I'm not sure if this sort of topic is allowed here and if it isn't, feel free to move/close it.
I have enjoyed LDD in the past and so I decided to get LDD 4.0. To my surprise, the program didn't do anythinig. It didn't open. It didn't show any error messages. So, I was wondering if any of you have had the same problem and if so, how did you fix it? Thanks.
@ montyofmusic: Did you follow the procedures in "Part 2" of this Eurobricks post? It says:
Part 2 - Turn advanced graphics OFF (because LDD is crashing or not starting)
Q1: I just installed LDD 4 over a previous LDD 3 installation, and now LDD will only start for a few seconds and then shut down. Why?
A: Most likely because you have a line in your preferences.ini-file left from the LDD 3 installation that says
UseShadersInScene=yes
UseShadersInPalette=yes
You need to edit the preferences.ini-file and set those values to "no".
For Windows 7 and Vista it can be found here C:\Users\UserName\AppData\Roaming\LEGO Company\LEGO Digital Designer\preferences.ini
For Windows XP here: C:\Documents And Settings\UserName\ApplicationData\Lego Company\Lego Digital Designer\preferences.ini
NOTE: If you can't find this folder, the read here how to make it visible.
Edited by DLuders
