Hey. I have recently created my first model in SR 3D and I want to create building instructions for it. I have seen that a lot of people just import it in MLCAD to use LPub, but I saw in SR 3D builder that there is something called Instruction Miner. Why do people not use this? Is it not as good as LPub?
Thanks,
Nathan
Yes Lpub is much better,you can do a lot more with Lpub that you can with the instruction miner with SR3D.
I only use SR3D for building, then I switch software and use MLcad before get the model ready for Lpub.
Edited by Alasdair Ryan
Ok. That's what I thought.
Thanks,
Nathan
I tried to open the file in MLCAD but every time I do it gives me a runtime error and shuts down MLCAD. How do you open the SR 3D file in MLCAD?
Well, the instruction miner isn't made for making the actual instructions, so that's why LPub can do more than the instruction miner :wink:
The instruction miner is made for adding Steps and Rotation steps and changing the order of the parts. This information is used by LPub to generate the instructions. It are the same META commands MLcad adds for the STEP and ROTSTEP :classic:
That worked!
Thanks,
Nathan
I opened up the file in MLCAD but I'm not sure what to do. Do I need to add steps in SR 3D Builder before I import because I can't add them between specific parts in MLCAD? It just shows the groups I made in SR 3D Builder. Also is there a way to add a buffer exchange in MLCAD? Again, I can't see individual parts. Should I delete the groups I made in SR 3D builder?
Kristel's guide can be found here.
I wrote a small bit on using buffer exchange which can be found in the guide (although the actual guide on this is on my blog).
When you are making models in SR 3D Builder, do you add steps in SR 3D Builder or MLCAD? Also, do you make groups?
I use MLcad to add steps or rota steps.if the model is big, I split the whole model into sub models (separate files).
I don't use the 'group function' a lot in ether SR3D or MLcad.
I add steps and rotation steps in SR3D Builder. I also use the group function to make my sub-models. When I'm done I export all the seperate groups and import and replace them all in MLcad so LPub understands the submodels (it can only understand mpd files, no groups from SR3D Builder).
Ah - I missed the rotstep capability of SR3D. Good to know since MRCad rotstep preview is clumsy at best!
