This is my Lego LDD Modularized Preserved Railway Station built from 10 Large modules and 18 small Modules and raised Lego Train Track on Lego Light Blueish Gray plates and Tiles. The Preserved Railway station can be increased in size and height by adding more modules. The Large Modules are divided into Platform Modules and Station Building Modules, while the small modules are thing like Lego Minifigures, Station Lamps, bench's, Station Signs,
Apart from the Lego Station Lamps and and the Lego Benches, the rest were designed by me, the LDD Lego Preserved Railway Station MOC has 4042 Bricks not including the steam Locomotive and Coaches, and the LDD Lego Preserved Railway Station MOC is 466 Studs long (145.62 inches), 56 Studs wide (17.5 Inches), 31 Studs high (23.97 Inches High).
The Preserved Railway Station can handle a maximum of three Lego LBSCR 48Ft Bogie Coaches and 1 Lego EKR No 5 Steam Locomotive.
View of the Lego LDD Preserved Railway Station from the top end of the Railway Station.
View of the Lego LDD Preserved Railway Station showing the station building and awning.
View of the Lego LDD Preserved Railway Station from the bottom end of the Railway Station.
Close up view on the Lego LDD Preserved Railway Station showing the awning and benches with two Lego Minifigures waiting for the train to arrive.
Showing the end of the platform with the Headshunt beyond the end of the platform.
Showing the headshunt and buffers which I designed myself.
Showing three Lego LDD MOC of the LBSCR 48 Ft Bogie Coaches awaiting for the Lego LDD MOC of the EKR Steam Locomotive No 5 to return and pull the coaches away.
Another view of the three Lego LDD MOC of the LBSCR 48 Ft Bogie Coaches awaiting for the Lego LDD MOC of the EKR Steam Locomotive No 5.
Showing the Lego LDD MOC of the EKR Steam Locomotive No 5 at the end of the headshunt.
Showing the Lego LDD MOC of the EKR Steam Locomotive No 5 traveling in a reverse direction up the run-round loop.
Showing the Lego LDD MOC of the EKR Steam Locomotive No 5 traveling in a reverse direction up the main line towards the Engine Shed and Turntable Module (still have to design that).
Showing the Lego LDD MOC of the EKR Steam Locomotive No 5 traveling in a reverse direction down the mainline towards the railway station.
Showing the Lego LDD MOC of the EKR Steam Locomotive No 5 recoupled to the Lego LDD LBSCR 48 Ft Bogie Coaches.
Showing the train pulling away from the train station.
Showing all the modules used to build the Preserved Railway Station.
I plan to build and incorporate this into a Lego Model Railway some point after I have designed the other modules and worked out what I am doing.
To find about the my Lego LDD MOC of the EKR Steam Locomotive No 5, see my post at
http://www.eurobricks.com/forum/index.php?showtopic=106298
and to find about the Lego LDD MOC of the LBSCR 48 Ft Bogie Coaches, see my post at
http://www.eurobricks.com/forum/index.php?showtopic=106446
