mostlytechnic Posted November 23, 2011 Quick question - I know to dual-motor a loco you can use the reversing switch to change the second motor. I don't have room for that. Am I correct that the center two wires in the PF cable control the motor, so cutting an extension cable and crossing those two would also reverse the motor? Just thought I'd double-check before I start cutting. Measure twice, cut once and all that :) Share this post Link to post Share on other sites
Mr Benn Posted November 23, 2011 I don't have one immediately to hand to test it out, but can't you just turn around the connector at one of the connection points - this will effectively be doing the same thing as crossing your wires over? Share this post Link to post Share on other sites
mostlytechnic Posted November 23, 2011 You could w/ the old 9V wires, but the PF can't be turned. They only connect 1 way. Share this post Link to post Share on other sites
Tearloch33 Posted November 23, 2011 (edited) Quick question - I know to dual-motor a loco you can use the reversing switch to change the second motor. I don't have room for that. Am I correct that the center two wires in the PF cable control the motor, so cutting an extension cable and crossing those two would also reverse the motor? Just thought I'd double-check before I start cutting. Measure twice, cut once and all that :) Philo has a nice article on this.....essentially shows that there are 4 wires....two for power and two for control (direction). He has schematics and torn apart connectors shown. It may be easier to take apart the connector plate instead of cutting the cable. http://www.philohome.com/pf/pf.htm If you reverse the connections for C1 and C2 in the schematic, between the motor and the IR controller (for the motor you want to reverse the direction of....front motor) it should do the trick. Edited November 23, 2011 by Tearloch33 Share this post Link to post Share on other sites
Snapshot Posted November 23, 2011 (edited) Quick question - I know to dual-motor a loco you can use the reversing switch to change the second motor. I don't have room for that. Am I correct that the center two wires in the PF cable control the motor, so cutting an extension cable and crossing those two would also reverse the motor? Just thought I'd double-check before I start cutting. Measure twice, cut once and all that :) Yes, that's exactly how to do it. When I've got restricted height in a loco so I can't stack PF connectors, I make a 'Y' cable that feeds both motors - one arm has straight-through wiring and the other has the centre pair crossed. Don't forget to insulate the joints so they can't touch each other. Edited November 26, 2011 by Snapshot Share this post Link to post Share on other sites
proraptor Posted November 23, 2011 Hi Guys I want to add another motor to my maersk. Can anyone direct me to the reversing switch I would need? Does the switch fit in the maersk? Thank you Share this post Link to post Share on other sites
kyphur Posted November 23, 2011 (edited) Hi Guys I want to add another motor to my maersk. Can anyone direct me to the reversing switch I would need? Does the switch fit in the maersk? Thank you LEGO® Power Functions Control Switch I'll know if it fits after the weekend when I try to double-up my Maersk Loco on motors. Edited November 23, 2011 by kyphur Share this post Link to post Share on other sites
Man with a hat Posted November 24, 2011 LEGO® Power Functions Control Switch I'll know if it fits after the weekend when I try to double-up my Maersk Loco on motors. Well, it worked for me. I now have two motors in my Maersk train. I must say that you need to remove some excess bricks to fit it though, apart from the normal modification shown in the manual. But you can do it without changing the exterior. Share this post Link to post Share on other sites
proraptor Posted November 24, 2011 Well, it worked for me. I now have two motors in my Maersk train. I must say that you need to remove some excess bricks to fit it though, apart from the normal modification shown in the manual. But you can do it without changing the exterior. awesome to hear got any pics of the location you installed it? Share this post Link to post Share on other sites
legoboy3998 Posted November 24, 2011 You can just turn the second PF motor. The wire comes out near the top allowing a coupler to still be attached. Sal WFB, WI Share this post Link to post Share on other sites
