Hi, I'm new on the forum and I'm trying to make my current railroad 9v compatible but I'm having trouble getting the switches and crossover pieces to work. Can somebody help me with this? Thanks.
Yea, for the mostpart, I know where to put the copper tape, but when i run a 9v train over it, it goes about an inch from where the switch lever is then stops.
Oh, have you made sure that the tape is connected with wire under the track?
Like here, all the red tape/rails have to be connected with wire, and all the blue tape/rails have to be connected with wire in order to work.
I didn't know there was a wire on RC switches
There is not on an RC switch you need to add one, they are there on the older 9V switches
ok, but is there any way i can get it to work without adding a wire?
At least you need wires to get electricity over the frog, but it would also be good to have the other wires too, just in case...
