Tags: Building (Spaceship Interior), Science, Spaceship
01 Oktobrinali 3815
MSS Titan, Strategic Navigation Suite
Keynes_zps7emvqgtn.jpgCaptain Keynes: “Gentlemen! Observe the 'Dynamic Galaxy Map' before you, and tell me how last week we:
a) ended up in sector E11 and not in D10 with the rest of Admiral SpacerSteve's fleet
and b) didn't notice until you clowns found some dangerous little space critter and no science vessel to take it to!
moose_zpshtneimaq.jpgMoose: "Sir, We were not aware of the error sir. We were just briefed to go out into the asteroid belt and survey for awesomnium Sir. We assumed E11 was where we were supposed to be; you don't expect to be dropped in the wrong system every day Sir!"
alvin_zps3xmnpvzp.jpgAlvin: “Sir, Moose is correct Sir. Our briefing did not specify which sector we were supposed to be in, just that we were to survey the current sector Sir.”
Keynes_zps7emvqgtn.jpgCaptain Keynes: “And you didn't think to ask!? Idiots! And as for you Stevens
stevens_zpsqanry2bc.jpgEnsign Stevens: “Sir, The D10 and E11 asteroid belts do look very similar on the map Sir. It is less than 1 stud per sector resolution Sir."
Meanwhile aboard the MSV Horizon 'Sal' Class Science vessel.
DrFields_zpsiedfcvwo.jpgDr Fields: "Research Log Entry Alpha two dash zero one. The creature discovered by the MSS Titan appears to utilise awesomnium in some part of it's digestive process. Its excrement is pink in colour and according to the MSS Titan crew indicated high levels of awesomnium, though the readings were not consistent with our baseline awesomnium signature records. Visual microscopy suggests the substance is homogenous and appears to have a metallic crystal structure."
DrFields_zpsiedfcvwo.jpgDr Fields: "I am placing a sample in the Awesome Nano Analysis Laser."
DrFields_zpsiedfcvwo.jpgDr Fields: "Sample has been accepted."
DrF2_zpsjqfcdrbx.jpgDr Fields: "Energising. Looks like the Titan crew were right! The ANA-Laser has isolated the elemental signature and it looks to be a stable second isotope of awesomnium. I best let Big Sal know right away!"
Aboard the Rescue Ship MSR Findy
17971638764_d8c2d39728_o.jpg Big Sal: "What is it? This better be important! I've just spent days stuck inside an asteroid with two morons!"
DrFields_zpsiedfcvwo.jpgDr Fields: "Sir, This is Dr Fields aboard the Horizon. The MSS Titan discovered an unusual creature in sector E11 and from it I have extracted and isolated a new isotope of awesomnium!"
17971638764_d8c2d39728_o.jpg Big Sal: "...You appear to have a standard issue data-pad in your hair."
DrFields_zpsiedfcvwo.jpgDr Fields: "Of course Sir. Where else would I keep it?"
17971638764_d8c2d39728_o.jpg Big Sal: "Pockets Dr Fields. Pockets! Don't tell me Accountant Long has now cut pockets from the science budget!"
DrFields_zpsiedfcvwo.jpgDr Fields: "Not that I am aware of Sir. anyway that's not important, did you not hear what I said?"
17971638764_d8c2d39728_o.jpg Big Sal: "Not entirely, that data pad is sort of distracting."
DrF2_zpsjqfcdrbx.jpgDr Fields: "Better, Sir?"
17971638764_d8c2d39728_o.jpg Big Sal: "Much, now continue...."
DrF2_zpsjqfcdrbx.jpgDr Fields: "Sir, we have isolated a second stable isotope of awesomnium!"
17971638764_d8c2d39728_o.jpg Big Sal: "Really! Wow! And how does it differ from the baseline element?"
DrF2_zpsjqfcdrbx.jpgDr Fields: "Er...I am still running tests but....so far as I can conclude....instead of being purple it is pink sir."
17971638764_d8c2d39728_o.jpg Big Sal: "Pink you say!? Hmm... what further tests have you planned? Injecting it into plants? Adding it to foodstuffs? Hmmm...actually on second thoughts, send me all your data and samples at once!"
DrF2_zpsjqfcdrbx.jpgDr Fields: "Yes Sir."
Back Aboard the MSS Titan....
Keynes_zps7emvqgtn.jpgCaptain Keynes: “For your absolute idiocy you will all be cut to basic apprentice pay and placed on latrine maintenance for..."
stevens_zpsqanry2bc.jpgEnsign Stevens: “Incoming transmission Sir!"
Keynes_zps7emvqgtn.jpgCaptain Keynes: “And you Stevens for interrupting me mid rant will get..."
stevens_zpsqanry2bc.jpgEnsign Stevens: “Its CEO Big Sal, Sir!"
Keynes_zps7emvqgtn.jpgCaptain Keynes: “Dammit, I'll deal with you later! On Screen!"
17971638764_d8c2d39728_o.jpg Big Sal: "Capain Keynes! I want you to promote the intrepid explorers who found the awesomnium creature in sector E11; they are to get double larvae privileges on all Fridays!"
Smaller builds this week as I had somewhat less time with bricks.
A bonus shot of the lab:
And the Map room in normal lighting conditions. The map is controlled and navigated in detail via the console and arm in used by Ensign Stevens: :
I'd been playing with the map room idea ever since the CAT C part of contest 2. I thought the hex pattern on the insectoid dome part reminded me of the dynamic galaxy map. Under the dome are a number of 'planets' to hopefully give a bit more impression of there being a holographic map rather than just a transparent dome:
