So, i finished my gearbox. It's too large for fitting inside some supercar, but i can imagine Hyundai Porter on Unimog wheels with this gearbox) Anyway, it's working, and i like how it looks and sound, so i decided to share this gearbox alone, without any car or something.
Gear ratios:
1st gear - 1 : 1.5
2nd gear - 1 : 1.2
3rd gear - 1 : 1
4th gear - 1.2 : 1
5th gear - 1.5 : 1
6th gear - 2 : 1
As you can see i used 4 shock absorbers for holding ratchet in postition and it's neccesary, because "hammers" resist and push "drum" back or forward by 30 degrees. I tryed to make some functional paddles, but failed - all that bionicle sharp parts and rubber bands just doesn't make sense here. So, i leave it with this yellow handle. Sorry for that)
Belly shot ;)
Assembling was a bit tricky, and fine tuning take 50% of time. After that tuning - selecting proper idler gears and adjusting hammer lengths - gearbox works fine, never stall, never slip, never grind (i tested it for 15-20 minutes in different conditions, hope it's enough). And, like a real one sequential 6-speed gearboxes, shfting time is measured in ms, disengaging-engaging almost instant, but it disengage first.
And video. i used M-Motor because used all my other motors in my previous MOC, and didn't dissamble it yet. And i gear it down only for this video, so difference in speed can be seen. I don't know how my gearbox will handle more torque, but it can handle much more speed - at each gear only 3 geear involved, so it's almost frictionless.
As usual - pictures are clickable for higher resolution, and more of it on FLICKR
Thanks for reading, i hope you like it)
it's cool!
but there's a problem: how much torque can it take?
when building a gearbox keep in mind that if you need a gearbox it's because your model is heavy, so you'll need 2 XL motors... if the gearbox can handle it without exploding than it's a good gearbox :P
Edited by piterx
Thanks for replies)
So, i decided to use my Spirit of Baja drivetrain for test. I connected gearbox instead of rear axle - there's 1 XL-motor geared up 1 : 1.67 connected via differential with 2 hardcoupled L-motors geared down 1.67 : 1... And it's all geared down 3 : 1 after differential. Sad, but i can't hold the phone, push IR controller lever and switch gears in same time, lack of 3rd arm) But i tryed it without filming - switching on the fly without any problems, no grinding or something.
Sorry for my incompetence but why are there two outputs.
Oh, my fault, i didn't explain))) LBG is input shaft, blue - output.
The idea looks really interesting, great implementation!
Now you need to attach the wheels and turn it up side down to see if it is grinding or not ;)
ehehe yes
No, it's not grinding at all. Only trouble that I discovered - gearbox seriously slowing down on 4th and 5th gears if I connect geared up 1:9 M-motor. But further tuning of this 2 hammers and their idler gears will help - they pushed down too hard and generate unnecessary friction now.
Yes, it's incredibly cool gearbox) But it's different approach, more typical for LEGO, using shifting clutch rings, addition gears e t.c. I just tryed to mimic real gearboxes, where's each gear using their own set of gears, and selecting gear do not involve additional idler gears, so i have only 3 gears per each gear now (sorry for that Gear-Gears =).
I have ideas about making similar gearbox, but with double clutch. There's some reasons - it will simplify hammer mechanics and allow me to use more gears, so 6+N+R will be possible. And i deleveloped nearly compact ball bearing this morning - i don't think it's really neccessary, but 100% pure LEGO ball bearing used in double clutch sequntial gearbox - it's cool as i think)
