I lightly modified the RGS so it has smoothed sides and wings.
See? Less random colors in the sides.
SNOT doors
Smooth wings, now i need wing decals.
There seems to be a height difference...
Oh, theres a hatch!
I think I like what you've done with the RGS, but one suggestion:
In regards to the photography: I love the angels that you have chosen, but I think if you used alternative light sources from different angels, rather than using the cameras built-in flash, you may be able to avoid the over abundance of white glare. You could also try pulling the camera back from the ship and use the flash (if you must :wink: ) and then go back and crop the image. This also helps to avoid white glare. There are many other techniques you can do to avoid that, but I hope these ideas help you a little bit!
Aside from that, I like that you've done away with the bacta tank area and continued the "window-vent" areas. It looks really nice, and I may consider using that on mine.
