Newest update: Completion! See the completed model here!
I've had a 3rd pair of Axial Ripsaw 1.9 tires lying around for quite some time, and I figured it's about time to use them. I'll be building a 6x6 truck based on this:
So far, I have the axles done:
Thoughts?
Edited by Victor Kojenov (TFOL)
Share this post
Link to post
Share on other sites
Good luck with the cv joints between the two rear axles. I have never succeeded at getting them to function in the manner it appears that you will be using them.
What features do your axles have?
-lockers?
-gear ratio?
-portal hubs
-4 links/torque arms?
-caster/kingpin/ackerman?
v/r
Andy
Edited by AndyCW
Share this post
Link to post
-lockers?
-gear ratio?
-portal hubs
v/r
Andy
Axles have portal hubs and will be suspended on a 4-link system. Gear ratio is 5:1.
Share this post
Link to post
It looks impressive with all those tires!
I agree that those CV joints will fail very fast even if they are geared down in the portals.. :sceptic:
Share this post
Link to post
I was gonna use the CV joints if there's a lot of stress on the driveshaft (from the 4-link geometry). I just tried it with UV joints and it works alright :P
Share this post
Link to post
Am I right that you have differentil lock in the first and third axle?
There are no differentials at all on this truck. 1st and 3rd axle are both steered, though :wink:
Share this post
Link to post
Ok, futile hope :D GL at building. ;)
Share this post
Link to post
Are you sure that those CV joints won't break? It may be stronger to use universal joints with an extending driveshaft. This does look very nice so far though.
Edited by Technyk32231
Share this post
Link to post
Already answered this question above :tongue:
Share this post
Link to post
Update!
Good news: I have a chassis. Bad news: I also have grinding gears.
Looks really awesome so far! Maybe you can make a Mercedes Amg 6x6,
Does your Mini AMG need a big brother? :tongue:
Share this post
Link to post
Who knows... :) Why is the front axle tilted so much?
It's the simplest way to add negative caster to the front axle.
Share this post
Link to post
Looking good! Those tires sure are awesome!
I would lose the front caster tho, it just isn't needed and will help save those joints! :sweet:
Share this post
Link to post
Can you post some pictures of the gearbox?
I'll model the gearbox in LDD and put up some screenshots from there, it will be clearer.
Share this post
Link to post
Wouldn't it be better to use one 12 tooth gear with a half bush on each side to make it inline with the 20 tooth gear?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
