRef rigidRef="232" a="-0.00061144330538809299,0,0.99999988079071045" z="-0.0031682527624070644,-0.99999505281448364,0" t="-0.80107516050338745,0.001888115075416863,0.79970264434814453"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="235" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="234" a="0,1,-4.2480089177843183E-005" z="1,0,0" t="0,-1.1999850273132324,0.40005257725715637"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="239" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> <RigidRef rigidRef="238" a="0,0,-1" z="-1,0,0" t="0,0,-1.599998950958252"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="240" a="0,0,-1" z="-1,0,0" t="0,0,-1.6000003814697266"/> <RigidRef rigidRef="239" a="0,1,0" z="0,0,1" t="-2.8000011444091797,0.40000179409980774,0"/> </Joint> </RigidSystem> <RigidSystem> <Rigid refID="241" transformation="0,-0.70710676908493042,0.7071068286895752,1,0,0,0,0.70710688829421997,0.70710676908493042,11.59999942779541,1.248525857925415,-3.248528003692627" boneRefs="692,693"/> <Rigid refID="242" transformation="0,0,1,0,1,0,-1,0,0,9.7599992752075195,0.39999797940254211,-2.3999998569488525" boneRefs="694"/> <Joint type="hinge"> <RigidRef rigidRef="242" a="0,0,-1" z="1,0,0" t="0,0,-2.2400002479553223"/> <RigidRef rigidRef="241" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> </Joint> </RigidSystem> <RigidSystem> <Rigid refID="243" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-26.39997673034668" boneRefs="695"/> <Rigid refID="244" transformation="1,0,0,0,-1.0000001192092896,0,0,0,-1,16.000003814697266,7.4069232940673828,-24.799999237060547" boneRefs="696,697,698,699,700,701,702,703,704,705,706,707,708,709,710,711,712,713,714,715,716,717,718,719,720,721,722,723,724,725,726"/> <Rigid refID="245" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-26.399995803833008" boneRefs="727"/> <Rigid refID="246" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-29.599977493286133" boneRefs="728"/> <Rigid refID="247" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,14.799999237060547,1.0069249868392944,-23.599996566772461" boneRefs="729"/> <Rigid refID="248" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,13.19999885559082,1.0069249868392944,-23.599996566772461" boneRefs="730"/> <Rigid refID="249" transformation="0,0,1,0,0.99999988079071045,0,-1,0,0,16.000005722045898,6.6069231033325195,-23.599994659423828" boneRefs="731"/> <Rigid refID="250" transformation="0,-1,0,0,0,0.99999988079071045,-0.99999988079071045,0,0,16.000005722045898,6.6069231033325195,-23.599994659423828" boneRefs="732"/> <Rigid refID="251" transformation="0,0,1,0,0.99999988079071045,0,-1,0,0,16,1.8069236278533936,-23.599996566772461" boneRefs="733"/> <Rigid refID="252" transformation="0,0,0.99999994039535522,0,0.99999988079071045,0,-1,0,0,13.200002670288086,7.4069242477416992,-23.599996566772461" boneRefs="734"/> <Rigid refID="253" transformation="0,0.38268390297889709,0.92387932538986206,0,0.92387920618057251,-0.38268387317657471,-1,0,0,14.800004959106445,5.1370701789855957,-37.389411926269531" boneRefs="735,736"/> <Rigid refID="254" transformation="0,0.38268297910690308,-0.92387980222702026,0,0.92387974262237549,0.38268303871154785,1,0,0,16.000005722045898,4.6778512001037598,-36.280757904052734" boneRefs="737,738,739,740,741"/> <Rigid refID="255" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,15.999998092651367,4.9905328750610352,-28.892423629760742" boneRefs="742"/> <Rigid refID="256" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,15.999998092651367,4.378237247467041,-30.370630264282227" boneRefs="743"/> <Rigid refID="257" transformation="1,0,0,0,0.92387908697128296,-0.38268452882766724,0,0.38268452882766724,0.92387908697128296,15.200004577636719,6.2151217460632324,-25.936014175415039" boneRefs="744"/> <Rigid refID="258" transformation="1,0,0,0,0.92388081550598145,0.3826805055141449,0,-0.38268047571182251,0.92388087511062622,15.200006484985352,4.6778464317321777,-36.280757904052734" boneRefs="745,746,747,748,749"/> <Rigid refID="259" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.19999885559082,4.9905319213867187,-28.892423629760742" boneRefs="750"/> <Rigid refID="260" transformation="0.99999994039535522,0,0,0,0.92388033866882324,0.38268104195594788,0,-0.38268104195594788,0.92388033866882324,15.200006484985352,3.759411096572876,-34.063449859619141" boneRefs="751"/> <Rigid refID="261" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.200000762939453,5.6028275489807129,-27.414220809936523" boneRefs="752"/> <Rigid refID="262" transformation="0,0,-1,0,0.99999988079071045,0,1,0,0,16.400005340576172,3.3001940250396729,-32.954788208007813" boneRefs="753"/> <Rigid refID="263" transformation="0.99999994039535522,0,0,0,-0.38268256187438965,0.92387968301773071,0,-0.92387992143630981,-0.38268265128135681,16.000003814697266,4.6778459548950195,-36.280757904052734" boneRefs="754"/> <Rigid refID="264" transformation="1,0,0,0,0.92387872934341431,-0.38268482685089111,0,0.38268482685089111,0.92387872934341431,15.19999885559082,4.3782362937927246,-30.370634078979492" boneRefs="755"/> <Rigid refID="265" transformation="1,0,0,0,0.92387878894805908,-0.3826848566532135,0,0.3826848566532135,0.92387878894805908,16,5.6028285026550293,-27.414216995239258" boneRefs="756"/> <Rigid refID="266" transformation="0.99999994039535522,0,0,0,0.92388045787811279,0.38268107175827026,0,-0.38268107175827026,0.92388045787811279,16.000005722045898,3.7594101428985596,-34.063442230224609" boneRefs="757"/> <Rigid refID="267" transformation="0,0,1,0,0.99999982118606567,0,-1,0,0,10.000001907348633,7.4069242477416992,-24.399995803833008" boneRefs="758"/> <Rigid refID="268" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-31.199979782104492" boneRefs="759"/> <Rigid refID="269" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,16.000003814697266,7.4069828987121582,-27.999975204467773" boneRefs="760"/> <Rigid refID="270" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.406923770904541,-31.19999885559082" boneRefs="761"/> <Rigid refID="271" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-29.599996566772461" boneRefs="762"/> <Rigid refID="272" transformation="0,0,1,0,0.99999982118606567,0,-1,0,0,10,1.0069248676300049,-24.399997711181641" boneRefs="763"/> <Rigid refID="273" transformation="0,0,-1.0000002384185791,0,1,0,1.0000002384185791,0,0,16.400005340576172,7.406923770904541,-33.999996185302734" boneRefs="764"/> <Rigid refID="274" transformation="1.0000002384185791,0,0,0,1.0000001192092896,0,0,0,1.0000002384185791,15.200004577636719,7.4069242477416992,-27.999998092651367" boneRefs="765"/> <Joint type="hinge"> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="0,-5.9653182688634843E-005,1.5999798774719238"/> <RigidRef rigidRef="243" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="-0.79999899864196777,0,1.5999984741210938"/> <RigidRef rigidRef="245" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="246" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="0,-5.9887257521040738E-005,4.7999825477600098"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="-1,0,0" z="0,0,-1" t="-1.2000041007995605,6.3999967575073242,-1.1999962329864502"/> <RigidRef rigidRef="247" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="-1,0,0" z="0,0,-1" t="-2.8000044822692871,6.3999967575073242,-1.1999965906143188"/> <RigidRef rigidRef="248" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="-1,0,0" z="0,0,1" t="0.40000233054161072,0.79999953508377075,-1.199998140335083"/> <RigidRef rigidRef="249" a="0,0,1" z="1,0,0" t="0,0,-0.39999973773956299"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="-1,0,0" z="0,0,-1" t="-2.7999997138977051,0,-1.1999979019165039"/> <RigidRef rigidRef="252" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="253" a="1,0,0" z="0,1,0" t="-0.39995980262756348,0.7999998927116394,-0.39999917149543762"/> <RigidRef rigidRef="244" a="0,-0.38268309831619263,-0.92387968301773071" z="-1,0,0" t="-0.79999732971191406,1.6838035583496094,13.265079498291016"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="267" a="0,0,1" z="-1,0,0" t="0,0,-1.6000025272369385"/> <RigidRef rigidRef="244" a="-1,0,0" z="0,1,0" t="-4.3999972343444824,0,-0.39999908208847046"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="-1,0,0" z="0,0,1" t="0.39999628067016602,5.5999984741210937,-1.199995756149292"/> <RigidRef rigidRef="251" a="0,0,1" z="1,0,0" t="0,0,-0.39999973773956299"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="268" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="0,-6.0004294937243685E-005,6.3999862670898437"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="269" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="0,-5.977022010483779E-005,3.199979305267334"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="-0.79999953508377075,0,6.4000048637390137"/> <RigidRef rigidRef="270" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="-0.79999935626983643,0,4.8000011444091797"/> <RigidRef rigidRef="271" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="272" a="0,0,1" z="-1,0,0" t="0,0,-1.6000006198883057"/> <RigidRef rigidRef="244" a="-1,0,0" z="0,1,0" t="-4.4000034332275391,6.3999981880187988,-0.39999845623970032"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="273" a="0,0,-1" z="1,0,0" t="0,0,-0.80000013113021851"/> <RigidRef rigidRef="244" a="-1,0,0" z="0,1,0" t="-0.40000113844871521,-6.0217360442038625E-005,9.199981689453125"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="244" a="0,0,-1" z="1,0,0" t="-0.7999991774559021,0,3.2000019550323486"/> <RigidRef rigidRef="274" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="250" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="249" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="251" a="0,0,1" z="1,0,0" t="0,0,0"/> <RigidRef rigidRef="250" a="0,0,1" z="1,0,0" t="4.8000001907348633,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="253" a="0,0,-1" z="1,0,0" t="0,0,-1.6000000238418579"/> <RigidRef rigidRef="254" a="0,0,1" z="0,1,0" t="1.2000000476837158,0,0.40000000596046448"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="254" a="-0.70710611343383789,0.70710760354995728,0" z="0,0,1" t="-6.7062735557556152,3.1162700653076172,0"/> <RigidRef rigidRef="255" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="254" a="-0.70710611343383789,0.70710760354995728,0" z="0,0,1" t="-5.5749030113220215,1.9848973751068115,0"/> <RigidRef rigidRef="256" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="254" a="-0.70710617303848267,0.70710742473602295,0" z="0,0,1" t="-8.9690093994140625,5.3790121078491211,0"/> <RigidRef rigidRef="257" a="0,0,1" z="0,1,0" t="0.80000001192092896,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="262" a="0,0,-1" z="1,0,0" t="0,0,-0.79999947547912598"/> <RigidRef rigidRef="254" a="0,0,-1" z="0,1,0" t="-3.5999987125396729,0,-0.39999997615814209"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="254" a="-0.70710611343383789,0.70710760354995728,0" z="0,0,1" t="-7.8376436233520508,4.247642993927002,0"/> <RigidRef rigidRef="265" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="263" a="0,-1,0" z="0,0,1" t="0,0.80000001192092896,0"/> <RigidRef rigidRef="254" a="1,0,0" z="0,0,1" t="-0.80000227689743042,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="266" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="254" a="-1,0,0" z="0,0,1" t="-2.4000046253204346,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="258" a="0,0.70710462331771851,0.70710903406143188" z="1,0,0" t="0,5.3789892196655273,8.9690265655517578"/> <RigidRef rigidRef="257" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="258" a="0,0.70710486173629761,0.70710879564285278" z="1,0,0" t="0,3.1162557601928711,6.7062802314758301"/> <RigidRef rigidRef="259" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="260" a="0,0,1" z="0,1,0" t="0,0,0"/> <RigidRef rigidRef="258" a="0,0,1" z="1,0,0" t="0,0,2.3999946117401123"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="258" a="0,0.70710486173629761,0.70710879564285278" z="1,0,0" t="0,4.2476210594177246,7.8376522064208984"/> <RigidRef rigidRef="261" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="258" a="-1,0,0" z="0,1,0" t="-0.39999747276306152,0,3.5999982357025146"/> <RigidRef rigidRef="262" a="0,0,-1" z="1,0,0" t="0,0,-1.5999962091445923"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="263" a="0,-1,0" z="0,0,1" t="-0.80000001192092896,0.80000001192092896,0"/> <RigidRef rigidRef="258" a="0,0,-1" z="1,0,0" t="0,0,0.7999996542930603"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="258" a="0,0.70710486173629761,0.70710879564285278" z="1,0,0" t="0,1.9848849773406982,5.5749034881591797"/> <RigidRef rigidRef="264" a="0,0,1" z="0,1,0" t="0,0,0"/> </Joint> </RigidSystem> <RigidSystem> <Rigid refID="275" transformation="1.0000001192092896,0,0,0,0,1.0000001192092896,0,-0.99999994039535522,0,5.6000056266784668,2.5998141765594482,-34" boneRefs="766"/> </RigidSystem> <RigidSystem> <Rigid refID="276" transformation="1.0000001192092896,0,0,0,0,1.0000001192092896,0,-0.99999994039535522,0,5.6000046730041504,4.1998143196105957,-34" boneRefs="767"/> </RigidSystem> <RigidSystem> <Rigid refID="277" transformation="0,0,1.0000001192092896,0,-1,0,1.0000002384185791,0,0,11.600000381469727,7.4069242477416992,-21.19999885559082" boneRefs="768"/> <Rigid refID="278" transformation="0,1,0,0,0,-1,-1.0000001192092896,0,0,10.80000114440918,5.0069246292114258,-20.399997711181641" boneRefs="769,770"/> <Rigid refID="279" transformation="0,0,1.0000001192092896,0,-1,0,1.0000002384185791,0,0,11.600000381469727,7.4069242477416992,-20.399997711181641" boneRefs="771"/> <Rigid refID="280" transformation="0,-1.0000001192092896,0,0,0,1.0000001192092896,-1.0000001192092896,0,0,11.600000381469727,6.6069240570068359,-20.399997711181641" boneRefs="772"/> <Rigid refID="281" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999980926513672,4.2069244384765625,-20.399997711181641" boneRefs="773"/> <Rigid refID="282" transformation="0,0,0.99999994039535522,-0.99999988079071045,0,0,0,-0.99999994039535522,0,11.199996948242188,4.2069244384765625,-21.599996566772461" boneRefs="774"/> <Rigid refID="283" transformation="0,-1.0000001192092896,0,0,0,1.0000001192092896,-1.0000001192092896,0,0,9.9999980926513672,6.6069250106811523,-20.399997711181641" boneRefs="775"/> <Rigid refID="284" transformation="0,0,1.0000002384185791,0,0.99999982118606567,0,-1.0000002384185791,0,0,10.799997329711914,3.4069242477416992,-20.399997711181641" boneRefs="776,777"/> <Rigid refID="285" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999961853027344,1.0069248676300049,-21.19999885559082" boneRefs="778"/> <Rigid refID="286" transformation="0,0,1.0000002384185791,0,1,0,-1.0000002384185791,0,0,9.9999961853027344,1.0069249868392944,-20.399997711181641" boneRefs="779"/> <Joint type="hinge"> <RigidRef rigidRef="278" a="0,0,-1" z="-1,0,0" t="2.4000000953674316,0.80000001192092896,-0.79999905824661255"/> <RigidRef rigidRef="277" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="278" a="0,0,-1" z="-1,0,0" t="2.4000000953674316,0,-0.79999905824661255"/> <RigidRef rigidRef="279" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="280" a="0,0,1" z="0,1,0" t="1.6000000238418579,0,-0.80000001192092896"/> <RigidRef rigidRef="278" a="0,0,1" z="0,1,0" t="0,0,-1.5999991893768311"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="281" a="0,0,1" z="-1,0,0" t="0,0,-1.6000005006790161"/> <RigidRef rigidRef="280" a="0,0,1" z="0,1,0" t="2.4000000953674316,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="284" a="0,0,1" z="1,0,0" t="0,0,-0.80000036954879761"/> <RigidRef rigidRef="280" a="0,0,1" z="0,1,0" t="3.2000000476837158,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="281" a="0,0,1" z="-1,0,0" t="0,0,-0.7999998927116394"/> <RigidRef rigidRef="282" a="0,1,0" z="0,0,-1" t="1.2000000476837158,0.40000000596046448,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="283" a="0,0,1" z="0,1,0" t="2.4000000953674316,0,0"/> <RigidRef rigidRef="281" a="0,0,1" z="1,0,0" t="0,0,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="285" a="0,0,1" z="1,0,0" t="0,0,-0.80000036954879761"/> <RigidRef rigidRef="284" a="0,0,1" z="0,1,0" t="-0.7999996542930603,-2.4000000953674316,0"/> </Joint> <Joint type="hinge"> <RigidRef rigidRef="286" a="0,0,1" z="1,0,0" t="0,0,-0.80000036954879761"/> <RigidRef rigidRef="284" a="0,0,1" z="0,1,0" t="0,-2.4000000953674316,0"/> </Joint> </RigidSystem> </RigidSystems> <GroupSystems> <GroupSystem> <Group transformation="1,0,0,0,1,0,0,0,1,0,0,0" pivot="0,0,0" partRefs="97,98,99,100,92,93,101,113,114,90,115,105,94,37,78,116,80,106,44,36,91,95,34,110,117,33,96,77,147,107,74,136,85,35,103,2,148,146,81,111,86,38,137,149,75,6,102,108,43,141,109,3,87,104,4,138,42,118,150,154,142,40,112,39,167,5,82,0,139,88,83,155,41,168,119,153,45,1,8,140,166,169,79,62,7,152,143,145,72,156,89,50,132,133,18,124,144,157,170,120,17,129,123,10,161,158,160,84,121,134,9,15,67,19,159,63,164,46,51,122,131,64,130,60,65,22,151,126,135,128,162,66,52,53,68,20,58,163,55,21,172,25,47,165,56,23,26,24,127,54,173,69,48,177,57,175,174,29,49,30,176,70,59,32,71,61,12,14,73,13,76,16,11,125,27,171,28,31"/> <Group transformation="1,0,0,0,1,0,0,0,1,0,0,0" pivot="0,0,0" partRefs="383,298,341,382,449,342,434,362,433,343,400,403,401,402,192,387,328,388,326,390,386,389,327,391,385,353,309,324,325,308,444,447,445,446,307,350,304,290,376,373,374,320,372,375,437,321,458,322,318,392,289,438,314,443,352,288,339,319,293,323,284,315,439,305,348,457,456,317,398,316,440,351,355,397,354,441,448,399,285,435,452,442,425,346,344,345,361,191,291,396,451,281,302,283,286,431,450,366,395,365,430,436,287,393,432,347,455,333,394,454,331,428,364,301,297,335,292,330,338,282,427,349,306,381,378,379,334,377,380,459,336,453,337,332,384,429,295,426,329,363,303,296,294,340"/> <Group transformation="1,0,0,0,1,0,0,0,1,0,0,0" pivot="0,0,0" partRefs="184,179,178,180,181,183,185,182,186,187,189,188,190"/> </GroupSystem> </GroupSystems> <BuildingInstructions> </BuildingInstructions></LXFML>[/Code]Once you are finished please repeat this phrase aloud one hundred times: "I promise I will backup important data." Edited September 21, 2013 by pbat Quote
Brawl Posted September 21, 2013 Author Posted September 21, 2013 (edited) Heh, I always backup my data. As a programmer, this isn't the first time I've had terrible problems like this. But, I'm not OCD to the point of making a backup every 5 minutes. Even making backups at a 'healthy' rate is never enough you know. Accidents are bound to happen. Anyway, thanks for the information and the lesson on how the files work! I figured it was an archive and the bone data was hidden somewhere, but I didn't know about these tools. I owe you one. ;) EDIT: Hmmm... I can't seem to open the file with that program. It opens fine with 7zip, but won't allow me to do anything to the files. :( Oh, scratch that, it's opening now. My bad. Yup, you're now my favorite person on Earth. :D Edited September 21, 2013 by Brawl Quote
pbat Posted September 21, 2013 Posted September 21, 2013 I owe you one. ;) I always wanted to have this set... Nah, just kidding. Well, not really. I actually want to have this set. But not as a reward for such a simple task. Anyways, have you ever considered to make your own electric power, so that you become independent from the power supplier and its blackouts? (and maybe dope your hamster...)Maybe you want to head over to this thread to request an auto-save feature for the next version of LDD to avoid data loss? Quote
