Here's two new mechs I built. ;-)
Thunder Fury II
Overall View.
Side View
Back View.
Powersaw Arm.
Cannon Arm.
Cockpit and Top.
Legs and Feet.
One of the most deadly mechs designed by the Robots, the Thunder Fury II has thankfully not been produced in great numbers. Designed after the fall of the Raging Storm super-mech, MkII is vastly different from the original model. Heavier armor, improved weapons, and a streamlined design make this mech even deadlier than its predecessor. When Exo-Force faced a squadron of 4 of these powerful mechs, they barely succeeded in driving them back, which makes the humans glad that there are only a few of them, due to slow development and construction.
Weight: Heavy
Speed: Medium/Slow
Armor: 11 inches of tenatium armor
Weapons: - Automatic Heavy Quad-Gatling cannon
- Titanium/Krillium Alloy powersaw
- 2 missiles
- 6 light lasers (not cannons)
Total Production: Estimated at 7 units
Turbine Tracker
Overall View.
Front View.
Side View.
Back View.
Cockpit.
Cockpit Opened.
Built as a scout mech, the Turbine Tracker gets its name from the two small turbines attached on its back in a similar fashion as the Fire Vulture. This small mech is fairly quick in the air, and often performs recon-missions, as well as assisting Fire Vultures in sole-air attacks. The Humans have had victories against them, but in sheer numbers these mechs are very powerful.
Weight: Medium/Light
Speed: Medium/Fast
Armor: 4 inches of tenatium armor
Weapons: - 2 light laser cannons
- 2 missiles
Total Production: Estimated at 170 units
Oh, and here are the links to two older MOC's I never got around to posting: Blade and Z-5 Scout Glider.
Turbine Tracker is my favorite. Good use of the wheels.
The T. Fury II is a bit too close to the original design, and the gun needs a bit of work.
The Blade is also quite good, but I personally don't like the bricks with print.
May I add the Turbine Tracker to my web-site?
Thanks guys, and Exo-Champ, I would love it if you put the Turbine Tracker on your website. It's easily my favorite out of all my Exo-force creations, and I want other people to see it. ;-)
