Has anyone measured and published the output voltage for the fixed output levels on the 9v transformer?
- BMW
- BMW
The fixed output levels? I'm not sure what you mean. The intervals between 0V and 9V? Well... you can open the regulator, use a multimeter and reassemble it again (it is easy to do without damaging the regulator).
You can measure it on the tracks with a standard meter.
It ia about 1.5V voltage step / click on the controller (4548).
Meaning 0 - 1.5V - 3.0V - 4.5V - 6.0V - 7.5V - 9.0V.
With more than one motor on track it is slightly lower.
That's not correct. The lowest setting is about 3 volts, and after that it goes up about 1.2 volts
per step.
