blaz62 Posted June 28, 2012 Posted June 28, 2012 Hey Few weeks ago I started build on this project. This will be clasic fire truck wiht working watergun on top and one small "high pressure" hose on back. Truck will be full remote control (drive, steering and working watergun on top). Chassis is finish and now buld cab-front mask. Truck have full suspension and 4x4 drive with differential. This is first video of this truck: http://www.youtube.com/watch?v=KUrLC4YwFcA New picture coming soon. Quote
timslegos Posted June 28, 2012 Posted June 28, 2012 I saw the pictures on Brickshelf, it looks great so far! How are you planning on powering the hose? tim Quote
blaz62 Posted June 28, 2012 Author Posted June 28, 2012 @timslegos Pictures on Bs? I'm not yet put pictures on Bs. For hose I will use 2 Lego mini pneumatic pump (I already tested and work). Quote
Edwin Korstanje Posted June 29, 2012 Posted June 29, 2012 (edited) Nice WIP MOC firetruck so far . Get keep posting pictures or video off your progres. I build olso some firetucks whit working water engines. Greets Edwin. Edited June 29, 2012 by VFracingteam Quote
blaz62 Posted July 1, 2012 Author Posted July 1, 2012 Now waiting for few brick from bricklink, and this is my little progress: Quote
timslegos Posted July 1, 2012 Posted July 1, 2012 Looks great. I meant to say I saw the video on youtube in my earlier post. tim Quote
Alasdair Ryan Posted July 1, 2012 Posted July 1, 2012 You are making good progress,well done so far. Quote
blaz62 Posted July 10, 2012 Author Posted July 10, 2012 Little progress, but still waiting for bricks from bl. I'm installed water tank and one pump, for one still waiting... Quote
timslegos Posted July 10, 2012 Posted July 10, 2012 Would you mind making a video of how the water system works, I still don't really understand how it works. tim Quote
blaz62 Posted July 10, 2012 Author Posted July 10, 2012 (edited) Inside this white barrel will be 2 (now 1) water pump-Lego pneumatic pump (x191c01)-from unimog set. Video will come when I will get another pump Edited July 10, 2012 by blaz62 Quote
blaz62 Posted July 11, 2012 Author Posted July 11, 2012 (edited) New video-pump test: Edited July 11, 2012 by blaz62 Quote
timslegos Posted July 11, 2012 Posted July 11, 2012 Thank you for the video! I finally understand! And you dont have to worry because the pumps are fully plastic correct? tim Quote
Phoxtane Posted July 12, 2012 Posted July 12, 2012 Could I make a suggestion? It may be a good idea to cover the water tank with a plastic bag; that way, if the truck falls over for some reason, you won't get water inside your Power Functions. Quote
blaz62 Posted July 12, 2012 Author Posted July 12, 2012 Yeah, I was thinking, because this is a serious problem. Quote
ciken Posted July 12, 2012 Posted July 12, 2012 your reciver is not water resistant but our motors can handele water Quote
Crazydance Posted July 14, 2012 Posted July 14, 2012 (edited) Thank you for the video! I finally understand! And you dont have to worry because the pumps are fully plastic correct? tim What happens if you choose to use an up-gearing instead of two of the same gears. Do you have more water pressure then or do you experience a decrease? It should be worth a shot because a lot of fire trucks have the hose on top of the verhicle. Thus more distance is needed for the water to travel to a actual fire. Do you know the distance that the water will travel once the model is done? BUT after seeing the video I think this is something TLC could take in consideration for a new flagship model. It only needs 1 new part (the water tank), and you're done! I wouldn't mind chasing after the cats with this bad boy! xD Thinking about the water tank and electronics safety: You could use a cap with a rubber band. Children's bottles do this all the time. Same goes for safeguarding your hoses. Rubber band around it and making sure it doesn't leak too much. I also think the cap should have three holes. One for the actual spraying hose, one to fill it, and one air-outlet, because pressure builds when you want to fill it, so that needs to go somewhere. All three should have pneumatic hoses in them so that you don't have to open up the truck to fill it. But then again you need to know how much water is in there :p Edited July 14, 2012 by Crazydance Quote
blaz62 Posted July 14, 2012 Author Posted July 14, 2012 Real fire trucks with water gun on top usually have a big water tank, because pump for this gun have power 2,500l/min+. These two pump don't have enough power, for high pressure, distance is only ~20 cm, for normal pressure would need minimum 4 pump Today i'm get one new idea, but for that i need 3 pump-water air pump. More about that, when will be completed. Tank is a big problem, maybe i will change. Quote
Alasdair Ryan Posted July 14, 2012 Posted July 14, 2012 The way you construct the pump's is important,You may want to try my design,in order to improve the pump rate. Quote
Crazydance Posted July 15, 2012 Posted July 15, 2012 The way you construct the pump's is important,You may want to try my design,in order to improve the pump rate. I wonder how much pressure you can create when you let THAT run like crazy! Is this even possible? I mean the compressor pumps do have a maximum they can be pulled out, seems liky you're hugging the limit there. It would be nice if this works. With proper gearing you can produce some serious pressure. Quote
ciken Posted July 15, 2012 Posted July 15, 2012 (edited) I wonder how much pressure you can create when you let THAT run like crazy! Is this even possible? I mean the compressor pumps do have a maximum they can be pulled out, seems liky you're hugging the limit there. It would be nice if this works. With proper gearing you can produce some serious pressure. i think he had only 1 new compressor part and 1 old He was still waiting for an order to come Edited July 15, 2012 by ciken Quote
Alasdair Ryan Posted July 15, 2012 Posted July 15, 2012 On my latest project i use my design above but with two new pump's. Quote
