AoM Farm Phase 1
This is my first MOC.
Tried to give it some terrain and a bit of rocks, I know there’s room for improvement so advise is welcome.
Very nice little build Puvel, the rocks and plants are great and the photography is superb! :thumbup: I would suggest a tad more texture on the ground and not making the brown lines so straight... a few studs could probably do the trick :wink: It is also nice if you could get a full picture of the build without cutting off the corners - still, an excellent first build, I'm certainly looking forward to your future contributions! :sweet:
Thanks for the comments, I’m smiling as I type!
Will play around a bit with ground texture and rocks and see what happens.
There are a lot of options so don’t know yet what to build next, maybe the little landscape will lend itself to something specific.
Glad to have you in Mitgarida, and this is a solid first build :thumbup: Perhaps lowering the reddish brown plates one plate, so that the surrounding terrain is a touch higher would look better.
Or you could do a raised bed :classic:
Hehe the main reason for using the vial was that I couldn’t find a rake or shovel when I was building this. I figured it could be some kind of cure or growth potion. Magic sounds good too, looks a bit like the plants just sprouted indeed!
Neat start, Puvel. The edge of the patch looks a bit sharp. Maybe a fence would work to give it a frame. And I don't know about the bark tan leaves on the rock. A plant should always have some kind of trunk, or at least roots that go to the ground. But good to have you in Historica!
