Anyone know of a clever way to keep the legs from doing that running motion? The AT-ST has one cross axle installed the connects the leg to the body (each leg is connected by its own axle), installing a second axle from the leg to the body would keep it from moving; however, the holes in the leg and the holes in the body don't line up for me to poke the axle through.
Anyone else have an idea or a recommendation?
I can't understand that its current leg attachement design could bug you, because it is able to stand properly without doing a running motion.
If you'd like to change it, you could of course remove the two smaller axles that connect to the legs and replace them with one bigger axle that goes al the way through.
It's about the one of the battle of endor, right? I think this may work.
Good idea. The bigger axle would at least be an improvement.
