the lego dwarf Posted October 16, 2014 Posted October 16, 2014 When news came of the start of the war against the drow. Lord Magnus sent his most trusted advisor Krom to Mitgardia so he could help in any way possible. Krom liked to travel with his servant Lorgar, so the two made their way to Mitgardia. When night fell Krom and Lorgar arrived at what seemed to be an abandoned camp site. The two settled down and started a fire. After a couple of ours a cyclops found the two men and mistook them for weaklings and it attacked. Luckily the cyclops made such a noise that Krom was able to react and in a fairly one sided battle the cyclops was defeated. Quote
Sir Gareth Posted October 16, 2014 Posted October 16, 2014 Great posing, especially that of the yellow fig. Quote
the lego dwarf Posted October 16, 2014 Author Posted October 16, 2014 Great posing, especially that of the yellow fig. Thanks I will be using Krom in the collab (if that is o.k with you.) Quote
Hammerhand Posted October 16, 2014 Posted October 16, 2014 Yes, nice job with the posing, looks really nice. The ground looks a bit irregular however, with the white, gray, brown, and tan. I would suggest one main base color, and then layering smaller plates over the top, rather than several large plates, which tend to divide the ground to much. Quote
Sir Gareth Posted October 16, 2014 Posted October 16, 2014 Thanks I will be using Krom in the collab (if that is o.k with you.) Sounds great Quote
Jorrith Posted October 17, 2014 Posted October 17, 2014 Posing is great! Only thing that could be improved is photography. The pic is a little bit blurry. Also if you use a curve in your background, instead of an sharp angle, it shows less shadow. I went to an art shop (those that sell stuff for painting and drawing stuff on paper and canvas) and got me two sheets of 100x70cm paper for just a few euro's. Works great as a background! Quote
