My first post here outside of the introduction thread. Here goes...
This is my large-scale Morris Mini that I've been working on for a while now. It's 38 studs long, 14 wide (not including the bumper bars and wheel guards). Not sure how many pieces, but alot more than I had anticipated. Several bricklink orders later (which added to the build time) I managed to finish it off.
I've left the engine-bay open as I intend to put a battery box in there hooked up to some LEDs for the headlights (there is a hole behind each headlight to allow for this), I just haven't found a suitable kit yet.
The doors open, steering wheel turns the wheels and the bonnet opens. That's about all the functionality it has.
Enjoy and please post C&C for me. Thanks.
Here are a couple of pics, the rest are here.
Sorry I will try to fix the brick shelf album. I haven't used brick shelf before today.
The wheels are already pretty big. The wheels on the real thing are small and if anything I think my model has the wheels too big.
Very good job so far but you have some funky proportions going on. The hood is too long and the windshield needs to be less slanted. The wheels seem to be the right size, perhaps a little small, but the way you have them it looks like it's been lowered too much. The wheel arches should follow he curve of he tire and yours open up front and back. Lots of good lines in your model however.
Edited by gotoAndLego
I don't use brickshelf, but I know the people there have to make it public so you can't really do anything about that
Very good job so far but you have some funky proportions going on. The hood is too long and the windshield needs to be less slanted. The wheels seem to be the right size, perhaps a little small, but the way you have them it looks like it's been lowered too much. The wheel arches should follow the curve of the tire and yours open up front and back. Lots of good lines in your model however.
That was why I thought the wheels needed to be bigger :tongue:
Your wheels aren't too large, but your proportions are off. The body need to be taller, the hood needs to be shorter with a less slanted windshield, you car look slik its been lowered, etc. Overall the size is fine, so it just needs refining.
Its easy to get close but hard to get accurate. I'm doing a miniland scale Mr Bean. so I know.
Edited by Peppermint_M
removed attachments as requested.
Thanks! :sweet:
I was considering making a Mr Bean mini, but I'm using all my Lime bricks for another build.
It was difficult for me to get this mini right. I don't own one or have access to one, and I never see them on the roads anymore, so all I had to go off were pictures on the internet. I know it's not quite perfect, but I'm still pretty happy with how it turned out. Always room for improvement, but with this one I'm not sure whether I will alter it at all. I'll probably need to pull it apart soon as I want to do another car, and I want to do it in red, so will need these pieces.
Edited by SamBo
Thanks! :sweet:
I don't have enough lime, so raher than hitting brick link I'm just using yellow.
I went nuts and ordered loads of lime to make this: Ford Falcon BA XR8 Utility.
I'm thinking I will be better off dropping the scale of my cars down a bit. Easier on the piece count (and the wallet) that way. I get my proportions a bit wrong (as you can see) so I think a smaller scale will make it easier to fix that issue.
Man, that's a lot of Lime, but your Falcon looks good. There is a good Mini on Cuusoo using those curved wheel arch pieces. Dropping the scale would save you pieces, but those large lego cars are really impressive.
