draganb Posted December 1, 2012 Posted December 1, 2012 Hey all! I'm working on a UCS size TIE Interceptor MOC, and I'm looking for an alternative for the very rare (and expensive) original windscreen: I was surprised to see there was very little alternative for that piece, only other transparent colors it comes in are trans blue, trans green, and trans neon green: There is a part that comes with some aqua themes, but also in trans blue and trans green The only other available and cheap part that would fit the description is this: But I'm just not very satisfied with it. Can anyone suggest any other alternatives? Quote
Bricktooth Posted December 1, 2012 Posted December 1, 2012 I would suggest a brick-built version with droid arms attached to clips. The only backside with this is that it doesn't have 'glass', so the cockpit will be open. Hope this helps! Quote
TheLegoNinja Posted December 1, 2012 Posted December 1, 2012 maybe you could use the cheap version with the printing from the republic gunship? Quote
Only Sinner Posted December 2, 2012 Posted December 2, 2012 Go with brickbuilt, you can make a better one yourself. Better than that printed piece anyway. Use droid arms, flagpoles, rods, whatever. Quote
draganb Posted December 2, 2012 Author Posted December 2, 2012 maybe you could use the cheap version with the printing from the republic gunship? I tried that, but it's just to oval and doesn't really flow right with the rest of the cockpit. Also it's 2 stud too small so it ends up sticking out from the middle awkwardly :) Go with brickbuilt, you can make a better one yourself. Better than that printed piece anyway. Use droid arms, flagpoles, rods, whatever. Yeah, I'll probably go with that. Do you have any examples I could shamelessly steal from? Quote
